View Full Version : Hybrid / Engine Swaps
- Finish this list please *URGENT* (h22a -> civic)
- ls/vtec problems
- electrical problem with ek... experienced help needed
- Heater hose on EG/GSR swap
- LS Hatch I.M. question
- K20a into DC2 questions
- Should I have any problems putting a B20B or B20Z into my 95 LS?
- distributor cap for 98 jdm itr (searched)
- Need help on intake manifold and throttle body
- a cable tranny question
- HF control arm swap?
- SAN DIEGO need motor swap!!
- DSS axles took a dump after one year...AGAIN
- 5 speed manual swap and ignition swap gurus i need your help
- Changing from Place Racing H22 mounts to Hasport mounts
- Help i need help
- Boiling Transmission (search was down)
- GSR Fuel Filter?
- How much is swapable?
- B15 to b16z6 change, pin outs
- motor just started tapping, question
- H22A Civic Won't shift into reverse (Just replaced pass. side Mount and axle) HELP!
- B20 swap...auto tranny?
- h22 civic driveshafts
- Just did swap. Engine not starting!!!!!!!!!!!!!!!
- 96 civic hatch b20z block with gsr head
- Hasport mounts with H22 problem in 92-95 civic eg
- h22 lsd fit into f22 trans?
- Box under the throttle body
- ckf sensor ,, is it possible to eliminate it
- b18b into eg6
- What distributor should i buy for my SIRI moter OBD0
- Are OBD1 and OBD2 distributors internal's the same? help!!?
- h22 in an EG with AC
- b18b in a 97 4-door
- obd1 b18b1 into 98 EK enigne harness question
- USDM b16a2 head on JDM B16a short block
- p13 ecu (auto vs manual redline)
- wiring for smog legal?
- 2nd gen integra rear disks on eg civic?
- clutch problems
- problems with si conversion
- Searched!!! non-abs axles.
- Anyone ever replaced bearings in h22?????????
- Shift Linkage Q
- B18a w/ 100k on it?
- LS/VTEC using a P30 Gasket HELP Please, Lining Up
- B18b1 swap into 98 auto DX coupe
- em i in the right place
- Swap Walkthrough for b18c into ek hatch....
- GSR Crank w/ LS rods and pistons
- Will a 96 accord alternator work on my h22?
- Distributor Swaps
- usdm itr piston, ls vtec
- Will the ACwork?
- F20B to be installed this month...........
- Anyone do the h22 belt tensioner to the manual h23 tensioner?
- b16 swap to b18b
- hot tank?
- D15B7 with VTEC valve cover?
- what compression will i get??
- EG HB question
- Midwest engine sales inc.
- LS1 FC project in the works
- crx poor itr setup, knock sensor code, octane or plugs?
- P13J CEL Code 36, traction control on an OBD-I H22A
- couple questions about OBD2 GSR into EK coupe
- 91 crx b16 hack job
- ***Which Power Steering mount for GSR into EK??***
- Piston swap.. Advice please..
- intake mani
- external coil on h22a civic's . ?
- Timing question
- Noobie with some redundant questions
- type R or h22a
- ls/vtec timing covers...
- noob Q h22 in eg
- Fuel Pump Question
- anyone here ever used a accord/prelude shifter with a k-swap?
- 1997 civic ek swap problems
- how much power will i gain out this set up
- Which throttle body?
- Yonaka Motorsport H22A Swap Mounts?
- Ls/Vtec distributor question.
- Buying a LS powered 90 EF
- axle fittings h22/accord
- JDM GSR all motor questions?
- 99-00 Si ecu throws a cel ???
- LS Wiring harness in gsr
- EG's 3 plugs on the passenger side frame rail harness to the ecu length?
- LSVtec sounds like a scooby
- mini me swap into dx vtec problem
- Help with 94 GSR swap in 93 EG Hatch
- used jdmb18c from H-MOTORS......is it safe to install......
- B16a 88-91 into 98 EX coupe
- 99 B16A2 into 99 civic dx. Need help with secondary o2 sensor wiring.
- sohc manifold to y8 manifold questions
- Guide book for swapping B18C
- Yes or No Gsr Block b16 head Ne Mods Needed
- Best single cam motor in 92 cx hatch ???
- lower a/c mount for a B series in a EJ1?
- Another GSR Swap problem need guru advice
- swap help
- Boy am I up a creek!
- OBD2 B18C1 into 94 hatch. code 41
- 96 b18c in eg, what intake should i use? OEM LOOK
- DC Sports Header H22A in EG/EK/DC2
- Early 90's Legend V6 into 4th Gen Lude
- Need help wiring alternator ASAP!!!
- Engine Swap Help plz
- jdm customs
- How come my 99 LS harness wont plug into the 92 DX firewall harness??
- K20A SWAP INTO 1994 EG, VTec Problem !! please help..
- need tranny help
- b18a into 93 ex mount trouble
- oil pressure sensor working?
- would you trust this radiator??? dual core....
- Rear disk 95 civic to 91 Crx... Same?
- NEED HELP W/ MOTOR SWAP??????
- Best B series option for EG Civic coupe?
- Are the B series alternator pulley and brackets interchangable?
- quick question h22 eg swap
- using a vx head for a si head
- Had A Semi-Productive Weekend...Few Pics From It (56K Warning)
- camber problems b18c1 crx si
- B16A inot egCoupe?
- f22/h22 hybred
- Throttle Cable Question!!!
- will dc integra camberkits work for a da
- Does del sol linkage work for an ls/vtec swap?
- problem with a mount during an LS swap...??
- tach problem
- Where do these VACUUM HOSES go??
- need your help
- am i the only one who cant to go hmo
- B18b swap info needed.
- ys1 hydro cable converstion, b16a proper half shaft for passenger side? 92-95 civic
- swap help please
- obd 1 & obd 2 distributor wiring... please help
- ***HONDATA KPRO HELP***
- Difference between USDM h22 and JDM h22
- h22 3 wire IACV where do i pin them out
- es inserts?
- euro-r Intake manifold on a h22
- h22 swap into 96 hatch injector question
- EG with B18c1 what ECU should i use ?
- Test pipe question
- b16a won't start anymore
- Wil this oil pan work, ZC-D16z6???
- Pics of KS
- d16y7 into 95 coupe
- stock fuel rail and injectors..need some help?
- Axle different for different tranny's?
- Number of dowel pins?!
- I need a engine
- Are all D15 blocks the same?
- ls/vtec top end
- Need links for 4g63 swap into an eg hatch
- b16a distrobutor for a b18b
- b18c1 into a 93 dx- wiring question
- IACV - differences between OBD0 and OBD1
- B18C obd2b car and obd2a motor (dizzi question)
- Build h22 Type S or get K20 engine...
- H22A vs. B18C
- engine Swapping
- Air Conditioner Pump Fit Between B Series?
- 95' B18C1 in 93 Civic LX. Cruise control doesn't work
- h22 swap into civic ecu
- h22 into 92 cx BARable?
- LS VTEC HELP
- IAB solenoid sensor wire up. HELP!!!
- radiator question: CSF
- 94+ acura tail pipe fit on civic 95?
- B18B Have a couple of questions
- b16a vs. b18c heads
- k20a2 into EG build up 56k :(
- B20 swap, piecing it together question
- REF question
- ht sponsor had odb2-1 $60 shipped who was it?
- Some interesting findings about the VAFC..
- gsr swap in civic coupe ?
- Free AEM Intake
- coolant hose for b series engine
- What to buy???Need Advice
- Sensors (TB, Intake Manifold, vtec solenoid) compatibility
- obd1 or obd2
- Ls block problem
- Swap is almost done. Man that Imagine Engineering head was a pain in the ass..
- B20 guys NEED ADVICE!
- Any difference between 99 and 93 h22a timing belts?
- JDM H22 tranny with USDM gears
- what would be the best head to put on an LS/VTEC
- Swapped b16a2... running into problems
- RSX type S swap into 04 civic coupe
- Any one know the AC timing belt size for b18c?
- first gen b16 into crx hf..what is needed?
- idleing issue with a h22a
- rod bolt question
- 94 civic si engine harnes compatible with 94 gsr motor ????
- *****BASE RSX w/ K20A TypeR swap*****
- --SHIFT LINKAGE QUESTION-- GSR tranny in 92 civic.
- Quick Exhaust Question
- 91 Integra engine into 89 EF
- Pics of my h22a del sol...finally finsihed and running
- F22 H22 hybred
- axle shopping
- Vtec wiring
- i need a motor?
- ctr crank pully
- fuel filter for h series sol
- b16a w/ b18c1 head
- EK B16 power steering?
- 01-03 CIVIC injector size ??????
- h23 vtec in an ek.....
- a6/z6 mini me
- civic m/c to h22 slave cylinder
- which method did you install the H22 in the EG hatch? from top or bottom?
- Integra/ civic struts ...Confusion springs?
- what AC hoses are needed for a b16a swap into a 98 EK hatch...the ones from the hatch are too long
- 93 civic lx b18a swap
- From F22a1 to H22 in 94 Prelude
- automatic to stick conversion on da car turns over and has spark and fuel but doen't run
- Skunk2 intake in a h22 eg?
- have to rev the car when first starts then idles ok
- built allmotor k-series in EJ1? or built turbo h22a in EJ1?
- Junk Yard IN Maryland Area for Swap???
- b18a into a 89 crxsi cooling sensor/harness problem, please help
- d15 into 95 gsr
- b20 in 95 integra ls alternator problem
- b16 in a dc2
- engine advice
- Anyone purchased from jdm-online.com?
- which b16
- Convert CRX Si rear discs to 4x114 pattern
- All of you B series guys help me out Please......
- which rear mount bracket do i need for a b18a into a 89 crx
- b18c into 94 civic ( wiring harness question )
- LS in crx. which radiator do i use???
- Something ain't right, can you find whats mossing in the pic ?
- ISO b18c swap guru in Sacramento
- need help with obd0 to obd1 conversion
- running a berametric press sensor code on an 98 crx
- Are b18c ARP Head bolts in B16a ok???
- b18c obd2 92si swap
- H22 Eg swap-Proper Axle Search!!
- Can somebody make a sticky for OBD2 Chassis with OBD1 H22a Swaps?
- 96 usdm h22a (obdII) into 92 civic hatch
- Selling 95 civic ITR
- CRV B20/ED hatch swap question.
- JDM B18C Header Problem
