PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Help On : putting B16a2 Vtec head on a B18 Block?! what would It TakE?
  2. NEED HELP w/ mini-me headgasket and timing belt
  3. turbo h22 92-95 civic. . . cant fit alternator... looking for alternatives
  4. cable trans OBD0 LS into OBD1 Del Sol
  5. B16a2 swap, wiring???
  6. 98 civic Cel
  7. need help tein suspension pleeease
  8. To All H22/Civic
  9. Porsche 912 with Turbo 3.8L V6 conversion
  10. could i use 90-93 teg shift linkage for b18c swap in a 93 civic hatch?
  11. B16A 92-95 (SiR-II) into a eg please help me
  12. before i decide on a b16 swap...
  13. does anyone have stock vs h22 eg oilpan clearances?
  14. Need some advise or does anyone know....
  15. d series parts interchangabe????? Already searched
  16. my ls vtech is running rich....
  17. b-series swap into EK
  18. where to find a k20a2?
  19. obd0 motor into obd1 car
  20. adding JDMb16a1(OBD0) into 92 integra b18a(OBD1)
  21. is this fuel pressure regulator any good?
  22. B16 swap Done by....
  23. what fuel pressure for a b16 block with gsr head
  24. H22 EVAP canister question
  25. obd1 to obd2
  26. 99 dx coupe, b18b.. what header?
  27. help with a 93 accord
  28. Motor is in and started but getting error codes
  29. ** H22A hybrid Intake manifold vibrating loose!
  30. h22 in civic, 2tone paint finally done!
  31. will pedals from 94 integra fit 97 automatic civic ?
  32. EX,LX,SE does it matter?
  33. Has anyone ever wedged an Accord V6 into a CRX or Civic? possible?
  34. post ur B16a EJ1 times HERE!!!
  35. b16a 1/4 miles times..is there a thread on this?
  36. b16 oil pan on b18b block?
  37. to build or to buy, that is the question.
  38. 2004 Acura TSX K24A2 6sp Complete Engine Swaps - 4 Available!
  39. What to do with exhaust.
  40. K20 into 2001 Civic
  41. B20 into 94 CIVIC DX
  42. b16 obd0 using a obd2a (96dx) using a obd1 ecu wiring
  43. Eg/H22 swap.... Fuel Pump Ques.
  44. H22 Swap/Heater Doesn't Work..
  45. best place to find a b18c5
  46. wtb k20a2
  47. 2 questions 1. body 2. axel shake and gsr swap info for ek if anyone cares....
  48. b16a2 in a 93 EG6!!!!!!!!!!!
  49. leaking axle.......
  50. d16z6 wiring ALREADY SEARCHED
  51. i need to know the turn to lock for a 96hatchback civic power steering rack
  52. B16B or B18C5??
  53. idle problem after b16 sirII swap
  54. Just got California BAR CERTIFIED with JDM B18C in EG!
  55. Need helping looking for a wiring harness!!!
  56. Assistance---b17a from 92 GSR into eg coupe.
  57. K20A2 immobilizer......help???
  58. ...what do you need to get a first generation b16 into a 90 crx hf?
  59. No fuel getting to the B16
  60. Running like a bag! (HELP)
  61. Mini me 91 si
  62. b18c rods in b18b block?
  63. Need Help Just installed JDM B16 and have NO spark!!!
  64. have a 93 ex coupe with a b16 gettin an itr motor what need to be changed?
  65. K20 into 90-93 integra, anyone know if theres a kit??????
  66. new fuel
  67. lsvtec alternator?
  68. GSR in a 92 Civic sedan exhaust question
  69. B18C5 bottom end/B16A2 head and engine harness in 93 SI Hatch
  70. Help Checking out a Hybrid Used Car
  71. What shift linkage B18C5 in EG hatch
  72. n tupper arms and lower what do i use for the swap lso with rear what do i gsr suspension on ek help
  73. ls/vtec
  74. What bushing kit to use with ITR suspension on a DA...
  75. 10 lbs of Sh!t in a 5 lb bag
  76. b20/Vtec timing question
  77. 2000 AUTO CIVIC TO OBD1-P28 CODE 14 HELP
  78. will 90-93 integra sus work on 99 integra?
  79. help, proportion valve question 95 CX valve different
  80. What do i need to run a sway bar on my car?
  81. better for boost b16a or b18c
  82. How much would it cost me to get these tools?
  83. Would a stock '99 Civic Si muffler be too restrictive on a stock H22 ?
  84. D16y7 Block - D16z6 Head Turbo Setup - Searched
  85. anyone with p73-ao in b18b? also lsvtec Question
  86. Engine swap shop in central florida
  87. timing belt question.
  88. APEXi Worldsport VS. Autozone cheapy VS. Stock Si
  89. ZC head block combos?
  90. First Swap need a little help
  91. HELP: Issues wiht NON-CHIPPED P28 w/ harness installed into 00 Civic Si
  92. h22a accord coupe vs. rsx type-s
  93. Where/What is vtec pressure Wire....
  94. WTF: I Give The Car Gas and it drops in rpms like a big gulp then recovers but sputters.HELP
  95. H22 HCP mounts gone bad?
  96. what shift linkage is this?
  97. k20a2 in 02 civic
  98. What's a better option?
  99. Swaps in the Tampa bay Area
  100. s2000 motor in anything?
  101. Bar Inspection
  102. Transmission mounting bolt problems
  103. Jdm b16a(obd1) into ek problem!!!
  104. ECU's w/ immoblizer...
  105. gsr into 92 integra swap
  106. Finished EK h22 Swap
  107. OT: Getting to know you guys...
  108. OBD2(B) to OBD1
  109. !!!!!poor idle quality and air/fuel mixture PROBLEM!!!!!
  110. FIRST SWAP AND NEED SOME SERIOUS HELP!!!
  111. General question about a 91 hatch swap
  112. B18 in 98 civc After that when i use my heater the water temp gauge goes way down.
  113. b18a in 90 hatch si
  114. 93 GSR parting out, what can I use in Ef/crx
  115. Motor swap.....started, now wont start?!?!?!?"
  116. problems with jdm b16
  117. Sputtering Question.......need some advice asap ......
  118. swap problem need help asap
  119. No more hybrids.....
  120. Poly-Urethane Engine Mount Inserts
  121. HOW TO ELIMINATE RESISTOR BOX. 91' CRX W/ B18A & 92' TEG LS ECU AND HONDATA S200
  122. Need help Quick! OBD-2 sensors and CEL
  123. dizzy cap, plugs and wires
  124. which harness to use
  125. H22 EK cooling setup w/ PC&AC
  126. b20 crank?
  127. 2000 gsr into a 92 dx
  128. Who has bought from Naganojapanese and experiences?
  129. Oil filter for B18c
  130. Impressions of Hybrid racing/Hasport K series, eg mounts...
  131. what is a good motor for a del sol
  132. B20 with LS Intake Manifold problems. (Injector Related)
  133. distributor ? on 00ls into eg
  134. emissions
  135. H22 EG hasport mount question!!!!
  136. Axle Problem?
  137. Who sales Place Racing motor mounts?
  138. Car stuttering in vtec ....
  139. Hybrid A/C components?
  140. b18c1 1989 crx hf obd 1 conversion throwing code 1 after swap.
  141. INjector Wiring questions....please help
  142. idle question on an H22 EK civic
  143. problem removing the pass side mount for h22 swap
  144. trail arm bushing are they worth the money
  145. Hasport Kit, can I use it???
  146. h22 into a 90 Accord??
  147. which REF STATION should I go in S Cal?
  148. rwd theory
  149. someone confirm before i start....question about my wiring job! just finished swap...
  150. Hybrid Car numbers
  151. HELP Wiring motor question - ASAP Please
  152. how to make a hybrid engine?
  153. First swap, need help!!
  154. Can you help this problem?
  155. Your opinion please! H22/Civic header question!
  156. skunk2 cams in h22
  157. power steering pump & bracket?
  158. NY people..where did u buy your swap?
  159. ls dizzy on lsvtec
  160. wich dizzy to use?
  161. TPS sensor voltage
  162. 91 ls motor into 90 crx
  163. Does anybody know what's up? b20z 98 civic...need pin codes
  164. Check these mounts out
  165. SI FR sway in a 99 civic dx coupe
  166. adjusting the TPS and throttle plate opens up is this normal or....
  167. Stock Civic EX tachometer waaaaay off.
  168. looking for so cal shops....
  169. HYBRID DRAG CRX- MID ENGINE REAR ENGINE
  170. EK coupe with b16, worth it ?
  171. 00 civic with H22a. PS and AC?
  172. ZC/B16A Swap(Canada)
  173. B17A with a B18B crankshaft
  174. 99 LS distributor, 99 si harness.. extra wire
  175. JDM Motor Swap wiring questions.......please help.........
  176. MPFI Swap, Main relay buzzes, no injectors
  177. VIBRATING NOISE IN H22A/EG NEED HELP BAD!
  178. Looking for a project car got a few questions
  179. ITR throttle body on ls
  180. california smog (already searched many times)
  181. B20/VTEC T3/T4 PROJECT CAR...
  182. ***SEARCHED***Need info on b18b swap into 91 Civic hatch back std. ***SEARCHED***
  183. Ek H22 Turbo?
  184. Dizzy harness switch????????
  185. TECHNICAL:OBD1 and OBD2 parts....
  186. Avid's got billet aluminum motor mounts
  187. brake and supspension swap on an eg2
  188. yeah i have a h22 with lsd tranny in my eg hatch and i have accord intermediet shafts and integra 90
  189. SEARCHED ALREADY: what ecu (program) for a jdm b16 obd1 in an eg hatch cx
  190. is it hard to go from a h22 swap and back to a b series swap?
  191. HELPPPPPPP!!! H22a4 in 99 integra gsr
  192. 5 lug type r suspension into my 97 hatch
  193. H22 swap into 94-97 accord / 97-99 CL questions...
  194. What's so great about the LS/VTEC?
  195. Larger fuel tank for 97 Civic
  196. Swap won't run unless throttle is open, HELP!
  197. Have a Swapped Car? ANSWER THIS POLL!!!!
  198. what head bolt to use for lsvtec?
  199. main girdle really needed for lsvtec build up?
  200. More H22-EG 1/4 mile times
  201. adjusting fuel pressure in an H22 civic
  202. Help!! Swap Wont Run
  203. AEBS intake
  204. what is better swap for my 2000 si, h22a1 or h22a4 ??????
  205. CRX gurus and Hybrid heads chime in.
  206. Quick Question About Motor Swap, Need Opinions!
  207. complete type r head NEW for $700
  208. Ek B18c Swap auto to manual
  209. B18C5 into 91 CRX si......axles
  210. B series
  211. Supercharged B18C5 SWAP
  212. b18c1 engine subharness for crx si
  213. so ive got the swap ...... now what<----NEWB
  214. NSX or Legend Calipers on a Integra LS?
  215. New del Sol owner here...
  216. K20 Swap In NJ/NY Area?
  217. quick zc swap question
  218. need help quick
  219. REVISED: I want a D-Series in my EG Hatch. But which one?
  220. -==Honda-tech Help me finnish ma swap.==-
  221. 2000 si with jdm obd1 motor question, thanks
  222. Wrecked and Running
  223. B16a2 swap into jdm civic ek...Need help
  224. EK B18C1 swap.
  225. Exhaust Running rich ??? Is it normal
  226. EDM Civic EK3 Swap ->B Series + Wiring
  227. help with cam angle/position sensor, someone plz hellllp!!!
  228. my wiring dilemma, some VX advice needed.
  229. Which would be the best motor for turbo???
  230. d16z6 swap??????
  231. I need help with this swap,PLEASE
  232. H22 Into 95 GSR Integra
  233. EK WITH GSR WHICH INTAKE WILL FIT THE BEST
  234. Which motor should i get???
  235. for sale
  236. Another Smog Question
  237. question about head gasket
  238. Looking to Swap B18B Automatic into my 97 Civic and have questions.
  239. d16z6 into vx wiring question
  240. gsr/type r
  241. Car won't start unless throttle is open
  242. Are you looking to do an LS/VTEC conversion???
  243. SENSOR: TDC and CKF Sensor
  244. ls VETCH b16 head
  245. b18c1 crx hf cooling fan not working how do i wire it up to work?
  246. b16b or b18c5??
  247. D16Z6
  248. need help with 2000 hatch!!!!
  249. Help with b16a timing
  250. can i put a gsr head on a ls block
