View Full Version : Hybrid / Engine Swaps
- P28 wiring diagram
- Muscle car Guy needs help from Former Prey
- Fuel inkecotrs not turning on-B18c5 in 99 si
- Tranny mount question
- another B18c5 swap question
- radiator hose for gsr into stock cx radiator
- Del Sol B16A
- spoon strut bar for hybrid
- CRX w/B16 ITRmanifold. What injectors?
- testing your decibel levels
- Y1/GSR/LS tranny LSD interchange ?
- b18b auto swap?
- 4WD Civic Wagon Swap
- CRX HF with B16A1 Swap???
- The LS/VTEC and B18C Alternative !! Has anyone read this ??
- crank speed sensor necessary? asap please, thanks
- K20A swap
- will h22a swap into a 90hb?
- Got a question.
- b16 crx exhaust question!~~~~~~
- what to replace when swapping motors?
- CRX-->B16 & B18 question for you Honda guys...
- Help me Name my CRV block cant decide!
- GOt a 94 LS chassis with....
- Dome height same as Piston-to-Deck Height??
- 1994 HB Hybrid MOVIE!!
- couple H22/ek swap issues, attn h22 swappers!
- H22A swap sensor problems
- 95 B18c engine into 98 4 door honda civic ex???
- *REF my motor in the bay area?*
- crv-tec what do I need?
- gauge cluster problem my gauges dont work ie
- B16 head on b18c block.
- Type R EG need help!!!
- h22/civic shaft question
- Searched: LS/VTEC spark plugs
- what clutch to get?
- Need some advice.
- Stroker kit question?
- b18C1 in a 90 CRX Si?
- How easy is an auto 2 auto trans swap?
- Where to get Bars Leak?
- JDM B18C-R ODB1 or ODB2?
- Help! crx swap.
- need help with jdm front clip!
- 91 civic std. (4 speed)
- More pics of my motor.
- Experience with www.JAYDM.com????????????
- mid swap ?'s b20 in CRX
- wiring vtec
- Motors from Flash Options?
- Intermediate Shaft Bolts
- Has anyone here bought a motor from password JDM??
- WTB and FIND Hotshot 4-1 h22a racing header (I need to know best price and location to purchase) new
- Hybrid newbie questions
- Another Swap Question (Sorry)
- Need IACV help for Y8 ASAP!
- ls-vtec helms manual
- B16a header brace?
- how to pin VTEC wires into ECU?
- Anybody make a reliable sprung hub clutch?
- 1st or 2nd generation B16a for my 94 cx?
- obd1 to obd2 conversion , is it realy worth it?
- PRE and POST VTEC torque drop. please help
- question about jspecauto.com
- 2nd gen integ--->jdm b16 swap????
- What exhaust for h22a/civic hybrid?
- '99 JDM B18B in a 1991 teg
- Aftermarket clutch question and oil pan
- h22 swap...shifter plate?
- How come I can't find the 3030 or 4040 numbers on my prop valve?!?!
- Can somebody posts pics of an EG with a B18C Turbo, A/C, powersteering.
- help this noobie>>>>choice of engine
- need wiring help 90 hatch with sir1
- Tunnig ECUs
- What kind of Slicks????
- anyone deal with osaka?
- no obd - obd1
- b18a or b18b...
- Wiring diagram 1991 ZC engine
- H22 swap...rumors or truth
- Most power out of an All Motor SOHC VTEC
- Where to find B16A performance parts?
- Yelo/GRN wire on 99 si harness-Fuel related
- Motor Mount Differences
- Lower control arm broke loose and WHAM!!!!
- prelude vtec swap help
- hybrid cat help-PLEASE
- HELP: H22 swap with CEL
- wait?? I'm confused now..
- Weird ECU Code
- Where to get my engine?
- Wont start!
- torque mount bolt on tranny..exploded ahhh!!!
- I need help with this 1st gen b16a swap!!!!!!!!!!!!
- b18a swap questions
- Ever hear of a B20TC?
- hx to ls wiring ???
- welp, aem cai hydrolocked 90 da
- Odd, TPS bad for the 3rd time??
- Swaping Secrets???
- LS ECU Question
- for people with hybrids.. which helms manual do you get?
- Head swap for '86 prelude
- catalytic converter for hybrid g2 teg
- starting woes
- tranny oil
- Good Place To Get Engine Block?
- B20z into 96 Civic LX--OBD2 ecu ok???
- b16a auto valve springs...junk?
- dallas area please help
- 2nd gen b16a question
- can anyone tell me if my header for my b18 ?
- Another discussion on ITBs
- Pr3 b16 in a 91 integra
- Intake manifold triva
- Pr3 ecu? what is the major improvement w/ p72 ecu?
- b18c running on si ecu question about vtec engagement.
- New H-Series Header
- Can i swap a OBDII (96+) LS Throttle body into my OBDI LS (94-95)
- help:question about pr3 ecu and gsr engine...o2 sensor wiring
- P72 is a gsr block..... right?
- Off topic, but where would i find a dsm motor?
- zc in 88 dx
- where do you guys buy your swaps?
- 4040 proportioning valve
- help???
- new member with new questions ???
- Went for my 1st emissions test today since swap...
- guyz quick question please help me......
- LS Side Engine Mount
- a "real" mini-me
- PWO or PR3 ECU Im confused????
- Can a 5 speed tranny off a f23b1 bolt up to a h22a or f22b1???
- sound clip of...
- Looking for a B18b?
- Problem with B16a Swap???
- Do you have a motor (d15b7) laying around after a swap?
- 90 dx to d16z6 wiring questions
- Need help in VA.
- swap guide
- Running lean in VTEC
- Making a list and checking it twice
- cheapest place to get a b16 engine and trans?
- Discussion of 92-95 coupe or HB for GSR swap...whats BETTER and why?
- Chipped P28,EXTREMELY rich or different pin-out???
- obd2 motor
- B16a cams
- anybody on here road racing a b16? doesnt matter in what honda, just need to know a few things.
- o2 sensor
- What size is the hub, axle nut on 95 civic and JDM H22
- LS/VTEC into EK (Im a newbie, but I searched)
- h22 in a 91 2dr hatch?
- zc swap o2 sensor error
- Is this all I need????
- Anyone know were to buy?
- need ya's help
- c32a into a 95 accord v6?
- Im planning on droppin a LS!! where do i start??
- b16 auto or manual??hugh?
- 92 civic vx question b16a2 usdm
- cheap engines
- AC bracket??
- how to get more power in a 94 dx?
- lsvtec setup(should it be safe on pump gas)
- main problems
- b20-vtec in CRX
- Ls/Vtec ?
- what to do with 3,500
- EK w/o P/S.....how tough is it?
- 92+ tranny in 88 crx speedometer sensor ???
- how much for b18c1 block with si head and si tranny?
- Resistor Pack question?
- B18a people HERE
- what kind of whp do you get on an automatic stock jdm b16a
- where to get auto to manual tranny mount for 95 teg?
- B16A almost done...throttle cable
- Ls/vtec problems
- Swap Question...
- 134 hp on b16a
- Difference between B16a1 and B16a2?
- 134 hp is this right?
- B18 with B16 Head vs. straight B16
- How to tell if a JDM motor is legit?
- b16 vs b18 vs LS/Vtec
- Just Ordered a 96 obd1 h22w/lsd from Osaka
- temporarily rigging the vtec
- Help.. what type of connecting rods in a B20B w/b16a head?
- 2000 Si head/ecu with 92 ls rebuilt block. Hurdles?
- swap knuckle on b18b swap?
- Another quick yes or no question??
- Putting 1994 B18B/B18C1 LSVTEC into 92-95 EG Please help w/ swap check list.
- Buying a B18C5 Bottom End with 100k on it, What to do to it??
- anybody w/ 87 crx si with b series swap??
- help w/ exhaust setup on b18c1 hybrid 5 gen coupe..
- no fuel in piston 4?
- B-series auto trans
- Check engine light
- auto to 5spd swap in a 97 civic
- B16a 90 civicHB swap
- 88 CRX to B16A
- b18c1 into 92 teg ls
- Auto to 5spd pedal assembly wiring question
- Need ECU Pinouts Please Help!!!!
- are all the d16 smallblocks identical?
- Motors from www.FlashOptions.com.....?????
- h22 question
- Putting a 95 D16Z6 into my 00 Civic, why won't it start?
- Building LSvtec questions
- Are DOHC mounts stronger than SOHC?
- B16a2 in 5th Gen
- ZC wiring diagrams
- JDM R motor, no vtec pressure switch...
- hondata questions about b18c swap...
- Help.. what tranny and flywheel on the B20Vtec setup?
- 96-00 civic motor ????
- p30 pistons in lsvtec vs pr3's
- How would you define a built motor?
- 3G Prelude & H22a ???
- ZC wiring diagram
- H22's why are they cheaper than b18c motors
- Do you think it is possible to run 13.6 with a BONE STOCK 1995 SI with just slicks?
- Question about doing LS/Vtec?
- vtec not hitting...
- Which would u buy?
- If you were Billy Mays...
- Few questions pertaining to Jdm B16a2 swap
- How to tell computer type?
- b16a sirII mount questions
- fuel line replacemtn help!!!?!?!?!
- Review: Osaka JDM motors H22/tranny
- Looking for B-series parts to drop an ITR swap into a Del sol
- Need Help: Radiator Coolant leaking from the back area.
- Questions on ZC swap
- A look at EricksRacing shop part 2 (project 2.0L completed)
- Head building...
- does 96 gsr head fit 2001 type r bottom end block?
- h23/vtech
- Starter problems
- Something wrong with my swap?
- H22 wiring to a 92-95 Civic Dx
- 99 b18b into a 93 hatch.....question about the ecu
- RSX powered Civic Si
- which ecu should i run with and h22a?
- wtf is up with the muffler tickets
- jdm itr vs. ctr
- 95 coupe si to.....
- Best way to spend 6K (canadian) !
- GSR into 92 Integra?
- JDM B16A build up
