View Full Version : Hybrid / Engine Swaps
- 2001 b20Z , is it OBD2? Will the 01 dizzy work? Someone told me that the hood will clear the manifol
- b16 arrived today, a few Questions
- smogging a JDM motor ??? need answers!!!!
- Where to buy high compression B20?
- where to get ecu pins...
- what shift linkage to use????
- BLEH. stupid mistake. please help!
- Hi 2 all
- yet another b20 question
- Newbie Question...What is This?? Pic inside...
- o2 sensor?
- 3rd gear grinding?
- sir turbo or gsr turbo??
- ls ecu??
- Finally the h22 is here
- h22ers brake question....
- have car runnin but bad jump-off
- Help! LS swap into 91 CRX DX!!! L@@K
- car won't start...
- h22 egr
- b20 question
- got the swap done but it smokes :(
- Where can I get a 96 VTEC...
- a couple of mini me questions
- It this ok to do????. I put a cx crank pulley on a d16z6 motor! HELP!!!!!F!
- poison,jason kidd,junglerunna,fastwannabe,h22 ek,redline h22-whats up??
- accord sohc motor into civic
- GSR Throttle Cable
- b18c1 into 99si?
- im sure its been posted a million time but couldnt find it
- I BROKE my driver side HASPORT mount!!!
- Header for 1st gen b-16a
- spark plug wire configuration
- DX into a SI
- need some advice on how to mount f20c into crx
- B18C5 Install in NC...
- ok.. did a search and got the run around.. just going to ask....
- to toPlace Racing Auto to Manual mount in eg?
- HELP Car wants to start but won't
- Anyone want to preform two swaps? Central NY area (or close by)
- NEWBIE to the HONDA CAMP SAYS, "B16A1 INTO EG6?"
- Gsr swaybar with 93si endlinks???
- B20 questions
- fuel pressure
- hasport tranny conversion problems....HELP
- Enjo H22 Mounts Suck!
- Is a P54 A/C bracket required to keep A/C in a B18C swap?
- type r axles
- Motor Mount Problem
- ls rods strong enough for ls vtec?
- b20z stock cams vs. b18b stock cams
- Swap advice for a 97 CX civic
- Should IAB valve be closed when engine starts.
- Exhaust Question on B18C GSR swap
- What's wrong with this picture
- b20 vs b18b, swap... uncomplete/complete....??
- older JDM swaps ?
- JDM B18C obd1 into a 1999 Civic EX
- Cabel B16 into 89 CRX DX?
- IAC valve trouble
- Problem! Car won't start after swap
- OBD 1 into a OBD2 car:crank angle sensor
- b18c5 wiring
- Are ALL 1988-1989 civic Trannies 20 splines?
- which would be quicker anyway? wiring it to my 88 wiring (if possible) or conveting to OBD?Do i have
- Which radiator hose to use
- Drops right in?
- Euro R Intake Manifold
- shifter pops out of 5th gear...help.
- wiring a p72 obd1 ecu for vtec
- Any updates on the k-series in the eg/ek/dc chassis?
- im lookin for b16 hp increase...help!
- matching up ECU with motor... question..
- ECU Questions
- 92 civic with jdm b16a problems
- OBD1 B16A2 in a 00 Hatch
- OBD1 GSR in 00 EK
- has anyone seen an automatic b18b in a crx
- greddy exhaust owners with jdm headers
- thermostat problem, take a look. give me advice
- O2 sensor problem
- www.japandomesticmotor.com
- what will i need to put a 99 gsr swap in crx.
- b20 or b18 hopped up on juice
- GSR eagle Rods in LS block?
- Lakewood traction bars for h22/civic?
- H23 Swap in 94 Accord EX
- gsr into eg.
- what is a MINI-ME?
- OBD II LS swap
- ls-vtec help
- last minute help for my H22
- b16a2 mounts in an eg
- for many of you turbo hybrid owners!
- Which Driver Side Mount to use for EK-22
- Axle problems......AAAHHHHHHHRRRRRRHHHH!!!!!!!
- THIS THING IS FAST!!!!!!!!!!!!!!
- NEED Quick info thanks
- *** Nightmare !!! *** 96+ Civic's with H22a swap with Euro-R manifold!!! almost impossible.
- questions about running a b18c in a 93 civic ex
- putting a v-tec head on an ls motor
- CODE 13(Atmosphere Pressure) on B16A engine/PR4 ECU
- A/C in jdm b16 swap-->eg
- ever heard of...www.japanmotorimport.com?? are they good or bad?
- H22 turbo eg
- should i get a zc motor
- Car cranks but wont start. HELP!
- i need an H22
- NEED HELP my 2.2 has big problems
- what axles do i use (B18C-R in EK)
- ek9 with GSR and EDELBROCK INTAKE MANIFOLD throttel cable HELP
- h22a in an eg.......what do i need???
- H22
- NEED HELP! b18b swap into civic hatch question
- what exhaust are you guys running on youre h22 civics?
- Which motor would be better?
- SOHC Vtec Dizzy ..Integra ECU'S AND Clusters!!!!
- Stuck on distributor wiring for OBD2B H22 into OBD1 EG
- b18c1 or h22 swap
- got a new idea: H22 in 2g integra
- Very pissed off.
- pulling motor from 99 si right into 93 ex, what changes need to be made
- h22 info needed
- ok... d16z6 with a d15b7 tranny... Is this OK?????
- Please!!!! Help me identify these tranny parts!!!!!!!
- 89 crxhf with b18c1
- I have this really stupid question about Wiring for b18b in 97dx....
- bunch of tranny questions... tranny gurus please...
- Help with ZC missing very badly under any load
- Tranny Leak
- cel 16: fuel injectors
- B16 into 1st gen Crx Dx?
- 93 Civic with b18c1 motor mount
- will ls auto ecu fit stick shift ls car?
- H22 Informatioin Needed!
- what the hell is this *version 2.0*
- code 7,14 and rev- limit @ 2500...
- B16 into 92 teg
- Incoming engine held up in customs...grrrr...
- H22 into EK ? about Pullies for A/C, Power steering??????
- 93jdm h22a in 94 ex accord: which cold air intake do i use
- how much holding back
- Anyone have thier swap insured?
- My 94 civic needs an H22
- Fuel line question
- Buying an LS motor.. Need Help
- engine swaps
- A couple of more H22 questions
- running out of money need help finding parts
- Clutching the difference
- LS motor in EJ6.....
- Finally got my Hybrid on the Road and it is AWESOME!!!
- Need an 02 sensor for B18c1 in EH2....how do i do this???
- Thanks Poison!!
- h22 swap 95 accord lx/Houston area
- Which dump valve?
- racecar wiring
- d16y from ej6 into 89 civic hb?
- p28 with h22 hybrid eg
- H22 individual throttle bodies: are they ok for daily driving?
- Presenting to you ATR Crank Pulley for H22 hybrids...!!
- b16a coolant tube question!?!
- Cold air intake to use???
- LS/Vtec oil lines
- H22a obd1 /96+ civic wiring nightmare....
- Can anyone help???
- What is this black box on a 95 vx
- Password JDM or Honda Motors Online
- need info on b16a
- wiring for iab for obd2 96 p72 is it A17 or A20??
- 75k too much on a gsr motor??
- 6th gen hybriders help me!! wiring harness question..
- SRS Question?
- What should i swap?
- help on b20 set-up!!!
- hf "all motor"
- Has anyone ever delt wit this company before?
- which wiring harness to use for H23 swapped 90 accord??
- axel question please help!!!!!
- 92B18a1 in a 95 vx vaccum and o2 help
- B 18 swap in a crx
- hydro to cable tranny conversion
- B18A in 91 DX Hatch no spark?????
- IACV obd2 or 1?
- Any EF's using a OBD1 B16 ?
- All you h22 guys..have any oil consumption problem?
- H22 Integra Questions
- zc in a 86 civic dx
- mini-me swap, need to wire vtec...
- B20B w/ JDM ITR transmission
- H22a problems?
- Iceman intake?
- B20 on the verge of starting, but WONT!!
- Evap Canister
- anyone using a B16A's ECU with a B18C1??
- correctly built ls/vtec costs
- can i do this?
- B18C into 92-95 CX model - have a question
- b20 vtec smog question?
- which ecu to get?
- b18c1 vs d16 turbo?
- Which H22 Civic header???
- Got new b16 swap, What parts should I replace? OEM or Aftermarket?
- auto and manuel tranny brackets... are they the same? 90-93 teg
- gsr in 97 ex won't trip vtec, any ideas?
- wiring up a jdm itr in a 96 ex (IAT/IAC help!) ASAP!
- need help
- tranny bracket question
- i need a sohc d16y8 bottom end or swap
- O2 sensor issues with a B16a1
- What axles are you using in ur h22 teg?
- ECU options?? p28 p75
- Hybrid Garage
- Need a PR3!! HELP!!!
- Axels ??? Need help
- Unidentified plug behind the block
- Swap favorites?
- need help with vtec wires. where do they go? (obd1)
- Need to swap MAP sensor when swapping from D15 to B18A? (1991 Std Hatch)
- QUICK help with o2 wiring...
- Question! b18c5?
- how do u set up the secondary butterfly on a b18c1
- intake for h22 swap in 5th gen accord
- header question
- Possible blown clutch or tranny
- Will a h22a throttle body fit on a b18c?
- B18a motor with PR3 Cam?
- H22 civic shifting problems?
- Throttle pressure sensor?
- D15B7 manifold in my 88 hatchback
- pix of h22 turbo in hatch
- JDM P73 speed limiter????
- what cold air intake are you guys running on youre h22/civics??
- H22 swap - low speed vibration...
- b20 block ctr head good or bad?
- Can i use an auto 96-98 EX harness in my B18B/EK swap?
- Reading a code - OBD1 motor, OBD2 chassis
- 93 DX with LS motor swap, doesnt wanna run
- S2000 fwd w/6sp
- b18a dizzy on b16???
- HELP!!! How do I get the bitch pin back in?
- How do you wire up IAC
- d15b vtec
- :Noob: Help me choose the right engine..
- d16y8 into a 96 dx.. help
- need help on motor swap!!!!!
- Whats it should the timing be set at for a jdm vtec d15b?
- '88 civic cx hatch and either d16 vtec or b18 non vtec
- I need a shopping list for B16 swap into 88 hatch
