PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Serious tranny problems
  2. just blew my motor. b18b1 into 99 civic si questions
  3. rear engine mount by firewall, how do i attempt replacement?
  4. H22 Build Up Thread
  5. Speed Fetish Performance K20a-EM2 swap
  6. CTR b-pipe with 99 Si question
  7. Very Fast H22 EG Hatch...pics and short clip of 1/4
  8. Toda Stroker kit
  9. need help with wiring help me please 94 integra ls into 98 civic with HX engine harness
  10. LS into EG
  11. motor mounts help?
  12. b18c head on a b16 block
  13. ZC into EG Civic
  14. How much did you pay TOTAL for your swap?
  15. motor swaps in the dc md area.
  16. Broken motor mount - what to use for replacement?
  17. GSR throttle cable in eg(b18c)
  18. Is the sensor on the power steering line behind the intake mani necessary?
  19. vx harness to 4 wire 02 sensor conversion
  20. Turbo valves?
  21. Question of the day!
  22. itr wont start
  23. Accord/Prelude compatability
  24. b16a3 in 89 crx
  25. where are the front torque mounts on b16a?
  26. Stock GSR intake in a 00 Civic?
  27. shop owners price for bacis b16-b18 ls/vtec, new water pump timing belt anyone?
  28. Not sure what to do
  29. vtec probelm ???????????
  30. k20a swpa or fully built motor with full race kit?
  31. please help, b16a into 94 eg couple motor mounts..NOT INTEGRA
  32. h22 ignition and dizzy question?
  33. h22a axles???
  34. H22 Crx project. *(pics)*
  35. what mount?
  36. DX CURB WEIGHT
  37. swapping d16 into my dx
  38. wiring diagrams
  39. Reverse lights - I've searched
  40. lsvtec swap trouble!!!
  41. EG suspension on a 00 si
  42. Are there any full tutorial write-ups on swapping a 91-93' B18 non vtec into my 91 civic DX??
  43. b16 starting problems
  44. B20B Flywheel...
  45. OBDII H22 in EK...ecu questions
  46. Swap help
  47. non vtec b18 into civic DX
  48. ats close ratio in YS1 tranny
  49. Which radiator hoses to use for EH GSR?
  50. B18C-R in EG hatch won't pull in the top of 4th or 5th
  51. Quik H22 in EK Questions...
  52. removing shifter cable from EG
  53. will 92-96 prelude front hubs fit into a 94-01 integra spindle?
  54. ECU smoking after swap install. NEED HELP FAST
  55. ATTS tranny to 96 accord
  56. What can I pull from my engine bay?
  57. H22 in ek hatc, running problems
  58. looking for info on getting bar'd
  59. K20 into EG....PS & AC removal...searched
  60. 95zc to 89 civic swap, something went wrong.
  61. correct axle for 89 civic hatch swap
  62. idle problem
  63. JDM H22 into 92-95 civic
  64. LS/VTEC dizzy question
  65. K Series axles for EK
  66. Whats the differences in these Suspensions?
  67. how to check codes
  68. best swaps for a del sol
  69. itr swapped civic EX
  70. B18C1 in a 2000 Civic - Heater Hose Issue
  71. obd1 b16 into 1999 obd2 b16 civic si
  72. gsr swap into EG, alternator fitament issues...
  73. B18b1 in 90 civic HELP
  74. what car is this distributor off of? it has TD-55U 3Y12?
  75. B20 swap time...
  76. Connecting injector resistor box, NEED HELP!
  77. H22 swap..Accord 91 shifter cables and assembly in 97 hatchback will it work..??
  78. What ECU + power loss
  79. EG coupe LS motor jdm B16 Trans (non-lsd)
  80. D16 Z?
  81. lsvtec / b20vtec legal?
  82. wanting to swap a b18c(gsr) into 92 integra
  83. Fuel Feed Line 94 JDM B18C int 92 CX EG Hatch
  84. do all obd 2 computers store the vins have to pass nys inspection
  85. How to check CEL?
  86. WHAT THE HELL IS CELL 40 ON JDM PR3 ECU!!!!
  87. 94 B18B1 into a 98 Civic EX......harness question..help????
  88. k-series cam gears on b?
  89. B20/Vtec/Turbo....LACK of OIL??????
  90. throttle cable problem
  91. d16y7-d16z6
  92. Turbo LS Vtec?
  93. Ticking in head, white smoke, low coolant in a JDM h22a
  94. What intake for a B18C1 in a 00 hatch?
  95. For Rally: Better ground clearance K20 or B18 in an EG?
  96. Can someone help me with secondary O2sensor?
  97. 98 Civic Coupe with JDM ITR swap
  98. f20b accord sir swap
  99. k20 for sale!!!!!!!!!!!!!!!!!!!!!!!!!!!
  100. Hydro clutch to cable conversion..... really stiff!
  101. GSR build - which crank and which pistons?
  102. LS-Vtec smog? Bay Area
  103. Full F20c swap into an eg or ek, anyone try???!
  104. D15 questions about turbocharging?
  105. H22 Swap in a 93 Civic SI
  106. 5 Lug conversion 01 civic ex
  107. need info on swap engine!!
  108. b16a swap distributer questions
  109. 99-00 Civic Ex harness - manual or automatic?
  110. what to expect
  111. Do i need a gsr cat?
  112. Intake mounting
  113. Trans identification
  114. Ls swapped into ej, having tranny/clutch troubble
  115. how can i tell....
  116. 95 GSR into 92 VX question. NEED HELP!
  117. DOHC Head Gasket Q?????
  118. b18b swap parts help?
  119. Head stud question???
  120. jdm gsr engine harness on US civic question...
  121. oil pressure sensor location on second gen b16?
  122. Bad input shaft bearing or throwout bearing ?
  123. LS/Vtec Swap Help!!!!
  124. finishing my ls/vtec should i use LS or B20 bottom?what differences would there be?
  125. h22 eg
  126. gas mileage?
  127. Need help doing a B16 swap but cant find axels.
  128. Will GSR motor mounts work in my EG? Putting a B16 in...
  129. jdm b18b into 90 ef, need help with code 4 issues
  130. Intake Setups on H22 EG/EK/DCs
  131. D series Swap ?
  132. is it possible to use a D16Z6 cranck pully on a B16A2 (asap)
  133. Need help with 1G CRX+3G Lude B20
  134. Few quick h22 eg q's
  135. swaping a 94 gsr into 92 cx hatch??????
  136. GSR Head on B16 bottom end Questions???
  137. cel 21 after swap
  138. CR-V Hybrid?
  139. How to convert an OBD2a 5th gens wiring to OBD2b
  140. B17 alternator interchangeable?
  141. got a motor swap ? its goin to be funny i think....
  142. how to re-wire jdm to usda harnesses together for swap?
  143. jdm d15b swap
  144. what plug is this?
  145. Rod knock, head knock, tick tock, WHAT THE FOCK!!!
  146. h22 civic compression and smog q`s?
  147. h22 compression and smog q`s?
  148. What catback to use
  149. s2000 2.0 Vtec into eg?? is this possible/has it been done?
  150. Euro 99-00 Civic Si w/ JDM B18C Swap ... ECU question
  151. HELP.!! b18c into EK
  152. help on intake swap!
  153. weird idle problem.
  154. B16 SWAP HELP!!!
  155. I'm confused, obd-0 to obd-1, i have this write-up and need some help
  156. H22 EG no start
  157. Accord V-tech Head Swap
  158. B20 into EK - axle problems - please help
  159. CRX swap with a/c
  160. AC bracket...?
  161. stock manifold on ls vtec
  162. What b-series header on a GSR motor?
  163. Transmission Problem
  164. itr 5 lug conversion brake question???????
  165. Help needed on D16A1 swap in 89 civic
  166. spoon b18c5
  167. leaks? were are they coming from
  168. where is ......
  169. Throttle Cable???
  170. Need a list or pre-wired cars.
  171. IAB Hook Up, quick question (95' dx hatch B18C)
  172. so i got this b16a2 from a junkyard (need help first engine)
  173. NEED HELP PLEASE ON LAST ENGINE CODE
  174. Power strearing on a b18c swap... I need some help...
  175. Quick Wiring harness Question, JDM B16, OBD1, chipped P28, 93 CX
  176. D-series D16A6 to CR/VTEC Swap or B-series swap people.
  177. h22 in an EG, what suspension for DRAG
  178. h22 92 civic hatch....how is the ride?
  179. help on D16A1 swap into 89 civic HB
  180. K20A2 and K24A2
  181. B16 bottom end With GSR head??...
  182. OBD2-0BD1 ENGINE SWAP
  183. b18c axle and shiftlinkage question
  184. Soon to be frankenstein (ls/vtec)
  185. a/c help
  186. b18c1 jdm or usdm harness
  187. Swapping into an EG need some advice on the Engine of Choice
  188. cable to Hydraulic Tranny help!!!!
  189. hmotors shipping charges and overall ordering experience
  190. Info?
  191. H22A in my EG hatch
  192. i dont know if my car is overheating, my temp gauge is goin up and down, help!!!
  193. b18b into an ek...what throttle cable?
  194. h22 with H2B adapter plate install
  195. Upgrade fuel pump?
  196. ???????
  197. puttin a k20 in my EK civic NEED some help on parts
  198. FAQ: K20a Swaps in Civic EG/EK/EF/CRX
  199. k20a Swap question?
  200. h22a civic qm times
  201. More questions about a B18C1 swap in a 2000
  202. code 20? electric load detector? what the hell is that?
  203. ecu harness 93 coupe
  204. H22A engine swap. Wrong Ecu?
  205. resistor box questions
  206. Bad oil pump in this H22?
  207. B18C1 swap into a 2000 hatch - what harness to use?
  208. How to fix the ICV?
  209. H23 swap in a '94 accord Ex.....
  210. code 20 on b16a swap, help
  211. need help with instructions for obdo to obd1 conversion
  212. how to add an aftermarker ground wire to my coil?
  213. LS/VTEC ECU question
  214. Unable to set timing on Jdm b18?
  215. OBD0-1 conversion , Ign. Timing Adj. Connector?
  216. d16a6 crank pulley on b16a?
  217. 91 accord with h23 swap code 41
  218. HELP !!! CEL code 4.
  219. what f22 parts fit h22?
  220. knock sensor....
  221. JDM B18C swap, OBD1, best way to get rid of Code 22
  222. Throttle cable for a B18C1 in a EK hatch?
  223. Coolant Hoses? (pic)
  224. :::whats the BEST N/A oem setup:::: (opinion)
  225. b16 conversion w/ front clip
  226. Finally got my k20A civic!!! Awesome...just some problems!!!
  227. 94-01 hood latch cable
  228. Had b16, now ls/vtec are my motormounts ok to use?
  229. b20 studder?
  230. problem with B16a swap into 98 civic
  231. h22 h22a 3rd gen (3G) 1988 Prelude 1/4 Quarter 1320 mile times (Search Friendly)
  232. Car will not run, Cel 20 and 41?? Help me pls
  233. ls crank in b16a block
  234. OBD 0 JDM B16A in EG6
  235. ****H22 IN CIVIC WON'T GO IN 2ND AND 4TH @ HIGH RPMS****
  236. Sir2 B16 in a 93 coupe..
  237. dizzy help please! 0bd0-obd1
  238. D15B7 with D16A6 Head Swap? Worth it? Possible?
  239. usdm b16 vs jdm b16
  240. WHAT'S THE DIFFERENCE BETWEEN B20B AND B20Z LONGBLOCKS.
  241. PR3 pistons which rings?
  242. Car wont crank...
  243. help plz
  244. hepl plzz
  245. tranny problems - knocking when in gear
  246. H22 Eg euro r iac relocation???
  247. H22 Swap to Ek. HCP. Accord Rear Bracket ?
  248. B16a2 and the B16a3?
  249. LS swap A/C help
  250. LS/VTEC, where to get good oil feed lines??
