View Full Version : Hybrid / Engine Swaps
- Crank Position Sensor
- P28 with B18B??
- B18B swap parts. How to identify?
- '95 LS engine into 92 Civic 4 door, whats the deal with the 02 sens? emulator?
- registering question
- 01Gsr engine harness on 94 GSR chassis??
- Speedometer is AWALL
- b20 head on b16 block
- anyone who's swapped an H22A themselves, please answer question.
- Turbo H22 CRX pt. 3 (almost done)
- B18C1 VTEC yesterday gone today. Everyting checks out ok. HELP
- Civic DX ZC
- jun short complete engine
- My friend needs SWAP help!!! ASAP...going back to the shop tonight!!!
- b18c crx dieing at idle
- idle problem need help!!
- CRX motor mounts
- Swap Question about my 92 civic vx
- B18B1 engine harness
- what will happen if( axles)
- d16z6 head on d15b2?
- trouble with hmotorsonline web site
- swapping the ls/vtec out of my 88 into my 92...
- Need help wiring gsr motor into 92vx...A17 wire??
- Help Swap Question?
- swap question
- Which axle to use!?!??!?!
- which h22 cat on a eg hatch???????
- What Headgaskets to you use for High comp??
- Almost finished B16A in EK
- can somebody clarify the years on ECU's
- OH CRAP!!!
- How To: Swap B Series Engine
- wuts the difference of all sensors of 99 si and gsr 96-up ?
- b17 swap into 90 Std. Civic, weird sensor on back of block
- Car is DIEING. help ASAP.
- Buying a Swapped hatch?
- del sol rad hose nozzle sizes vs. civic ex rads??
- Wirinq Q for a B18C5 into a 88 CRX...
- b18b head onto b18a block help!!
- best hybrid choice?
- Question about the extra wiring involved swapping a b16 (99-00 si) into my ej6 (99 non-vtec dx)
- having difficulty with swap
- finished swap not running right
- Finally ordering my B18c1 on monday!!!
- I NEED HELP WITH A H22 SWAP REALLY QUICK....PLEASE!!!!!
- ac mount on 96 ek with b16
- which shift linkage for b16 swap?
- ok, IAB wiring driving me nuts!!
- h22 civic, changing clutch master???
- will poorman type r pass smog?
- h22a swap in ek
- d16z6 into crx si, how hard?
- RSX-S Motor/Tranny into 02 LX Coupe
- Automatic tranny axels VS Manual tranny axels help.
- YS1+lsd
- k20a in civic coupe
- 92-95 civic ex fuse box diagram
- Will a CRV MC and booster work
- K20a into an EK chassis? Let's get all known swap info in this thread!
- Insurance/Motor swap/ fake reciepts
- ecu, axle question
- H series motor and the front motor mount
- h22 integra sway bars (h22a dc2)
- 5-speed swap info....
- Swap Question
- civic/integra
- wiring knock sensor
- when replacing synros, do you have to change out gear as well?
- Just swapped in a B18b1 into my cx and turboed it
- What is the weight difference between a 89 and 92 HB civic?
- I need help with almost completed swap. (Quick question) Please Help
- Hmm newbie question about b18b
- 96dx hb motor swap help
- B16b swap
- tranny problem
- JDM B16A SiR-II in a 5G Civic
- Ice box
- What are the REAL specs on my JDM B16A SiR-II?
- Cooler thermostat? JDM B16A SiR-II
- EK sohc auto to manual conversion question
- Air Conditioning with JDM B16A SiR-II?
- Water pump for JDM B16A SiR-II?
- ECU and Distributor
- header too short!!!!!
- 99-00 Civic SI motor into 5th gen! QUICK question!
- LS turbo vs. b16a
- problems with b16a swap
- whats the diff between obdIIa and obdIIb???
- b16 top with b20 bottom in a 99 si
- 95' B16A SiR-II in EK
- rpm climbing at idle
- Tool SET?
- H22a swap questions
- JDM H22 Wiring Harness ?'s
- ZC dohc Swap in 95hatch
- Progress on swap so far
- automatic ls swap in 98 coupe
- Fuel Pump nightmare.. Help car hesitates, and dies...!! URGENT
- Which engine should i swap to?
- injector sizes ???
- anyone had problems with z10 oil feed fittings with ls/vtec
- ????'01 GSR into a '96 Del Sol?????
- b18c1 and tranny into a 93 teg ls...
- All B-series front tranny mount/bracket same?
- '91 LS distributor on LSVTEC in '90 hatch?
- 00 civic SI exhaust
- how bad are your POLY mounts ?
- Engine Swappage
- Poor Mans Type R Q's
- B18c1 into a CX
- Am I starving my B18C with my stock....
- BAR approval sticker
- convert to a 4 wire o2?
- Cheap swap(D16z6)... worth my time????
- LS in an EK
- First gen b16 into a eg mount question
- k-series CRV-tec swaps.
- auto d15-manual b16a hydro swap on a EG questions
- Don't ask why: Sohc into a G3 Teg Q's ?
- DC Sports h23 Header and h22 header
- need some h22 help
- D16z6 Computer. Which is best bang for the buck??
- Parts and/or advice needed for an LSVTEC to be CA smog legal?
- My h22a civic hybrid EK Pics... will keep updated... (feedback welcomed)
- H22A in 94 Teg complete, no ECU codes, but problems idling
- 98 USDM B18B1 - No Charcoal Breather Canister?
- B16 in an 85 crx. No prob?
- JDM sux?
- Single Cam VS. Dual Cam
- ctr in a 96 ek, idle problem
- ls/vtec help!
- Euro R intake fit in H22 civic?
- swap a b16 block with a b18?
- last question bout resistor box(did search)
- I'm getting screwed, please help me
- injector resistor pack for h22 civics ( h22 hybrids ---help)
- temp guage reading retarded in B18c1 CRX
- need picture of b18b in ek: right driver side mount bracket
- abs master cylinder question
- Quick Questions #1: GSR to ITR, Engine Conversion.
- Car has trouble starting.
- JDM Clips
- h22 hatch!
- DSS Stage 5's, H22/EG, Street Car?
- b20 turbo swap for a 2000 civic si
- would map sensor cel stop vtec from workin?
- GSR block girdle
- how much does a 1st gen b16 with tranny weigh???
- 00 Exhaust fit a 96 hatch with type-r swap?
- B18B1 with GSR tranny?
- PLEase Help... Swap question
- Help Quick - Radiator Hose size...
- Need some tips on engine removal/install
- B16a2 when where how what when who what, blah.
- B16 Tranny Question!
- where to find a usdm b20z?
- Can anyone tell me how to wire this switch for power folding mirrors!!!!
- If you have a b18 in a cx you might find this helpful.
- map sensor code 3
- b16a firing on 3 of 4 cylinders...
- d17a swap into a crx?
- Axles
- Will GSR engine harness plug directly into Ls?
- B18C1(USDM) Swap just complete. A few need to knows?
- d16y8 swap
- CAN you pull a motor with out pulling the axles?
- Question about possible bad injectors
- h22 in 99 hatch
- dch22a suspension problem!
- h22 eg mounts
- 98 B18C1 into 96 hatch exhaust question
- itr pics
- b16 clutch in LS?
- please some help please
- b16a sir II ecu pinout
- b-series swap in my 91 si hatch... suspension setup from itr?
- Need input on cv shafts "out of alignment" after 92 civic hatch 95 GSR Swap
- I still can't seem to find this erratic idle problem....
- lsvtec header clearance Q's
- Cheapest way to build a Bseries engine???
- ECU QUESTION!!!
- where to buy a rebuilt motor online?
- 4 wire O2 problems
- 95 dx harness, 95 b18b engine
- 2k gsr motor into 94 ls, any problems?
- PROJECT GSR/R *lets work together on this*
- Problem: B18c1 Into 90 teg
- A/T to M/T can i use a M/T ECU?
- STILL throwing code 41!!!!!!
- b16swap, CEL, help
- Can i use a 96-98 dx harness in my 99 ek??
- 93 Integra
- EG in an H22 ... A/C issues (What lines to use ect...)
- 98 spec ITR motor in EK wiring diagram! IAVC doesn't work.
- dx auto to ex manual???
- help me wire vtec
- Afterthoughts on itr (b18c5) swaps?
- p28 or p30 pinout
- I need a Motor mount kit!
- b18c1 Turbo or b20/vtec Turbo
- speed sensor problem in H22a EG
- 88 hf crx, b16a shaft problem
- D15B2 crank work in D16A6:?
- Kind Of OT, But Check Out This B18C
- Need a pic of HCP passenger mount H22 into EG/DC chassis
- h22 civic weird problem help..... possible vss?
- SMSP, Hytech, Comptech race header fit in an ef?
- How much HP can 90-93 Integra axles hold...?
- Runs Rich on "Rundown" From 4-5k To Idle - Help??
- Oil on #2 Plug, Compression is Fine
- LOADED with questions. ( about swaps )
- Those that did Brake upgrades!
- Much Needed Help with engine swap (H22)
- I never see the 86.
- need help, i need a TPS sensor for the 1st gen b16a
- my car idles at 2000 can someone give some info
- Auto to Manual conversion
- 6g swap question
- Beating a semi-dead horse: OBD2 B18B1 into OBD1 95 Teg LS
- Factory B16B + Spoon 1.8 kit, anything else?
- K20 --> EM1
- 93 civic B16 SIR 2nd gen in need of tranny mount
- 1st gen B16 head vs 2nd gen b16 head?
- what is a good swap for me
- a/c question
- CEL 14 JDM B16a2 in a 5th gen civic
- please help me swap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- best obd1 ecu for my b20z
- Anyone have....
- Help Me!! EG H22 mounts.
- 99 SI (B16a2) swap into 93 civic SI
- need help on a jdm b18b swap into my ek. harness/ecu ??
- H22 eg people
- New 6gen EK swap page.......
- 93 civic swap B16 SIR 1st or 2nd gen
- k24 same tranny bolt pattern as k20?
- h22 swap in accord wagon
- help..all motor topic gives no help! ls internals in gsr block?
- excessive engine vibration pulling through 3rd and 4th gear
- need help looking for a part for my swap
- blue plug on 98 ex harness under IM
- Need Help ASAP Please
- who sells VTEC heads
- hmotorsonline.....anyone used them?
- Why do some fuel rails on the b16a have a pulsation dampener and some dont?
- tax on motors?
- should i or should i not
- 00 Si Tranny On B18b
- Need best prices for for h22 hasport mounts and level 2 dss axles
