View Full Version : Hybrid / Engine Swaps
- Interest in H2B chromoly flywheel for normal style clutch?
- What injectors can I use?
- Another Civic Problem Thread - No Power To Main Relay
- b16b swap help
- 92' EG B20 Swap
- 94 Ex with LS swap, idle high and sometimes surges?
- swap question
- wiring question 97 civic ex 5sp
- 98 EL b18a1 swap, limp mode, rough idle, crazy speedo/tach, battery light HELP!!
- 96 civic with bseries swap!!
- I need a How To Guide! OBD0 to OBD1 Engine Conversion! Please!
- Just ordered swap, need help on which header/exhaust combo would fit properly?
- Ls integra soon to be type r swapped need some advice
- B20 IN EK WRITE-UP NEEDED!!!
- 98 Ek GSR Swap
- swapping b18a1 into 96 civic dx. need advice
- Car is slower when Warm!
- quick dsm injectors h22 question
- B18c1 swap with code 23 (knock sensor)
- Automatic H2B, tuned on NepTune. Yes it's possible
- Has anyone kept there Auto pedals when converting to Manual
- B18B1 into a 97 Civic HX Transmission issues
- Need your guys help
- Can anyone tell me if.......
- 99 hatch Axle issues
- 87 Crx sleeved h2b turbo swap build...
- 94 Gsr Motor into 93 hatch
- Swap Type R Running to Rich Failing Smog
- B18c type r swap into em1
- OBD1 LS distributor needs to be wired to EG harness
- High Idle after B Series Swap (LS)
- F23 swap
- b18b swap axel bind 99 civic si
- k20a3 cams (and girdle) in a z3? please help
- 98 civic. just swapped a b20b1 ls.
- post any h2b/f2b/h2d/f2d builds pics
- which short ram (not company but for which chassis)
- H22 EK randomly goes into and out of limp mode???HELP!!!
- b20 wont start when hot
- B18C Alternator
- 1996 ITR engine in EJ8 drive shaft question
- EM1/gsr swap - need help with msd installation
- 92 civic vx 93 b18a1 code 9 runs sluggish
- balance shaft belt broke!
- B Series Swap INTO EK Sedan
- F22B6 block with VTEC head?
- ls vtec swap ??????
- H22 EG mount problems
- looking to swap b18c in my 95EG
- newb obd2 or 1 dizzy?
- b18 running rough
- HELP, B18B in EJ8 throwing 5 codes
- GSR secondary butterflies setup
- multi code help/ limp mode
- GSR P72 OR P28
- Looking for some Help
- 1996 Civic with ITR ECU Code 90.
- b18a1 swap into 95 civic ex
- LS Vtec better than GSR
- b18c in eg hatch mess ecu trade
- H2B Header
- H22A4 into 96 Odyssey
- AC & PS Bracket
- Dc2 type R looms problem
- 94 Del Sol GSR Starting Issue
- JDM B16a Vs B20b, 2 Questions
- Oil cooler fitment.
- EM1 and DC Bseries halfshaft the same?
- Civic sounds like a Subaru
- 1996 b18c in 1996 hatch. what is this hole for? pic inside.
- b20/b16 swap
- Need Help on Engine Swap with CA SMOG
- EG B18A/B Bogging down
- Engines dies when braking hard.
- Integra Type R motor 95 civic coupe
- F20b Please Help
- Questions on LS / B18B into EK
- H2b eg wont rev past 6k HELP
- P1256 Problem HELP i need to pass inspection!!!!
- B18B1 into an EJ1
- b16 or b17 tranny?
- K20A2 or B18C Type R
- help!!! ek b18b w/automatic tranny swap
- NYS Inspection With 99 Civic Gsr Jdm Swap HELP!!!!!!!!!!!!!
- f20b swap into 99 civic ex question?
- JDM B18B1 into '93 Del Sol Si - help/info
- 1992 Civic with JDM Integra Type-R swap AC question
- axles for b20b
- eg civic with lsvtec (speedo problem)
- EG/EK Swap Help
- 95 civic b20 swap throwing codes 3,4,41
- Need some help. GSR swap into a 2000 sedan. Auto to manual wiring??
- which flywheel on my b18c99si swap
- EG hatch JDM GSR swap
- dizzy question?
- 2000 dx hatch GSR swap... bad idle, very random codes, etc. HELP
- What to do a legal JDM Engine Swap in CA?
- B16 valvetrain need help!!!
- k20a2 clicking on uphill any ideas?
- Help!!!93 civic b20 swap no power until 4k
- gsr dyno numbers
- What header for H22/EK Swap and Catalytic/Cat-Delete Style?
- SR20DET P28
- trans has no gears
- Harness Wiring Help Needed
- Activate vtec on P28 without speedo/VSS?
- shifter cable length?
- wiring mess b18b
- Help! Can't pull cel codes. b18c in eg hatch
- wiring with a B20b swap into a 98 civic ex 2dr
- Mount Question
- obd2b civic with obd1 b18b ecu questions.
- 99 gsr swapped ek hatch vtec problem
- 3 wire to 4 wire obd2 square alternator plug
- 99 Gsr OBD2a With a SI Wiring Harness Help!!!
- Jdm f20b
- clutch kits for my b18c99si
- OBD2 to OBD1 VSS question.
- GSR swap HELP!!!!!!
- K20a Type-r anyone know about my specific motor??
- 94 eg hatch swap help
- NEED Help 99 GSR EK SWAP
- P73 ECU Problem In 96 Civic with ITR Engine
- H22 civic loses power an dies when comes off gas..
- jdm h22a civic hatch 00
- Need!! Help 1999 civic si with b18in it
- Brake Job 2005 Honda Accord Hybrid
- Left mount question
- 95 civic dx b20b swap runs like shyt
- 98 civic with lsv, spark, fuel, compression, and timing correct but no start
- LS/VTEC problem
- 96 jdm gsr in a 96 hatch hose questions.
- b20 swap help??
- need help b-series ac compressor on a d-series?
- b20/v or head build?
- H2B and B20vtec legality in CA?
- I need some advice on a B18C5 engine.
- eg hatch b20 swap issues
- where's the swap guide?
- NEED HELP!!! JDM B16A in a EK
- 96 ek hx type r swap wireing help
- Old G23VTEC motor, have a cam question
- Fresh LsVtec build falling on its face
- 00 Civic EX w/GSR - want A/C
- 1996 Civic si F20B swap???
- F23 swap in EG, search and read before you do.
- J32 eg help
- EG GSR Dead Cylinder After Hot Start
- ITR headers on a GSR Del Sol
- b16 swap
- b20 help
- ITR AIR BOX AND TUBE IN A 99 EK HATCH/B18c1 swap QUESTION
- b16 vs b18 swap
- f20b swap
- Gsr into Del Sol HELP!!!!!
- 1996 civic ex swapping to B18b
- h2b/f2b/h2d/f2d 1/4 times or dyno sheets-what can an h2b do
- GSR ek wireing help
- 1998 civic hx D16y5 to B18B1
- Del Sol swapping into any accord engines help please!!
- Looking for a swap shap in SoCal.
- Best bang for the buck swap? K24 K24 B18 B20 ?
- B series swap (EG)
- CIVIC SRT-4 SWAP DYNO
- 94 eg coupe h22a in now, h2b?
- I need help!!
- OBD1 LS-Vtec in OBD2 car?
- JDM H22A type-s in Ek9.. Idle Issue :[
- H22 or gsr swap 00 hatch
- j swap guide anywhere?
- P0130 issues
- F20b ek install thread!
- 95 hatch b20 swap issues
- Blackworks vs golden eagle b20v kit
- j swap people i need sum help!!!
- bleeder valve
- 99si 18c swap cel code 45
- b16 b20 head gasket, water pump help?
- Default D16y7 to d16z6 using stock engine wiring harness
- i need help: SOHC ZC VTEC SWAP INTO MY EF
- B series Injectors capabilities
- Jdm gsr obd2a into 96 civic cx
- What would you do.
- car wont rev
- JDM B16B R or B18C R in 00 EX Question
- b18b swap into ek coupe
- H-Car RHD H2D EF Hatch
- EG SI GSR SWAP
- b20 swap?
- B18 EG basic swap questions
- b20z2 or b18b??
- What Engine Should i Swap into my 98 Civic?
- H22 turbo, 5th gen Civic, alternator fitment
- ls-vtec build
- H22 DYNO RESULTS
- i need help 99 civic with b18b1
- i want to swap a gsr in my 00 hatch
- Engine swap for a 99 EX
- Advice Needed on B16a swap for my 94 cx hatch
- b18c swaped si
- need help with b20 swap in eg 4door
- Diagnosing Idle and RPM issue on H2B
- pleasee help mee 1993 honda del sol b20b swap
- 95 civic coupe
- D16y8 + D1618 internals?:
- Best route to hit 12's with b18c in hatchback cx
- More wiring help. IAT, and alternator.
- p2v clearance issues with high lift cam
- Need an engine for my 2000 civic ex coupe!!!....what do i get?
- 94 civic Electric Power steering pump
- Need help on Obd Conversion!
- OBD2 Distributor on my OBD1 B18C??
- 1995 Honda Civic SI: Engine Swap
- Ls should i or not
- car dont start
- B18C1 with turbo for daily use?
- My H2B build
- 98 civic Ls swap iacv help
- JDM B18C into a 99 SI quick ECU?
- b17a1 in 94 integra engine mount help
- battery lite?
- EK/SI...B18C5? Where do I start?
- H2B oil pan from MOROSO designed by QSD
- another ls wirring problem ,dual port/ multi port
- CV Shaft Problem
- Quick iacv question.
- sticky for adding vtec to a 96-98 civic
- OBD2B gsr swap into 93 eg si.. help appreciated
- 98 Civic B20/VTec not starting
- B18a1 00 Civic
- oversized bearings????
- crazy idea
- weird h2b timing question
- Want to do a H2B build... help finding the h2b kit from qsd??
- vtec killer cams in my Euro R h22
- B20 questions
- B swapped '00 Coupe Problem
- h22 ek motor mount help
- new f2d write up
- which harness to use
- H22 Type-S (Red Top) EK
- Honda k series in a 1933 ford hotrod??
- Engine Overheating*****rad question
- H22 swap -- boiling!
- b17 Wiring questions just checking
- B18B Swap Into EK Questions?
- jdm b16a on a 96 hatch throwing a code9
- H2D ek coupe
- OBD2B to OBD1 Auto Harness conversion Question
- EK b20 problem
