View Full Version : Hybrid / Engine Swaps
- Where do you source obscure bolts?
- SOHC F2D Question
- F22C/H22A Hybrid Motor Build?
- '92 vx b18c1: knock sensor(code 23)
- h2b oil reading?
- H2B nitrous
- K20 Cable Issue, Please help!
- Wiring Trouble Shooting Help - CRX / B16a / EG Chassis Harness / GSR Engine Harness
- F20c RWD RHD EG hatch build
- cable to hydro conversion question
- H2B Smog issue
- h22 swap fan question
- any news on a hybrid element?
- H2B Balance Shaft Question
- ESP Alternator Bracket.
- Hazards not working after AP1 cluster install
- Going J-series few questions
- h22 accessory belts 94 accord
- H2B Mounts
- 98 Accord J30 and AEM 30-6051 questions
- f22b head on f23a?
- Carb'ed Z6
- 94 b16a swap power steering
- H2B EF (NO KIT) PERFECT HOOD CLEARENCE
- Compression test on 99 Jdm itr motor result inside
- B-Series Cable to Hydro conversion question
- H2B P/S and A/C EK
- Yellow Spark - b18c in a 92-95 civic hatch
- h2b 4.9 final drive??
- Non Vtec B16 Whatcha think?
- K20 EG / Temp gauge and fan switch. Hybrid Racing Harness
- h23a in obd1 eg hatch
- f20b swap on integra wont start!! pliz help
- 93 del sol with h22, supercharged?
- Is anyone rockin' a B20 in an EG hatch?
- Evo 8 Injectors, what plugs do i use?
- h22 p2v question
- Safe to run p72 ecu on jdm itr eng?
- B16B for parts
- d16z6 to d15b
- Out of the game for a minute
- quick easy question
- k build
- my gsr swap cuts off at 7200 rpm?
- ITR HEAD Stamps?
- which harness/ecu i need for a h22a in a
- Crx obd1 engine harness question?
- can you use gsr valve springs in a ls head?
- which harness do i need ? b18c in a EJ1
- need help on ef swap
- what can you swap into a crx?
- Question, do you know...
- hondata h2b swap headache
- k20a3 compressor
- Steering Rack RATIO (NOT LTL) info request
- b series intake on h22
- H series swap to an EG
- H2B Alternator Question.
- Qsd flywheel bolts?
- need opinion?
- h22 question
- B20 into 95 civic
- f22 into vx eg hatch
- trying to get intouch with qsd
- CR-Z K20 powered - Hybrid ?
- J Series in an EF
- Your opinion on my B-series build re: piston choices
- NEED SOME HELP!! no spark
- What's a good exhaust for a ITR
- 99' civic dx with 01' d17 straight pipe
- F20b OBD1 vac lines..need help
- electric a/c
- OBD0 Engine into OBD1 Chassis - Easiest way with what I have?
- F/S: H22/EK Hasport mounts and stage 2 axles
- H2B Evo/Bisi or QSD Slave Adapter ?
- AUSTRALIA 88 EF B18C swap wiring problems help please!!
- Transmission swap problems.
- question about fujitsubo rm01
- h23a Ek intake fitment?
- Converting OBD1 B16a To OBD2B
- eg9 manual to auto swap
- k24a8 help plz
- help with s2000 cluster on eg civic
- B20 Vtec Auto?
- 92 civic lx sedan - How do I make a b18b1 swap work?
- rsx cluster in ef hatch problems!
- full s80 gearset in s1 case, with s1 diff
- Wired in IAB/KS: Throws CEL
- OBD2 gsr in ej1
- obd2 motor, obd1 car
- b20vtec question
- ignition problem
- B20 OBD-1 into an EF Sedan - Two Questions
- metal grinding when trying to start
- h22a1 obd1 dizzy ? 94 civic
- H22a with prelude halfshaft - Rattling Sound (Video)
- Civic Dx w/obd1 h22 problem
- Pippen's All Motor EG QSD H2B setup
- Mount Identification... Ek H22.
- how big can i bore an h23 block too
- JDM B18C into 98 EX few questions
- U.K H2B EK Civic
- SAFE MODE HELP! LSVTEC
- A Review of Alternative Motorsports (OKC) 1.5/5
- F22B1/M2S4 into 96 civic CX need help
- F22B2 with F23 pistons?
- P28 or P72
- Fuel injector question
- g23 piston dome
- h22 into eg shifter cable routing.
- Vibration while turning
- evo kit h2b into ek que.
- Replacing my h22a with h23a blue top
- clockwise b-series
- Idle issues please help
- Help with Decisions and Questions...
- 99'B20b what ecu should i run? obd1 conversion
- h22 swapped integ dc2 speedo inop
- what do i need from my lude to swap my motor to a eg ?
- b16 head with b20block
- NEED HELP! TIMING BELT KEPt JUMPING
- drivers side mount on evo h2b kit
- Help me identify my B18C please? Is it type R?
- What mounts for gsr into ek
- pure odb1 crx!
- 92 eg b20v help
- Where to Buy K20A2/Z1???
- G23 V-tec Clarification
- Ignition problem, starts then dies
- obd1 differences
- O2 Sensor
- B18B1 auto swap into EJ civic
- H23/F22 frankenstien low oil pressure?
- h22a4 eg swap questions
- Type S 6 speed tranny in EP3
- Help! Need 2wd car to a 4wd Civic guide
- yea i searched...
- B16b clone...
- Thinking J Sawp for my 95 eg
- Honda J32a2 v6 Civic does 11.8 sec
- CRX ODB-1 Conversion Questions
- B18B (OBD2 LS) swap into EK Coupe - Do I have all the parts needed?
- newer honda coils
- D17A2 into an EJ7?
- h22 engine misfire
- K series Engine Swap Questions??
- h22 shifter box question here....
- Type R in a 95 GSR vtec help
- Do these Cams Look like Type-S or Reg. H22 Cams
- 93 integra atmosphere pressure
- Sp00nFed EM1's back again[QSD, S2, GP WHITE]
- OBD1/OBD2 B16A into 95 cx wiring question
- J32 DBW success!
- H2B Valvecover
- b20b p8r
- I searched everywhere for this easy question which intake for my swap???
- BrownKid's H2B
- H2B Kits - Evo and QSD
- With swaps, how are systems that don't exist in the car being swapped get sorted out?
- J swap LSD options?
- hasport cable to hydro conversion, do i need a clutch master?
- im tryin to bar my usdm gsr swap in California
- SP GARAGE 2.0 build thread
- supercharged OBD2 h22 into OBD1 eg civic?
- crank pulley interchange; F23-K20
- h2b swap no expensive parts other than qsd
- mahle piston H22 set-up
- 97 ex h23 vtec wiring issues
- GSR Turbo Build. *Car does not stay on!*
- Crankshaft question
- need p72 basemap chip
- 5 speed crv trans gearing question
- GSR Turbo Build ***Wont Start!!!!!!!!! ***
- b18c1 into 99 civic..few questions.
- 95% done with wiring a STD hatch and hit a speedbump
- f22 block h23 head
- what ecu for h22 eg?
- Ls/vtec obd1 or obd2?
- H22 Ek Hasport axle problems & exhaust problems
- alternator fuse
- H2B with no adapter plate / kit : Q's
- which engine would be best?
- HELP!!! PLEASE ON F20B SWAP ON INTEGRA
- adjust speedometer after swap
- Just bought an 88 CRX HF w/ LS-VTEC. What's this plug coming out of ECU?
- Civic 96-00 , want to swap an F22, same mounts as H22?
- k20z3 swap?
- ITR cams
- H2B width vs a B?
- Is f2b ac compatible in the ek chasis?
- Stock Piston sizing
- Nick j32a2 trip-tronic desol
- DBW EK J32a3 swap w/ P&P HARNESS
- OBD2A engine into OBD2B car and OBD1 ecu
- gsr block ls crank ls rods cams???
- Oil bubbles in headgasket!? =s HELP PLEASE!!
- Will this tranny work?
- QUESTION:Y8block/Z6head..how do i time it.
- J swaps!!!!
- K20Z3 swap questions *searched*
- Honda Accord 95 AWD conversion?
- hydro to cable clutch
- D series head question
- 2001 gsr swap
- gsr help, ls crank, ls rods, type r pistons
- can you straight swap a 1.6 D head onto a 1.5 D?
- D16Y5 HARNESS QUESTION,PLEASE HELP
- Power steering bracket
- OBD2a GSR motor on OBD2b harness and ecu
- 94 gsr into 92 cx issues... help!!!
- best balance shaft removal??
- HELP PLEASE!!!!!!!!!! LSVTEC motor mounts?
- A few swap questions:
- issues with d16 will b16a2 swap solve them?
- ls vtec question
- Hydro to Cable in my del sol running into a few problems
- EG Goin K on boost, nt sure if k24 or k24/k20
- Parts to complete GSR Swap in an EK.
- k-tuned immobilizer bypass donīt work
- auto to manual tension conversion on h22
- ls vtec problem i think
- ATTN: HELP! EG KSWAP SHIFTER BOX PROBLEM
- B16a into 99' CX
- LSVTEC or CRVTEC
- Our shop car. '89 civic hatch NA Drag/Street
- how to block off egr h22a eg bogging out
- F20B auto ver + M2Y4 VS full man F20B
- P30 pistons on a B18c1?
- Soon to be F2D T!!!
- can someone confirm which one is right dizzy wiring
- Auto to Manual LSVTEC Problem!!!
- MR-S with K20A swap! Kuwait
- 91 integra with 97 jdm b18c vtec. wont idle or run good.
- P30 Intake Manifolds
- 1992 festiva D16z6?
- Hondata s300 code 11 issues
- g23
- h22 v h2b
- H22 EG Revs Crazy
- What CAI for a h22 EK hatch with euro-r manifold?
- D-series Swap 93-96
- H22A -- Elimination of two OEM parts
- H23/F22 no start
- 2.2 b16b
- What to do? Exhuast Setup for Fitment
- All 97-01 Prelude ECU are obd2a
- h22eg which rad hoses?
- Swap Integra exhaust to a 95 Eg
- Question about bad rings...
- k24 eg swap questions
