View Full Version : Hybrid / Engine Swaps
- What mounts for B-series in EK
- repining integra cluster onto an ek.........
- k20 harness diagram for crx?
- OBD2-OBD1 CONVERSION HARNESS FOR LS/VTEC...
- b16 trouble..cel 14
- pics of prelude cai on an h22 swap........
- ECU Pinout, please help
- can i keep a/c???
- Anybody running Baker heads?
- p13 into '93 del sol?
- Much needed install instrustions for Golden Eagle VTEC Conversion Systems!!!!
- Coolant Hose Prob/h22accord!
- idle and clutch prob
- K20A in EK9
- H22A in EG (request)
- what kind of harness is this
- 95 LS motor into 93 teg problem.
- OBD2a to OBD1 conversion harness question
- HOW TO EK firewall conversion
- obd0 to obd1 o2 sensor?
- B18C swap P.S. questions?!?!?!?....HELP
- difference between b18c1 short block and b18c5 short block?
- zc mini me ?
- NEED Help with a 98 h22 swap into my 99 civic coupe...
- H22 Head on JDM F22b
- Project Log of 90 CRX HF with a JDM h22a swap!!! 10 lbs of shit into a 5 lb bag!!!
- D16Y7 tranny
- What tranny comes with JDM 92-95 B16A ?
- h22a engine mounts for crx
- bouncing idle...
- Problems with my H22a swap into my EG
- drive without ecu???
- wiring for obd-1
- D series AC compressor on B series engine?
- d15B in EK
- B18C1 in EG Coupe CEL?!?!?!
- Tranny question!!! NEED HELP ASAP!!!
- Will any other motors distributer fit a b16 if modified?
- Timing belt problemes..
- rear motor mount ?
- Brakes Locked HELP!!!
- Best Engine Swap for a D16y5?
- No fuel line pressure
- new b16 rex wireing help!!!
- Guys, what does a civic with a h22a in it run in the quarter? Say stock?
- Engine swap ?
- B16 Trouble
- b16 ef hatch trouble..please help
- HOW AM I GOING TO PASS inspection!!!!????!?!?!
- Auto wire harness in Manual integra!
- f20c motor and k20a tranny with adapter plate????
- B-Series Turbo
- Euro auto P13?
- jdmshit jumpers any good???
- ODBII GSR into ODBI Ex
- d15b7 mini me into 99 ex..plz help
- question on hybrid smogging
- The Real Story About h22/Accord Swaps
- civic cx with b16 swap? HHEELLPP!!
- GSR axles work for H22 eg swap?
- 92 civic h23 axles are these the right ones to use?
- b series axles
- problems with my swap!
- B16A2 Or GS-R???? Help me Out Plz!!!!
- CRX REF Certification....
- b18a into 93 ex
- IAB WIRING!!! i searched!
- obd1 b18b into obd2a civic dx Please help
- b18b1, b18a, b17a once and for all please....searched
- H22 in EK with H22 axles, springs, shocks, rotors, brakes etc...?
- Need some opinions on a hybrid car project
- CRX swap question
- EK ITR Question
- Is there a difference in 92-95 civic and 94-01 integra Speed sensors, vss
- ls/vtec timing belt
- vtec diagram 93 prelude
- Question about N1 crank pulley and alternator belt
- Will my Air Conditioning system Interfere with my Type R Swap?
- Money for motorswap!!
- oil pressure gauge install (i searched)
- K20A from DC5-R into ES2 Civic Sedan
- Will parts bought for '89 H/B B16a swap fit in '92 H/B?
- b20 no start need help please
- B18C sensor question?????
- H22 axles in EG. axles don't 'look' right...no 56k
- B17a Head + B18c1 Block
- Front tranny mount. on b18b swap into eg
- 95 civic VX w/h22 Question about P/S and A/C
- Shielded Wire Question
- engine harnes
- is it hard to pass smog with a ls vtec setup?
- Buying an LS block tomorrow....need help.
- B18c swap into 98 EK 5speed...problems.....??????
- help asap! obdo-obd1
- Awesome installer in PHX area.
- What do i need to get for my B18 swap?
- ls swap what tranny?
- Any benefit to throwing a JDM D15B head on a D16y8 block?
- Code 17 (vss) gauges work but other wierd shit
- what year legend calipers for ITR 5 Lug? need to know ASAP....
- JDM ITR B18c swap?? Difference between pre 98 and 98+ JDM ITR motors
- Is a Skunk intake manifold shorter then a B16???
- Finished my first swap last night
- Which radiator for B18C1 GSR into 93 Civic?
- Would a B18C1 (GSR) motor fit easily into a Honda Civic CX?
- h23 non-vetc manifold on a d16z6 head
- LS1 in 240sx
- h22a distributor problem
- B16B throttle cable.....
- Prelude h22a Intake Control Diaphragm
- Hasport Press Release
- Please help! del sol B16 wiring harness replacement
- y8 manifold onto d15 motor after y8 conversion the car smokes
- HELP me out CRX won't stay on!!!
- Del Sol Swap
- i just got a 1.6 vtec head and.....
- ls-vtec dyno results
- I need help on what type of cam gears and cam shafts i should get.
- obd1 engine harness question...
- Suggetions on Engine harness?!??!?
- k20 oil pan clearance on a ek
- Looking for the best place to by k20 type s with 220hp
- K20 swap into a ek? need some insite.. pics and how to would be great!!
- 1.6 SOHC head on 1.5 block???
- which is better for na build, close or open decked h22?
- Turbo b18c in a 2000 ex cpe, pics, does your a/c fit.
- Auto h22 into auto ek chassis
- Custom axles, where can I get some?
- aem v2 on h22ek??.......
- What linkage for b-series Del Sol?
- How to make your own axles for K20a /k20a2 /k24a hybrids eg/ek/dc2
- Wildest hybrid I have ever seen
- b series IACV?!?!
- Does anyone have information about putting a 4g63 in a mirage
- URGENT HELP........Distributor wiring and axels
- B16 linkage problem?????
- JDM OBD1 P30 ECU..hondata?
- TOOLS for EG SWAP
- What AC Compressor bracket to use for a D series pump on a b series motor
- skunk 2 obd2 to obd1 conversion modifications
- D-Series w/ Cable Tranny
- which radiator do i need???
- Help If you know
- how much did you guys pay for your b series swap?
- b16a2 wiring
- what D swap should i get for turbo/uberdata applications?
- stupid question, b16a engine into crx.
- question about b16a engine with type r head?
- p28 ecu + obd-1 ls/vtec .. which harness?
- FI or NA
- CRV-tec
- Wiring Diagram for b16 SIR I into 89 SI
- this might be a dumb question... K series ?
- throwin knock sensor code. Will this cause vtec to work sometimes?
- best ecu to use???
- prelude B20 ?
- h22 into ek ex help
- IAC or Something ELSE? I ned help
- B18C swap in a 98 Civic EX...Throttle Cable question????
- h22a into a 1994 civic cx
- Will this be a reliable DAILY DRIVER setup?
- GSR tranny into 95 civic please
- JDM D15 and CX exhaust manny
- B16 in DA Axles
- Weak bottom end on B20B?
- New Shop
- B16B into 96 DX?
- Need a good shop.....
- my dyno LS/VTEC
- Gsr swap+96 hatch=pain in the ass!
- People with B18b (LS) swaps: Where to buy and how much?
- K20A2 in an EG Hatchback?
- wiring 94gsr into 96 ek hatch help please
- Where does it go?
- p28 or p13 on a h22a ek?
- vti swap
- obd1 1.6L sohc non-vtec ecu
- PISTON HELP!!!!
- Question from the UK, Contact number for place racing?
- HOW CAN YOU TELL THE YEAR OF A MOTOR?
- OBD0 B18A1 to OBD1 B18B1????
- Need help with h22 civic!!!!PLEASE!!!
- F22 in 94 civic
- What accessory Belts?
- ecu sticker codes
- b18a into 93 ex motor mount bracket trouble
- Converting OBD2 Injectors
- im buying a b16a2 for 800 bucks with tranny Is it worth it ???
- h22 into ef
- Exhaust swap question?
- need wiring help to finish up d16z6 swap
- obd2 B18b1 swap into a 1998 Ek
- Avid Mounts
- THROTTLE CABLE BEATDOWN
- Code 21 Driving me nuts. b16a2 - CRX - conv. harness
- What is code 22 on an obd-0 b16a?
- just bought a h22a for my honda civic 94 lx, i need help
- D16Y7 to B18C5
- h22a4 civic shifting problems....
- h22 into 96 accord
- how to change from 3-wire IAT to 2-wire??
- INTEGRA BACK DISCS IN AN EG?
- F22b1>EK civic
- skunk 2 manifold purge control solenoid? Need quick response!
- axles question need HELP?
- B16A2 -> B18A1
- xsi swap
- 98 Civic LX, looking for the right swap.
- BAR Approved
- searched read 70 post cann't find it obd0 to obd2 alternator plug
- new hasport mount for 92-95 civic for h22
- HELP
- Just finished swap, B16 overheating problem & fuel pump
- z6 swap wiing
- Knock Sensor Wiring Question
- Wiring Diagram Question
- K24/20
- h22a-crx or type R-crx
- 00 ls motor in 91 civic ???
- f20c (s2000 im trying to refer to) in a civic or anything fwd to rwd?
- b16a2 swapping to b18c ITR 96 spec??
- 89 civic si w/1st gen ls vtec.
- skunk intake manifold for 1st gen. b16a
- JDM B18c swap into 92' Si
- B20 in a DA: what's needed
- is the LS oil pan and b16 oil pan the same??
- ITR SWAP INTO EG6?
- ITR 2000 brakes on a Civic EG 1995' HB, will it be a problem?
- B16 just swapped in crx and check enigne light
- HELP! Head swap problems
- b18b1 with itr crank
- still this darn clutch!!!
- ls/vtec timing questions
- b18a into 93 ex mount trouble
- please help with this swap, d16y7 MPFI into 89 dx DPFI
- ** PLS HELP!!! Which WIRE HARNESS TO USE?? **
- obd0 to obd1 alternator ????
- NSX powered Accord
- golden eagle ls/vtec conversion kit question.....
- SR20 in an eg...
- 86 Crx- ZC swap
- ls/vtec problems.HELP!!!!!!!!!!!!!!!!
- Head games, questions before i swap heads.
- ls vtec conversion
- sohc TURBO z6/ b16 w/ bolt ons..???????????
- Engine mount brackets or engine mounts for EK swap??????
- Anyone know what kind of connector pin you have to use for wiring in VTEC Solenoid?
- #04xxxxx series b16a?
