PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 [129] 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. need help on nos!!
  2. need help?
  3. answer needed right away!!! timing belt....
  4. swaping B18c5 into a civic
  5. 01 B20z into 99DX...wiring help needed
  6. To those seeking to do H23VTEC or H23VTEC into a EK/96-00 civic....LOOK
  7. JDM cluster??????????????
  8. what motor to get???
  9. Kenji !!! need your help
  10. help me out if you can...
  11. Will They Work
  12. How are those mounts from Motormountworld.???? aNyone
  13. H22a midshaft
  14. obd1 h22a into 96 accord
  15. quick Q for ls/vtec's with 11.5 or higher compress..
  16. All-motor
  17. need help emissions
  18. Motor Swap or Not?
  19. What to use?
  20. Code 91 need help?
  21. 94 ls dc header on a 93 gsr
  22. Can I run this GSR obd2 catalytic converter in my Eg hatch?
  23. reprogrammed ecu
  24. We need a Hybrid expo.
  25. Will an 94+ LS alternator belt work on a B20Z?
  26. Question about my LS Civic
  27. F22B1 in 92 accord LX
  28. B16a2 axles.
  29. could this be cause of my messed up thermostat or what???
  30. What is wrong with my swap?
  31. 4.785 Final Drive Kit
  32. b20 gas mileage?
  33. p28 chipped or stock p72 ecu
  34. WTB:mounts and linkage!!!
  35. ECU help!
  36. B20 into EJ....
  37. 2 liter ls vtec
  38. After a swap...
  39. 98 EX motor into a 00? Swap or do I need to change some stuff?
  40. 4th gen Civic swap
  41. Fuel Line?
  42. h22a eg civic *power steering*HELP!!
  43. I need help with ecu
  44. really crazy swap idea
  45. Swapping B17A1 Into 92 VX. Need help with converting to a 4-wire 02 sensor.
  46. IAB not working
  47. need help with broken engine mount
  48. Need help 1995 Civic Hatchback SOHC
  49. My swap is done!
  50. evap system on a 96 ls?
  51. 12.9 on CTR cams, is it possible??
  52. What are these?? B18C 5th gen civic
  53. Honda Insight?
  54. b16 question
  55. 92 Ls full swap into 88-91 Dx hatch!!!???
  56. What Mounts
  57. After swap
  58. crvtec dyno just finished the swap today
  59. crankcase breather?
  60. zc?
  61. b16a and b18b intake runner question...
  62. SOHC Vtec into a 1991 Crx si, Starter and Alternator Question.
  63. b series trans
  64. 2001 h22a4 sh into 92 civic need wiring help!!!!
  65. 2001 h22a4 sh into 92 civic need wiring help!!!
  66. need some help rewireing my 88 crx si harness for a b18c1
  67. H22a question
  68. idle rev problem! b18c eg
  69. SWAP TODAY! Send me a link to the wiring please. b17 in EG
  70. Automatic swap
  71. h23 or b16
  72. Building up an engine, piece by piece
  73. Problem- CRVTEC woes.... strange engine noise...
  74. H22a Crankshaft
  75. what to expect out of a LS in a EG
  76. Suggested shopping list for honda before i start my swap...???
  77. engine arrived today from HMO...
  78. place racing h22 shifter box for a civic
  79. will a b18/b16 hydro spoon clutch fit in a b16 cable tranny
  80. D-series engine weight vs b?
  81. Type R swap
  82. Quick LS swap question
  83. B18b Price
  84. turbo type r hatch
  85. JDM B18Cr Motor into 92 Si.. Alternator Wiring??
  86. Cut engine oil pressure switch wire, and knock sensor/CKF confusion. Help.
  87. fs: complete b18c5 swap
  88. White w/Blue strip wire??
  89. need help on finding ecu for gen 1 b16
  90. Where did you get your B18b swap
  91. Swap arrived with bag of bolts and stuff......
  92. anyone here with supercharged b20?
  93. osaka, HMO, jdmhondaparts take notes! Engine swap IAS style! 56k Beware!
  94. daily post... h22 build from scratch or buy??
  95. Where to attach hoist to block to remove?
  96. Tranny Problems...
  97. LSD for JDM S1 tranny
  98. EG B16a2 Swap ?'s
  99. horsepower GAINS
  100. WHAT would you get....?... SI or GSR
  101. H22 FLorida
  102. B20 swap specifics?
  103. what ecu/harness for a 91' block, JRSC, b16 in a 96 dx hatch? new to b-series
  104. B18C1 Hitting Hood on EG?
  105. mini me help?
  106. B18b N/A in a eg???
  107. decent idle... but when revving up, its all wack
  108. torque mount maxed out. anyone else??
  109. difference
  110. Why can't I use the OBD2 GSR ECU w/ my Eg?
  111. b18b in 93 eg 4dr
  112. Jdm h22a wiring
  113. canadian dx
  114. H22 AEM short ram???
  115. help: obd0-obd-1 wiring question (for blown90hatch's coverter jumper)
  116. jdm b20b vs usdm b20z
  117. the time has come! what B series motor should i get?
  118. how to check and see if a motor is stolen or not?
  119. preobd fan switch to obd1 fan switch help!!!
  120. ls/vtec out,b16a2 in,What parts will I need?
  121. New LS/VTEC Kit from Golden Eagle
  122. HELP!! Hybrid won't statrt!!
  123. pistons: pr3 vs p73-00
  124. Best way to build a b16a?
  125. ls/vtec
  126. Non-OBD to OBDII distributor connections (can anyone verify?)
  127. USDM vs. JDM engine wiring differences
  128. H22 question
  129. head?
  130. CEL code #23 ?
  131. Need a wiring GURU....Prob w/ELD
  132. DSM hybrid
  133. Whats the best for the price??
  134. jdm type r pistons??
  135. ls/vtec kits...interested?
  136. steve at H-motors online (HMO) gets a A+ from me
  137. How much oil in the ZC????
  138. Highest Reliable Boost on Stock B16
  139. B18b in an eg civic coupe MOUNTS questions
  140. Does a 94+ GSR block require external oil lines with a B16 head?
  141. gsr cams in turbo b16
  142. Will disconnected KS cause CEL?
  143. b18c crx suspension help
  144. hmotoronline price match guarntee?
  145. SWAP Problems............B18b in EK!! HELP
  146. Do i need this mount?
  147. Straight up trade - B16A3 for B18C1 - good deal?
  148. JDM1.com?
  149. eg b18c swap ?'s
  150. What to do when wiring an B18A OBD-1 into a 91 DX hatch?
  151. Help fast! Flywheel and clutch questions.
  152. www.silentrage.net,Cheap engine prices?Any Reviews?
  153. vtec not working
  154. h22 header pissin me off!?
  155. h22 type s on a teg dc2 needs headers,aftermarket computer
  156. VSS fuse keeps blowing iin 99dx w/b18c
  157. b18c1 hybrid... best cams??????
  158. Is it worth it for a swap?
  159. Tach and Vtec not working in 99 DX
  160. Here is the truth about Newman!!!!!
  161. 12.2 or lower compression pistons
  162. compression with 91 octane
  163. What trannies will fit my 95 JDM B16 Sec Gen?
  164. clutch question!!!!!!
  165. 93 ex powersteering pump....work on b16 block?
  166. VTEC Problems. Knock Sensor Help. JDM B16 Sec. Gen into 93 Si Hatch
  167. Part # for 94+ Integra Front transmission bracket for B-series swap?
  168. Any place sell Test Pipes sized for hybrid?
  169. www.spituning.com,anyone ever order engines from them?
  170. Vehicle speed sensor not plugging up??
  171. HELP HELP HELP i need help starting my new motor
  172. 3" intake on a ls/vtec? (type r aem)...
  173. keeping my A/C.....how?
  174. Help! irratic bouncing idle and engine check light props up after short while?
  175. Jim Fab Vs. OEM.... (install)
  176. H23 5thGen Civic
  177. which air intake for h22 on an eg
  178. distributor question
  179. compression and leak down testing
  180. do the 99-00 Si motor brackets come with full swaps?
  181. LS/VTEC questions, pics, etc.........need insight
  182. what do u guys do?
  183. Spark problem in b16
  184. looking for a pic of 1/8th" npt plug for ls/vtec?
  185. the PERFECT close fit alternator belt for crvtec
  186. Mpfi swap misprints in SCC/Hasport info...
  187. Which engine in an eg, B18C1 or B18C5?
  188. swap ?
  189. b18c1 axles and linkage with a b18c5?
  190. Problems with B18b into Hx?
  191. ZC motor questions
  192. HCP Mounkit Groupbuy...??
  193. What do I need for a B18C5 Bottom End and a B16a1 Head?
  194. VINs Please look at the post
  195. how to wire vtec in LS Itr?
  196. who here knows
  197. B18 SWAP ?'s
  198. LS wiring harness on B20.
  199. 4g63 dsm engine into an integra??
  200. h22 in ek (shifter?)
  201. motor came in today!!! 56k beware!!
  202. Anyone need help on swapping go here..
  203. H22 Clutch line question for civic
  204. F20 questions
  205. Power steering for b18c1 swap in eg????
  206. Hom many B16 hybrid's have the JDM 4-1 DC Header?
  207. Insuring a hybrid
  208. Help I cannot get rid of code 10
  209. h22 altonater belt question?
  210. zc vtec swap in del sol
  211. whats the best uneversal exhaust to put on a 91 civic hatch
  212. any one done a d15b swap
  213. LS or GSR????
  214. h22 swap radiator???
  215. Norcal Hybrid Meet Feb 23, 2003
  216. Quick swap question from an EK newbie
  217. radiator fan works... but no power from connector.??
  218. transmission !!!!
  219. quick ek hybrid question..
  220. What to get for a b16a2 in a 94 civic?
  221. d16y7 Harness AIC wiring to b18b
  222. 99-00 Civic Si AC bracket same as Del Sol P54?
  223. knock sensor
  224. Missing Vtec Oil Pressure Switch
  225. Help me pick out either motor!
  226. good setup for crv-tec or no
  227. VTEC wiring into a 94 Civic dx(I've searched)
  228. h22 swap into in a 92-95 civic shifter question please help
  229. Need help with swap!!!
  230. crx good buy or no
  231. www.passwordjdm.com
  232. Hood to clear B18C in '91 CRX.
  233. Cool website for any swapper and JDM nut
  234. h22 injector resistor
  235. ls/vtec ?
  236. mini me problem
  237. Which coolant reservoir tank for my Eg / GSR Hybrid?
  238. Look what I picked up!!! (My Hybrid Part I)
  239. Look what I picked up (PART I of my hybrid)
  240. help with wiring
  241. axel question....b16 swap into 4th gen civic dx Hatch
  242. Help me fix my B17's problems!
  243. B16B ecu
  244. 92 LS swap into 88 CRX!!??
  245. i cant find my post
  246. how many egs with b20s?
  247. how to break in your clutch properly?
  248. Splicing PR3 2nd o2 sensor wire into first?
  249. injector?
  250. '95 LS 5spd Integra into '93 auto civic....
