PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 [98] 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. zc swap
  2. My Differential when bad Today!!!??
  3. swap
  4. F23A1 into 94-97 Accord???
  5. OBD I wiring in a EF!!!!
  6. B18B swap
  7. B20 and H22 pistons
  8. transmission problems, popping out of 5th gear
  9. Wiring question!!!!!!!!!!!!!!
  10. Wiring GURUS look at my B16sir2 wiring harness into a VX Is it okay?
  11. edelbrock throttle body with skunk2 intake manifold on gsr???
  12. Trannies that fit the B20A3(Prelude S Motor)
  13. what do i need?
  14. b18 ,b16 hybrid
  15. converting OBD1 dizzy to OBD2a ....help???
  16. B16 TRANNY
  17. cranking trouble
  18. Ok to leave swap in garage without a drop of oil?
  19. SOS wireing help
  20. THIS SUCKS!!! What is wrong. NEED help!!
  21. usdm itr engine harness will it work in a 92-95 EG? help question
  22. OBD2 to OBD1 conversion. Please help
  23. KS on a PR3 ECU
  24. 626 so cali swap shops
  25. vibrating problems with gas pedal under stress-ur opinions please
  26. shot in the dark but would anyone know where i could get a pair of nsx tail lights for mod
  27. Fuel Pump for H22 Civic?
  28. which harness conversion?
  29. need an END-all wiring for VX 5wire to 4wire chart w/Vx harness & P28 ecu
  30. 96 itr wheel bearing?
  31. swap a b20a into a 90 prelude w/ b21a
  32. D15B help
  33. people in nc with hybrid!!!!!!!!!!!!!!!!!!!!
  34. PWO and PR3 differences?
  35. Online schematics for motors
  36. b16 crx to b18c
  37. Help Needed: wiring an obd1 h22a into 97 lude...will paypal someone $10 if they get it figured out a
  38. 99si in a 92 sedan
  39. Advice/Input on this car (h22 si hatch).... also, an estimate of worth?
  40. mini me parts list
  41. How do you tell if a P28 ecu is 5spd or automatic?
  42. shifter comes out of gear while shifting past 6K
  43. G2 nteg pedal assembly fit in G3 nteg ?
  44. YS1 Cable -> Hydro Chassis ?
  45. Someone tell me whats wrong with my car! Car Choking!
  46. B18C1 w/ JRSC into 91 CRX Si
  47. I will try here. Torque spec ?
  48. knock sensor? car turning over?
  49. distributor has no spark, obd0 b18a in 89 civic
  50. could it be possible that the mph are off
  51. H22 intake manifold vacuum
  52. h22 ek axle problem...i know...i know...
  53. My Idle Problems Still Exist
  54. whats mods to do to my b16b?
  55. Has anyone experienced low voltage after swap?
  56. h22 accord problems
  57. maintenence to do before swappin it in?
  58. exhaust for gsr swap
  59. ?? on Poor Man R build up
  60. b18b swap help?......
  61. h22 in a 93 vx
  62. IAS sell d16y8 engines?
  63. Axles for a JDM GSR Tranny??
  64. raxle Axle / lowering issue?
  65. H22'ers LOOK!(Suspension) Lets get some feedback....
  66. Diagram for Type R EVAP system anyone?
  67. any 1 here wired a 91 teg cluster into 89 civic?
  68. Will a 99 Accord Type R Steering fit a Civic EK96?
  69. OBD2 ECU reprograming
  70. Anyone else have trouble with tranny hiting lower strut bar after B16 Swap?
  71. JDM to USDM ob1 to OB2 wiring harness?
  72. b18c1 timing desperate help!
  73. to people with VAFC's....
  74. Header questions for an H22 in a del Sol
  75. UK: does anyone know if the Rover k-series motor is made by honda?
  76. LS intake mani on a B16???
  77. Ok well I did a search, couldn't find too many details..b16 into 2000 civic coupe
  78. 88 crx dx to 94 gsr wiring harness???????????
  79. hey guys which radiator do i use on a b16a2 swap into 92 95 civ
  80. Can I use a AT wire harness on a manual EX motor???
  81. does a obd1 94-95 gsr p72 ecu have a Knock Sensor reading?
  82. jrsc h22 ek
  83. 91 LS engine into EG, wiring quesiton?
  84. Looking fo 92-95 civic dx p06 ecu.
  85. any F-series in civics?
  86. my car dies all of a sudden, please help
  87. H22a4 B16a2 wiring harness
  88. h22 or b18c1 for 98 ex??...NEED HELP
  89. B series Motor Mount question
  90. Crx HF B16 obd0 swap.....
  91. the b16b ex and my beater 00 si!in the snow
  92. What obd1 computer swap will work with 98 dx SOHC non-vtec?
  93. 93 LS AUTO IN A 86 CRX?
  94. Engine swap wiring need help
  95. changing wire harnasses
  96. Need Help!!! Car is dumping fuel in cyl.
  97. B16 in a Civic
  98. 94 and up front brakes/knuckles/hubs work on an ED with a cable b swap?
  99. OBD1 distributor ?
  100. PLS HELP WITH B16A2 SWAP
  101. PLEASE HELP... Transmission VENT??? on my JDM B16 Tranny??
  102. b18c1 in ek!?
  103. EVAP on a OBD2 engine in a OBD1 car, HELP!!!
  104. swapping this weekend
  105. ls vtec Knock Sensor
  106. IACV compatibility (OBD-0 and ODB11)
  107. which shift linkage do i use? 92-95 civic b16a2 swap
  108. 02 sensor in b18c into vx hatch
  109. my EK wont start
  110. Number of splines?
  111. 2000 si engine into 96 dx
  112. H22 in 99 Si (need help)
  113. problems with zc swap(please help)
  114. Starter not getting power
  115. 88-91 Civic DX B18 Swap....CODE 4
  116. !)Fitment question!!!
  117. Another LS/CRV-vtec discussion
  118. Guys I need your expert advise with my H22 to my Civic Hatch
  119. code 91, how to get rid of???
  120. B16 Primary O2 is the Green Plug correct?
  121. b18c5 with delsol ecu having idling problems!!!! HONDAFAMILY PLEASE HELP!!!!
  122. Trouble with crx mount
  123. Please help idle stuck at 3000rpm
  124. Carbing Fitment on civic
  125. CBR 1100 into civic?
  126. WOULD A D-SERIES VSS WORK ON A B-SERIES TRANNY
  127. ? h22 into ek radiator
  128. intermeadit shaft
  129. b16 header on b18c1
  130. couple questions concerning my b18c swap into my da9
  131. tranny and ac bracket stabalizers/mount?
  132. wiring reference for knock sensor-help
  133. Alternator Identifying?
  134. JDM Engines
  135. Ignition Switch?
  136. Difference between the AEM FPR for an Integra and the universal one?
  137. What o2 simulator totally replaces the 2nd o2 sensor?
  138. K20EF pics ....
  139. Swap or turbo
  140. Would a 2001-2002 civic dx intake fit on my 98 dx hatch?
  141. Codes PO136 & PO138
  142. A Honda-tech moderator protecting a fraudulent business
  143. post you videos up!!!!
  144. GSR block with LS head
  145. Q on mc/bb and pvalve swapping (rear disc swap related)
  146. if you have h22 swap....can u go back to b-series...in your eg
  147. Anyone have experience with o2 simulators? Inspection?
  148. motor wont start
  149. Don't know what to do!!!
  150. A couple of overall questions about H22 hatch's
  151. Just curious why company took off alt belt,ac belt,ps belt?
  152. car wont start no fuel and no spark
  153. Need recommendations on a muffler..
  154. b16a swap into 90 civic. Need help!!
  155. need exhuast for 93 ex!
  156. warped crankshaft?
  157. 96' B18C GSR swap into a 95 civic HB si, need help..
  158. Map sensors
  159. Fast Idle Thermo Valve
  160. h22 vs crvtec
  161. my rhd civic with h22
  162. jdm b18c swap into obd1 teg
  163. Car wont start?!?
  164. F22 tranny bolt to H22 block?
  165. Accounting for all the ctr swap post pics if u have any.
  166. How much is my motor worth?...
  167. b16 into my DA
  168. pics of my b16b swap!!!!
  169. what is the advantage of hybrid
  170. d16y8 into 92 cx
  171. Distributer on a B18A
  172. gsr cams into b16
  173. help needed! 96-98 civic ex harness pinouts!
  174. LS swap into 92-95 Civ Coupe, Motor Mount Question
  175. H22 eg axels
  176. driver side mount replacement options
  177. Converting wideband o2 harness to stock 4 wire o2 sensor help please.
  178. So Cal Dyno Day
  179. B18C swap into a CRX
  180. b18a swap in a 3rd gen
  181. mount compatibility?????
  182. Knock Sensor problem... Code 23...
  183. IAC TEST???????/
  184. new guy here needs some input
  185. 98 dx o2 sensor wiring????
  186. looking for oil pressure reading for a b18c
  187. Distributor question
  188. 99 ex engine harness into 97 cx hatch?
  189. how do i post pics?
  190. Service manuals for jdm motors?
  191. h22 questions
  192. videos of your hybrid?
  193. Any News on Hybrid Garage?
  194. 99 GS-R Vtec swap into a 91 LS
  195. Which Tranny for setup and clutch?
  196. civic eg cluster
  197. SOHC NON-VTEC ZC?
  198. CARBON BUILD UP
  199. help on ls vtec install instuctions parts needed. swap conversion turbo b16 type r
  200. Fan wont turn on. Bad Relay?
  201. Axles for B16A 3rd gen civic
  202. some old, some new
  203. Ls vtec gasket question
  204. Check my work: Wiring Harness For H22 using VX harness.
  205. JDM D15B longblock from hmotorsonline.com
  206. cable to hyrdo conversion
  207. cable tranny problems.
  208. 94-00 gsr cluster into eg
  209. 99-00 civic swap- o2 help
  210. what fuel pump for a b18c1 in a 89 std hatch?
  211. *need help! 95GSR obd1 into 94 Si knock sensor problem*
  212. K20 in DC/EG..H22 in a CRX! PICS!
  213. Quick? Please Confirm(GSR in DA)
  214. camber on rear disc conversion.
  215. B series CTR swap
  216. B18C5 with 22k miles should i change the clutch now or wait?
  217. Need Swap info: B18A into '93 Civic CX! Help!
  218. 95 Hatch Si w/ B18C1 swap...Idle Probelm...Need help quick!
  219. Drivers side axle popping out.
  220. Which exhaust manifold should i buy? CTR/GSR/ITR?
  221. K20 Mount Kits and Info
  222. Anyone have the OBD0-OBD1 ECU conversion harness instructions?
  223. 94 GSR-Puttering when hot, 97 GSR-Puttering when cold
  224. s2k s2000 gauge cluster fully functional in an eg or ek?
  225. OBD2 B18B into a 95 DX with P06 ECU
  226. which rad hoses?
  227. mustang throatlybody on a D16z6 intake??
  228. h22 bolt up to h23 transmission?
  229. gsr resistor box?
  230. i have a trany question
  231. **** K-Series ~Continued~**** Product updates.
  232. K-series into Ek/Dc/Eg and EF chassis
  233. HELP: HOW DO I GET MY SPEEDO TO WORK?
  234. Best place to buy a D15B vtec?
  235. h22 civics. tell me what u think about my new exhaust.
  236. OBD0-OBD1 engine harness conversion... two identical white wires on dizzy plug???
  237. WTF? After my swap, my steering wheel is not straight anymore...
  238. b18 tranny adapter onto h22
  239. throttle body compatibility
  240. Vaccum hoses -
  241. Can you put fog lights on a Civic Hybrid?
  242. Need Work Done - SoCal - Hybrid
  243. Enjo mount kit
  244. 95 b18c1 into 93 integra?
  245. H22 hybrids, whats your vtec rpm? mines maybe too late!
  246. Si gas tank in a cx?
  247. AEM V2 on h22 in an EK?
  248. tach goes crazy after 6500 rpm
  249. H22 Swap into an Integra with JDM front end??? Possible??
  250. B18C Valve train differences - Auto vs 5 speed
