CRX S2K cluster swap - VSS wiring problem
Old 04-10-2011, 11:13 AM
french_yogi's Avatar
Default CRX S2K cluster swap - VSS wiring problem
Hi,
I'm currently working on the upgrade of my french CRX. Upgrade include the swap of an AP1 S2K cluster.
At this time, all is wired for getting a functionnal cluster. But problem : speedo doesn't work ...
Here is the setup on the car :
- On the cluster side, all runs well. SpeedoHealer V4 test shows a 7 on the cluster. SpeedoHealer wiring is ok for power and cluster connexions.
- On the VSS side, Power and ground are connected (ground and +12V). For information, the Gearbox is a S9B coming from an 1L8 B18C4 civic aerodeck from UK (three pin on the VSS) and i have pics of a running aerodeck to know which wires goes on which pin on the VSS.
But finally, no speedo running on the cluster (the signal wire is connected on the cluster).
--->>> Do you have any idea ? Perheaps VSS dead ??
Thank's !!
Old 04-18-2011, 06:24 PM
unusual71's Avatar
Default Re: CRX S2K cluster swap - VSS wiring problem
i used +3700% for my correction value in the speedohealer. Also the speedohealer i got was unclear about the wiring for the signal. it just had +12, ground, and 2 signal wires. mine didn't work until i switched which of the signal wires went to the vss and which went to the cluster
burnykawizzle
04-27-2010 07:55 AM
b.d.racing
03-15-2006 01:49 PM
importboi22
05-31-2004 10:32 PM
XEF-9X
10-14-2002 09:38 PM
Quick Reply: CRX S2K cluster swap - VSS wiring problem
