View Full Version : Hybrid / Engine Swaps
- OBD1 to OBD2 for BAR
- jdm SWAPS for accord
- WANT TO BUY RC INJECTORS, BUT?
- type r rods in a ls block
- b16a2 block with what head?
- VTEC on my Mini-Me isnt working...
- ek with skunk2 mani and gsr tb...what throttle cable too use?
- TypeR Throttle Body on B16A in 1991 Civic Si
- Help figure out my engine problem and i will Paypal you $20
- h22 swap done but not starting HELP
- b16a2 obd2a into 99 civic dx hatchback with CTR ecu..
- fairly good prices on swap motors plz read if interested in swapping your motor
- 94 VX hatch W/GSR Wiring ?
- Wiring Type R motor in EG
- s2000 swap into 93 si
- theives suck
- Any reason why my car idles up and down even after it warms up??
- B18C5 into my 93 civic coupe engine engine running problem
- HELP OBD problems in integra wiht h22
- TYPE R IN A 88-91 HATCH DIZZIE QUESTION
- why would my h22a run crappy until it warms up?
- Safe to use P75 ECU?
- b18c1 hatch
- motor mount question
- Please help wiring / swap ?'s
- How do I get rid of this motor!!!????
- Obd 1 Obd 2 alternator help
- Q on a h22a in a civic//rpm's climb real quick at low mph?
- h22 turbo, which is best?
- Hcp instructions....I didnt get any..help?
- Car won't start...No voltage at ECU
- B18c5 swap in 93 civic ex
- h22 eg swap wiring questions.
- J30A1 3.0L V6 swap into my cb7
- H22 Civic regulars, your preference on AC, air conditioning...
- PS Pump GSR Swap
- 1ST GEN B16 Valve size?
- which prong is the speed sensor on a p28?
- b20/vtec or rebuild my gsr?
- What the diff between b20b and b20z?
- gsr crankshaft into a 1st gen b16 block
- Need a header for 92 civic/gsr
- EG civic / DC integra type r suspension question
- K'd out (K20 EG and K24 EM)
- stock 99-00 Si exhaust on a b18 swapped 97 civic?
- got a chipped p28 and a p72 for my h22a. The p28 throws the speed sensor code but the p72 does not??
- Usdm vs. jdm b18c
- b20 in 94 hatchback
- head swap ?
- b18 question
- B20vtec swap ?'s
- wire question
- 2001 h22 in a 1998 integra GSR????????
- How do I make sure everything is right...
- GSR swap a/c question
- b16b questions?
- gsr swap into eg rear mount bracket
- LsVtec Need help...
- d series longer gear tranny?
- someone be my hero and tell me what injectors i need
- Bossted B18C Longevity?
- prelude b20's the same as CRV's?
- How do you add a Wire to the ECU plug?
- gsr swap hood wont close help
- thirsty GSR?
- ls/vtec question
- k20/jazz
- Will a 2 1/2 inch radiator fit in a H22 Ek???
- Tranny problem, Only in 5th gear.
- H22 Wiring: Pins?
- Which Swap should I do?
- head swap from a B20A5 to B21A1 block and intake manifold? in need of some good ol b-series knowledg
- V6 CIVIC
- WILL A TYPE R SHIFTER FIT IN A 99 SI ??????
- eg h22 axle problems (not which one work)
- cut O2 wire
- H22ed coupe exhaust.
- ls cable trans with b16 shift linkage
- H22/CD7/Prelude Mounts?
- what intake for a k20 in a ek
- Doing jdm 2nd gen b16a motor swap into EK hatch...what mounts are needed?
- obd2 to obd1 which ls ecu to run?
- **94 gsr wire harmness diagram tutorial ***
- Wut wiring problems? CRVTEC in EG using complete GSR harness and ECU
- OBD1 to OBD0 -- Whats involved?
- Need help ASAP - B20 vtec swap with internal oil line
- please help! b16 in EF not starting... no spark, new dizzy
- b18 problems
- axle clicking after installed a new remanufactured from autozone
- Gsr swap boggs at WOT between 1st and 2nd gear shifts.
- gsr wiring harness on h22/resistor box???
- Help : DA b16 - ECU question/ Fuel
- K20A CRX?
- Temperature gauge problem after swap
- GSR SWAP????
- New donut gasket w/ swap??
- which ecu to use for a h22a swap p28 or p72
- what does barometric pressure mean???
- Looking for H22A VTEC engagement point
- insanely great gas mileage in my LsVTEC!?!?!
- my new killa
- clearance for h22 in an EK
- OBD0 to OBD1 conversion, where to get conectors?
- budget ls-vtec build
- my VT-R EE9
- distributor for dpfi to mpfi conversion
- RHD Conversion... What's the right way and what's the wrong way?
- EURO-R IACV troubles
- DPI to MPFI w/ JRSC and OBD1, need help!!!!!!
- dont need a crank sensor on hybrid?
- some one show me how to rewire obd1 dist to work with obd2 engine harness?
- STR H22 intake mani in EG?
- ITB Flavor w/NO2 ****VIDEO****
- cel 41??? o2 sensor heater circuit
- K20 vs. H22 axle question in EG....searched
- Calling all b series owners... Which one of these brackets do i need? Picture.. Help
- Wiring issures with 95 gsr swap into a 99 ex
- Block
- B16 with 2.0L pilot head
- Throttle Sensor Wire on ECU(C6/C11) Missing on my EG???
- Anyone throw a cel code 23 (knock sensor) on a p72? What was the reason?
- Questions about B20 Swap setup, Parts etc..
- Will a 97 accord knock sensor fit a h22a4?
- H22A with F22B tranny (M2J5)
- EG to integra
- h22a eg's using HASport mounting kit. What rear engine bracket are you running?
- ECU question for b16 swap
- EK swap questions/confirmations
- h22 fuel problem
- 1993 Honda Civic DX Motor Into a 1991 Civic DX
- B18C vs. K20A
- Need Help Wiring GSR into EK
- Swap Question.
- 95 GSR CORRECT SPARKPLUG GAP?
- GE, Venom, STR intake manifold users please look.
- Will a 96 civic Cluster fit a 92 civic hb si?
- Can you use H22 shifter box and cables for a K20 swap??
- Eg h22 info
- need help with tranny
- Speed sensor trouble in 94 civic b18 swap with a cable tranny.
- What is this???
- H22 Swap into EK coupes
- MORE h22/h23 info in a EK/EG chassis
- obd 99 gsr confirmation
- AEBS/B16 CRX throttle cable ???
- Question for h22-EG owners
- skunk2 h22 intake manifold
- EK JDM H22 SHIFT CABLES
- Changing rear engine bracket while motor still in car?
- tried searching, can i swap dseries vtec distributor(obd1) guts to b16a (obd0)
- 99 civic dx which harness??? please help
- Will type r rods fit a b18b block?
- LS/VTEC w/ CEL VTEC Engages?
- Need help, H22a into 92 eg, axle problem because of 3inch drop.
- how can i know if my D14 tranny good for d16's ?
- hybrid engine swap?
- What radiator fan for a 92civic with GSR motor?
- Help
- what do you think of used pistons..
- Reliable High Revving CrVtec
- Why would a p13 ecu not work for my h22a???
- c32 civic
- Pr3 Ecu?
- Anybody in Austin, TX to help with swap.
- 91 Civic Hatch EC8 with 1.3L
- Best swap for a 98-02 accord ex??????
- Integra obd1 alternator
- LS/Vtec Rough Ideal Please help me!!!
- Civic VX getting a D15B...Oxygen sensor wiring question
- ls/vtec question
- oil burning
- can you do a mini me with a cx block because i have spare parts around to do one
- www.japandomesticmotor.com/shop.html
- H22 In a DC Integra? Quick QUESTION??
- Please Help I am pulling my hair out on a swap!!!
- obd-1 ls ecu p74 Pinouts
- K20A3 into EK
- cable-hydro conversion....the HARD way
- b and d series vtec solenoids interchangable
- 5G Civic with b16a OBD2.....what to do??
- sold the h22eg hatch now what?
- mpfi wiring 90 hatch
- JDM DOHC ZC
- gsr wring diagram !!!!!!!!!
- car dies out and afterwards, car has a hard time starting
- Is anyone using a J1 tranny with a B20/Vtec swap
- Starting on my H22A EG swap end of this month, need help and checkups.
- Need help!! Just can't do it.
- code P505
- already searched, what parts to change before doing swap.
- Y-8 Dist in OBD-0 wiring
- VTEC for a 99 Integra GS
- 96 ITR into a 93 hatch. extra plug... help!
- OBD0 head on OBD1 motor?
- Throttle cable unhooked from gas pedal
- pvc intercooler piping
- Enjo engine mount wont go on my h22a4. This is bs
- Wire Harness with GSR swap
- accord with H22
- ITR suspension on a EK ? (yes tried the search already)
- what would be better?
- ecu and distributor for a 96-98 civic
- Is this engine the right way to go???
- JDM K20A2 into EDM K20A3 CRV. PnP?
- K20 Powered DEL-SOL!
- trying out ls/vtec
- Would it be worth swapping out a B16A2 For an H22?
- I already searched, but I have a harness question....
- Engine Codes??
- K20 ( type r ) into DC2. weight distribution? other problems?
- Please Help. Integra/civic swap mounts? Brackets?
- k24vtec in a ek?
- H22 in 99 civic ek obd 1 or obd2?
- CRV/EG/DC suspension compatibility
- idle ? need help
- Skunk2? How can i tell?
- Anyone know K24 Wrist pin size???
- 90-93 b18a longblock into 92 EG??
- H22A Power upgrade options
- Need help ... H22 into a 97 hatch....
- I have an EG with orginal OBD0(europe), but can i convert? check pictures!!
- new ecu mounting spot. h22/civic/gsr dash
- would a chipped p28 work with a h22a in a civic hb???
- Hydraulic tranny in 88 crx hf?
- H22a1: Confusion everywhere:NEED HELP and CONFIRMATION!!!!
- Need help on my 2nd gen B16 swap!
- Beaten to Death, K20a into EK... What do you need?
- repin plugs?
- wiring for a h22a type s into a 98 ls integra
- 96 Civic D16 into 90 CRX?
- anyone in md wanna help with a swap??
- Which vtec harness for a b18c5 swap?
- b18a/b18b questions
- TOTAL JDM or HMO?????
- Drive Shafts for H22 conversion
- JDM h22 auto - sport button pinning ? anyone ?
- d16a1 - what tranny?
- H22 without VTEC?? WTF? Need help
- how can i contact honda ??? (swap problems in israel)
- engine swaps and DMV's
- b18a or b18b in a 97 ek hatch ?
- airbox for eg itr swap?
- B16a2 Long block
- timing belt trying to come off on my h22a???
- Help 2000 si w/01 b18c5 swap Cal Smog
- thanks to HT, got my 2nd selenoid hooked up on my b18 in my 00 si...
- h+k hybrid?
- I need wiring pin outs for H22 swap in Civic
- need help with type r tranny
- Swap going in tomorrow...a couple of questions!!
