View Full Version : Hybrid / Engine Swaps
- LS/ Vtec talk
- 2Bills for CTR pistons w/ Rings 10 over sized
- hub for bb6 fit in to us itr knuckles
- Very high idle K24 swap into EP3.
- GSR/ITR Rebuild; Need Help
- about to drop in a b18c1, need wiring help
- Identify these H22 & D16 Sensors
- 99 CX with 98 EX power windows, locks, CC, PS and engine - What to do about wiring
- Civic DX GSR swap question.
- Taking off 99-00 Civic Si Wiring Harness?
- 87,89,91 civic hatch + f22b1?
- fwd s2000 civicquestion
- Does P28 ECU look for Secondary O2 sensor?
- Is this Radiator Single or Dual Core?
- help!!!!!!!!! quik ????? about a check engine light
- Whine/Whistle/Squeal From intake manifold need help NOW! Please!
- are the rsx base and type s shifter box different?
- popping out of 5th gear?
- Car running Rich Shooting to solve problem....
- h22 Transmission Breather??
- where to buy
- f22b1 sohc vtec with h22a dohc vtec head?!?!?
- Anyone using Innovative H22 EK mounts?
- Need some more out of my Ls
- Air From Dip Stick??
- TDC???
- B and D series trannies
- help jdm h22 dizzy
- obd 2 head and obd 1 everything else
- EFK1 in euro ED9 ?
- Anyone use Streetimports H22 mounts for EK?
- where to get mounts for b series swap in an ek?
- spoon exhaust with 3inch piping?
- Engine Harness Swap
- Tools need for swap... b18c into 92 eg..
- H2B plate. how to me to purchase this?
- Problem with the distributor plugs for my engine swap
- who are the swap gurus around here?
- B18B with B16 tranny?
- K20 tranny on K24?
- ED8 CRX DX tranny swap help
- 99 b16
- B16a2 into 96 Civic Dx have questions..Please
- wiring vtec in an h22 prelude...
- Play in Pass. side Axle B16
- Anybody manage to fit AC in a H22 EF using the new Hasport kit?
- B18C4 into CRX
- Can I use a 92-95' SOHC rear motor bracket on my 99' EK?
- How do you put L3 trans in 1st gear
- Hondata S200 hondalogger.... does yours read vehicle speed?
- So Who Has a B18c5 EG/EH?
- How to swap an LS motor into a 93 hatch
- b16a2 into an ek... revving problem
- swapping 95 gsr brake booster and master cylinder to 99 si?
- FS: SPOON Valve Cover - B Series
- FS: JUN3 Cams, TODA Cam Gears, TODA Valvesprings
- f23 into a ek? possible?
- Is Agx/sportline combo off a 96 integra will fit a eg or ek
- Throttle cable???
- oil pan and valve cover gasket leakage..
- diagnosing timing issue??
- B16 turbo or ITR all motor?
- Map sensor wiring and connection verification (h22 civic obd2)
- Help on wiring!
- lsvtec update and questions
- b16 timing?????
- B21A1 heads on A20A3...
- help pleaz
- B16 IACV on GSR
- Hybrid CRV Project
- B20 P8R Valvetrain?
- Shift linkage already searched.
- 94 coupe h22
- type r or gsr
- head decisions
- super duper rich.....
- WILL SOMEONE PLEASE HELP!!!!
- Finally got my motor...one more question ASAP!!
- Quick h22 shifter question
- Where to get a obd2b to obd2a jumper and 99-00 si rear mount
- Reuse D series mounts on B series swap?
- swaping a b16 into my ek what mounts do i need..
- Which A/C compressor in a EK with a B18C1?
- D15b vtec in a 2g crx/4g civic, which fuel line did you use?
- K20 RWD
- TRANNY ???
- How do I retain a/c and power steering in Ek?
- Need wiring help
- OBD Wiring Mess
- H22 swaped 93 eg still not finished but getting there
- k24a2 in eg?
- H22 Crx High Idle
- *searched* link for b18b swap into ek civic
- JDM b16 half shaft problem
- RB25 project
- dodb2 to obd1 distributor problems
- B20z pressure plate in b16a
- B18c1 Obd 1 question
- JDM B18C1 swap into a 00 SI shell, wiring questions
- clutch problem with cable LS tranny with B16a in 89 crx si (clutch not disengaging)
- Vtec not working for h22 in a del sol
- my b20z2 swap
- engine harness??
- tach gauge has odd hic-up, gauge jumps around from 400 to 1200 but motor doesn't??? anyone?
- GSR or ITR swap??
- H22 VS. K series swaps....
- hello i need to figer something on D16Y8!!
- EG Pedal Set in a EK????? Auto to manual conversion
- Mahle Pistons install direction
- Took out cat and lost power??
- going ls/vtec...need some help with what i need asap
- skunk2 stage 1 cams w/sk2 camgears/ w/w portflow dual valve srpings and ti retainers? whcih injector
- Question: Can anyone...
- Can Civic Si 2000 with a K20 be B.A.R.d in california?
- AEM V2 intake in a 2000 Civic hatch with a GSR motor
- hcp mounts
- soft gas pedal....adjusted throttle cable..what else?
- ls/vtec w/jrsc
- f20c in eg95?
- ITR BOGGING
- B16 with hydro
- Starting a project, need help deciding on my route.
- GSR wire swap?
- lsvtec questions
- does it matter
- quick question...answer asap.
- wiring v tec
- B16b passing smog in CA
- Ek h22 headache. Obd1 ecu, Obd2 harness obd1 external coil h22.
- b16a runs rich and high idle.
- 2001 gsr motor into 96 ex coupe.
- Selling the K24a2: Now What?
- ek swap
- ob2 -obd1 distributor and conversion harness ?????'s
- obd2 b18b swap into EK CEL code 41 help!!!
- EG Swap H22A or B18B1
- can't choose an engine!
- Tranny pin
- Clutch cable on DA H22A?
- all you d series gees...d16y7 block d16y8 head..?
- BYPASS OIL PRESSURE SENSOR FOR VTEC?
- help code 22
- question about LS motor with ITR pistons
- 95 cx with si cluster.. speedo not working
- Worst swap experience ive ever heard of....... cinci oh
- h22 in eg with AC
- Integra Type R steering rack on Civic Ek4 2000
- Anyone hear anything about clutchmaster's flywheel for the H2b setup??
- LS swap into 92 civic
- SIRII Swap Into 99 Civic Ex
- Wiring help on EF Hatch with b16a
- 99 Civic EX swap questions, please assist
- b16 swap
- b18a1 into 95 civic
- could this pcv setup be affecting my idle
- rsx-s suspension
- MODS CHECK IN PLEASE.
- best ecu for ls/vtec civic 93 ex?
- d16z6 or d16y8?
- H22 vs. B-series in an EG/EK...handling?
- Need opinions.
- ENGINE HARNESS HELP PLEASE!
- debating between h22 turbo swap or ls turbo
- 96 GSR motor into 97 civic EX 5spd - pretty easy right? Tips?
- Would 99 Integra Brakes Fit an EG?
- B16A in to 92 civic HB
- Quick question on b81a engine
- An Integra Type-R intake on an H22 EG hatch?
- a little help..throwing codes 3 and 12
- accord evap canister for h22a swap
- lsvtec coolent and oil mixing please help asap
- Car dumping oil after swap HELP!!!!
- transmission adapter for D series
- which motor?
- EK9 LSD in a DC2
- H22A Vs B18C in EJ1.
- vx block P08 head = d15b vetc?
- cannot scan obd2 codes- after swap? is somthing pinned wrong?
- 92-95 civic coupe swap ?
- Cable to Hydro
- MY TYPE R DEL SOL WONT RUN!! PLS HELP ME!
- New swap-What do I need to replace?
- How many different types of crank pulleys are there? Which Oil Pump? Timing belt? B16a
- Cable 2 Hydro Conversion
- LsVtec power steering help please
- ne one have a set of used b-series mounts for crx swap
- Civic H22 swap misfiring and running rich, bad ECU?
- Please help with h22 shifter in integra
- Anyone here has a diagram on piston ring installation the right way???
- B16 head on GSR motor
- low h22 idle
- How to get info on a b16a...?
- How do you identify and b18c R short block?
- Help with ARP head stud..
- JDM D15B VTEC - MINIME question
- timing belt help(searched)
- vss code 17..what is the difference between obd0 and obd1 vss?
- Quick question need answer ASAP
- EK specific auto to manual conversion questions
- HOW TO KNOW IF MY TRANNY IS BLOWN?!?!
- 99 b16a2 into a 97 civic wiring nightmare (please help)
- OBD2 to OBD1-Motor swap
- switching wiring harness on a crx
- turbo and auto-manual on a swap questions
- Check Engine 13
- 2000 B16B into 99ex wiring help please...
- ls/vtec headgasket problem? dont line up
- H22 swapp harness Question
- Runnin rich???
- Ok here goes finally finacially stable SWAP help
- i spun a bearing!!!! will this crank work in my h series
- what else do I need??
- What Shifter Bushing Do I Need?
- Where to get header for h22
- gsr question
- h22 eg question...ASAP!
- supra motor in old school nova
- D16Y5 to B18B swap - Will o2 sensor harness work?
- Mount problems with B18C1 into EK
- H-T Gurus, please help with h22 swap issue...
- what should a ITR head read????
- 98 Accord auto to OBD1 H22A auto...tcm question
- need p2t ecu info. and a few itr after swap questions?
- Lost Engine Harness - What to do?
- Speed sensor and reverse switch question
- Can i use those parts of the D16 on my B16 swap?
- B16 swap- Satisfied or unsatisfied
- Mini-Me
- h22 engine harness
- F22B DOHC head + F23 bottom end possible?
- gsr swap in a del sol what stock air box?
- Please help with swap. weird problem. MAP cel
- What would you do
- LS/VTEC POWERSTEERING PUMP?????? WHICH ONE???
- should i put b16 pistons in my LS/vtec?
- b16 wont rev past 3000 rpms PLEASE HELP ME!
- ls/vtec help!!!!!!!
- h22 into del sol question about shift linkage
- Best OBDI ECU for non-VTEC B18B Turbo?
- Posted in Tech Forum and didn't get any help
- Need help with A/F, Oil, and Water temp gauge wireing into 97 h22 teg
- Is there a diffrence between the 00Si and 97 GSR fuel pump..?
- Which shift linkage?
- Do I need to replace my fuel pump when swapped ?
- LSD trans???
- Infinite Tonaka H22 civic mounts
- i wnat to put ac in my 93 civic with h22 swap
- info on H22 swap ...
- IAB still not working. HELP!
- New to honda
