PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. swapping back to a sohc couple questions
  2. JDM H23A OBD II DOHC VTEC in a 99 Honda Accord
  3. Need someone to confirm this dizzy jumper 0bd2-1
  4. legal smog?
  5. Increasing Stroke
  6. Gsr in 99 civic si,Car jerks when shifting into into 2nd and 3rd at high rpms!!!HELP
  7. Where are the best places to find hybrids forsale?
  8. exhaust back pressure
  9. which civics comes with 190cc injectors???
  10. B16a2 in my CRX
  11. need info about f22a1 block/ swaped with h22a1 head
  12. k series shifter box on H series tranny???
  13. Another Ls Vtec turbo question
  14. JDM ITR Wire harness question (O2 sensor)
  15. calling all h2b i have a question
  16. CEL code 41. looking for help.
  17. aTTN: JDM EF SIR RIGHT HAND DRIVE OWNERS
  18. y8 intake manifold on mini me
  19. My Build!!!!
  20. odb1 p72 ecu kicks code 41? secondary o2....
  21. ///////////F20b block w/ H22a head? Will this work, or be usefull in turbo set-up?\\\\\\\\\\\\
  22. I SEARCHED>> H22A1 IN 92 CIVIC SI. fuEL QUESTIONS
  23. H22 swap in to EJ1
  24. code 8 tdc 97 civic h/b with odb1 gsr swap idle spike and surge i'm stumped guys
  25. h23/f23 crank/rods into h22 HELP
  26. 89 hatch with LS engine will not turn over
  27. Swap Question?????
  28. car barely runs
  29. F22B1 w/ H22A head.
  30. Frankenstein
  31. b18c1 into EK...
  32. auto to manual conversion?? anyone know how???
  33. Suspension/Brake Swap 92 Civic Hatch
  34. Air intake on your swap?
  35. ECU problems HELP ME!!
  36. cap and rotor interchangeable between B16 and B18 distros?
  37. Should I swap an H22a into my Civic
  38. GRS in Ek3
  39. gsr intake manifold into a b16
  40. h swapped civic brake more axles????
  41. Mazda rotary engine
  42. Quaife LSD from a J1 JDM tranny - what else does it fit
  43. B18b into 98 civic ex issue.
  44. A/C Belt and vacume line ?
  45. gsr wireing diagram
  46. H2B guys, which intake manifold provides more firewall clearance, euro R or skunk2
  47. b18c1 swap into 93 del sol, which shift linkage to use? any help would be appreciated!
  48. k24a4 into EG swap... need some kinda info
  49. torque specs for arp gsr head bolts
  50. O2 sensor help
  51. best shop in the NW for a swap?
  52. B20 swap into EK probs....lets get this shiza going!!
  53. OBDII GSR swap in a 92 Si, OBDI pwr steering pump....
  54. Where to find a dip stick tube?
  55. whats this check light -----> (O)
  56. whats this check light -----> (O)
  57. whats this check light -----> (O)
  58. obd1 motor in obd2 car
  59. ahhhhh crap. obd2 gsr into civic.
  60. Noob question, did a search.
  61. h22 civic missing after 4k crome tuned ecu... I've tried everything
  62. fuel pressure problem w/ B20 in EK
  63. SOME QUICK QUESTION ABOUT MY 99 CIVIC
  64. CTDI swap
  65. axle combination (SEARCHED)
  66. h2b project
  67. B18c6 in EG5 suspected purge tank/idle prob
  68. h2b EK
  69. Where to buy my Cap And Rotor? JDM
  70. OIL LEAK ??????
  71. B20/ vtec??????
  72. Simple Exhaust Question... Swapped Civic
  73. NON VTEC ECU?
  74. ********lsvtec timing belt covers.... HELP*********
  75. ******WTB h22 alternator relocation kit asap**********
  76. obd2a gsr into em1 chassis
  77. Help, engine wont start, drowning in fuel?!
  78. need 92 integra transmission or alternative
  79. How many of you guys actually pased ref (legally) with your h22 in an eg/ek
  80. $50 TO ANYONE WHO CAN GET MY CAR RUNNING
  81. vacuum lines off the transmission?? need help
  82. Troubleshoot my Project - Win a Prize! All I want for Christmas is my car on the road
  83. keep power steering in b18cR EK
  84. Question about K series swaps
  85. B20B, B20Z question...
  86. Just swap Motors
  87. Some Final Swap Difficulties.
  88. storing car for winter what do i need to do??????
  89. quick axle question
  90. b16a2??
  91. quick question....
  92. transmission from a shuttle on a civic hatchback?
  93. my car doesnt move when in gear..
  94. hey buddies, flywheels mixable? im new here.
  95. Rebuild Tuning
  96. H22 CRX w/hasport mount. Engine alignment question?
  97. Bay Area Importers?
  98. // 92 CIVIC HATCH \\ TURBO // HELP \\\
  99. HELP. Slipping belt/air leak noise at startup on B18C.
  100. Very very sad day for 96 ek hatch. Water may have gone through engine why???
  101. buying new intake manifold and throttle body what to buy?
  102. jumper harness question
  103. JDM vs. USDM Ecu's
  104. Who made the K20 prelude?
  105. can some one help me on a B17 swap?
  106. Oil light flashes when braking
  107. obd2 gsr ecu?
  108. looking for info on putting an itr into a 90 civic
  109. HELP. Slipping belt/air leak noise at startup on B18C.
  110. Need to know how to install shift linkage
  111. HELP!!!!!!!!!!!
  112. B20z valve clearences with B16 head
  113. 96+civic swap mounts?rear mounts? pics here
  114. wiring help asap
  115. idle problems
  116. b20/vtec
  117. aggrivating exhaust issue... b16 in a 96 hatchy
  118. Rod and Main bearings
  119. Using P73 ITR ecu in B18C ITR swap in OBD1 eg6???HELP????
  120. ecu fuses????????
  121. fuel pump question for b18c5 motor!
  122. sorry search but couldnt find answer
  123. spark plug wire location???????????
  124. B18A1 Ls with B16 head
  125. b20/vtec timing belt ?
  126. F22 block + H22 head, will it get lower or higher compression?
  127. obd1 lsvtec swap in a 96 dx won't start no fuel / spark please help
  128. Swap + Auto-->Manual Guru's Step Inside!!!
  129. Swap + Auto-->Manual Guru's Step Inside!!!
  130. need some advice from some experts!!
  131. h22/b20-vtec dc2
  132. b20z question
  133. B20/type r
  134. smog legality
  135. f22/h22 Rod Bolt ?Question?
  136. Hypothetical.
  137. D16Y8 anyone?
  138. gs-r motor wont start in my 00 si NEED HELP!!!!
  139. 98 GSR in 95 hatch dizzy issues...
  140. Distributors: OBD1 - OBD2 interchangeable?
  141. IAC ERROR? B18c Hondata s300
  142. eK HESITATES BOGS , THEN DRIVES NORMAL. HG LEAKING AGAIN
  143. What year motor to get?
  144. gsr swap/94 civic
  145. Power steering belt?
  146. CRX D16 to H22, VSS (vehicle speed sensor) required. Wheres it located?
  147. Datalogging cable
  148. SRT4 Engine
  149. crooked engine mounts?
  150. i built the best sleeper first pass 12.6 @110mph
  151. Converting obd2 motor to obd1?
  152. Problem with axles in an '89 civic swap
  153. Does anyone know where you can FINANCE a jdm motor????
  154. rewired dizzy for OBD2, done correctly? starters starts but...
  155. b18c4(like b18c1) or b18c5 with b16a2 head ???
  156. Problems with my b18c1 in my ef hatch
  157. EF bseries. Searched!
  158. going to buy dc 94-99 gsr header and obx hi flow for swap ek
  159. quick question, moving everything from a GS-R to an EJ1
  160. rsx 5 lug on eg?
  161. Thermo Ground???????
  162. Which Distributor and Ecu to use for 96' d16y7 swap in 93 ex???
  163. Resistor Box ?
  164. h22a swap (having vtec issues)
  165. What is the best swap for a 92 Integra gen2 b18a1
  166. what catback exhaust you guys use to bolt on ek hatchback with gsr swap??
  167. engine mounts
  168. CRVTEC gods help!
  169. y8 harness to b16b ctr
  170. Yet another H22 EG thread. IAB related.
  171. this is complete crap. (96 civic, 00 gsr)
  172. Which of these engine brackets is which?? Pic included
  173. 3 Stage Vtec D15B Swap
  174. auto to stick
  175. B16a Head cams wont turn
  176. 2000 ex motor in crx with hydro transmission
  177. Simply B16 or B18???
  178. Help with H22 swap?
  179. New to the hybrid scene...transmission help
  180. tranny question
  181. gsr into a ls obd2 obd1
  182. dpfi to mpfi in a 89 hatchback???
  183. H22 part list almost done
  184. gsr swap wiring question.
  185. swap question
  186. Need some help on pricing.
  187. Difference between H22a type S and H22a euro R?
  188. any one got some nice pictures of some swaps?????
  189. k24 question
  190. h22 swap...intake manifold/chipping the p28
  191. Changing from fuel injection to carby on 16V SOHC VTEC 1500 cc
  192. Engine code 16...injector test/swap
  193. H22 into EK Swap *PICS*
  194. h22 crankshaft in f22 engine build
  195. Need help with mini me build
  196. B-Series shift linkage question ????
  197. A/C bracket
  198. motor mount breaking
  199. Conversion harness not fitting with wire harness?
  200. k series question?
  201. 2 Liter B-Series Hatch not starting... Spark, fuel (?)
  202. b20 swap help
  203. crx springs on dc???
  204. duralast motor mounts good?
  205. who can make my civic bar legal?
  206. 2000 CIVIC TOTALED AND WHAT TO SWAP PARTS TO MY 1993 CIVIC EX!!!
  207. code 15 car just died please help.....
  208. b18a1 into 94 civic, is this all correct?
  209. backwards LS/B16 swap
  210. Quick help please Exhaust!
  211. 94 h22 into 2000 si?
  212. Best ECU to use with OBD1 ZC if JDM ZC ECU not available.
  213. K-Series help
  214. first timer, any tips?
  215. [FAQ] "My VTEC doesn't work"
  216. HELP NEW SWAP NEED HELP
  217. d15b..alternator question
  218. h22 swap vs 2005 mustang gt hehe
  219. im converting my auto teg shell to 5spd
  220. d16z6 manual and auto
  221. my swaps not running right
  222. making sure of something need help about obd1 ecu
  223. ls vtec parts need
  224. 97 OBD2 GSR in a 95 EG HELP!!!
  225. Ls Vtec problems
  226. H22a
  227. h22 cable linkage bracket ??
  228. new h2b kit
  229. ls/vtec rod question
  230. just thinking of stuff...H22 EG
  231. HCP Mounts
  232. d16y8 into 92 eg hatch what dist to use???
  233. Y8 head on my Y7
  234. b20vtec swap into EG...gsr head................
  235. emissions on the a 97 ob2a hatch.
  236. B16 into EG...rear bracket problems
  237. h2b header need one asap??
  238. from h series back to b seires (mount question)
  239. b20vtec will not idle
  240. best head for ls block
  241. Pr4 vs. P75 ECU
  242. How to read Engine Head & Block code?
  243. i have an idea
  244. Which clutch?
  245. power door conversion
  246. MPG for ctr b16b
  247. milky oil after swap
  248. Should be a easy swap question about intake and exhuast
  249. 98 civic HX auto to 5 speed conversion
  250. tranny help
