B16a engine with b18c type-r 96 head Which ARP head studs do i need?
I'm confused i'm running a b16a1 engine with a spec 96 type-r b18c head.
I want to buy me some ARP studs to keep the head from lifting when pushing with the nitrous.
Does anyone know which studs i need u have got the 208-4601 for the b16a and the 208-4303 for the b18c.
ARP says:
Kit # 208-4302 (b18a)has 8-studs at 7.100 long & 2-studs at 8.000 long
Kit # 208-4403 (b18c)has all 10 studs at 7.250 long
Kit # 208-4601 (b16a)has all 10 studs at 7.100 long
I don't know if the length difference is in the head or block. You would need to check that on your end.
Re: B16a engine with b18c type-r 96 head Which ARP head studs do i need?
Is the 0.150" longer a problem since i'm gonna go b18c next year probably?
Also thought that, the 0.150” that they are longer shouldn’t be much of a problem probably and i that way i can also use them when i get myself a b18c bottom end.
