b series into 92-95 civic mounts and brackets???
i searched this for days and i got mixed answers. still dont know what i need
i know for my 96-00 civic i was told to buy all the mounts and t bracket. ended up using no mounts and only a t-bracket from a si and post mount so please only reply if you have done this swap and know for certain without guessing
from what i understand i only need the complete set of mounts(driver,rear,passenger) from a 94-00 integra and i need the t bracket from the same year integra. is this correct
what about the post mount
Seagull Management
Re: b series into 92-95 civic mounts and brackets???
All you really need is the T-bracket, lower transmission bracket and A/C bracket, if the engine is from an integra you'll need a '94 - '01 Integra driver's side mount ('94 - '95 EX/Si/VX models use this same mount as well, it's the aluminum one) if the engine is from a civic or an orthia you'll need a normally '92 - '95 civic black painted steel mount.
ok thanks the engine is from an integra and has the silver aluminum mount so im good on that
and i got the t bracket so i guess im all set then
and you mean the passenger mount transmission bracket right. not the tq mount brackets because i wont be running tq mounts anyhow
Seagull Management
No I meant the torque mount bracket, upper mount is the same between '92 - '95 Civic and '94 - '01 Integra. I'd highly recommend running torque mounts though unless you're running really good aftermarket mounts.
92civtegra
09-20-2008 06:09 AM
vtecb20coupe
06-25-2004 07:38 AM
wm5holla
07-24-2003 01:12 PM
