View Full Version : Hybrid / Engine Swaps
- Z6 intake on Y7 head
- HELP!!!! No spark and this is driving me nuts!!!
- Any combo to make a civic trans rear wheel drive??
- How to check error codes on P30
- GSR head w/ which block ??
- Starting my LS/Vtec Swap...Couple Questions
- 92 DA Integra motor/trans into a 93 Civic...Couple questions.
- H22 obd1 injectors in B20 vtec obd2?
- Future Twin-Charged G23 95Civic Project
- 97 b18 block 99 b16 head ??
- OBD2a engine/chassis, OBD1 ECU, which alternator?
- F20b w/ RBC manifold
- What intermediate shaft do I need?
- cable trans + cable cluster -> P28?
- H2B with DSS 5.9
- EM1 Si civic wiring loom and tank
- f23 rod bolts
- F20C into S15
- J swap in an ABS EG?
- "phantom car": prelude type R
- What's Wrong here...
- B18C1 block with B18C5 head
- Suoer Noob Question
- EG/EK/DC QSD H2B/F2B Guys need help! Measurement! $!
- <<SMOG HYBRID CIVIC NO ILLEGAL OUT OF STATE REG>>
- prelude SH swap into regular prelude?
- My J32A3 Integra
- Quick B18C1 in to a Eg question.
- sensor identification on b16
- swapping d15b7 to d16a6 help please
- Stock H2B EG 4dr went back to the track getting a little better RESULTS INSIDE
- innovative transmission mount h22 92-95
- B20b swap in eg
- H and F series compatibility
- 4 vs 5gen civic engine swap options??
- Went to the track yesterday Stock H2B eg 4dr LX results inside
- I need help on build.
- DOHC D16 head on SOHC block, I has been done.
- delete moved to tech
- b series headstud question
- k20 swap into gm (opel) speedster
- 1st gen non obd b16 into 2nd gen civic
- Rear of car sits too high after H22 swap? EG civic
- A few B20vtec questions
- Using B18C5 Power FC in H22 Swop
- H22a1 Map sensor
- p8r head on a LS?
- ls block w type r pistons..what head?
- 91 hatch, mimi me swap?
- Confusion with distributor cap for GSR
- does it matter which h22 head for g23 swap?
- H22 with M2B4 into EG hitting
- need cel help with obd1 lsvtec
- Help me Please
- Quick Hybrid Question
- witch rods and pistions???
- B18C EK swap idling issue
- need help with distributor g23 build
- USING OBD2 DIZZY and obd2 wire harness with OBD1 GSR ECU
- 88 crx si with p28 board CODE 20
- d15b showing check engine
- Quarter sports H2B bolts?
- LSVTEC on DELSOL nightmare
- need some guidance/ideas for welding up a mount
- GSR cams for Lsvtec B16 stock head?
- charcoal canister + b18c swap
- ls vtec build
- b16a1 mounts
- jdm h22 distributor
- vtec on h23a
- What starter??
- HELP!!!H22a Head on F20B Block?
- OBD2b to OBD1 = No tach
- what belt b18b & y8 pump
- B series throttle body on a h??????
- Link to single cam integra
- b16 block- b18 type r head q's
- *** the OFFICIAL Hybrid picture thread **
- f22b sohc fuel rail on f22 dohc ?
- F22 Dohc swap
- diagra to convert 0bd2 to 0bd1 dizzy
- 92 CX with H22 Swap
- d series in a da
- b16 head on a b20 block will it work?
- d16y7 to y8????
- D16Z6 w/ DOHC head
- '98 EX auto wire harness & throttle body the same as a 5spd's?
- h22 into a civic eg d13
- ls fuel rail on b16
- obd1 in obd0 car
- h22a head with a b20b block
- Victor x manifold stock fuel rail
- VSS Question(s)
- Which stock head cylinder better for turbo??????????
- EM1 K20 Bucking issues no vtec?
- CAlling all TROUBLE SHOotERs FOR SWAPS
- b18b1 with itr pistons on ls rods
- eg6 water in floor board.
- My J series daily driver...
- zc awd crx
- some people
- k20 wiring harness help
- DC2 with H22 hood clearance...
- J32a into acura legend
- any difference between the sir2 manifold and a si manifold
- ARP head bolt stripped...
- eg6 h22a control arm & axle help!!!
- intake manifold sir2 help
- Pistons rings, how to know if gone????
- LS/VTEC- WHAT EATERPUMP AND T-BELT?
- k20 swap questions
- Jdm B18c IAB Wiring
- y7 block/y8 head
- d series swaps??/??
- S Spec H22 CIVIC SWAP
- v6 da integra
- JDM ECU's Have immobilizers?????????
- Name that Harness...because I have no clue what it is
- f2b swap (accord engine SOHC)
- Electrical Water temp Guage..Where to Tap?
- Doing a mini-me swap.
- b18c1 intake manifold question
- throttle body question
- d16y8 to DC2....let the flames begin
- To the J swappers out there...please read and help me out.
- f23 auto ecu need help
- turbo a b18c engine
- ek steering coulmn swap?????
- D15B vs. D15B (obd1 vs. obd2)
- k20 eg build help
- B18b CRV issues
- b18 into eg swap help please
- DX to GSR throttle body ???
- 1991 accord a/c convert into 2000 civic a/c
- obd2 gsr in eg fuel issues
- K swaps in an EG. Why the extra wiring?
- b swap - PS, A/C??
- Reusing H22 harness in civic swap
- MAP Sensor Question/Problem...
- h22 header/civic exhaust???
- B18C GSR Motor Questions!!
- Who here has seen or done a dyno comparison bet these 2 headers on a Stock Hseries
- OBD1 B20Vtec into 97 CX... Help!
- putting together a stroker?
- 97 Civic 4Dr - D16Y7 to D16Y8
- H22 axles
- OBD2b 99 ex wire harness PLUG DILEMA
- OBD 2 B18C1 into OBD1 LS
- b20 crank
- B18C4 (B18C1) Swap Problems, Wont Start but have Fuel and Spark
- HELP ON MY G23!!
- H22 in Eh
- clutch splines stripped????
- h22 del sol shifter problems
- LS VTEC to GSR....Can You Help???
- Integra turbo 4wd: The project start
- Distributer differences and or plug and play help!!!
- f22b block/h22 head
- i need opinions on budget build !! a few bseries and a da9 story
- POOR MANS TYPE R TIMING COVER?
- speedo healer question
- K Motor Forum
- b16 swap question
- b16 vs ls question
- vtec oil pressure switch harness
- OBD2a Engine into OBD1 car (Both JDM spec)
- Will a OBDI LS ECU work?
- gsxr600 itbs on b16 mani tp sensor question
- Intake question..
- POST YOUR LOOPED P/S Setup!
- Karcepts with an H22 swap
- Turns, but won't fire
- b18c1 ek swap
- 93 civic cx mounts
- B series with auto in 96-00??
- b20vtec head gasket
- V-6 Motor Swap Done!! EK Chassis
- MSD Questions
- SHop seem to have lost my CX harness...
- obd1 jdm b16 block with obd2 usdm b16a2 head?
- B18C into 90 Si Hatch swap questions...
- OBD2 USDM b18c1 into 92 dx hatchback..please clarify
- P13 ECU, IABs on H22 EG civic
- coil pack on H2B build?
- B-SERIES REAR T-BRACKET NOT FITTING
- J32 Swap Build Thread? Info
- CRV Swap???
- H2B resistor wiring gone wrong?
- question on gsr has anyone done this
- Are EG and DC2 suspension arms/forks/knuckles/hubs 100% identical?
- b20vtec questions
- D-series and B-series knock sensor question.
- 91 Prelude with JDM B18C-R everything...shifter problems
- F20B dizzy wiring
- Anyone ever start a D16Y7 with a P28?
- Need Help...K20 swap into Itr...Wiring question
- EVAP with a jdm itr swap
- just wanting to know what to expect
- Hood Spacers for h2b EG
- help please prob bin asked b4 but pulling hair out
- H22 Innovative Mount kit axle issue 92 civic
- H22A4-F22/H23 crank and rod ???
- Engine swap
- 01 EX thermostat into 00 EX
- EG AWSD (H22 turbo 4WD and 4WS)
- H2B, TPS,ECU, EGR
- h23/h22
- F23a1 transmission bolt to h23 block?
- LS intake manifold on GSR?
- 2000 civic si need help sawapping 2009 si engine in it
- h23 vtec in 01 accord
- Just got my swap done and have a few ?'s about the CEL codes
- ek swap help
- Questions about a mild build on a Bluetop H23A VTEC motor
- car will not rev
- Prelude shift linkage cables to accord
- Remove engine from top or bottom? K series different from B and D series
- b16 idles at 2.5k and timing retarded??
- Swap Axle Question
- About deck height - B18C and B20B?
- s2000 cluster in a 97 civic dx.. help
- OBD-I P07 ECU from VX being used with OBD-II Y5 Head?
- Wiring question for a obd1 GSR into a 1998 GS
- swapping F22A6 into civic
- obd0 ls dizzy on obd2 head
- ITR Swap Axles?
- ls/vtec help
- h2b shifting problem
- Charcoal canister wiring - GSR into 98 GS
- EG H22 ESP Mount
- Can i use gsr throttle body on ls/b20 motor?
- obd1 b18a1 work with 97' dx 5speed engine harness?
- General H23 VTEC Questions...
- possible to depin obd1 injector clips?
- questins i have before Swap f22b1 into 94 EG civic
- Bad QSD batch or ME
- 94 civic hatch b16aII swap rear trans mount doesnt fit any ideas
- help g23 vtec build sputters till 5k
- 92 Civic h22 swap want ac
- Innovative Motor Mounts
- Vx fly wheel good or bad on a d16z6
- F20B crankshaft in F23A1
- h22/eg swap harness ?
- First 200whp EG Build.
- F series parts to a d series engine
- LS block; GSR Internals?
- How can I tell I've got a OBD-1 alternator (B-series)
- H2B or H2D? EF h23vtec
- bought crashed 97 prelude for swap
- b16 or ITR/GSR water and oil pump? HELP!
