View Full Version : Hybrid / Engine Swaps
- need suggestion on extra mods...H22 in DC
- jdm distributor
- b16 into a 90 civic SI
- wiring questions: LS swap into 96 civic EX
- GSR into a Del Sol....help!!!
- h22a accord...how fast?
- LS/V-TEC oil pump
- how to make a jdm R engine pass emissions in CA???
- Deciding on my Swap....
- Hondamotorsonline.com, JDMhondaparts.com, and JayDM.com
- no one>
- Price Quote for B20 Motor Work?
- z6 in 96 coupe?
- NYC!!Looking for a swap-shop?
- crvtec-problems
- LS swap pinouts
- b20vtec on ls tranny?
- how much would you pay for a b18b
- best place to get a b16
- leaking oil
- oil leak from hell
- The real deal with H22 swaps!!!
- mount rushmoore...
- bearings for a b16a1
- Shift Linkage Question Again.
- H22 in 94 teg LS problems
- What do you think of this...
- can Del Sol Si (not the DOHC VTEC) axles be used on a B18C1?????
- B18A swap... linkage question
- H22 TypeS Jspec in a 92-95 hatch.
- eg gsr swap????? need help
- 1/8 Time Slips
- b20b question...
- obd0 - obd1 conversion
- Hybrid Idea.
- Automatic 92 Lx to automatic B18B?
- 12 second All Motor B20 Hybrid
- 18 wheeler delivery truck with NO crane
- where to buy B16a CABLE TRANNY?
- Which intake?
- best swap?????
- Need to remove stock Rev limiter on stock p28 ecu
- who here has a H22/23 in there EF or CRX??
- fastest way to afford swap
- $20 to the person who can help me out...
- what's the engine classification for the 2001 and 2002 civic EX?
- Passenger side motor mount
- FastBrake front 4pot kit, did you clear it with your slipstreams?
- H22 hatch maniacs!
- LS/Vtec Pass smog in Cali?
- The time has come for my Engine Swap!
- Thoughts on changing the timing belt on a jdm motor before going in the car.
- B16a/B18c1 block difference
- Wiring help!! B16 in a g2 integra
- 4 wire O2 sensor to 1 wire? possible?
- Need your help for ls/vtec swap type-R head on b18b
- Car is shaking???
- b16a1 into JDM EF3
- 1 wire O2 Sensor to a 4 wire O2 Sensor HELP
- Cluster swap-Gsr cluster into a 91 crx....
- "Frankenstien" engine swap
- B16a fuel problems?? Help!
- 0db1 ls swap in 87 hb??help
- is it posible
- HELP...couple of possible PROBLEMS: 1) White smoke, 2) Low idle
- More B16A Question..
- gsrblock vs ls block
- b18c1-b16a? size differences??
- swap not starting pt.II
- Spark gap
- jdm b16 2nd generation vtec
- JDM ITR 5 Lug Conversion on 99 Civic SI - HELP
- Explain advantages of using a gsr block on a b16 head.
- I want your trash people......please?
- b20 vtec top end problems
- tranny spec...
- hondamotorsonline.com
- ng which rear engine bracket for place racing?
- ecu/wiring help???
- diffrences between 2nd gen & 3rd gen LS blocks ?
- H22/EG Only 2 CEL Codes, I think my ECU is playing with me?!?
- B18C5 swap into a 4G civic/crx.
- Money over HorsePower?
- fuel pump
- 93 Civic VX turboed...tired of it...wanna hybrid
- what axles for h22a swap into 96 civic?
- What Motor Mount? HELP!!!
- H22 in integra (1990)
- my car is done....
- Has Anybody put a jdm b16a motor into a 99 civic dx can help me out
- need some engine swap info
- wiring hep
- Distrubitor INterchangerable?
- Best Trans. For Swap?
- need to find someone with a rechipped p28 or someone that reprogs them near chicago!
- B20/DX alternator/pulley change?
- ls in a 96 coupe?
- another dx to si swap question
- aonther dx to si swap
- Damn got beat by a....
- NEED CIVIC obd 2 pinouts please!!!
- NEED Pinouts!!!
- about how much is a gsr knock sensor going to cost? new or used
- Still need 99-00 b16 wiring harness.. Old harness is an LX need........
- b20 in a integra
- Where can I find a gsr tranny?
- h22 problems, please help
- GSR motor in EF?? what is involved?
- How to TRULY lighten a RACE only car?
- Knock sensor required for B20/VTEC
- si engine swap into dx chassis
- Head Gaskets!!??!!
- What ECU to run on my hybrid H22A?
- GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB
- Making a '90 Integra GS into a mid-engined experimental racecar....
- does anyone make mounts to drop an H22A into a 2nd gen integra?
- need strong a$$ driverside engine mount for 99 ek hb w/ GSR swap
- Someone help me with my H22 coupe suspension PLEASE
- B20VTEC Setup
- first gen b16 into 91 civic standard....no spark on cylinders #2 and #4
- conflicting info - ARP rod bolts for LS and B20B
- need help: H22A eg + road course?????
- Tranny hybriding
- SOHC Vtec into 87 crx???
- 1989 DX To SI Civic Conversion?
- b20 Vtec problems! Need info quick
- ***HELP with APEX VAFC wiring on LS crx***
- What spring rates are you using for your h22 swap
- B20 -> EK Hatch
- H22A AC Bracket... some picts
- H22 Swap Into 88-91 Civic DX
- Emissions- How to pass emissions with a engine swap?
- JDM1.com
- LS distributor...
- have you heard of Stren Aguzze 15 wheel?
- What are internal differences between USDM B20B and USDM B20Z ?
- Which ECU with B16A2 Motor in 96 Civic?
- New to board..Question on Hybrid...
- how can i do this? and will these work? help....
- Are all 94-01 Integra starters the same?
- How do you get the pin out that holds the shift linkage?
- odb 1 b16a motor missing distributor. HELP!!
- what ecu should i use for my ls/vtec?
- What are the plugs on the drivers side fire wall??
- axles..
- b-series in a 7thgen!
- lsvtech spec questions
- 99 ek Hb with GSR swap,, keep power steering or ditch it?
- H22 Civic swap help,HCP mounts?
- H22 in a 95 GSR
- 1996 JDM B18B into 1990 Integra RS
- any info on the jdmclub
- 85 prelude custom
- ls/vtec
- What linkage to get?
- i need an LS tranny
- thinking about LS/vtec..need help/advice
- For the people with G2 Tegs
- obd2 d16
- NewB Question~*
- 90-93 integra mounts same as 92-95 civic??
- noob? about gs-r rear swaybar on a 1994 cx
- How to add a wire or repin
- Wiring Harness
- Help on a SOHC Head swap.
- Need wiring harness for a 2000 b16 to put in a 99 4door civic!!!!!!!!!
- D16y8 92 CX
- can u...
- LS motor with CTR pistons
- ECU, wire harness, and OBD questions for B20Z in a 93 Si
- All the differences between B16a1 and B16a2
- went to capitol raceway last night
- HondaMotorsonline problem....
- GSR Swap with B16A Computer
- hey KATMAN answer this, does jdm small box comp. have speed limiter
- 88-91 hasport question?
- cheapest place to find ls "complete" motors?
- b16a2
- 1998 ex ls swap
- I/H/E which to get ????????
- 96-98 civic harness for 00 itr swap. what wires to add?
- Place Racing / Prothane EK motors mounts....
- To all ho have a red Valve Cover(ITR)
- '92 Civic engine/tranny swap or engine?
- H22 Swap, Into 98' Civic Coupe
- GSR cams, B16 head valve adj. specs
- ls people got a question...
- **need valve adjustment specs for skunk2 cams**
- 2.5 vs. 2.25?
- Which mounts to use?
- Radiator fan doesn't come on!!!!
- need some help, car being bad again.
- New Swap unfirmilar
- map sensor for OBD 2 GSR
- odb2 to obb1
- Can I use any Integra axles for a B16a1 swap into a CRX
- Write Up on Putting 95 GSR into 93 Civic Si HB
- lets trade rims...
- B20Z intake manifold
- O2's in 92-95 b16?
- info about CRVTEC...inquire within
- Mini me help!
- JDM Engines
- CAI for a B18C5 in a del Sol
- Part number confirmation: del sol A/C bracket
- need help finding motor mounts in Md. Va. area.
- Cataylic Coverter Question
- what computer for H22 in DC???
- stolen motor?
- My wife is tired of me doing swaps for everyone else.......
- Where is the best place to swap in South Cali???
- Major Questions on h22a swap
- engine swap....possible?
- Speedo accuracy: Tire size, or Engine/tranny?
- del Sol swap info...*did a search*
- Locating a B20z
- Motor mounts??? Spoon or Mugen...
- Exhaust manifold for 92-95 w/ B-series....
- 89 CRX SI, B16 ecu--pin question
- swap problems...
- Swap starting problems...
- Putting together LS/VTEC - Dallas Area
- calling b18b1 ls guys help!
- header torque
- cleaning engine compartment
- you guys ever buy from www.hybridautomotive.com? Got good deals on lca's and rear disc swaps.
- is this price about right?
- What is involved in adding a GSR block to an 99-00 SI head
- Got a Question for you Si drivers or Ek swapped people
- which fuel pump to go with? ITR, walbro, ect?
- **95 JDM B18C1 head install: need bolt torque specs!**
- sir lower crossmember
- 1st gen b16 takes any tranny???
- Rated power for Integra?
- oil pressure sensor on a 1st gen jdm b16 in a 88 crx
- JDM B16A Question
- I am new at this, dont make fun of me...
- People with hybrids, how old are you?
- intake manifold leak
- gsr w/b16 head
- ek rear disc problem
- CRVTEC with prelude block?
- Swap...FINALLY....done. Problems here: coolant bubbling, knocking sound, etc.
- When does VTEC kick in?
- EG/h22 cooling system questions....sorry :P
- b18b (obd2) in a '94 cx: Question about sensors
- stock injector question for ls/vtec
- axle problem
- Do integra 94-98 and civic 92-95 have the same suspension bushing size?
- Dallas/FtWorth area Hybriders?
