View Full Version : Hybrid / Engine Swaps
- Obd2a p72 us on a LSv in a 98 civic Dx
- b18c block w/ b16 ported head
- k20a ek swap.cm1 harness with no pin b18?no charge!
- h22a eg help
- Tl-s swap into Civic BAR legal?
- Honda Project
- Need help! on sleeper build
- F20B swap help please!!
- B18 Idle issues
- Civic ek with k20z3
- Ls/vtec oil leak
- Swap Opinion
- B20B into 95 eg civic swap
- what harness to use?
- Help!!!!!!!!!! Needed tcm schematics 96 98 integra and 96 98 civic
- lsvtec ecu question??
- what cold air intake will work on a 97 Civic B18C Type-R motor swap?
- b20 auto into EG
- F20b engine swap questions
- ODB1 B18C in 98 EX Issues starting
- wire harness vender,custom
- 93 honda del sol si b18c type r start up problems, some one please help me out
- F20B eg axle problem
- k swap
- m's jdm motors? good?
- gsr swap in 1993 del sol
- b18c swap cranking fast but wont turn over??
- 96 gsr swap on a 94 civic ex help!!
- Rough Idle / Acceleration Issues
- Ls/Vtec b16 head running on p28 question
- h22a s300 sensors problems help
- lsv eg wiring
- h2b options ?
- IACV help f2b
- Will a CRV IACV work on a B20 obd1 auto ek Civic?
- trying to get the most for my $
- changing engines
- Need Help/Insight on GSR Build
- B18a1 crx rywire harness
- pm6 for b18c1
- Can I use a obd1 p13 on a obd2 h22 in a obd2 ek
- Can I use a obd2 wire harness from a prelude in a obd2 ek
- B20B with OBD1 LS Auto in OBD1 ECU/TCM dilemma
- Which IACV for my B20b with Integra LS auto obd1?
- Anybody know any good people that can chip and tune ecu's
- Axel problem
- 36mm axle question
- H22 dizzy question
- GSR in a EK question...
- B20 swap quick question
- Swapping a Obd2 h22a4 into a Obd2 ek Ecu help.
- EG H2B gas milage????
- JDM OBD2 GSR harness in eg
- 94 hatch with h22 hasport kit and axles
- Crx switch back to obd0
- 92 hatch b18 swap question
- Innovative Mounts H22 Alternator Relocation Bracket (H-Series)
- Civic Swaps?
- DIY LS-V Kit
- civic eg h23a blue top swap. help!!!
- h2b - alternator wiring help 4pin to 3pin
- 99 Honda Civic SI - issue with exhaust/headers.
- Grinding issue
- anybody with f20b experience?
- h22 spark plug wires
- 95 civic lx swap to b18b1 automatic
- Doing a B18B swap/ 5 speed conv. into a '96 Civic LX
- gsr swap wiring help please!!!
- Delsol b18 swap
- B20VTEC !!
- lsvtec injector code only over 7.5k rpm
- crx swap please help makes no sence????
- 94dx shell B20B turbo motor mounts and brackets I need can't figure it out
- B20v running like crap
- JDM B18B Rings & Main/Rod Bearing Sizes??
- leaking coolant out the head
- rt4wd rear axles
- OBD help swap
- 1st gen b16 Intake manifold swap
- F20b crank swap
- first gen crv 5spd f20b swap nightmare! help please, running but not good.
- 93 del Sol Type S Looking For Pros vs. Con Between B16/18/20 OR H22
- Type R swap
- b18c1 swap questions!
- 1992 civic, zc mini me, intake manifold wiring help
- em1 w/ itr tuning issues
- B18 Del sol Swap issue
- H22a CRAZY ISSUE (No spark, random starts)
- B18 or B20 intake?
- crx swap
- Question on 99 GSR Swap in 96 CX
- Stock lsv in a gsr build horsepower and torque
- j32a2 swap into 92 civic dx 4 dr
- SOHC ZC swap?
- 91 crx hf with 95 integra donor car
- awd conversion first drive binding up or big vibration
- obd2a to obd2b swap question
- New Project: B18 GSR into 99 Civic Si
- H23 vtec blue top or F20b
- Question about OBD2 motor into a OBD1 car
- EJ engine swap?
- h22 EG problems during swap.
- found aK24A2 for $800. What to look for before buying it?
- 93 Civic Swap Ideas
- p72 ecu burn q3 help?
- 94 si b16 swap help
- AWD CRX Build, Rear end options?
- Which alternator and p/s pump for my lsv ek build
- Help on a Gsr in a Delsol
- d series into a classic mini
- Mini me spits and sputters out of nowhere??
- H22 92-95 civic- which axle solution worked the best?
- What is wrong with this gsr swapped crx???
- H SERIES SWAP
- K20 or D-series turbo?
- Spark but no Fuel
- Best Mount kit for turbocharging a K-series Ek Swap
- B18c1 Swap Wont Stay Running
- D15b7 Swap to B18b2 Possible?
- 93 eh/D16Y7 swap - need advice on improving performance
- Help please, gsr in eg hatch :( at a loss
- Possible to swap a type-s h22a into an ej1 without any major modifications?
- i have a question on doing ls vtec
- CRX SI B18A1 Distributor question
- need help guys!
- K20 will not rev over 2000 rpm, what could be the problem? throttle body sensor?
- Questions about ls vtec.
- usdm ecu recommendation
- found a h23a1 block at the junkyard
- B16a2 crank, rods and pistons in a b18c4 block
- B18 swap in a 88 crx si..help!!!!
- MDX injectors into a F23?
- Gas mileage for B18C
- f22b1 swap in to 92 civic hatch need help!!!
- Em1 CTR swap having issues
- Stuffing a J series V6 into my Triumph?
- Trouble with H2B CRX...wont start.
- Emmisions Help
- How do I wire vtec in 94 dx civic?
- B18a1 obd0 engine in Ek???
- Twin Turbo RWD V8 Civic
- h22 crx skunk2 intake manifold question.
- Ej2 b18c-r swap check egine light
- 1,5 + 1,6 combo
- Swap ideas!
- Question about automatics
- Gsr swap into Ek
- The latch to my glovebox came off :/
- mini me swap helpp
- F2B problems
- SO my master cylinder went bad..
- Mini-Me (d15b7 to y8) questions/info please read
- ls vtec fuel problem help!!
- 96-97 jdm b18cr swap guide?
- gsr issues
- B20 swap into an ek Civic converted to obd1
- F20b stroker update (dropped valves)
- 96 Type R help with mods
- mini-me D16Y8 / Y7 questions
- Ticking sound coming from z6 head
- Any one using supertech valvetrain
- GS-R SWAP ISSUES
- Rhd Type R 4 Door Conversion
- I blew my gsr
- obd2 ecu to run obd1 motor?
- 97 Civic HX d15b7 swap help!
- b18 conversion in ek civic
- Mounts Needed for my B20 swap into my EK..Pleas confirm I have searched
- B Series Transmission for a Sand Rail
- y5 to y8 swap
- rebuilding poor man type-r (h-t advice?)
- Help with OBD2A B20 in OBD2B 2000 Si
- Jumper Harness HELP!!
- H22 EG AXLE?
- ecu help
- LF - B20b swap to 1993 Del Sol- Parts (Tips?)
- '99 Civic HX motor Swap
- Lsvtec build, whats my tuning options
- H2B alternator and crank pully kit
- 99 LS into 91 ef hatch swap
- H2B IACV 3 wire to 2 wire HELP !!!!
- ej2 B18c-r swap oil cooler
- EG H22 mounts that dont vibrate to death?
- K24a4 Motor Questions
- 1995 civic k24 swap question
- HELP need some q for my eg doing JDM dc2 type R
- integra inner tie rods??????
- Comfused plz help
- B Series Shift Linkage
- HELP! swap wiring troubles. HELP!
- JDM H22a ,H23 Vtec or Euro R H22
- **Thats right another catchcan B20 question???***
- Frankenstein B16/B18C swap into '91 Si
- dizzy on h22a4 swap
- B20 VTEC Help!
- BWR Header for B20
- B18C in my Eg or K20a2 ?
- Fresh swap - rough idle, skipping, low/ no idle
- H2b intermediate shaft problem! Please HELP HELP HELP!!!!!!!!
- 93 honda dx B18C-r swap
- B20 Vtec Help!
- D16 Eagle rods in a B16
- 99 Civic GSR Problems Running Well Wont Rev Plus Blowing Fuses
- Parts that Fit From a 98 Integra type-R to a 2000 civic SiR--EM1
- b18b1 crx. won't run right
- chase bay engine harness
- Obd1 Ls swap in ef. Limp mode and no cel?
- D16y8 in eg
- EK B20 A/C options
- Budget exhaust options for my ek Civic B20 non-vtec swap
- Gsr swap with vx fuel pump... Redline at 7000???
- 97 Accord won't rev past 5500 rpm
- Need info on wiring: Two wires crank sensor to OBD0-OBD2a Jumper Harness
- d15z1 block with a z6 head
- D15b with z6 head swap help
- One of these Magnaflow mufflers on my ek b20
- Will stock EK mounts work for a B Series?
- F20b swap
- H22 Lean on All Cylinder/Hard starting.
- B20 crx ecu map sensor and start up problems, please help
- oem/nippon/rs machine pistons on aftermkt rods
- Bar'd h22 in INtegra/civic - owners
- which intake mani gasket should I use?
- H22 Timing Issue
- Will a B20z with short intake fit in my ek Civic...
- 2.0 DOHC Vtec not Engaging
- B18B1 swap into 2000 ex.
- Distributor wiring question
- 94 EG haych Gsr swapped Turboed On 12psi
- F20B with lsd trans bolt up to h22a with non lsd mounts in an ek?
- h22a type s swap in EJ1
- ej1 with gsr throwing code 9 cyp?
- k24 into ef 4 door questions
- Crx HF H22A swap. I Need Help
- B16A2 into 94' Hatch
- Do all Integra automatics use a tcm?
- H2b / f2b hybrid stroker motor dyno results
- h22 Owners - long block + Transmission Sensors/ plugs List ?
- H20B harness and computer difference from AT/Man
- OBD2 Integra LS Automatic with an OBD1 ECU
- eg civic with b20 starts but dies
- 98 b18b in 2000 civic bar-able
- K24 in 93 del sol
- p28/p30/p72 ecu on d-series?
- cbr 1000 cop on b18? any chance???
- will an h22 crank pulley fit on a B series?
- b16a gen 2 and gsr cams
- Found a 00 Honda CRV in a local junkyard. What parts can I use from it on my ek?
- What EK B20 swap mods are most mpg friendly?
