H22a Swap - Stuck on Wiring, Mounts, Shifter
Re: H22a Swap - Stuck on Wiring, Mounts, Shifter
I belive I am asking a little too much. I do have a digital copy of the civic manual and prelude. They have the harness layout which gives each plug a number, where it goes, but no wire colors or name so it fairly useless. I did find all the names and write them in but i dont have colors to go with, and that is the prelude anyway.
The civic has a diagram with colors but I am not able to read it.
So i need something like this because I dont think it can be dumbed down anymore than this.
Also
I removed the little heat shield below the alternator, i believe that is for keeping the AC komp away. Hopefully thats k00l with you.
The belt works thats posted online from napa. 060370 -napa It is a little bit longer than necessary, you could go with a shorter 6tooth if you want. but its fine. Obviously if no PS or AC
These injector orings work. Oile'd em up and didnt break anymore injectors " ik2902 " oem h22a1's
My favorite chunks of sound deadener! big pieces eah?
Also
Kozanatos, if you have a digital copy of the manuals I think your best option at this point is to look for each one of those sensors in the manual and on the testing part of it, it should tell you about the plug (how many pins) and what colors are there. You can also look at the wiring charts and it'll tell you the wiring colors for each component.
//edit
oah I know what your talking about. The electrical diagnostics! I still dislike the diagram on the engine bay
could somebody identify the sensors on the H series? I do know a few of them but it's all the intake sensors and they are all bunched together.
i cant get my fuel fitting on the fuel rail, the filter, and the intake...
How do you relocate the filter? I replaced it with a new one, but disconnect it and make a strap that goes around it and self tap it to the firewall? and bend the stock fuel line?
yun_cheezie
06-09-2003 04:02 PM
