PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 [139] 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. 5g tranny- 87 si crx
  2. one to 4 wire o2 sensor
  3. tools for changing flywheel/clutch ( ring gear holder, or crank pulley wrench?)
  4. stupid ? but don't know
  5. ITR clutch master cylinder
  6. need help on v-tech head
  7. how to tell if engine is from auto car?
  8. WTB: 99-00 rear engine, ac comp, driver side mount.
  9. Are all B-series shift linkage the same?
  10. d series thermostat, b series motor
  11. b16 swap wiring.
  12. ZC valve cover ?'s
  13. H22 and H23...does the .1 liter actually affect anything that much
  14. H22 in the back of a Hatch?
  15. will a complete prelude sh drivetrain go into an acura 2.2 cl pretty easily?
  16. cheaply priced b18c1?
  17. Strange MiniMe distributor problems..
  18. idle problems with H22A swap into 5th gen Accord
  19. building my own motor
  20. b20 Vs. ls/vtec
  21. Best Header for Ls swap hatch......
  22. B16 water pump for CRVtec?
  23. How much does a 00 si B16a2 cost?
  24. vafc settings. HELP!
  25. 99 B16a2 in 98 civic ex parts list needed PLEASE HELP
  26. stay OBD0 or go OBD1?
  27. what to do about busted ball joint bushing on hub knuckle????
  28. Help!! my gsr is jerking at low rpms
  29. all done but wont start
  30. 85 CRX swap?????
  31. b16 hydro tranny in b18b EG
  32. ls swap...money involved?
  33. D16Y7/Y8 Mini-me questions...(did search)
  34. looking for a machine shop in NW FL or Southern AL
  35. swaping b20 into g3 Integra
  36. may need a new tranny in my 90 SI hatch,,what to get
  37. What are you guys getting out of your B20/Vtec? Any one using a GSR head?........(HP/Trq)
  38. Give me a $10,000 car that is reliable and as much fun as a honda Hybrid.
  39. 94 civic cx swap to integra ls
  40. Fuel pumps
  41. cell 22... vtec pressure switch
  42. AEM cold air intake on eg?
  43. H22 speed cutoff
  44. build d16 or swap?
  45. HASPORT Wiring Harness Question
  46. ef/gsr tranny-many?s
  47. Which Speed Sensor (VSS) should I use?
  48. std-d16y8 need help
  49. what are the best mounts to get for crx B18C1?
  50. Looking for an old thread
  51. Any Tegs here w/a b20 motor in them?
  52. Question: G2 b18a w/ 97' ITR Pistons and engine mods
  53. what's the difference between LS axle and GSR axle?
  54. help.. which dual core radiator to use with b18c in ek? thanks
  55. B18c1 in a crx
  56. Compression Ratio JDM H22 Motor? help
  57. help! DA power steering removal.
  58. vtec pressure switch -not getting a code? -
  59. h22 in a gsr...
  60. how to run block number
  61. emissions in CA
  62. about to embark on obd2 b18c1 swap in eg last minute questions
  63. can i run 2.25" for a while....
  64. S2000 Engine swap to an old Alfa Romeo??
  65. 94 octane on 12.5.1?
  66. Hybrid hatch with B18C is faster than Audi TT....at least top end.
  67. obd 2 LS into a 5th gen civic wiring...
  68. Mini Me Questions Pls!!!
  69. New site, Needs members
  70. Anyone want a GSR mota?
  71. Mid swap pics of H22 EK
  72. Is this a right time?
  73. Osaka H22a Engine
  74. need a b18b1?
  75. Is this possible with rsx type s
  76. CRVTECers: How is your PCV system holding up?
  77. Smog regulations for dohc engine in sohc-engine chassis.
  78. code 14 help!!!!!!!!!!!!!
  79. Prelude swap and hondata
  80. If you could do it over
  81. Shifter rattle in CRX si w/ B16A1
  82. ecu/injector help
  83. Question::: D16 tranny fit B16A?
  84. Does my D16 tranny fit up to a B16A engine?
  85. B20B mounts into EK??
  86. OBDI GSR Swap in a 95 Civic EX, NO SPARK>>>
  87. what exactly makes the difference in power between 93 and 94 acura ls?
  88. Which ecu is in the 96-98 jdm b16s?
  89. B16a in a 4th gen civic
  90. Map sensor for 93 cx JDM b16a motor .
  91. zc wiring
  92. Cylinder Sleeving - How To?
  93. Attempting first motor swap....few questions (GSR into Civic coupe)
  94. ECU Problems
  95. B16A. 170hp or 160hp?
  96. About MY tranny
  97. New Hybrid born in HT
  98. My Boosted Hybrid was stolen this early morn...
  99. reverse lights??
  100. SOHC Japanese D15b throwing 10, 14, and 41
  101. Not getting any spark in my b16
  102. Best Source - or any source for Hubs In Swaps (B series into 84-7 CRX)?
  103. Plz help I've spent all day looking through old posts & cant find the answers I need!
  104. Shift linkige problem after swap B18C1 into 00 Civic Si
  105. What drivers upper moter bracket for EK
  106. Hybrid EK
  107. Help: B20/Vtec Head Diagrams/Pics?
  108. Do you think this is going to be to hard?
  109. Does anyone know were www.crvtec.com has gone? Or is there another site as good?
  110. H22A in EG gas question
  111. b20?
  112. site w/ detailed H22 install?
  113. b16 swap problems, HELP!!
  114. Building a n/a B16A, what is better for road racing, mid-range power or pure top end?
  115. did a search. aynone using GSR suspension on B18c EG?
  116. Anyone Have the An-R.com's street or race header ????
  117. turbo size relates to engine stress level question
  118. 2000 b16 into 95 ex...quick question..
  119. GSR oil pan fitment problem...
  120. B16a1, What should i replace before installing
  121. B20b with a B16a1 head?
  122. JDM motor legal issues
  123. where are my h22a brothers at?
  124. About my crx
  125. How much power can this LS/VTEC setup make..
  126. rsx motor swap into 6th gen civic (area 51)
  127. shift linkage for an h22
  128. Do you really need a block girdle for a sleeved 84mm ls/vtec?
  129. putting a 91 CRX Si engine into my 91 LX
  130. Type-R swap
  131. Techs Help Please!! (CEL CODE 72)
  132. h22 civic short shifter
  133. 93 gsr eg question
  134. Spot face - head porting - bay area shop?
  135. how hard is it to swap a vtec motor into an 86 CRX?
  136. b16a2 swap, CAI, no cat....running lean :( HELP!!!
  137. B18B into 90 Integra
  138. you guys are going to kill me for this one, but H22a (type-s) or JDM B18c (type-r)
  139. B16 Rear Trans Bracket
  140. tell me your 1/4 mile time!!!!!
  141. B16 OBD question help?
  142. MY Swap please me me *****
  143. b16a2 swap
  144. Civic wagon?
  145. ZC oil pump???
  146. car wont go into gear when warm
  147. H22 Swap Wiring with ATTS in 94 Del Slow...
  148. NEED HELP: B16A1 in EK want B18C1... Can i keep eveything but the engine it's self???
  149. help, my swap is done but not running right.
  150. Anyone buy motors from Osaka?
  151. b16 civic crx swap guide and shop manuals
  152. Streetdragz?
  153. Skink2 Or PYR Chip
  154. Water leak EK hatch
  155. plug on top of intake manifold???
  156. Building up my itr motor before i swap, suggestions??
  157. H22 hatch becomes fastest all-motor honda car in canada
  158. need some tranny help here please
  159. sohc distributor on a dohc
  160. Q regarding putting on older model year engine in a newer car
  161. Bored out B16A block vs. stock B18C1 block
  162. h22 Exhaust questions-- to flange or not to flange?
  163. HOW TO STOP A THEIF!!!!!!!!!!!!!!!
  164. B16a2 swap complete... but have problems
  165. Really think I screwed up Hybrid wiring, need Help (H22 in 90 Accord)
  166. alternator pulleys....on my engine
  167. into same area with vtec line..please help oil question
  168. h22a swap and questions
  169. top 10 ways to lighten your car
  170. ready built crvtec
  171. what p/s pump with b18c swap into ek
  172. Please Help me!!!!
  173. Which Altenator to use for Crvtec swap into 92-95 Hatch
  174. 97 B18C1 into an 88 CRXsi?? need some help
  175. Shifter assembly placement and routing in 94 Civic Coupe... AND Yes just spent last hour searching f
  176. mid swap pics
  177. b16a 1stgen cost
  178. How do you guys add wires to the ECU..........
  179. outer cv loking c clips
  180. Need Connector pinouts
  181. how can u tell if the engine is stolen....???
  182. ECU: 4G EF or 5G EG ?
  183. Civic shock forks and type r bilsteins.
  184. got the car dynoed yesterday
  185. The race motor in my CRX, need some help.
  186. b20 headers ... which will fit?
  187. Opinion wanted...about to drop some $ on GSR Swap
  188. swappin 94 ls motor in a 95 civic
  189. Which intermedaite shaft for my swap??
  190. What do you use to get error codes?
  191. are stock sleeves ok for b20 vtec with a 55 shot?
  192. D15 non-vtec to built D15/16 Vtec block HELP!!!!!!!!!!!!!
  193. Help needed! and opinion on Motor Mounts!
  194. JDM B18C into my 1994 delsol si, more...
  195. LOOK HERE i need help easy stuff for experts
  196. need help wit h22a4 swap into a EG hatch
  197. 93 si engine into a 94 cx..please respond quick!!
  198. vafc and ls ecu???
  199. obd-2 ecu on obd-1 car
  200. JDM engines for sale
  201. Quality Ls/vtec shops in the bay area
  202. Anyone using JUN cams with different valvetrain components?
  203. where to go to find info on h22a swap for a 95 teg
  204. help with sohc vtec swap in 95 dx
  205. Cheaper To Stroke a B16 or build up a GSR block?
  206. asking for a friend whether d-series mini me needs external oil feed? y/n
  207. H22 swap distributor issues..NEED HELP RIGHT AWAY!!!!!!!!
  208. PPL w/ a LS *b18b* swap in a 96-00 Civic, what wiring harness you use?
  209. B18c swap questions
  210. b20 or LS vtec?
  211. need help... GSR pick up and windage tray on LS block???
  212. b20/vtec OR turbo LS
  213. B18B crank in a B16A?
  214. fuel or vacuum?
  215. hmotorsonline swap
  216. RC Injectors?
  217. ARP Head studs a necessity?
  218. JDM SiR Cluster
  219. gsr mount questions
  220. Ls/Vtec what is really involved?
  221. Best EF Header?
  222. gsr clutch problem
  223. 92-00 (B16A Sir 2) Long Block eg swap pics??
  224. Tranny?????
  225. mini-me swap?
  226. Skunk 2 ECU?
  227. ITR pistons or B16a pistons
  228. b16A1 vs. b16A2
  229. difference between ls and gsr axles
  230. Problems with the new baby...
  231. B16a2 into 94 coupe.
  232. b20 vtec n/a or turbo.
  233. j1/y1/s1 trannys
  234. All motor set-up.. Which header
  235. Swap Madness
  236. Import builders motor
  237. Code 3 on a 1994 Integra Ls...who knows what it is?
  238. *** CAMS for LS/VTEC???? ***
  239. *HELP* which pistons and rods with a b20 with gsr head???
  240. anyone looking for a H22/civic hasport kit?
  241. How much does a GSR run for, just engine, no tranny, or axels or ecu, just engine???
  242. need ifo on ac bracket help me out please for gsr swap into civic
  243. GSR Motor swap v-tec nightmare
  244. just orders a full jdm b16 swap.. what other parts will i need
  245. B20Vtec Question. New To forum. Please answer.
  246. sohc vtec turbo vs. b16????
  247. b18 from LS into 97 civic dx...
  248. lsvtec TRANSMISSION /lsd /axle info needed
  249. tell me what you guys know about h22a's...help!
  250. *** Best valves, valve springs, and retainers??? ***
