View Full Version : Hybrid / Engine Swaps
- throdobody tps sensor
- OBD2 Swap into a 90 CRX
- charging system numbers
- 90 Integra GS to recieve a B16
- need some help! 98 jdm R into 94cx wiring problem
- ys1 and a b18b1 help!!
- b-series swap
- H22 Into OBD2 Integra
- crvtec into 87' or older crx?
- just did h22 swap
- swap question, please help?
- how do i remove ecu pins from the connector
- Tranny for B20 (searched)
- GSR in DA--2 extra plugs-pic inside.
- ???timing belt cover???
- For a LS-VTEC to go into a 88 CRX???
- ECU pinout help?
- Question about parts compatibility...ZC and GSR...
- cost of motor!?
- HX Model
- Shift Linkage?
- k20 swap found for 4k
- 99-00 Si exhaust(Apexi n1) on B16 eg. Will it fit?searched
- Need help! wanting to put a 96' JDM B18C into 93' integra....
- Swap insurance question
- just did a swap and will not idle help
- $200 up for grabs
- DC chasis harness to EG...
- jumper harness problem
- o2 wiring question..
- 96-98 CIVIC DX IN A 90 CRX SI HELP
- Obd2 jdm civic type r and smog test (sniffer test) ??
- question about wiring
- Full OBD1 conversion in an EF (not just a conversion harness)
- P28 ECU problems
- b20 ?'s
- Walbro 255lph hp fuel pump and fuel pressure gauge
- H22 swap ride height
- gsr in a 2000 civic ex coupe
- Enjo mounts?
- high compression LS
- Got my h22 today from hmo. What else do I need?
- Good swap shop
- Need A Tranny!
- Low idle problem!
- Where to find P08 (d15bvtec) pistons?
- HOW TO IDENTIFY B16A SIR2
- 90 4 door civic exhaust question
- Wiring B18C1 IAB in a 96-98 EK
- Wiring Question ?
- Need URGENT help with my h22 swap!!
- Anyone using spoon mounts instead of the hasport kit?
- Is It Possible To Have More Than One Map Sensor
- secondary butterflies cause code 23? knock sensor?
- Okay, it's time for the 2nd Annual East Coast H22 Hybrid meet!!!
- Which is best/easiest for a H22 transplant, EG or EK??
- obd 1 Distributor Pinout Question (to obd 0 harness)
- Engine Mounts (B18C in EG) searched
- JDM EK4 B16A is on the way...but i have some Q's...
- a new understanding of HYBRID ... 1990 Mazda RX7 powered by a 2001 LS1 V8
- H22A into 88-91 civic
- doing a b18c5 swap into a 94dc2ls could i just use the harness from the b18c5?
- HX Model
- H22 Civic running.
- b16a cam question
- What sensor is This
- 7 to 4 & 1 to 4 Wire Oxygen Sensor Conversion "How-to" Document
- GSR Swap Questions (searched)
- b18a/ef swap distibuter wiring
- engine mount question
- i need motor mount
- jdm importers in northeast?
- OBD 0 to OBD 1 Distributor Pinout Differences (or how do 8 wires go into 9)?
- put a 99 B18B1 in a 93 civic EX
- mounting slicks on stock wheels . will it work???
- in need of obd0 vtec distributor
- eg hatch gsr swap??
- where to put plugs
- H22 civic shifter
- Jspec motors
- wiring help? 99 ls swap in 96 ek
- grinding noise when starting up
- big bore?
- h22eg a/c ?'s searched(newman, poison)
- (b18c into vx) need to know where some plugs go (HELP)
- anyone running a ITR trans on a b20vtec??
- Fuel Pump?
- Fuel pressure releaving itself into my IM after swap!!!!
- K20a2 or Turbo B16a2.... In Civic Si..... tech question's...
- Hasport mount(s) question???
- 2.25" vs. 2.5" exhaust piping (GSR hatch)
- are axle dampers important?
- 95vx with 99'd16y8....Need Help and Advice
- help d15b swap problem
- LS swap ac pump
- I was thinking about something
- Got a question about the B series and H series in a 96-00 Civic
- Swap was fine but fuming now..
- Need help with h22a-accord wiring
- Need help with h22 swap
- Are all prelude half shafts the same?
- vin # ques for legit swaps
- will h22 JRSC fit h23???
- Just did H22 in eg and wont go in gear!!!
- My swap is done: axles are torn, which replacements to buy?!??!
- K20 into EG updates
- A couple of really basic questions
- does anyone correct color chart (ECU)?
- Question for a B18C5 motor swap into an EK Hatch
- Not Hitting V-tec
- Looking for shops to Swap in the SF Bay Area
- which axles fit 97 civic ex with h22
- What Motor Mount Inserts For My Integra?
- identify these sensors plz!
- oil control orifice ? whats is it ? do i need one ?
- i'm looking for a vtec oil pressure sencor, oil control orphist plz help lol
- gsr in 94 hatch. . . want JDM 4-1 itr header, now? ? ? what exhaust will fit?
- H22 Engine Conversion Harness
- Idling problem on B18CR into a 93 civic Si
- middle of swap: some questions/concerns.
- Can i use stock JDM GSR motor mounts on my 98 civic?
- lsvtec how long problems mods
- Just hit the dyno. What do you think?
- GSRcivic with chiped mugen p08...what plugs and wires???!
- USDM B18b into 5gen Need Wiring Harness?
- OBD0-OBD1 conversion GURUS HELP NEEDED
- puttin a jdm gsr swap into a 94 integra. need help w wiring
- B16 into a DPFI wireing
- All you H22 guys running a p28, tell me which chip to go with!!
- super charged jdm b16 question
- i need to put my 96' JDM B18C into my 93' civic Si HB. need help!!!
- What can i do?
- broken hasport mount
- ls vtec rod bolts
- WHAT COLOR LED'S
- P73 ECU
- accounting for all the ctr motor!!!!!!!!!!!!!
- B18c1 into 91 CRX Swap Won't RUN!!! Please help!!
- h22 eg: how many miles do you get on the tank
- '91 b16a...i've put 50K on it...maintenance?
- p13 vs. p72 pinouts
- No Map Sensor?? Wtf??
- Looking for 98 civic ex d16y8 complete intake manifold
- B16A2 swap into 2000 civic dx o2 sensor question. Please help
- The Vtec D15B engine swap
- how to tell aut ECU from STD ECU??
- Doing Tbelt on JDM B16a,,,, need some info...
- Isnt there a plug and play resistor pack for H22/EG?
- ECU error codes, 19 and 20
- need FAQ file for a B18B to B18C or B18C5 swap?
- B18C GSR motor into a 93' integra?
- Hasport K20A Press Release
- h22 ek
- I need vouches saying i dont need a new harness!!! h23a1 to h22a swap!!!
- JDM P72 obd1 ecu or JDM P73 obd2 ecu? please help asap
- Anyone familiar with HMO engines and/or their own swap????
- what mounts do i need for ls/vtec swap in 96civic
- power steering question?
- Draft:external to internal coil on h22 accord swap???
- A/C Bracket From Ha sport please help!!!
- 5g Prelude brakes/hubs and ek?
- A few b18c swap wiring q's
- Tranny Code
- WHAT AXLES TO USE WITH H22 IN A 89 HATCH?
- p06 or p28?
- 98 dx ecu swap (p06) obd1 cel light?
- B20 in an EF. What tranny?
- hasport axles
- 0bd-0 swap o2 sensor help
- b20 crank pulley
- Help: engine swap with picture instructions.
- JDM Pr3 Vtec ECU OBD-0
- opinions of B16C5's from hmotorsonline.com?
- how to tell...
- hear of them...
- H22A Del Sol Dyno plots
- One question regarding H22A into an Ek
- ls/vtec oil line fittings
- B18C into EG....Few questions
- best swap feed back please???
- LSVtec in EG VTEC Wiring Question
- Halfway done w/ b16 into ek.... gotta few wiring q's??
- does a 94 or 95 gsr harness work in a 93 gsr?
- Pictures showing clearance of Jimfab bars in a H22/EG
- B-series in a EK can I use my stock shifter linkage rods?
- mini me swap nfo needed asap
- What ECU are you runnin??(H22 Hybrids)
- 90'ls b18b to 95'gsr
- anyone have problems with bseries swap in an ek?
- 1st gen b16 into EK (yes i searched, Please Read!)
- D16 for a B16....EASY?
- o2 sensor......diff. between obd1 and 2
- stock exhaust
- What A/C Bracket
- Press Release: 1st Gen B16 header
- B16a Wont crank/turm over after swap.
- LS/VTEC post your thoughts on it
- Looking for a blown (not supercharged) B18c with a good block.
- Poll: How long did it take everyone to do there h22 swap?
- Spoon Calipers-Replacing the pads??
- b20 with b16 head
- lsvtec->eg swap wiring/sensor q's
- Need serious Tech help/#4 cyl. misfiring
- distributor question
- Erratic Idling Problem,Help
- 4th generation accords with H22A using AN-R header?
- i vd searched no luck ( 5 speed tranny into automatic)
- Axle and Tranny Questions...
- How hard does your VTEC hit?(H22 Civic Hatch!)
- motor mount bolts
- h22 tranny f22 motor
- RSX interior in a civic pic request
- Which engine would you buy I need some help?
- OBD II B18 into 1990 Integra GS: monster garage style
- Have tried, tried, and tried to figure it out. What's up with my h22?????
- Civic fuel filter on h22a engine
- Doing a swap is it worht it to put a more performant clutch
- AVID stg1 H series civic axles ?
- crap---need hynrid help asap!!!
- P08 ECU
- D15b swap complete but ?????
- LsVtec head bolts?????
- b20 hybrid
- 90-93 integra axles
- Will I pass the obd2 scan?
- how does one check to see if motor is stolen
- O2 sensor ? b18c in eg d16z6 harness
- Ls/Vtec swapped, now problems begin!!!!! LOOK!
- OBD1 P72 or OBD2 99 Si ECU???
- valve cover
- pics of h22 ek civics..please post up your car pics..(lowereing issues?)
- which company to go with...
- Do transmissions have to be from matching years to pass CARB? In CA?
- B16a gearbox question.........
- are there shorter synchros for h22 tranny?
- Wiring question on 95 vx to jdm d15b?
- H22 swap to integra
- I need a TPS for a second generation ZC engine CIVIC
- B18a in a OBD1 EG Hatch HELP!!!
- electrical problem help
- 95 civic with usdm type r susp.
- Cusco EK Civic Engine Mounts
- golden eagle is screwing it up. PLEASE READ
- turbo zc in del sol
- wiring harness ?
- runny h22 with accord tranny, which clutch
- obd2 h22, how do i run with obd1 ecu in obd1 car
- which axles for a JDM B16A swap into an EG?
- Single long slow flashing engine light????
- type-r suspension on EK
