PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Euro R 3 to 2 wire iacv Idle Issue
  2. F22b swap to h22z1
  3. GS-R engine swap problems
  4. Swap extras?
  5. DA to K20a2 - What's the hardest part?
  6. obd-0, 1 or 2?
  7. Feedback request: Engine Swap options for E85. K20A2 or H22A4?
  8. B18c swap homestretch help
  9. Is AC possible in a J swap?
  10. H22a swap to a h22a4
  11. swap from d16y8 to d16a
  12. TLX: Build up 2.4L or stick with J35? (for fuel consumption)
  13. G23 oil cooler
  14. F20b w/ t2t4 in 00 EK civic
  15. EK Swap
  16. Help! Cheap and fast build advice
  17. B16A engine swap into 00 EK Civic
  18. B16A engine swap into 00 EK Civic
  19. Civic f20c key problem
  20. EG Sedan Tachometer Question
  21. JDM B16a ITR intake manifold swap help
  22. LSVTEC do I need a tune?
  23. K20z1 EG Swap Questions
  24. honda logo
  25. Gasket set for bored engine
  26. New to Honda - Help me choose a drivetrain
  27. Rsx engine in a prelude
  28. Strange yellow goo in harness connections
  29. B20vtec Starts and Immediately Dies
  30. Honda Odyssey Motor Swap/Upgrade advice
  31. Choosing an ECU for a LSVTEC build
  32. D16y8 ob2 to d16z6 ob1
  33. Which swap for my EG
  34. O2 sensor for H23A with PCF
  35. d16y7 block with Z6 crank??
  36. 70MM Sk2 TB & Manifold question(not installation related)
  37. B16 - was it boosted?
  38. AWD CRX donor, B20 or K24a1 CRV?
  39. B16a2 Idle Surge
  40. D series mini me to B series
  41. B20 head swap questions
  42. Do I have a “mini me” build? Need help
  43. B20z2 into eg
  44. OBD2 b20 civic distributor pinout
  45. 1991 civic dx d15b2 block y8 head questions
  46. K-swap EK: Help, no spark
  47. EG6 with H22a shifter gear problem
  48. Civic EG6 shifter gear issue
  49. 00 Civic ex, B18c1 OBD1 Swap, Tach not working all of a sudden
  50. H23a VTEC & PCB need wideband O2?
  51. Assistance needed: D16Z6 ECU / Wiring Harness Diagram/ Pinout for classic Mini Cooper
  52. 00 ex GSR swap OBD1. No tach. No Speedo/Odometer
  53. -Need Help Please- K20A swap in 00 EK sedan EX.
  54. How To : K24Z7 swap in EG civic. Complete how to!
  55. Troubleshooting: B18C5 Swap questions
  56. ecu
  57. J32 swap Immobilizer
  58. J32 swap questions
  59. EG H22 Swap Code 6
  60. B18b idle fluctuations in eg hatch
  61. Mini Me Swap Trouble
  62. Lsvt Help
  63. 95 Eg hatch D series to b18b1 LS
  64. h22a
  65. un- tapped vtec head does it suppose to look like this?
  66. B20Z w/ 4WD trans into EF?
  67. Can anyone identify this ECU?
  68. **NEED HELP INDENTIFYING SOHC VTEC HEAD**
  69. J37a4 stand-alone setup in jet boat
  70. D swap in Geo Metro?
  71. EG Hatchback RWD Conversion Ideas
  72. 1998 Honda prelude codes issues.
  73. D16y8 head with a y7 bottom help!
  74. 2000 honda civic lx auto swap?
  75. J-Swap EK Shifter question
  76. F20b manual in a 2000 Honda Accord auto
  77. Brough performance H2b EF firewall Clearance?
  78. D16Y7 to D16Z5 ???
  79. B16 Swap Into A 95 EJ Civic
  80. OBD0 89 CRX HF to B18A1 OBD1 which harnesses do I need? Will need to pass BAR
  81. Ktuned traction kit clear h2b ef w/ innovative alternator bracket?
  82. 94-95 GSR donor swap into EF questions
  83. Hx issues
  84. Late model engine swapping questions
  85. DOHC D16ZC 1ST GEN CIVIC Tuning
  86. i have 2003 honda accord ex coupe with lsd 6 speed
  87. Introduction!
  88. i have 2003 honda accord ex with j30 and 6 speed shifter lsd
  89. 5th Gen Euro R Swap in Austin, TX
  90. Honda Civic 1997 engine swap to B20.
  91. Eg with type r k series or buy 2jz for my g35???
  92. h23a in eg civic
  93. 1999 Civic SI Minime Swap-lots of pictures
  94. Seeking help f22a6 in 2000 civic ex
  95. F20B/H23A VTEC Dizzy pin out to OBD2A harness
  96. Honda Element wiring research help needed.
  97. 96 Accord OBD2/H22a
  98. B18C swapped EG not getting spark?
  99. d15b1 head change
  100. K24 swap donor car available p, what should I take?
  101. OBD-2 ZC SOHC Non-VTEC in EG Hatch?
  102. Weird Idle, Low Fuel Pressure
  103. starter for manuel h23a vtech bluetop
  104. Classic Austin Mini
  105. 96 civic 5 speed
  106. H2B w/ 4.7fd Type R search. Wanted to say thanks.
  107. 2wd 91 civic wagon
  108. NorCal shop to swap h22 in CRX??
  109. 04 civic ex crv swap
  110. F22 engine/trans in 5th gen prelude axles
  111. F23a ek swap internal dizzy
  112. Engine mount bolts needed: D15Z1 engine into 1987 Civic AF chassis
  113. part help confusion
  114. Mini me swap auto trans
  115. Swaped b18b1 into ek does not start
  116. C27A swap - 91 civic
  117. B18C1 basic tune
  118. Nj emissions pass with a jdm which ecu do i use?
  119. Doing b20vtec is stages
  120. 89 CRX H swap with Innovative mounts and pro traction bar, experience? Fit?
  121. 1992 Civic with B18C(obd1) Catalytic Converter and CARB Compliance questions.
  122. B20 swap low idle issue (obd2b 2000 Civic)
  123. OBD2 GSR Wiring IAB/EVAP Purge
  124. CX swap
  125. Which drivetrain to go with?: '01 BB6 Prelude
  126. h22 Civic is running terrible.
  127. Integra gsr jdm type r swap usdm ecu swap
  128. i own a 98 civic ex 98 4door sedan and was to swap in a d16y8 with a z6 head
  129. H22a swap idles at 2000rpms. Please help.
  130. Troubleshooting; h22a idles at 2k RPM's
  131. Are these quotes for engine swaps reasonable?
  132. Jdm d15b non v swap problems (dseries/engine swap help)
  133. H22A1 into a 1999 H22A4 prelude, no injector pulse?
  134. what wire harness do i need for my b18c
  135. CRX JDM H23A BAR CA legal since it was a Federal Emissions vehicle?
  136. Why B over H trans? Is H trans really that bad?? Please help need to start swap.
  137. B16/B18 hybrid a.k.a. Poor Man's Type-R engine
  138. First H2B/strategically done first mods
  139. Sourcing B swap parts
  140. GSR Swap w/ S2 Intake Manifold
  141. 95 civic d16y8 swap. Ecu questions
  142. ODB II controling JDM 1.5 will not turn above 3500 RPMs
  143. Spark plugs
  144. My plans for a J35A8, 3.5L V6, RWD, 6Spd Conversion-('01 Prelude)
  145. 91 Civic DX b20vtec rywire harness issue
  146. Problems swaping d16y8 on an eg4
  147. HELP NEED GUIDANCE
  148. Mugen F20C/K20A Hybrid details?
  149. G23 vtec all electrical info please
  150. swapping a d15z1 into a eg coupe with a blown up d15b
  151. Someone PLEASE HELP!!!! Lsvtec problems
  152. [H22A ?Redtop? 6th gen swap] Need help identifying some things
  153. H22 adapter plate for d series tranny
  154. 00 civic jdm itr swap evap gas question help
  155. Size of L15B7 vs K20
  156. Converting Engine to OBD2B?
  157. Project integra k24 swap/ help
  158. Fuel pump not coming on with J32
  159. Specially constructed vehicles and titles
  160. Map sensor ?
  161. Continuation of Issues after Swapping D16Z6 into 1997 Civic DX
  162. Got some questions for my car
  163. main relay no ground (possible bad underdash harness)
  164. H22a into EK Vacuum lines question
  165. 97-98ish PCT B16B pinout.
  166. D16a8 vs d16zc? 87 civic swap
  167. Adding knock sensor on z6 block
  168. wiring secondary o2 for non vtec b20 in 96dx civic
  169. Issue with c1 wire b18A1 swap
  170. H2b info
  171. H22a swap bogs out. Fuel issue?
  172. Ls/Vtec, NA
  173. Fill me in on a D16Y7 to B20B swap please...(00 civic lx)
  174. headlights dim when press gas, brighten when let off gas
  175. K20a2 swap dc4
  176. D16y5 To B18b1 Swap
  177. ECU not getting power
  178. B20 into 94 Civic cx
  179. PM6 to PCT jumper schematic
  180. ‘00 Ek with GSR emissions and CEL problems
  181. ac idler pulley noise b18c r in ek
  182. D16z6head/D15b7 miafire cyl3 & valve knock that goes away
  183. Swap K20A4 with K24A4 on Honda CR-V 2004
  184. Obd2 engine in obd1 Car
  185. RYANCF$'s H22a Build in CF4 chassis
  186. 1993 Del Sol D15B Swap question
  187. main relay no ground k swapped ek civic
  188. GSR integra obd2b pinout/rywire harness issues
  189. Strange noise! Help
  190. B20b4 distributor with em1 obd2b harness
  191. H22 Swap Axle Issue
  192. hard restart at gas station, evap purge problem?
  193. D- series swap Questions!
  194. JDM B18c 98+ Spec Emissions in AZ
  195. J32A2 Swap Tach/Speedo Question
  196. iat sensor plug different
  197. 1992 Civic GSR Swap Tach Not Working
  198. Ek b swap exhaust
  199. 94 H22 into 99 EJ9(EK)-Wont Start:(
  200. CB7 H22 swap with MT swap
  201. swap f22 to f20b
  202. Need help to identify JDM D15B
  203. What would you do??
  204. H22A Into EK Shell Stutter & EML flash
  205. EK J-series mount question
  206. Crank, no start ek civic problem
  207. B18b in 2000 civic ex no start
  208. Few simple questions.
  209. Engine swap
  210. f20b EK Limp Mode (CKF Sensor?)
  211. GM 3800 V6(L36) into 95 Civic
  212. Obd1 harness and obd2 engine
  213. Is it possible to swap a D17 Engine into an ED9 CRX Chassis? If so, how?
  214. B16A2 with PR4/LS rods CTR pistons
  215. ZC cam help!
  216. K20z1 into eg I need help wiring my engine and ecu
  217. EK F20b Fires but doesn't run
  218. em1 carbon fiber
  219. H2b da9 hood pics
  220. engine upgrade
  221. EK F20b Swap
  222. 1990 Civic SI with D16A8
  223. Mini-me's and wannabe's and lower compression in 2018
  224. EF B20 Vtec Innovative Mount gap, driver side
  225. '99 Civic hatchback G23 swap Rad
  226. Sacrifice's K20 DA9 Build
  227. SWAP Civic Coupe 1998 D16Y8 V-TEC TO K20
  228. Completing ECU and DASH to engine harness (GSR)
  229. low compression b18c/b16
  230. wher is the fuel pump fuse located ? How do you identify it ?
  231. H22A7 Swap Honda Prelude BB9
  232. Is this a legit B18C or a ls/vtec ?
  233. H2B H22A w/F22 crank main seal oil leak
  234. 98 Honda Wont Revv Past 4k
  235. Diesel FWD transmission onto an F20C engine...
  236. b20v cylinder 1 misfire help
  237. Need info
  238. b20v high idle and will get stuck
  239. B20Z Swap Harness Troubles
  240. Is it possible to swap the internals of the D16A8 into a D16A9
  241. D16Y8 in EG swap, VTEC not working
  242. Accord V6 6MT ---> EG Civic J swap?
  243. D16y7 engine swap from D13
  244. questions on building a "g23"
  245. Swapping B18B1 into '99 LX
  246. B20B swap questions.
  247. Will d16 fpr work on b18
  248. Engine swap possibilities for a 2005 Chevy Classic (2.2 litre)possib
  249. H22 Auto in a 5 speed Accord body
  250. J swap no spark
