PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. ITR buildup
  2. I done a few swaps for friends and now people want to pay me.
  3. type r 5 lug into my 94 ls???
  4. Any K20 90-93 integras here?
  5. Early redline on a b18c...
  6. 2002 civic si. K20=OBDI OBDII OBDIII?
  7. 1978 Civic Hybrid?
  8. D16z6 swap
  9. poor mans type r
  10. ECU problems...Will Pay Big bucks
  11. Went junkyarding today. Good news!! Some questions
  12. Wanted: Street mechanic who can help me to install engine.
  13. j30a into ej
  14. were did you get you motor from
  15. which motor mounts? for ek civic?`
  16. 92 Civic Si swapping B16A3 please help
  17. Just recieved my swap from Import Auto Salvage - The Pictures Speak for Themselves!
  18. can i run obd0 injectors in my obd1 car? and how do i tell what obd the injectors are?
  19. last code!.. EVAP
  20. no vss would that cause limp mode?
  21. Post your B20 Problems...2 answer my questions.THANKS
  22. Crx Suspention Question
  23. b18c1 1989 crx hf couple of problems Idles good but tryign to drive it dies/ fan wont come on
  24. ctr suspension
  25. hey let me know?
  26. What will I need for a D-Series swap into my EG?
  27. b16 swap help!
  28. any reliable shop to do the swap
  29. b16a swap w/continuing probs
  30. std hatch with crx hubs
  31. b20/vtec dyno sheet
  32. b18c turbo in 02 civic in New Orleans
  33. did not clay motor...
  34. tranny identification
  35. Any fitment issues with a World Sport Exhaust on a swapped EG hatch?
  36. Motor/parts sites
  37. B20vtec problem fixed/new question
  38. obd2 itr swap into obd1 hatch.... what harness?
  39. ATS FD 4.9
  40. h22 crx motor mounts
  41. What would be the best oem piston in a Gsr for boost. That will fit Gsr rods.
  42. k20 swap eh2
  43. Knock Sensor ?
  44. getting pars for a h22 into a 94 eg .. please help me!
  45. 36mm ITR axle probs - the dyslexic version
  46. Can I run an OBD-1 p13 ecu with my current fuel injectors??
  47. would a B16B type R fit in to a 94 sol
  48. dosen't freakin' idle!
  49. Can I make my engine swap street legal?
  50. trying to make my own wiring harness
  51. 2001 H22a4 into 95 Accord with p28 ecu
  52. what can i use from my h23 on my new h22
  53. jdm d15b -> 90 DX hatch Some easy questions
  54. Idle Surge Problem on my H22 EG---please help!!!!
  55. 3rd gen si v8
  56. OBD1 to OBD0 conv. Harness ??????
  57. OBD2 GSR motor into OBD1 LS car
  58. is this what you guys did with you fPR and what ever this sensor is?
  59. oil pressure problem with my zc
  60. WTF HAPPEN? WOKED UP AND THIS!?? (not another missing R motor!)
  61. Someone please pimp-smack me with a link...
  62. JDM b16 OBD0 in 92 CX hatch not starting
  63. Belt question...K20a2 w/ep3 p/s idler and no a/c
  64. bypassing IAC and fast idle thermo valve.....
  65. Cant figure out whats wrong
  66. Uberdata tuners in NJ, NY? I need ya!!!
  67. B18B into 2K EX
  68. Different Idle problem - No vac leak. Is it PA sensor related?
  69. what parts needed for a swap
  70. H22A Civic cv boot tearing problems, Help!
  71. SWAP!!!
  72. Mating a y8 tranny to d16z6
  73. CRX h22 ECU question??
  74. Need Wiring Diagram For b16a3 95 Del Sol ECU
  75. host pic help!
  76. ls/vtec clearance issues?
  77. B18Cr with constrictive intake??
  78. im curios about what s faster an 91 LS integra motor or a 93 sohc vtec motor
  79. question about b16 into a eg
  80. H22A EG Mods Part 3
  81. ZC from EF to EG
  82. I NEED HELP I CNT GET MY AXLES IN MY LSD TRANNY
  83. ls/vtec tech help
  84. b18c1 crx hf engine is in and car wont start just keeps cranking....thermo ground?
  85. Vtec and ecu question!
  86. ? For those who have converted to OBD 1....
  87. EG/EKs (with swaps) timeslips
  88. trouble finding spark plug wires
  89. ls tranny on ls vtec
  90. MY Hybrid post (b17a1)
  91. B18a1 & B18A1 Is There A Difference?
  92. OBD2 B20 Distributor ----> OBD2 JDM GSR
  93. b18b in my ek coupe questions...idle issues and seems very noisy.
  94. where can i buy a ls
  95. APEXI VAFC VS HONDATA
  96. Best Swap for civic ex '98
  97. prelude 5 lug on civic...... is it possible?
  98. Maintenance Required LIGHT IS ON
  99. 2000 ITR into '98 EK?
  100. Alternator Clearance with a B18C5 in a CRX
  101. Please, please help, got an issue on a sohc swap
  102. question about injector type on d16z6 crx
  103. question about injector type on d16z6 crx
  104. D15B Vtec Turbo
  105. B18A1 Crank bearings.
  106. V8 IN CRX VIDEO!!!!
  107. B18 In Eg6 Pics Soon
  108. complete swap or just motor and tranny? crx si
  109. CHEVY 350 INTO 3RD GEN Si
  110. B18C into EJ1
  111. HELP! Few Problems With B18a1
  112. obd2 - obd1 ls block differences??
  113. B16B Civic
  114. B16B Civic
  115. smog check in tx sucks
  116. Swap 95 obd - 1 into 96 obd 2
  117. What are my options? h22 into euro chassis CRX
  118. extra plugs after swap
  119. Wooohoooo, installed EuroR IM!!!
  120. My engine died is dead...What's a good swap?
  121. jdm k20 into dc2 for $9999
  122. Fuel pressure help on H22/Civic!!!!
  123. sirII into 94 civic ex
  124. which car engine is 3inch in diameter?
  125. when doin lsvtec how many dowel pins do you need?
  126. Endyne
  127. B16A2 swap w/gsr tranny grinding in hi RPM Y?
  128. Kermit overdosed on K20A
  129. B16a Swap.. IAT Sensor Question.
  130. H22 shifter... HELP
  131. Knock sensor LS-VTEC (searched)
  132. K20-EG shifter question(s)...
  133. b16a2 ek vtec problem
  134. IACV d16z6 difference
  135. help!!! type R teg motor swap into a 99 gsr..wont start
  136. JDM B16A Obd0 converting to Obd1 need help with distributor
  137. 00 ls motor goin into 97 civic ex... which ECU to use??
  138. Tranny question for my B18B1 swap
  139. LS/VTEC HELP!
  140. H22a help!!!!
  141. b20 vtec?
  142. H22 Civic Mods/Part 2
  143. H22A / EG guys: possible to use 97 lude midshaft w/teg (custom) axles?
  144. HEPL ME URGENT B16 HEAD IN B20 BLOCK
  145. Engine Code location on block (i searched)
  146. DYNO for a h22a in a 90 accord
  147. missing plug on throttle body
  148. How to fix ecu immoblizer in 2001 GSR without removing it
  149. lsvtec question
  150. adjust throttle cabel????stupid stupid question hehe
  151. LS/VTEC issues
  152. swap dash?
  153. can you revers the fuel line ??
  154. what valves do i have? help me out
  155. what does a b17 come out of
  156. B20 Vtec for sale.... Full swap
  157. b18c1 problems please help!!!!!!!!!!!!!
  158. F20C/F22C in a Miata?
  159. 90 accord..h22 wont catch gas???
  160. needing some help on a b16a swap into a 97 civic ex
  161. eg h22 ...h22 vs f22 tranny
  162. question for people with eg/del sol h22 swap
  163. Question for VA H-Ters w/ swaps
  164. CTR LCAs in a DC4
  165. hey i need help on a civic motor swap
  166. Best stock intake and exhaust setup for H22 EK Civic
  167. RWD K20A conversion (56 k be patient)
  168. Help me out here swap ?
  169. LS/Vtec Fuel Injector ?
  170. Need Help Please Stock D series 5 speed tranny swap.
  171. Stock AIr Box for my JDM B18C swap in a EG
  172. What do you think about this swap quote I got?
  173. OBD2b D16Y7 ?'s
  174. OBD2 motor not starting in OBD1 car
  175. VX harness on B series?
  176. H22 Swap In EG - Problem with interior Console PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  177. H22 hesitation @ about 2200-3000 rpm's
  178. crank fluctuation sensor
  179. b20vtec
  180. How to Tell Prop Valve Size?
  181. LSVTEC + VSS CEL = NO VTEC= HELP ME PLEASE :0(
  182. gettin ready to start up my b20
  183. 99 B16B (CTR) Engine / 96-98 EX Engine Harness / into 96 EK Hatch Swap Question
  184. type s cams valve lash
  185. Golden Eagel VTEC adapter plate Fitment ??
  186. anyone knows how to do uberdata in Sac or Nor Cal???
  187. whats the deal with CHP???
  188. H22 EG header... AN-R or Imagine Engineering
  189. Driveaxle problem... Please help..
  190. need help rewiring vtec switch...
  191. z6 tranny, vtec head and mani on stock y7 block
  192. b20b into 91 civic hb
  193. Setting up climate with dash conversion
  194. Bseries swap, the pieces are coming together...
  195. need motor!
  196. Help.. JDM D15 VTEC in VX
  197. B20vtec what axles and intermediate shaft?
  198. 92 CX Hatch Weight
  199. need someone who has a obd1 swap in a EF
  200. Vac. on b18a Crx?
  201. stupid ppl in lude forums
  202. d15b swap , better than d16y8 swap
  203. ECU in H22A EG
  204. H22 ECU???
  205. code 43???fuel supply system??95 teg gsr B20
  206. b16a2 in eg what power steering hose?
  207. Questions of H22A4 in to 99 Civic CX, Please Help me...
  208. RSX-S hub/brakes on a EK/EG?
  209. Pics of my swap
  210. b16a3 in 92 vx
  211. 93 CIVIC IDEAS
  212. Ls motor in 97dx
  213. :any D series into a 84-87 Si hatch???:
  214. B20Vtec question on dowel pins
  215. Car didn't pass emissions test, any suggestions??
  216. I NEED A NEW TRANNY
  217. anyone know if the gsr fuel line is longer than the stock b16 fuel line
  218. Cable Trans. Syncros vs. Hydro Trans. Syncros
  219. can someone measure the fuel line from fuel filter to fuel rail on a gsr for me the length
  220. is your h22 swap a gas hog
  221. K20a3 swap question(s)
  222. k series motor in a eg
  223. h22a axles in 99 civic
  224. Need help with vacuum on OBD-1 GS integra with OBD-1 B16A swap.
  225. B20 integ NEED HELP
  226. Integra brakes into 93VX, what stainless lines?
  227. B16 into 86 CRX, axle question
  228. H22 ECU question, Does anyone know this?
  229. power steering on B17A Del Sol
  230. what head gasket should i go with b18b
  231. POWER STEERING in the VX
  232. Have to get ifo on B18c5 into Lude
  233. B18b to b18a
  234. Buy civic eg hatch and swap k20a or modify 05 RSX??
  235. Which engine harness for 97 civic dx motor swap into a 94dx EG?
  236. which axles? please help!
  237. H22 Swap: DETAILED instructions on shaving Prelude driver's side mount to fit?
  238. 94b18c1 into 92vx...no vtec ???HELP!!!!!!!!!!!!!
  239. 4th mount for EK
  240. verry strange no start after swapping stock motor back in
  241. B18 manual cable tranny axles into '91 CRX SI
  242. turbo ????????????? D15B (non vtec)
  243. Has anybody already done this D16ZC in an EB1... ?
  244. Evo engine
  245. Hybrid-Racing site back up!!!
  246. NO FUEL PRESSURE.......B18c into 92 EG..........
  247. 96 b18b auto in a 99 civic body
  248. Ugh . . . did I punch a valve?
  249. The ECU challenge question of the day.
  250. b16a pr3 ecu or pwo ?
