View Full Version : Hybrid / Engine Swaps
- b20 in 00' gsr?
- F20C into a 85 hatchback
- B18C EK (97 ) swap, alternator plug issue. 3 wire to 4 wire.
- 3 stage VTEC D15B into a 96+
- D16 into 86 Civic
- acceleration issues b series
- K20 civic?
- Couple questions
- d seireis trans
- TD22 OBD0 B16 IGNITION COIL
- Hasport Press Release - K-Series mounts for 92-96 Prelude
- LS/V conversion
- 2-post or 3-post motor mount?
- f20b compression readings
- k20 heads
- 98 civic CAI with gsr swap
- Old school engine swap will it work?
- b18c1 w/p73 manifold. idle bounce
- 97 hatch with gsr
- Hybrid f20a+f20b?
- B and D series dizzy question
- ek mount questions
- H2b h23a vtec crank pulley clearance??
- LS/vtec Troubles!!!!
- can you use a h23 block for an h2bsetup
- Quick question
- d16z6 block with d16y8 head......in EF?!
- D series Distributors
- smelling engine oil burn bad ?
- Idle Issues with GSR in EK w/Type R Intake Mani.
- Can a stock GSR valvetrain handle 8800RPM??
- dsm injectors on d16
- D16y8 to d16a6
- ls motor is crx, wiring questions?
- k20 gas mileage
- H22 INTO EK HATCH STILL GOT SOME ?'S
- How do I know if my Y1 is a lsd or not?
- Wiring my 2 o2 senors on my B16?
- f20b stock dyno
- obd1 integra harness in a civic
- Need advice on best Engine Fit
- Swapping Motor/ Exhaust Q's. (B18C EJ8)
- K20A2 question, please help me!
- LS Stock Ex. Manifold fit B18c/b16
- HELP- b18 wiring question
- I'm NooB~~!! Have question on H22 civic
- SiR2 timing belt, which one?
- ECU question
- couple problems after swap??
- What ECU Came in the 96-98 Civic SiR?
- OBD1 B16 in to 98 civic problems
- hmmm......
- Need Help Identifying these parts/components.. thanks
- temper mental b18c5 coupe
- Stock97 Civic DX Fuel Line to Fuel Rail Dont Fit
- Which transmission for H2B build?
- Axles for 99 GSR b18c1 in a 1996 civic hatch?
- Hey someone told me that I cant use these injectors but car is running sweet.
- DSM 450cc injectors, OBD1 Prelude Resistor box, in a civic...PnP?
- JDM B20b - won't start - what am i missing?
- Bought a swapped EG.... no o2 sensor????
- Crower vs Skunk 2
- Will stock ls pistons work for a ls/vtec turbo build
- B18 help!!
- b16 swap blowing main relays?? obd2 in obd1 car???
- Engine bay/firewall parts removal before b18 swap
- Measure the width of your rack for me? DC, EG etc guys please >need to match EF8 part
- 1991 integra engine/Trany in a jdm B16 Equiped ef9, what is Needed??
- h22 ecu question!
- h22 swap kit help?
- JDM ITR motor into GSR..LS wiring harness need help
- Unsolved Mysteries: '94 GS-R in '94 Civic
- h22 motor in a 92 teg???
- need help. obd2b to obd1 convertion.
- Is my DX radiator too small to flow a B18C??
- h22 going into my integra, questions before i decide on this?
- Hasport Hybrid Axles Install
- i want to BAR LEGAL A GSR/ITR IN MY EM1. REF
- Electronic/Mechanical VSS Interchangability
- What ecu do I need for my B16 to pass smog ?
- going from b16/b20 to other b series. Conflicts?
- 1994-97 Del Sol b16 vtec ecu?
- custom wiring h22 into cx hatch.
- will k20 fit in del sol.......
- h22 h23 swap is frustrating
- vx with d16z6 o2 question
- ls/vtec swap
- h22 eg linkage HELP!
- Computer on a 91 integra and computer of a J-spec B16a
- 2 O2 sensors on a B16?
- Does anyone have a "How to" guide for an H22a turbo swap on an EF civic?
- Trans swap question.
- f20b tranny?
- b18c sluggish behavior
- questions for h22 or h23 swap to f22b block and ecu
- I need some injector help for my B18C (what size)
- b18a1 into a eg axels ????
- Upper radiator hose for B18C5 EK?
- Main relay fuse keeps blowing.
- 2point6's CB7 going K24
- ~~94-up teg coupe exhuast, fit a EG sedan?~~
- Where does it go????
- anyone swap a regular auto in place of a CVT?
- o2 sensor clip is broke!
- MY VTEC NOW WORKS!!!!!!!!!!!!!!!!!!!! h22 hatch
- Alternator compatibility? I mean the insides...
- ls vtec problem
- JDM & USDM h22a tune up parts the same?
- k24 for 95 accord
- what obd do i have
- got bad work done to my car. need help!!
- H22 INTO AN EF! WONT START!
- D16Z to B16A Sir II
- BAR LEGAL QUESTION
- boosting an ef h22
- H22?'s EG axles to Ek hatch Need help!
- Can't Believe I'm Posting - Euro R w/H2B, or K20A2/Z/R to replace B18C5 Swap?
- Best write up for tranny change ?
- Dumb question on 02 sensor about b18c5 into civic.
- b16 engine mounts
- h22 b18?
- No power on b18c
- SWAP PROBLEM
- one arp head stud wont go all the way down
- any h2b kit 1/4 times and in what carz/setups
- h22 crank pulley
- h23a or f20b in 6th gen accord?
- My JAYDM F20c + ae86 swap *56k ..see you in 08'
- kseries question help anyone
- kseries owners help anyone thanks
- clearance issues with h22 skunk2 pro intake manifold in 96 hatch
- will these pistons work?
- e85 conversion with a b18 and boost
- b20 with b17 crank....Possible?
- h22 head, k20 block?
- h2b with out a adapter plate(This is for u do it yourselfers)
- another mini me question(searched)
- swap labor concern
- New swap (B18c-type R) bad sputtering/bogging/safe mod
- rpm tack problem
- B16c1 engine ito a 00 civic dx (D16y7) HELPPPPPPPP
- H22 EM1 front end shake under load
- which axles are these
- injector question, confused (re: obd0/1/2 connectors), thanks.
- EF swap speedo question
- HELP:Weak Vtec crossover in H22a
- Hybrid Element in the plans? Fuel Cell Trailers?
- very FIRST LSVTEC build
- ****Need Help please!!!!! B18C1 GSR swap into 97 EK running PCT ECU bogging and backfire******
- still no vtec, please help me out guys
- Alternator Q's
- aftermarket clutches??
- quick b18 question, need answered kinda quick
- ZC in an EG
- engine Legit?
- o2 sensor
- b18b into 1998 crv, crank position sensor code (no signal)
- HELP! B18C in 99 em1 check engine light on
- d15b2 block, d16z6 head mini me questions
- Car has a B18 ref sticker...can i go back to D16 ?????
- a question???
- MASSIVE D16Y8 Head Onto D15B7/8 Block MiniMe Swap Writeup!!!
- H22 build QUESTION
- B18c Engine harness on ek?
- WTB S2000 2004
- d16y7 block and y8 head
- RWD Conversion
- Gangsta Lean H2B
- b18 half shaft help
- CRX B16 alternator belt replacement....Help!!!
- will my axles do???
- integra break conversion on an eg help
- Which Bypass Valve for AEM Hybrid 92-95 EG
- stock B20B intake manifold fits in civic?
- knuckles: 2000 Civic Si vs. 1996 Integra
- why is honda-tech filled with ricer pussies?
- b16a2 in 97 ex coupe with CEL code 9
- H22A Euro R miss in certain RPM Help!
- throttle cable too long
- CRX b16 pcv black box leaking.......solution to eliminating it???????
- exhaust question for k20a2 swap in ek chassis.
- 00 b20z in 91 si hatch falls flat on face when punched
- f22 in 95 dx coupe
- b20 with b16head
- What kind of numbers are LS Vtec's makin???
- d15b block, d16y8 head, mini me
- 3 questions i need to be answered
- b18a1 into 93 civic cx with b16a swap
- b16a2 swap in a 96 civic ex
- fuel tank pressure sensor?
- SpoonEk253 Please Respond
- Cant find a straight forward answer for my question...
- best exhaust for k20a2. ek chassis.
- Daily driver dc2, h2b swap, QSD or Evo kit?
- So after reading tons and tons of posts I believe I figured out what swap I am going to do... commen
- not sure if this belongs here...obd2 alt in obd1 car???
- where's a good place to buy a motor?
- WRX POWERED CIVIC SI
- 1988 crx hf d16zc
- HELP!! h22 swap NO vtec
- b20 vtec or ls vtec?
- '93 b18a into a 92 civic
- Car not starting..electrical issue
- H23 / H22 Swap
- H23 rotating assembly in H22
- D16Y8...
- H22A in my EK bouncing out of VTEC w/CEL and Limp Mode
- B16 mani to SKUNK2 manifold.........questions
- BS removal on h2b
- H2B wiring harness
- Am I hydro or cable? should be quick answer, please help
- ATTENTION "6SPD_EK" PLEASE RESPOND
- LS Swap...Need Help..
- h2b how big is too big
- ?? ls/tech line
- Interior Swaps
- F-series hybrid theory N/A build
- ecu questions for h22 in 95 civic dx
- DC integra k swap?
- h2b swap questions
- OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched
- H2B solution
- "Extreme Help Needed on H23A Please"
- LS engine Swap..Need Help
- Your perfect k24 build
- Can't remember the webiste, they do obd conversion harnesses and swap conversions.
- swapin out my b18b for a b18c1
- H2B questions
- Will a 96 JDM ITR Swap pass smog?
- confussssssssssssed h2b or k24/k20
- Just got my car back
- cable tranny part numbers
- K20/K24 '02 CR-V headswap?
- vafc question
- Shift linkage??
- n00b CA BAR/smog question
- what ecu's are you H2B guys running?
- h22a euro r
- h2b adapter
- Does anyone know where i can get a TPS sensor for a H22?
- H22 can fit in what cars?
- B swap question
- Will A 95 B18C Exhaust Manifold Bolt up to A 00 Civic EX?
- H2B & F2B picture & video thread!
- K24 All-Motor with APIDAdromics valve timing
- what gas octane to use on jdm h22a
- K20 Swap question
- Which header for h2b swap with QSD kit?
- B20z vtec asseble problem! please help
- 98 spec JDM ITR wiring question....
