PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. need help with my v-tec wiring GSR (pics inside)
  2. what power steering set up
  3. need pics of h22 shifter cables in ek mostly where it bolts to the tranny already did search.
  4. B20 VTEC 94 Hatch
  5. B16a2 motor mounts which one???
  6. Swap shops in northwest
  7. PR3 Automatic ECU Chip/Modification
  8. d16y7 to d16z6 swap
  9. Euro-r h22 into EG - wiring question - opinions required
  10. Obd1 motor into obd2 car...
  11. just did swap, shifter moves side to side in gear??
  12. Finished my swap today... car ran...well sorta
  13. started swap today help with idle issue thank you.
  14. what b16a to get for my crx swap?
  15. which ecu to use? ( mini me swap)
  16. p28 chipped vs p72
  17. I'm a newbie..I need help???
  18. Few problems after my swap
  19. :fuel cutting off way before redline?? b20z in EG
  20. losing 1 quart of oil after swap?
  21. PR4 rod question.
  22. OBD 1 ecu pin outs for iacv,help!!
  23. Poor Man Type-R
  24. 2000 civic si ecu- on 99 ITR swap? good? bad? should or shouldnt do?
  25. need help terrible
  26. HELP! 2001 Civic Si-R swap! >>LOOK<<
  27. Please give some help h22 civic swap
  28. B18C 94-97 (GSR)
  29. b16a3 into 92 cx
  30. Clearance Measurement Please
  31. someone rigged this harness. 99 itr swap to 98 ek help me... please
  32. Evap Purge Control Solenoid Valve
  33. k20a drop into a Toyota MR Spyder
  34. vtec crossover
  35. Iab problem-Gsr swap
  36. ARP HEADSTUDS - MANUFACTURING DEFECT?????
  37. odb 2 to obd 1 HELP!!!!
  38. LS into a 95 ex
  39. sohc NON vtec head swap NEED HELP PLEASE
  40. need help with a swap
  41. Need help! (F20B Swap)
  42. Fuel Tank Pressure Sensor FTP CEL 90 in EK 96-00 Civic
  43. Need Help Problem On B16 Swap
  44. k series engine into del sol.
  45. check engine light question
  46. G23 ?s alot of questions.
  47. help with axles
  48. WTB: ODB1 GSR Computer
  49. H22 runs like poopy. It bairly runs.
  50. K series or B series?
  51. would a....
  52. h22 advantages and disadvantages
  53. What should I be running with this setup?
  54. HARNESS QUESTION- PLEEEASE HELP!
  55. B16B IACV same as B18c5?
  56. what belt/pulley setups are you guys using for your k20 swaps????
  57. b18c5 in an EK????? BAR questions
  58. b18a1 turbo build up
  59. What serpentine belt fits on a K20A2 without a/c ??
  60. h22 ac question... help
  61. CAR WILL NOT START
  62. h22 in the car today looks like sh#$% usiing hcp mounts...
  63. d16y7
  64. h22a hatch wont start(obd1 h22a ek)
  65. obd2 dizzy crap
  66. correct plug gap for b16a
  67. ZC head swap
  68. k20a2 em1 swap
  69. d16w/vtec swap will not start and dont know what else to do. PLEASE HELP!!!!!!
  70. My Ls/vtec build...I need help on parts list to get.
  71. JDM D15 VTEC swap CUMMON! SOMEONE ANSWER ME PLS!
  72. changing a motor in a CRV
  73. My B18c in a 92 Hatch Wiring: Please double check me!
  74. somebody help me out... i've been searching and about to kill myself.
  75. anyone have a B20 head gasket laying around?
  76. K20 swap arguement. Somebody set me straight:
  77. replacing IAB tank
  78. b20 vtec ?
  79. Wheel bearings and ball joints
  80. NSX suspension
  81. b16a in 5th gen civic....shift linkage?????!!!!!
  82. b18c1 swap in 00 EX
  83. HELP axle popped out, LSD trans, HELP!!!
  84. B18 tranny questions
  85. b02 with gsr head
  86. B18B1 SWAP INTO A 93 CIVIC LX
  87. wiring diagrahm
  88. b18c1 in 92 cx using civic harness
  89. Need new bettery for my new swap!
  90. H22 Vibration & idling
  91. B18C1 in del sol?, need some tips for the swap
  92. H22 Euro R Intermediate Shaft, for EG
  93. LS swap in my 93 ex
  94. how to covert VX 5 wire o2 sensor to work with a 4 wire o2 sensor
  95. NEED SERIOUS WIRING HELP NOW!!!!!
  96. h22 swap with A/C
  97. Anyone heard of an iron block F-series block with H-series head and tranny?
  98. b16 problems SOMEONE PLEASE HELP!!
  99. how to tell what ecu i have?
  100. B18c hatch?
  101. h22 into eg help!
  102. OBD2 swap into eg questions??
  103. throttle cable and bracket
  104. boost @ 10psi good injectors
  105. h22 timing ? please help this is the only thing i need to get up and running.
  106. whats wrong with my tranny? pics!
  107. H22 integra axle ?
  108. straight up best h22 header ground clearance, pics.
  109. Middle of B-Series Swap along w/ Auto-5spd Conversion...Have some questions
  110. b20 swap question...
  111. Question: ECU's
  112. 89 cx hatch jdm d15vtec swap. ECU question. possible to use the stock one??
  113. i like to know..!!!
  114. ek4 project need some help b18c5 vs. h22a????
  115. auto to maual... help me out!!!
  116. H22 crx thread H2B specific
  117. What is the best ECU for 98 civic /B20 swap?
  118. CRVTEC...cel 10, and vtec wont engage..please help!!!
  119. HELPPPP
  120. 2 Cylinders Sparking WTF
  121. h22 civic brakes problems?
  122. ls swap in 97 civic hx
  123. jdm ecu help
  124. JDM Front Clip Questions
  125. What SHORTY 3" intake to use for B18C1 EG w/ Victor X manifold?
  126. Swap Help!...(GSR in Accord)
  127. can a d15 non vtec wiring harness work with a b16 swap?
  128. H22 is acting GAY WTF??????????
  129. b16/b20 hybrid motor
  130. Want opinions on your d15 sohc vtec swaps
  131. TPS keeps throttle plate open?
  132. IACV question? HELP PLEASE!
  133. <<<<<<<<<STATE REF TICKET>>>>>>>>>>
  134. D shfter and b shifter help
  135. tranny adapter plates?
  136. Need help with engine serial #'s
  137. b18a1 in a 96 hatch searched
  138. motor swap question
  139. Driving Impressions: h22 EF's and eg's *owners chime in*
  140. CEL 22 - VTEC pressure valve? need help!
  141. Need help, EG with JDM gsr b18c..
  142. vtec pressure switch
  143. different IAB plug?
  144. keep cruise controll in ITR swap
  145. 99 civic with h22a1 HIGH REV when starting up??
  146. Using a p30 ecu on a GSR swap?? NEED INPUT
  147. Easy Question: What size is a OEM JDM GSR exhaust manifold flange? 2 1/4 or 2 1/2?
  148. Bought a 90 Integra W/ Turbo B18C MAJOR PROBLEMS NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!!
  149. where to get k20 motor swaps?
  150. obd1 b16 into ek
  151. NEED JDMB18C1 Help!!! OBD-2
  152. H22/EK intake question
  153. EK w/ b18b/b18c with skunk2 intake manifold - need to know what throttle cable to uses
  154. B18B INTO A VX HATCH WIRING QUESTION ***SEARCHED****
  155. wiring experts... what the hell are these wires for? help searched for a week~!
  156. i need help and advice!!!!
  157. got a integra parts car . what to take for swap for civic
  158. HCP mounts on civic ek dosent seem rite someone please help???
  159. Will a 1996 Civic EX, Cabin Wiring Harness work with a 1996 Integra LS?
  160. jdm itr swap into 96 ek what motor mounts
  161. H22 Civic guys, lets talk about trannys and master cylinders.
  162. how to tell the difference between obd1 and obd2 harness
  163. Help reading PR3 ECU Code
  164. b20 head and f22 bloc
  165. hydro trans in crx
  166. obd2 in crx
  167. Switching from Cable B16 Tranny to Hydro GSR Tranny, what is needed?
  168. Rear Brake conversion question...HELP!...pics
  169. B20 swap
  170. HELP! 97 gsr into 93 si
  171. GSR into EF
  172. help with a b20 swap
  173. S2000 Cluster Swap Wiring Guide
  174. screaming alternator
  175. axle problem
  176. Ls/vtec help~! NOT STARTING.
  177. iddle surge
  178. OBD1 Gsr in 99 EK Hatch
  179. HELP!! i might be going k-series on my ek9
  180. Obd1 motor into Obd2 car
  181. Difficulty rating of removing h22a's head while
  182. simple questions, im just not sure.
  183. ls/vtec in 93 hatch wiring ?s w/ PIC plz help
  184. eg h22
  185. CEL code 22 help....
  186. b16 tapped head
  187. What AC bracket to use for b16 swap in eg?(already search)
  188. these rods
  189. D15B2 with D16Y8 head...proper head studs/bolts?
  190. Have you heard of this happening?
  191. ZC Swap Wiring Help! (Pics included...)
  192. h22 swap into 98 civic o2 sensor quick question please help out thank you.
  193. For those of you owning B20Vtec's, I have a question????Please help???
  194. hasport h22 ef mounts
  195. hey does nayone have info about the shock towers in eg's
  196. CIVIC VTI ENGINE SWAP SOME HELP MUCH APPRECIATED (PROBLEMS)
  197. thinking bout h22 for da hatch
  198. H22 swap into EG... how much did you spend after everything?
  199. Type R swapped sol, Fuel Pressure questions
  200. Explicit Speed Performance H22A mounts - good or bad?
  201. running lean in vtec with jdm h22. please help
  202. Wiring Vtec for a b20vtec?!?!?
  203. No o2 sensors, Is that a problem?!?!?!
  204. starting my LS swap into 95 CX hatch, few questions.
  205. please help po mans r
  206. Wiring needed
  207. Skunk2 B18C5 Swap
  208. transmissoin swap done today have a quick ??????
  209. DA ingtion work in a eg coupe?
  210. LS/vtec BUild..???
  211. question on wiring up z6 into 97 dx?
  212. what distributor can i use for h22 swap
  213. which dizzy is obd1 has internal coil and will run a h22a4. i need to know b4 they tow!!
  214. Knock sensor and Iab location on h22
  215. GSR swap, emission line problems....
  216. Spoon K-series EG/EK mount kit
  217. need quick help dizzy problems and solid ecu code
  218. Which Clutch and Flywheel?
  219. ls/vtec question
  220. h22 in 96 ej8
  221. Looking for some info/help about a gsr b17a swap into a d16y8 98 2dr civic ex
  222. 95 JDM h22 into a 98sh prelude..what's stopping me?
  223. What mounts do i get if im swapping in a B16A2 in 92 civic VX HB
  224. Other Parts needed for putting B16A2 in 92 VX civic hb?
  225. running lean in vtec with jdm h22. please help
  226. h22 into ek distirbutor question almost done please help????
  227. How to eliminate Crank fluctiation Sensor
  228. Will 99 Si harness work for EG B16A swap, or do I have to get 97+ GSR harness?
  229. building a b20 frank...
  230. PARTS NEEDED FOR A K SERIES SWAP INTO AN EK
  231. gsr block b20 crank
  232. b18b1 into a 99 civic ex, crank position sensor trouble
  233. Question lsvtec
  234. Password 3PT ST Brace EG H22
  235. what do you prefer?
  236. H22 swap, mount not lining up! Plz help!
  237. ***Quick Question***** Swap Complete Need to do this one last thing*HELP!!
  238. Should I need a Main Girdle?
  239. sh-awd swap
  240. might be a crazy K series question but...
  241. running lean in vtec with jdm h22. please help
  242. h22 in 94 accord problems
  243. after i relaced the valve cover gasket with grommets......motor still sputters a bit
  244. help find this peice
  245. Type R head On 1st gen B16
  246. B16A; Integra xsi vs civic engine, what is the difference
  247. can anyone i dentify a transmission wia the barcode sticker number
  248. H22 head bolt on???
  249. Can I convert a Auto GSR ECU for Manual Tranny use?
  250. 90 Acura B16 trans install HELP!!!
