PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. B20 Swap in 95 Hatch (Tubo vs CR-Vtech)
  2. whats ur setup?
  3. ls swap question
  4. Is it worh it to put a b18a in a 98 civic?
  5. how to wre up the vtec wire on b20 vtec
  6. replacement mounts or inserts for Accord/H22 swap
  7. h22 swap...speed govenor bypass??
  8. b4 swap maintenance
  9. What OBD is this engine?
  10. LOOKING FOR 4-1 HEADER FOR MY PRELUDE ENGINE..THANKS
  11. swap into my ef help..............
  12. Just want to double check(motor mounts)
  13. crx si motor into dx(searched)
  14. 90-93 clutch cable into b16a rex.... Please help
  15. SWAP ISSUES...PLEASE HELP!!!!!
  16. How much extra power will i make with an Open Air box? factory eg DX box w/B18b
  17. H22 EG Enjo Mounts
  18. Need help finding the right Half Shaft..
  19. B20 into an EG...which ES motor mount inserts?
  20. swap problems
  21. B18a Crank
  22. H22 Ek Mounts
  23. Mugen Chipped p28 On h22???
  24. engine cranks but wont start NEED HELP PLEASE!!!!!!!!!!!!!
  25. h22 not running at potential
  26. OBD1 and OBD2 wiring harness
  27. Where to find thorough info on ITR swap (97-98) into DA?
  28. H22 92-95 civic weird driveshaft problem...
  29. put a b16 in my ek, now some loud ass noises from engine bay
  30. civic si-r/ del-tegra conversion
  31. Where do i add trans fluid to??????
  32. WHAT IS V-TEC?
  33. Brian G. It's APRIL where are the 92-95 K-series mounts?
  34. radiator help....
  35. exhaust question
  36. 89 integra D16A1 head to 88 CRX Hf Is it possible?
  37. HF Mini-Me Swap
  38. need write up of b16a1 swap into 91 civic si
  39. H22 EG Spring Rates Suggestions?
  40. H22a mounts: Hasport vs HCP. (Opinions)
  41. difference between a1 and s1 and ys1 tranny
  42. H22 EK Swap
  43. Enjo H22 Mounts
  44. please help the noob
  45. Skunk2 Manifold's fit in a H22 eg????
  46. PCV in B20?
  47. Thanks GroundZero!
  48. ill be rinning this on my k24... so sick
  49. b18a into eg...quick question!!!
  50. Review of Skunk2 Intake MAnifolds?
  51. what ecu are u running with a k20 eg swap?
  52. GS-R throttle cable/bracket; JDM or USDM ??
  53. Question about compatibility
  54. What LSD do i need guys?
  55. Engine Swap- Help me out guys!
  56. B16 block B18 head? WIll it work
  57. b16 idle surge
  58. Swapped out b16 in my 2000 si and put in fully built GSR now some things are acting up.
  59. B20B/Z into '88 CRX
  60. Strange power loss, need help.
  61. Tranny swap problem: When I put it in gear and press the throttle it will die or try to die.
  62. obd0 to obd1 dizzy wiring
  63. looking for NEW header info
  64. Big Brake Kit (not a normal question)
  65. ZC into 5th gen
  66. Finally Got it started, but ............ I get a code 22
  67. clutch release fork ....B-series and D-series the same?
  68. Another BADASS creation brought to you by K20EG's mounts......
  69. Is the crank trigger sensor necessary
  70. 1999 Acura GSR SWAP HELP
  71. 1/4 Time with a LS in a 90 hatch and a B16 trans?
  72. what is THE honda engine to use for a swap?
  73. just picked up some b20z pistons...but am curious...are they oversized?
  74. Anyone know what is the longest Honda flywheel bolt??
  75. p28 on a non vtec SOHC
  76. Run a OBD1 Dizzy with a OBD0 PR3 ECU??
  77. need help about getting bar sticker
  78. which ecu do i need
  79. ls/vtec head gasket rivets
  80. check engine light, but no code?
  81. Whats the difference between PR4 (obd1) and P74/75 Ecus?
  82. DA shocks in an EG
  83. b20 cams in a b18b
  84. 94 D-16z6 v-tec head to 96 D16y7 block into 94 ex
  85. H22 EG... Time For Some LIME
  86. brake swap si on ek
  87. 5 lug on 93 si?
  88. help: crx si harness into dx chasis
  89. Someone, anyone, help me out here! backfire through intake on b20vtec
  90. When Buying a used ENGINE
  91. CEL 20
  92. leakdown on k20a2
  93. Ran my h22 EK today. Et..........
  94. Swap aftermath...idle problems, throwing code 7, no VTEC
  95. converting my eg to cable
  96. B16a1 head onto a GSR Block/TYpeR Block????
  97. Raxles? Any experiences....
  98. d15b vtec into a Canadian civic vx
  99. torque specs on arp head bolts?
  100. upgrade master cylinder w/ rear disc swap?
  101. ZC in a 5th gen
  102. Anyone in here still reprogram ECU's?
  103. 98 EX to 99 Si Conversion
  104. Can i put my B18C main girddle into a B20B???
  105. i need help and yes i already tried too search
  106. My setup, My problem
  107. b16 oil pan into a 96 gsr
  108. b20 vtec into a 98 dx (confirmation)
  109. LS/VTEC assembly
  110. Pics of the h22 swap, 1/8 mile times, and VIDEOS!
  111. element block ep head?
  112. 92 h22 hcp mounts?
  113. h22 turbo a/c ek?
  114. Anyway to have AC on an H22 swapped EG?
  115. Can OBD2 be reflashed to OBD1 and what ECUs to run H22A?
  116. Looking for a part number
  117. OBD1 b18a to OBD1 B18c question
  118. B16a built from scratch swap into 96 civic ex
  119. Gauge cluster swap for 92-95 civic with GSR
  120. Whats better to use GSR Head or SI Head??
  121. wheels spin when vtec engages
  122. help me please huge problem....
  123. B18b intake manifolds
  124. vtec my 91 dx?
  125. *96-01 LS CRV Distributor Plug, what is the difference?
  126. JDM or EDM
  127. can i put b16 gears into a gsr tranny?
  128. b16a2 into 93 del sol, help please
  129. crx resistor box for h22?
  130. D series vs. B16a1 Intake manifold
  131. Wiring harness
  132. 88-91 b16 please help with o2 sensors question?
  133. B and D series distributor compatibility?
  134. Advice on b20/vtec route
  135. 1 to 4 wire o2 sensor
  136. B16 Header question?
  137. rpm switch to control vtec?
  138. JDM Sir EG rotor size?
  139. 1/4 mile time on gsr in a 6th gen
  140. chipped p28 problems
  141. H22 Supercharged fitment question *eg*
  142. b16 and b18 dizzy question
  143. Wiring help for lsvtec in 92 vx
  144. A little swap help . .
  145. What cars would an s2000 engine fit in besides a s2000?
  146. Why is my civic b16a2 swap hard to start
  147. did a b series swap in my ek but i need a powersteering pump bracket?? which one??
  148. DA and B18B swap question
  149. CRX swap nightmare
  150. B18C Spec-R/B18C5 into '98 civic HX...in need of experienced advice on extensive questions.....HELP
  151. h22 swap finished....few questions
  152. obd1 LS swap in obd2 sohc car. . . . what do i need to change LOOK inside
  153. smoking LS
  154. '98 Civic Hatchback - Swap with what?
  155. what header clears ac in an h22 eg ?
  156. Please help,vtec problem
  157. type r into g2 integra, need info
  158. swapping prelude brakes to a Eg
  159. Does any1 have a suggestion for a new engine for my civic
  160. 89 civic automatic dpfi to mpfi help please
  161. Like a Misfire under 3000 RPM ????
  162. b18 for sale
  163. HELP.....H22 idle problem.........
  164. RB powered S2000
  165. itr tranny price
  166. Are all halfshafts the same?
  167. need help please
  168. halfshafts?
  169. Inspection ???
  170. wiring problems
  171. anyone in Nj who knows what they are doing wanna do a swap for cheap??
  172. b16 swap question
  173. Kseries into a 1996-1998 EK
  174. Throwing code help please
  175. h22 tranny rpm/speed
  176. 1992 CX/jdm d15b
  177. ls in a crx throwing code 5 map sens.
  178. h22 in 89 civic 4dr or hatch?
  179. CEL but no code, No VTEC
  180. My H22 civic pix!
  181. 01 B18C5 into 99EK Immobilizer suggestions please
  182. ecu question
  183. K24 into DC2
  184. B18C1 into a 99 Civic DX: LAST QUESTION! Help!
  185. 94 JDM H22a into 97 (obd 2) Accord Questions. NEED HELP ASAP.
  186. SiR LSD into GSR tranny ?
  187. OPINION PLEASE
  188. Si or SiR fuel pump for my GSR swap ?
  189. Need Help: code 41 in 94 cx w/jdm b16
  190. Power LOSSSSS
  191. long and short blocks
  192. Wire size for b18c (knock, Vtec, etc)
  193. question about timing and gas milage
  194. code 54, obd1 engine obd2 ecu
  195. Ls B18a to B16a Vtec swap
  196. Changing from Place Racing H22 mounts to Hasport mounts
  197. ITR Header.
  198. H22 into EG w/ integra axles
  199. vtec = no power
  200. can someone do a complete write up of B16a1 into 1991 civic si??
  201. Vacume/Map Hoses
  202. New to Forum.... Seeking Tranny
  203. what to expect with this setup...
  204. B18C1 into a 99 Civic
  205. need help with typeS head on crv block
  206. Distributor & EGR wiring. Plz Help
  207. Clutch Cable fits but......
  208. piston ring question?
  209. JDM B20?
  210. ep3 head stud torque?
  211. 's i need your opinion/knowledge.
  212. S1 axle/tranny Seal
  213. b16b 1/4 mile times!
  214. Putting VTEC head on b20z
  215. sending out an S.O.S
  216. B20B w/ Vtec swap help!
  217. obd 0 b16 in eg help wiring
  218. Draft:MIA Screw please Help.
  219. distributer for a B18C swap into a EG
  220. How to swap civic AC compressor onto integra?
  221. H22 Swap Done, Now The Questions
  222. Have you gotten your motrom from hmotorsonline, passwordjdm, or totaljdm?
  223. EG with b18c; O2 sensor installation problems???
  224. ls vtec swap complete........but vtec problems.
  225. d16y8 manual tranny on a d16y7 auto motor
  226. please critique these faq's
  227. B20A5 Vtec???
  228. What injectors? B16
  229. in Florida .. where is a good place to get a dyno at.... prefer somewhere in daytona
  230. What exhaust for a B18C5 in an EK hatch?
  231. 1992 Civic CX with a H23A DOHC VTEC Swap----->Exhaust Question...
  232. NO POWER ANYWHERE
  233. piston and rod used when putting prelude b20a crank inside of b16 block
  234. DOHC Del Sol VTEC Exhaust Manifold
  235. gsr intake manifold whistle verry loud
  236. Hybrid Transmission Plans: Anything else I need to do?
  237. more dpfi to mpfi issues
  238. my first DYNO
  239. obd0-obd1 conversion done, now i have codes 9,20,22
  240. A question about axles
  241. ls/vtec swap install question................
  242. ITR engine wiring harness on a GSR
  243. IAB Wiring A17 or A26?
  244. Is this an OBD1 or OBD2 ecu?
  245. p28 in 1989 CRX hf
  246. k20-r... smog legal?
  247. will need h 22 head
  248. zc sohc in to 5th gen dx
  249. differ types of B16s whats the differ
  250. 2000 b18c1 swap in a del sol
