PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. stick on side moldings
  2. gsr harness on b20 vtec????
  3. Info on trade?
  4. JDM ITR front help...
  5. D series tranny bolts fit B series?
  6. G23 questions.
  7. civic hatch 1997 B20B MT swapped wiring
  8. 97 ek hatchback
  9. 94 civic b17 final problems
  10. couple questions with my 96 ek with b18c1
  11. 00 jdm ITR header....
  12. 99 SI TURBO TYPE R SWAP WONT REV OVER 5000 RPMS
  13. Why dont more people build up F23 block and head?
  14. H22 or b16??
  15. H22 swap in EK OBD2
  16. 2 or 3 Bolt Post Mount for 97 B18c1 GSR into 97 Civic EJ8 Coupe
  17. b17 axles issue
  18. trans, axles and intermediate shaft ?'s
  19. h2b
  20. cr-v suspension on civic eg??
  21. Civic EG9, B16A2 to JDM B18C swap
  22. B17 Project just pictures.
  23. b17 motor mount issue
  24. 94 civic ls swap no fuel or spark
  25. DSM injectors OBD1 - Resistor box?
  26. jdm b18c5 head onto usdm b16a1block
  27. '99 Civic auto - options for increasing power?
  28. Obd2 to obd1 no spark question
  29. 95 civic dx jdm h22a swap
  30. Intermediate shaft differences?
  31. whitch axels?
  32. Motor Swap Help Plz!!!
  33. D16Y8 in DC2
  34. honda civic eg6 complete swap integra type r
  35. NEED HELP! please. b16b swap wiring help!
  36. good mounts for a h22a
  37. Can not get my 99 ex with b20 to start. Reaching out for help.
  38. B18c1 Revving 500 to 3500 cold start tryed almost everything I think????
  39. H22A to Civic EK, OBD1 or OBD2? HELP
  40. 98 Civic/B18 swap - Low RPM Stall CEL Light (!!!Need Urgent Help!!!)
  41. Best B series swap for everyday use
  42. auto to manual problems please help guys
  43. D16A6 With B16A vtec head
  44. NEED HELP!!!! no power to injectors
  45. 93 del sol questions
  46. Help
  47. OBD2 Immobilizer issue
  48. Problem
  49. b17 axles
  50. b20 in em1
  51. how to keep power steering in 96 hatch with b18c swap
  52. need wiring help
  53. b20 - Two center spark plug holes filled with water
  54. b18c1 wiring?
  55. D16a8 into '95 ex help.
  56. Unaligned transmission mount bolt
  57. 94 civic clutch cable diagram for b17
  58. JDM H22A START UP HELP!!!!!
  59. 97 sedan b18c typer bulid
  60. B18B in ej6 throttle cable question
  61. B18C into 99 EX (header rubbing oil pan)
  62. Future Plan Questions. Opinions wanted!
  63. B16 block with GSR head will it work???
  64. Throttle Cable
  65. B18 problems.
  66. I NEED HELP B18B1 ON CIVIC VTI EG9
  67. K24 EG Civic engine mounts?
  68. Question about ATTS when building H2B
  69. h22a cranking problem
  70. B18b1 or b18c1 help?
  71. B20ek speedo problems
  72. H2B EG SKUNK 2 APLHA TB PROBLEM
  73. B18B 2000 Civic Exhaust Question
  74. b17 swap 2 questions
  75. Poor man's type r questions.
  76. H23 swap, car chokes power after 3k rpm
  77. My First Car/1993 Honda Civic Si LS-V Build
  78. b18 into 96 civic
  79. h23a blue top rough idle!
  80. b20 water pipe question
  81. eg b series shift linkage
  82. What do I need to consider when planning an H2B swap, '98 Civic EX
  83. 94 civic ex auto harness for gsr swap!!!
  84. CRX F20B + B series Rebuild..without Kits
  85. eg h23 swap help
  86. What cams are these (b series)
  87. please help with 93 civic with b18
  88. B16 head on B18 block.
  89. H22 custom timing belt cover
  90. ITB's
  91. Honda B Series 4 Wires O2 Sensor
  92. j series gearboxs
  93. rbc/rrc on h22
  94. can anyone help with info on a b19 hype-r conversion
  95. South FL suggestions on Reputable Shop to Perform an Engine Swap
  96. H22A into EG - Silicone Rad Hose Question
  97. what swap should i go for???
  98. GSR To EG
  99. New EG Build in Ohio- Advice and Suggestions
  100. HELP! GSR SWAP!
  101. B18b in ej6 low idle after warm up
  102. Poorman's Type R Question
  103. lsvtec sluggish. no power. timing question
  104. motor mount question d to b swap
  105. GSR swap no spark, no fuel please help!!!
  106. ESP altenator bracket issue h2b eg hatch
  107. how could this be done
  108. Need a little wiring help. Swapping a 95 LS B18B1 into a 2000 civic ex..
  109. EJ8 with swapped H22A SES Light no codes!!!
  110. H2B Q's
  111. b series swap questions
  112. How-To Wire Automatic B18B1 into EG Chassis (Pic Heavy!)
  113. F23 3wire iacv swap to 2wire???
  114. ITR throttle body on b18b
  115. b20 vtec issues
  116. 1995 Honda Civic EX Sedan with ABS. What harness for B swap??
  117. h22 eg hatch build options
  118. Turbo d16 VS "B" VS "K"
  119. Differnet F22A intake manifold options
  120. Surging idle on b18ba/b16a LS/Vtec
  121. h22 wierd idle problems iacv?? stumped
  122. 96 civic GSR swap IAB question.
  123. H22a in Ej1 wont start! Need help!
  124. No ground condition on h22 in eg on injectors.
  125. k20/k24 setup eristic gasket kit?
  126. 95 hatch with b18b1/b16?? build startup
  127. building a coupe!
  128. trouble with my h2b need fixed by thursday HELP
  129. F20b with 5spd Lad; Will It Fit.
  130. Need Help Please Car is missfiring
  131. h2b/h22 issue
  132. my f2k integra project..
  133. HELP!!! h22a swapped ek wont hit vtec
  134. turbo mimi-me will not idle any suggestions??
  135. Axle Seal replacement B20B B16 transmission
  136. im stumped - car stopped and won't fire
  137. auto j32a2 mating with a 6 spd tranny along with a auto harness. in a EG
  138. h2b instructions NEED THEM ASAP
  139. gsr swap help into del sol :(
  140. I just PASSED emissions/smog with JDM B18C
  141. engine questions.......
  142. ej6 euro r swap
  143. Crazy Thinking...H23V BT Block F23 97mm Crank...Eagle B Series Rod...H piston...Turbo
  144. F20b build. any info would be most appreciated
  145. B16 block with ls head up and running in crx
  146. h2b frame clearancing
  147. HELP distributor
  148. Help. Trying to fix 96 Civic/H22a swap - exhaust system question
  149. Need to know throttle cable set ups for b18c1 in eg
  150. B20b swap into 99 Ek (harness help)
  151. 96 civic sedan swap 94 b18c1
  152. Confused about ECU's what to use?
  153. B18B1 Swap issues Oxygen Sensor related
  154. J35a1 block with j32a2 heads?
  155. K series injectors in h series?
  156. 92 Civic Si with 97 LS swap
  157. J35a1 questions
  158. GSR Head Assembly...Missing Parts
  159. Can 96 Civic wire harnesses be used for an OBD1 00 Civic/B18b1 swap?
  160. EG coupe with a j35 help
  161. Which B20B motor do I have? P8R Head.
  162. B20 Bearing questions
  163. New to imports and thirsty for knowledge on my b18 w/t60 @16lbs
  164. B18C1 Rod Bearings Re-Used
  165. H2B with Air Conditioning. YES IT CAN BE DONE
  166. Civic Ej1 d16y7 to B18a2 swap questions with pics
  167. What ECU to use 99' Civic B20B
  168. Vitara pistons + d15b crank + b7 block
  169. EM1 With B20B Questions....
  170. gsr on a Eg with a b20???
  171. 94 d15b7 want to swap with b18a1 help please
  172. 94 hatchie with d16z6 - What engine/tranny swap?
  173. D15b crank + GSR rods?
  174. review my parts list
  175. b18c1 swap, do I have everything I need?
  176. b18c1 into EF.. Dizzy questions!
  177. single cam harness on b18b?
  178. Distributor help
  179. B Series Motor Mounts.
  180. h2b questions?????? help me figurw this out
  181. 94' Coupe B18B1 swap motor with issues
  182. ek hatch gsr swap o2 code 41
  183. h2b wouldn't go into gear HELP
  184. need some opinions
  185. eg sedan trying to ls swap!!!!help please
  186. Best throttle cable for a B16B swap?
  187. $$$Need info on engine$$$$
  188. 99 ek JDM h22a... intake manifold upgrade???
  189. Civic VX GSR Swap HELP!
  190. K24A4 head build help.. Pics included
  191. innovative relocation
  192. B16a vs K20a3
  193. j32a2 questions
  194. b20 swap cv axles
  195. B18B turbo swap and auto to manual conversion
  196. cel on after completing itr swap. help
  197. HELP! 99 GSR swap in 98 EK chassis with stock harness.
  198. K20 EK questions!
  199. best B20 for a B20vtec build?.
  200. f20b or h22a block which to buy????
  201. EK GSR swap cel help
  202. Problem with my F20b very strange
  203. eg dash wiring question
  204. 2000 EM1, what block to make more torque?
  205. 92-95 eg h/f mount questions
  206. b18c1 acceleration problem
  207. F20B into EJ7 OBD-2
  208. 99 hatch swap questions...
  209. 2000 Si With B18c1
  210. need help with obd2a ls swap in my obd2b civic dx
  211. couple questions about a b20 going into my Ej8
  212. 1999 EX With B16A Swap - Want to Keep AC
  213. B16a4 Turbo or H2B on EM1
  214. H22 into eg wiring question for coolant temp switch b
  215. k20z1 93' eg CIVIC COUPE
  216. B20 running rough in EK.
  217. H23A IACV Compatibility problem
  218. JDM ecu work on a USDM engine?
  219. j32a2 swap into eg
  220. 95 b18b ls into 89 crx hf
  221. Question about the balance shaft
  222. eg h22 moving alternator to where power steering use to be??
  223. My h22 swap wont start
  224. H22a from ek to eg
  225. EG b18b1 swap wiring problems
  226. B18B1 swap into eg - required swap parts
  227. B20 quick questions!!
  228. JDM H23 Vtec Running OBD-2 EK?
  229. What jdm itr b18c engine and transmission do I have?
  230. RSX fuel tank in EG/DC chassis?
  231. B20v Swap
  232. ITR to eg6 help
  233. Ek axle problem
  234. h2b vs itr?
  235. 96 EK CX to b18b1 swap wire issue
  236. 92 eg hatch f20b
  237. Grounding Issues? Running out of Hair to pull out.
  238. h22a swapped 94 accord...please help!
  239. driveshaft legnths required
  240. talk me into h2b please
  241. F/H/4G63 hybrid
  242. k24 swap into ek which shift box an cables?
  243. "g23v" guys please come in
  244. k24a2 w/automatic tranny into 1993
  245. F/D into an EG Questions (F/B could be insightful as well)
  246. driveability problems...
  247. 2003 hch and 2003 honda civic ex/dx
  248. EM1 - Harness Question - B16a2 => B18c
  249. C-lo Nitrous H2B 391 HP STOCK BLOCK
  250. D15b7 into 2000 em1 ?
