PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. AC, radiator question
  2. Still use 94-95 teg mounts for b18a into eg?
  3. power steering pump for B18c into EG
  4. auto to manual intake manifold question
  5. Strange Vtec problem
  6. who's put a b18c5 into del sol with b16a3
  7. where did buy your engine hoist & stand? how much?
  8. Is there any advantage with the B18B1 block vs the B18A1?
  9. H22 converted to OBD 1 - What ECU are you using?
  10. Is B18C and B16A AC braket the same??
  11. How much should I be spending on a B18 ls swap for my 94 EJ??
  12. 92 hatch-b18a speedo cable
  13. anyone in the East Texas area: Ill pay you $$$ to do my b16/crx wiring
  14. k20 in EK?
  15. B20 block swap
  16. type-r block with b16a2 head and ctr pistons, what cr would it be?
  17. Hi, fresh b18c swap in crx. Code 20 electrical load detector? PLease Help!
  18. fellow hondatuners...please help..crank angle sensor...
  19. *pics* My new power plant...
  20. Y1 Cable Tranny
  21. B18C1 swap in 94 civic... mounts??
  22. Axles on my h22 accord 5th gen problem, driver side, cant use accord
  23. header
  24. B16B into a 2000 Civic Si - can I keep my existing AC bracket?
  25. how can you tell from what year motor it is by looking at the head?
  26. Im going to build a b20!! wish me luck!
  27. B16 A/C and P/S
  28. Strange noise on cold starts...
  29. daygo heads that do motor swaps
  30. b16a2, stock intake manifold. need help with the AIT SENSOR
  31. ait sensor, d16y8 swap on a eg, code 10! what to do?
  32. b16a2 in 88 crx, car is obd1, cable tranny, code 17 = vss, need help!
  33. H22A Axles in DC4
  34. Engine swap ? For 98 EK Hatch
  35. My Review: JDMShit.com's P28 H22a Race Program
  36. Did the shop give me wrong axles? h22 motor in 95 accord
  37. Just got my JDM GSR Swap in on my civic 4dr. Pictures soon to come.
  38. sparks/wires recommendation for gsr hatch
  39. ATTN!: Cable Transmission Owners!!!
  40. ls widage tray for ls vtec??
  41. Issues With Putting Si Power in a CRX HF Chassis?
  42. wiring before swap or after? some questions & confirmations!!!
  43. Using a PG7 on a Sohc set up?
  44. another IAB problem
  45. Aftermarket parts for a JDM ZC
  46. A-Pipe
  47. si mounts in a 98 EK which ones do i need?
  48. budget decision between swaps
  49. prelude to accord
  50. H22 in Del Sol? Any of you have it? Any difference than swaping in a normal Civic?
  51. Thank God it started! Couple of small issues with B18c in EG
  52. is it possible? 5 lug on crx (88 si)
  53. H22A In a Del sol
  54. newbie question about p28?
  55. B18C1 in 92 civic vx
  56. H22 GC Spring Rates for EG
  57. cylinder #2 quits working
  58. b20 vtec pistons???
  59. 2000 Civic Si motor in 1993 Civic DX
  60. h22a civic video.. 2nd gear tramp...
  61. H22 guru please help
  62. 99 dx hatch B16 SirII ?
  63. what mounts do i need???
  64. d16a1/z6/y8 vtec hybrid (i searched already)
  65. Ect sensor problem
  66. B20 vtec question
  67. wtb a hybrid civic ... new jersey
  68. skunk 2 cams
  69. abs swap?
  70. ECU and jumper harness problems!
  71. where can i get an h23a vtec/accord sir motor?
  72. Need help with H22A4 swap.....ATTS
  73. what difference between usdm and jdm motor swaps?
  74. CEL stays on
  75. Is there anybody in the Philly area or close that'll help with an engine swap?
  76. 93 integra Ls axels/ 91 civic dx hubs Not going in, not even close. PLEASE HELP!
  77. B18C with auto tranny
  78. my b18b eg wont stay on without revvin it
  79. yonaka H22 mounts
  80. CAI for Eg with GSR motor
  81. rear disc brake caliper mounting bracket pin is stuck!
  82. I've been lurking around here for a while, so here goes:
  83. Is thia a Xsi 92 or 92 b16 SirII motor??
  84. ? *I NEED* 98 civic hx wiring diagram (v-tech not working)
  85. what kind of mpg for a b16/ef ?
  86. GSR or Type-R Swap??
  87. 1/4 mile GSR EK HATCH
  88. need solution to problem right now
  89. Dyno'd the K20A Swap
  90. K-Series Shift Linkage
  91. Q's about EVAP system on my b16a2, with PICS!!!
  92. What all do I need to put a b16 SIR2 in to a 93 cx hatch.
  93. Engine stall if i pull the car?
  94. AC + engine swap in EK
  95. Do JDM B20z's have higher compression than US B20z?
  96. OBD0--->OBD1 Wire color corrisponding to functions needed...
  97. VSS on 89 CRX with B18C1?
  98. What distibuter do I use for a EG w/1st gen b16???????????
  99. H22A4
  100. honda/acura head bolts?
  101. Z6 head questions
  102. H22 in a 84 crx????
  103. Power steering
  104. 93 DA gsr - Looking for weld in K20 mounts -
  105. Swapping engines between cars question...
  106. WI and IL , who is really good at tuning the SAFC???
  107. wierd idles, wierd hesitation, wierd everything =\
  108. D16y8 5spd Manual installed with Auto wiring harness; bogs. CELs!
  109. exhaust is soooooooo loud!
  110. Interior Wiring Harness
  111. Anyone with a GSR swap in there 99-00 Civic Si's??
  112. skunk 2 ecu can be tuned with SAFC??
  113. 98 5 lug swap on my Civic......need info from you ITR guys
  114. B18c1 @ 200k miles... good buy?
  115. Fitting a D16z6 into a 1g integra....
  116. Integra Type R Legal, but Civic Type R is not?
  117. retaining items with a swap?
  118. Is this possible???
  119. Hasport's 455whp K20 EK
  120. K20 Type R into EK Civic SI: Am I a ballarr?
  121. Noise Coming from Tranny after rebuild???
  122. Confirm this please! 91crx/b16a1 swap-I need 90-93 teg rear mount bracket
  123. Solution for engine rubbing hood in 88 CRX Si B18c
  124. Del sol brackets
  125. Integra Upper Driver Side Mount in EK?
  126. what mount to use?
  127. jdm -98 itr vs. jdm 99 itr
  128. Price for a B18C auto swap into a 95 DX Hatch/ H22A auto/B18B
  129. Best Place to buy B18B in PA or have shipped. Opinions wanted!!
  130. would a 92 1.5 civic cx tranny work on a 89 si block 1.6
  131. 96 civic hatch gsr swap quick overview.....
  132. I need help with a Full h22a motor swap in a 93 Civic Coupe
  133. 00 ls in 00 civic ex need help wiring for the ls ecu
  134. need help with distributer wiring from 93 vtec harness to '00 h22 distributer!!!
  135. B16B Wiring into a 99 DX
  136. iam puttin a 89 si on my 92 civic cx. i have a question about the electrical
  137. Eg Gsr Swap AC Question PLEASE HELP!
  138. OBD2 codes
  139. i have a question about changing my cx ecu and harness to si
  140. California Law and a B16b in my 2000 Civic Si
  141. GSR into civic CX quick question....
  142. 2000 LS motor in a 97 ex
  143. what axles to use?
  144. GSR head bolts are the same as B20 bolts?
  145. can i swap a d17a2 2002 civic motor engine in my eg hatchback 94............
  146. 98 LS swap into 96 HX....Which ECU?
  147. help me with swap
  148. D15 VTI / Worth it or not?
  149. i got wiring trouble , 96 b18b1 into 98 hatch dx.. please help
  150. del sol shift linkage help
  151. First mass production fuel cell car (Honda of course)
  152. Hey, gotta question...GSR vs. K Series
  153. Type S Engine Swap
  154. Oxygen Sensor (O2) The Same?
  155. Eg6 auto to stick changerover
  156. b16a3 into an ek
  157. which radiator hoses do i use?
  158. Need a 96 del sol A/C bracket and a 95 - 01 GSR throttle body cable ASAP
  159. Running Obd2 ecu on obd1 enging
  160. Hybrid is having troubles...Please look
  161. smoking swap, opinions
  162. 97 EK GSR swap Harness ?
  163. Vacuum host question on jdm b16a2 swap in an EG
  164. where and how you drill 11in. rotors
  165. Type R swap from EF to EG
  166. i have four check engine lights left need help..
  167. revving a B18C
  168. Pittsburgh Import Night
  169. Can I chip a vx/cx ecu
  170. Ok H22 or ITR in 92 civic vx
  171. TDC sensor .... Help with repairs and probable causes
  172. HP FI GSR
  173. which bushing application?
  174. shift linkage help
  175. weird ? but need answer for swap
  176. automatic single vtec del sol h22 mount
  177. Engine Management??? anyone heard of Haltec E6K?
  178. when doing a 96d16y7 swap with b18c1????
  179. codes 1,5,7,10,14
  180. Lowering Compression On B18c1
  181. weird idle? after swap
  182. B18c1 or B16A2 with LSD....
  183. 1st Gen B16a in 98 honda civ
  184. vtec wiring and skunk 2 harness
  185. any hidden troubles/costs w/ putting an h22 into an eg....
  186. k20a?
  187. Code 10 and 14 VX Harness to H22 (EG)
  188. B16A2 swap to '92 Civic - Needs advice!
  189. !!!!!!HELP!!!!!!
  190. d16 crower 84166 kit...anyone with experience
  191. What kind of pump gas are you putting in your Stock JDM swap?
  192. spark plugs and wires to upgrade or not
  193. all d series 92+ civic use same shift linkage?
  194. what parts for 5sp conv.????
  195. D15B2 to D16Z6?
  196. yet another "swap that wont start/run"
  197. need help with swap
  198. Help! Does anyone have these spare brake parts?(disc brake swap)
  199. a/c with type-r radiator
  200. can u use an automatic motor for manuel trans
  201. Need Help, Tranny/Axle problems since the swap
  202. covered a thousand times but not specific enough........wiring vtec
  203. who sells k20a2 swaps?
  204. can i make it turbo ?????
  205. oil catch cans??????
  206. Vtec wiring?
  207. h22 ?'z
  208. swap help, injector problem, 00 ek->h22a swap
  209. Recomended suspension on h22a eh2?
  210. Which block will have MORE POWER: High Compression B18c (ctr pistons) or STOCK B20z??
  211. d16z6 longblock in 4g Si questions
  212. Auto to Manual tranny swap 90-93 Integra's
  213. Has anyone swapped an H22 into their Civic (EG or EK) for their first engine swap ever?
  214. NON-ODB B16a ????
  215. OBD1 Conversion Problem
  216. b16b or b18c-r
  217. MSD on my Gs-r motor
  218. Motor goes flat at 4 grand.
  219. how would this auto swap setup run???
  220. Maryland swaps......
  221. att. Greasemonkey
  222. Lower Radiator Hose temperature?
  223. B16 Sir 2 hydro tranny ------------which clutch to use
  224. B18c1 head on B16a block is it possible?
  225. ecu codes with scanner
  226. B16B (CTR) Complete Swap from Hmotorsonline--What else do I need?
  227. mileage on engine?
  228. GSR Swap in Ek need a little help
  229. Question about Rear Tranny L Bracket
  230. EK GSR swap question
  231. S1 tranny question
  232. Ls/vtec PCV, Im consfused...
  233. LoveFab header
  234. OBD1 b18a swap help
  235. WTF? Fuel + Spark = No Start
  236. I'm lost...can I turbo my H22 del Sol or not?
  237. use 95' del sol VTEC dizzy on B16a2
  238. gsr swap help
  239. USDM Flywheels VS. JDM Flywheels
  240. Keep blowing 100A battery fuse
  241. 2000 JDM Honda Accord SiR DOHC VTEC H23A engine...
  242. Dallas B18C1 swap
  243. swapping 90 integra to 94 civic help
  244. whinning noise!!!!!!!
  245. Type R fuel pump into an EG?
  246. JDM ITR suspension and brakes install on USDM Integra GSR
  247. Not moving with Quaife LSD?
  248. Need Help On Auto to 5-speed conversion
  249. 96 CIVIC LX B18C SWAP questions Help!!!
  250. PLEASE HELP ME INSTALL CHIP IN P72 JDM SMALL ECU ...
