View Full Version : Hybrid / Engine Swaps
- Need help building a set up.
- Gsr sedan vtec issue
- Help me decide, b18ls or b20ls
- Civic SI '93 GSR Swap won't start! HELP!
- Del Sol with GSR Motor Mount
- need help b18c swap low compression in 3rd cyl.
- ed7 project plans
- EF Civic GSR Engine Swap - Parts question?
- Help me please!!!!!
- 01 h22a4 swap in 99 Civic ek coupe
- 1997 Civic lx j30a1 swap with 04 accord manual transmission with throttle swap
- B-Series cable - hydrolic conversion
- Problem with Shuttle Swap !
- EF Civic EX Engine Swap - B16A SiR vs. B16A SiR II - Opinions?
- 90 Civic EX Sedan Engine Swap on Daily Driver?
- taking apart 03 pilot for my future J swap - what else should i take??
- engine swap help
- h22a swap axle help
- Swapping a 00 GSR in an 97 Civic Hatchback
- help with my civic eg
- Helpp!! How to make usdm obd1 gsr. Vtec crack using usdm obd2 ecu
- B18a1 swap in CRX questions
- Rough idle B series.
- issue in starting b18c :( help needed
- Why no monthly H2B F/S Sticky thread??
- LSVTEC Engine Harness QUESTION HELP!
- b series swap no start?!?!?!
- obd2b questions
- h23a with s2000 f20c ap2 tranny...possible??
- JDM P30 OBD1 ECU into USDM B16A3, with smog check
- b18c1 into ek motor mounts
- b20 v running like crap when cold
- 1997 Honda civic lx j30a1 swap with 97 acura cl ecu running smooth no CEL's
- ******99 SPEC ITR SWAP WEIRD PROBLEM'S******
- No power after 4K rpms!
- 91 EF swaped b18a1 vacuum line help? pics**
- F20B w/ T2W4 Tranny?
- honda civic 99 with b20 swap problems
- d16 o2 on a h22
- Jdm Engine year and bar question
- HELP PLEASE: B18a / B18b question
- 93 b18b eg
- vaccum help
- Obd2a Ecu with obd2b engine?
- b swap in 94 civic dx
- cant decide between h2b or fully built ls/v
- EJ6 B16A2 problem. Help!!!
- B series axels with k series outer cv joints? Possible or pointless?
- Intermediate shaft???
- H22 Swap Help!!!
- Using an OBD1 Engine and Harness in an OBD2A Chassis (99 Integra)?
- My CRVTEC H2B 4x4 & possibly rwd
- b16b starts but don't stay running
- civic dx
- B series swap help.
- How do I make an obd1 d-series harness work on an obd2 ls?
- B18b Swap
- B18A1 CRX NEED EXPERT HELP!
- d16z6 swap in a 2000 civic dx HELP?
- 98 ek coupe b18b1 swap in limp mode :(
- PR3-3 Head + B18C5 Bottom ECU Question PLEASE HELP!!!
- Power Steering....
- ef si gsr swap issue
- Swap Question, F20B into EF Chassis
- Civic f18 swap
- eg hatch gsr wont start
- B18B1 in 98 DX Hatch, P75 Ecu fuel pump no work
- help with axle info for h22 swap
- Swap question
- H22A Starting/Idle Issue
- Y8 head on Y5 block, What do i need?
- 96 B18b1 swap looking for a little more power...
- K series pistons in F20b
- Logic Motorsports customer support and h2b header review
- b swap problems
- b18c swap, but no start??
- F22a6 swap in EJ1
- Eg hatch b18b1 swap confirmation
- First mini me swap...Help anyone?
- Which B20 makes better power non-vtec and n/a?
- f20b into ek hatch
- Lsv help
- JDM B20b Turbo Eg Hatch-Cylinder 4 Problem?????
- bard gsr ef body using e85 fuel
- b18a1 boosted or gsr?
- vtec!
- F20b Swap
- h22 civic mounts YONAKA???
- H22 swap wiring harness
- da kyb struts with tein gold lowering springs HELP!!!
- 97 honda ls vtec b18 wiring problems
- Engine Swap from 95 Del Slo into 99 Hatch
- About swap da6+b18c to civic ed???
- Wiring in IAC on a '91 Integra LS Swapped CRX?
- tranny question
- 99 Civic ex w/b18b1 swap not firing up? help?
- H2b vs ITR Pros/Cons
- Will the jdm b16 automatic or b18 automatic fit my Civic (ek) better than the other?
- Internal swap question b series trans.
- D17A1 in EK or EG
- Help please OBD2b to b18b1 OBD1!!
- b series, d series, or k series?
- b18a1 civic still running rich, code 43
- civic hb apexi ws2 on tegg help
- Cold Air Intake that'll fit Civic B20 swap
- Crx/Ef Hatch going H2D (Bisimoto)
- Obd2 harness in obd1 car
- WHERE DOES THIS HOSE HOOK UP TO?
- Honda newbie, starting project crx
- JDM B18C GSR - EJ8 Throttle Cable and Cat Question
- Tach bounces
- OBD2 B18B1 EF Sedan?
- My H22a ate a rod bearing, whats the best motor to replace it with?
- B18B1 bottom end B16 VTEC head build
- 99 h22a4 swap in 92 eg
- LS swap in HX - when I snap the throttle the engine boggs out and shuts off
- H22 Swap into 2000 civic
- 91 CrX si B18C1 Gsr Start Up Problem
- Tranny mount identification
- need help building a G23
- eg hatch awd, what trailing arms do I need?
- JDM B18C SPOON HELP!
- gsr swap help!
- QSD h2b kit consideration
- Radiator Leak B18c Stock EK Rad. (no cracks)
- S2K into Civic Swap
- axle popout
- LS Vtec EG hatch help!
- B16/B20 Build ls/vtec
- ECU swap help
- H22A EG Problem (Still)
- dseries tranny mount to b?
- EF swap to d16Y8, can I keep my PM5 ecu?
- 1997 honda cx with 94 lsv swap help
- Help choosing Cat/Test Pipe
- heater core hoses??
- 96 hatch ecu question
- Another Idle question
- Will a swap affect the clutch system?
- ls eg smoking!
- GSR EK hatch doesn't like OBD1 ecu
- LS b18 turbo build 1991 civic hatch
- H22 EK Hasport Mounts - ANOTHER Axle Issue
- f22 transmission into eg
- H2B issue!! pls help
- New to Honda
- OBD1 2 o2 sensor wires?
- H22A EG Wiring Questions...
- What b18 internals will fit in a b16a
- b18 vs k20
- h22 install help
- Running too rich?
- LS/VTEC... no oil pressure at the head = No VTEC :(
- r18a1 in eg swap questions
- Injector wires
- Ej8 h22 tranny question
- gsr swap/trade questions
- Throttle Cable Question 92eg/B18c1/Skunk2 manifold
- Car running too rich, can't go higher than 2,500 rpms. B18cR jdm
- need info, 95 civic b20 swap
- 97 ex build
- *87* crx si swap questions.
- H-Car 85 CRX J35
- wire harness question
- 1997 Honda Civic LX Automatic swap to a B18 with Auto???
- obd 2 p72 ecu problem?
- GSR SWAP HELP!
- Wiring Question: 97 JDM B18CR & 99 EK Hatch
- 89 Civic Si w/ 96 B18b1 runs, but having a leaking issue
- won't start!!
- B16a to B18c
- Honda Civic CRX awd b18a
- INFO NEEDED ON JDM B20B AUTO SWAP IN EJ6
- F2B help
- dseries starter, alt to bseries?
- 93 Civic Hatch w/ 94 B18C1 misfire?
- LS VTEC Timing Cover Options
- Auto eg rear t bracket (staying auto)?
- b18 swap starting probs
- check engine light wont turn on
- weird issue(s) with ls vtec after swap
- obd0 ls wiring
- 1989 Civic DX Hatch
- 1992-95 civic cx vx hatch gearing/swap ?s
- H22A Swap Problem.
- 95 eg with h22a swap need help asap!
- B18C in a 1959 Morris Mini
- cb7 f22a4+h22a head =.......
- EF with b16A shaking?
- B18 swap in del sol having issues with fuel.
- 1997 Civic Si H22a4 swap
- 1996 b18c bouncing idle. cleaned iacv and there was a loose oring inside of it.
- Throttle body question
- ls vtec on 99 ek sedan
- 98 hatch with a b18c1 - no spark and fuel pump kicks on if I jump main relay
- Wierd squeal from GSR?!
- gsr swap help!
- Del sol swap problems...
- Swapped b18c5 oil question
- vTEC wiring plug
- H22 swap, No vtec after service.
- 2000 civic ls swap question
- Too much fuel in cylinder?
- OBD1 B18B1 into 00 Civic EX Parts List Inside
- Question on inspection
- 97 Civic EX GSR Swap Problems
- LSV Wiring
- timingbelt issue b series
- H-Car H22 with B-Series Manual tensioner conversion
- ***HELP*** GSR B18C1 OBD1 into 97 EK Civic Hatchback OBDII with OBD 2 ECU
- GSR dowel pins
- is it a good idea to put a b20 in a del sol?
- help with Bswap in ek hatch
- B16a vs B18 LS?
- 1999 civic dx with b20 RUNNING ISSUE
- DX hatch with B18C1 - CA smog PASS/FAIL ??
- h22 eg to h22 integra
- B16, B18, B20 CAD Model
- Gsr swap Boggs
- GSR motor (black vacuum box)
- FML: No spark or fuel: 93 Si Hatch, OBD2 B18c
- M2B4 Tranny clutch and flywheel
- Help with my parts list for my em1 . So i can buy
- B18c type r swap into ek troubles
- b17 Head Gasket Change
- lsv on ek hatch swap help
- F22B2 to JDM F23 problems
- EG hatch swapped only running 3 cylinders...
- 95 civic h22 swap
- B18 auto in ek, yes i got ut done. Ecu issues urgghhhhh
- H23A/EK hatch VTEC WIRE UP
- POWER STEERING bracket help!
- gsr swap into ej1! i need help!
- 97 hb/GSR swap has idle issues
- 97 civic with a b18c sputtering/hesitation in vtec
- 98 civic coupe with lsv swap problems, cut out at 3k, smoke, noisey head.
- Need help with B18c swap into 99 Civic EX
- B18C1 GSR into a 90' CRX Si?
- h2b issue
- Creating a frankenstein build...
- OBD1 LS into 97 DX Hatch... Wiring Questions
- Engine Harness Question
- PLEASE HELP 2000 CIVIC ENGINE SWAP
- 98 civic coupe lsv swap harness question
- Need help Smog California
- 2000 Honda Civic Si Sir w/ JDM B18C GSR Sir-G Wiring Questions with Pictures
- H22A In EG Shifting Problems
- Ls swap randomly cuts out??
- Del Sol Swap Question (b18c)
- NEED HELP H23/EK HATCH
