View Full Version : Hybrid / Engine Swaps
- Help! h22 EG and Jackson racing sc.
- new to honda need some professional advice.
- B18C5 into a 92 cx auto
- Help Me Identify a Rattling/Grinding Noise - Sound Clip Inside!!!
- ecu for b18c1 and pr3 head? OBDI
- H22
- Throttle Body for H22
- Cable on back of EF tranny?
- Swapping ls into hatchback
- obd2b to obd2a distributor (searched)
- ecu ?
- shift linkage question
- k20 Question
- Thinking about selling my motor for a swap. What do i need to sell with my motor and tranny.
- H2B??????
- obd1 alternator in obd2a car
- Alternator belt question....
- tranny help on b series
- Filling holes for head swap?
- B16A Vs D15B (Forced Induction) Vs B18c ???
- IAT and IAC Wire colors (SEARCHED) Getting CEL's GSR SWAP OBD1
- i need a motor mount
- EF b18a1 motor swap
- JDM H22 parts?
- D16Z6 swap
- which header
- GSR into a 92 accord lx
- h22 or ls/vtec in 93 sol
- Quick: Gas/Temp Not Working
- show me the different k20a intake manifolds out on the market *please*
- LS 5th into GSR tranny
- ITR Header on my B18C1 Swap:
- car began to bog
- i really want to know why my car is throwing a code 23
- hondatech's input on a swap?
- NOVA where good shop to do motor swap?
- GSR Pistons,Rods,Crankshaft in B18b1
- 00' EX harness to 97' GSR distributor
- GSR into Ek
- H22: Custom Fuel line.
- H22 Map sensor questions?
- Changing b18c1 for H22a pros cons??? imma noob
- quick gsr swap question
- B series engine, K series tranny, is there an adapter plate/is it possible?
- K24 in EG Civic?
- Im not understanding the situation.
- 7th gen transmission swap questions?
- B20/VTEC swap problem
- Integra engine brackets, Same as civic?
- Need some help (d16a6 --> 93 civic ex)
- 2 unconnected plugs gsr swap
- DX to ZC SOHC
- Converting B18a1 into a B18b1?
- is the knock sensor necessary to wire up??
- d16 MOD ???
- f22b head on f20 block, will it work?
- Gsr swap into 95 civic ex
- ALL EK H22s with midrange VIBRATION!!!!
- Whats the difference between B16A1 and A2???
- 1998 Civic Dx: Jdm b16a obd1 swap Need wiring digram to use OBD1 dizzy
- fuel pump or something else
- Possible fueling problem
- 1993 Civic CX swaping in a d16y8
- b16 into 94 civic ex
- 5 wire o2 to 4 wire o2 (hx to jdm gsr)
- keep the a/c....
- Has anyone ever done this?
- Distributor swapping questions
- Need some advice with H22 in coupe
- jdm k20a (type r) or usdm k20a2?
- Quick question 2000 Prelude susp. on 91 Accord
- Smog test visual
- H22 EK guys... cables through the firewall?
- oil control orifice on b20
- Do 96+ JDM H22 motor swaps Exist???
- h22 in eg which ecu do i use?
- Integra Type R into 1992-1995 Civic's (wiring)
- b16 da9 swap --- whinding noise from motor
- K20a in a EK
- replacing a clutch how to
- idle problem
- idle problem
- 02 vtec 1.7 head fits...?
- fuel rail compatiblity
- what ac bracket for b20 in 97 teg?
- rpm jump needs help please
- obd0 b16 into 92 civic vx
- swapped b16a1 intp eg bubble
- I feel like giving up. (on my hmotors b16) need suggestions.
- what clutch do i need
- OBD0 B16a Into 93 Integra
- 97 EJ8 with H22 and 2 inch drop. Problems? Suspension questions
- SIR 1 problems after swap Wha happened ?
- What Ecu For Ek h22swap? preferred or better?
- b16a2 into 1998 civic ex coupe
- Identify these things.
- Timing is off with poor mans R
- what axles for 5 lug swap into k20a civic hatch?
- B18C into a 93 DX Civic HB
- 1987 Honda City Hybrid
- b20b into 94 eg
- After months of trial and error im at a loss with the setup..
- B18C-EK Swap...let's clear up motor mount & bracket issues
- wideband commander
- b16 in 93 bubble
- rod bolts for pr4(LS) rods
- Radiator Swap?
- Anyone Else have a problem with RY Wire Conversion Harness
- just spent 5000 to get a crvtec in my crx , this piece of crAP WONT EVEN STAY IN 5TH GEAAR!!!
- Good Bseries FAQ?
- Koyo Integra radiator into 6th gen, Denso or Showa type?
- 96 LS motor in 91 Teg
- DV/DT Engineering Mounts - Where? Website?
- Here a nice lil' vid for ya'll...all-motor civic hatch MOVIN' ON YA'!!!
- H22 In An Accord
- how does vtec work on a d15b w/o oil pressure switch?
- ek swap..no start..lost of problems.
- Constant code 41! Dont know whats causing it!
- Question about cam clearance with LS VTEC
- getting dyno and tuned
- Need Some Help Please...b18b into 93-95 Civic EX...details inside!
- VTEC WIRING
- b18 wireing on a H22a
- b16 pistons in b18c1 will it clear
- Answer my b20/vtec question and I'll give you something FREE.
- Results with a K24 hlock/K20 head?
- 14's with a mini me posible
- vtec valve control.
- Honda Insight suspension
- Questions about a k swap into my del sol
- Those of you with a b18b in an eg...
- d16z6 harness
- need you guys advise..
- Need INFO with wiring a 97 USDM ITR into a 00 Civic DX hatch...
- m.a.p
- Just got my b swap, now what all do i need to drop it?
- is this a good deal on a complete h22 change over..
- what is the benifit of ITR LCA's?
- K20EK by KAIZENSPEED on the prowl
- Ordered the REAL pair of axles for h22 into ek today
- opinions wanted - noob needs help
- what headstuds do i need for a b16head and b18c1 block
- head gasket for poor mans r?
- H22 powered eg
- Hood wont close!!!!!! with my b18a1 swap?????????/
- EMERGENCY~~~~~- buying b18a1....seller is waiting on answer he is right here....
- Just picked up a 97 ex and a H22 swap and got some questions?
- Is JDM H22 OBDII same as USDM H22A4?
- New B18c1 swap questions
- traction control h22a4
- b16 to an ls swap
- best transmission
- H22A4 EG Axle Hybrid
- ***OBD2 Head OBD1 ECU???
- Think you can get this small v-8 into my 99 si? well.. i am, PIC
- H22 Civic EK Owners: Handling on freeway.. WTF Over!
- 92' Civic H22A Hatchback; traction bar and turbo options!
- b16a in a 95 integra
- h22 ek: help finding axles
- B18C1 into 94 Civic DX
- B16A2 in a 95 GSR??
- Anyone ever get a moto from Jhot-exports? I did and my motor is messed up.
- transmission problem or minor??
- Parts needed to do ls/Vtech???? help please
- Hasport Shift Linkage needed for b-series swap?
- h22 swap with D/B series trans?
- Oil Pressure Sensor needed?? obd0 obd1 DX to GSR
- I want a PROFESSIONAL to do my swap......any SOCAL recommendations?
- tsx block head swap, help
- H22a Del Sol won't turn over.
- AEM EMS h22a4
- Engine swap problems...
- Crower Cams
- b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles
- EF9 LSD bolting ?
- D16Y8 head swap
- swapping to better mounts
- iacv swap
- auto wiring harness question
- new to honda swaps
- wiering h22a
- k series in eg videos...
- EGR problem h22 crx!
- 90 Accord Automatic - Swap in 5spd H22a
- Another MOUNT Question!!!!!!!!!!
- Girdle
- disc brake conversion
- valves
- Help using PR4 IM for swap in EG
- TPS TAS h22 crx problem!
- H22 Balancer Question
- Ground controls H22 Integra
- How hard would it be to swap a F22B into a integra?
- rty
- B20z/Vtec No power Steering!!!!!
- swap question?
- vtec problem
- can a b series tranny work on a d series
- Quick H22 question
- B18c1 install on wiring harness off a b16a2...
- da h22
- k20 in a 2000 civic hb questions
- ek h22 with power steering?
- need help with the H22 SWAP
- which conversion harness??
- Im New and need help
- im confuesed by the dowel pins..b20vtec help..
- used K24 short block ??
- Who sells a b18b? I cant find them anywhere!!!!!!!!! plus some other questions
- DOHC V6 vtec in a 5th gen. honda prelude?
- h22a1 swap wiring trouble..
- GSR abs brake conversion into EG hatch - yes i searched
- Project G21 (H23A1 + F20)
- ahaha, i dint know how to search for ZC since its only 2 letters so yeah...
- Hybrid header question....
- obd 1 h22a in a del sol saturated or peak and hold?
- jdm itr swap into 96 ek...throttle cable too short????
- top end racing
- 90/91 Integra Axle vs. 92/93 Integra Axle
- What manual should I get ?
- A5D tranny??
- B20 Tranny
- Hybrid Setups
- Hasport Axle CV Joint Rebuild kit?
- obd0 B16A in EH troubleshooting.
- h22 swap exhaust headers...
- del sol VTEC into civic cx i searched
- what engine is this tranny for
- fuel injectors not firing after b18a swap into ef
- HELP! need to convert my obd1 motor to obd2 for obd2 car
- d15z2 mini me possible?
- WHICH ONE!?!?!?!
- H22A flywheel info!
- reverse rotation h22
- Integra Dash in EK Questions and Answers
- b18 or H22 civic?
- Problem with rear tranny mount, B18C1 in EG with 99-00 Si tranny
- What is the cheapest setup???
- ok gettin my jdm gsr swap soon
- ex engine harness wiring on jdm itr motor help
- B20b help.
- Will an ITR intake manifold bolt onto an LS head?
- D16z6 or B18a swap?
- D16z6 head in 91 HB, OBD change questions
- Anyone have a supercharged GSR EG CIVIC?
- 1996 GSR ABS into 1995 Civic VX??? Is this possible? Anybody ever do it?
- LS/V parts list...suggestions?
- DYNO H22 NUMBERS!!
- b16a ecu error code
- Need Serious Help picking what wiring harnesses 99 EM1 Civic Si HELP PLEASE
