My stock H2B Dyno tuned
Its a jdm h22a. Internally stock. only thing it has are the
rmf looking headers from full throttle
68mm throttle body
removed balance shafts
Im running on ectune with the demon board. i got it from xenocron
216HP 172TQ dyno tuned by ME!!
68mm throttle body
Re: My stock H2B Dyno tuned
is hp and tq line is meeting at 5252rpm on this sheet? dyno corrected? what tranny? pass on 3rd or 4th gear?
not doubt those numbers are real.
The numbers are good, do not listen to those people.
You should lower vtec and run a longer intake tube and larger to gain power. It is tapering out on power up top.
i tried a longer and shorter tube but it didnt change anything, i messed witht he a/f ratio and timing. but i didnt try a larger one, ill give that a try next time i go to the dyno, thanks for your input man!!
it was open header
i was wrong bout the mph it was 108, my 12.5 pass was 107
60' 1.77
330 5.061
1/8 7.847
mph 87.89
1000 10.261
1/4 12.332
mph 108.65
60' 1.77
330 5.061
1/8 7.847
mph 87.89
1000 10.261
1/4 12.332
mph 108.65
