View Full Version : Hybrid / Engine Swaps
- Small review of the DTRFAB K20A header for EG/EK/DC2 we just got
- I guess this is what I get for trying to be original...
- car has no power
- h22 computer problem...OBD2 computers??
- Another B18C1/EG question
- First K20A Swap Into DC In Canada
- d16z6 to b18c5
- where can I find 11" 4-lug brake rotors?
- EG/H22 HASPORT .... HELP...
- Calling on all members for help on this one > NEED ECU pinout for JDM Euro ATR H22 OBD2a
- Which parts a swappable from a d15b7 into a d16z6????
- Need help w/ wiring... B18C into 96EX
- difference between b16a1 (92-93) & (88-91)
- whats better k20 or b20
- K24 in a RSX?
- charger in H22 hatch
- H22 Teg ..... NA or Boost?
- does anyone know where to get a b20z
- 93 accord ex h22 abs light
- K20A2 guys what are you putting out?
- Did search, need help! JDM 96 spec P73 ECU Pinout NEEDED! HELP!
- 92-95 ex headers
- H22 in 96 civic, staying in LIMP mODE? WHY!!
- Any places to buy B series swaps in the Bay Area?
- 1250 rpm idle???
- how many shifter components do i need to buy for my situation (h22/97hatch)
- F20c hybrid ? ? ?
- rewiring a obd0 3 wire Alternator to a odb1 4wire Alternator
- Replacing the wheel studs from front hub.. what needs to be removed?
- 99 LS into 96 Civic Cx
- help with a 97 gsr into a 91 teg.
- HELP!!!! B20 BRACKET MOUNT QUESTION
- what timming belt for b16a sir?
- h22 accord swap question... tried searching
- What swap should be reliable and put out good HP?
- idle and redline problem
- h22 inbto a 90 accord, what belts do you use for power steering and ac?
- 96-98 civic ex 5spd harness
- which axle seal to use on j1 tranny
- engine won't turn over help
- questions about my LS/VTEC *pics*
- D15B ECU & tranny
- what mounts are needed for b series into 88-91 civic?
- Who has put comptech TSX header in k20R EG?
- OBD2 to OBD1 distributor
- What timing bel to use?
- H22A H22 Skunk2 Intake Manifold
- IACV CODE and TPS CODE
- Hasport Mount and Axle problem
- B18B into 93 Del sol .. a few questions for those who have done it!
- Here's some pictures of H22 hatchy
- b18c7 ??
- whos a good lsvtec builder in socal
- value of b16 autos
- how do you make sure youre engine is clean
- Reverse mini me (a6 head z6 bottom) with obd1 distributor and ignition timing
- B16A little rattling sound on startup
- another satisfied Hmotorsonline customer
- Something interesting i read today....
- B18C1/EG Problem
- B16A swap (93 to 96)
- OBD0 to OBD-1 Conversion problem
- 2000 hatch back with b16a2 swap help!?!?!?!?!?!?!?!?!?!
- question on H22/EG.....
- Yet another B16/EF swap problem...
- Blitz Turbo Timer Wiring Question??
- B16 Swap problem
- Finally my H22 turbo dyno in my 93 civic 4dr!!!!!!!!
- Code 12 EGR help
- H22 transmission mounting issues. Please help!
- will an integra gsr instrument cluster fit in an eg civic?
- What alternator for a SOHC ZC?
- which engine swap to do?
- b18c5R or k20?
- 1/4 times?
- code problems!!!!
- b20 vtec ?
- lsvtec with PR3 pistons - how much milling with big cams?
- which Trottle cable do I use...
- B18C with Y1 tranny.. Axles?
- what ecu
- B18C Header to Catalytic Converter
- 99-00 Si Cat mate up to jdm gsr header?
- breaking up at 1/4 throttle, hauls ass otherwise HELP (jdm b16 in 90 STD hatch)
- k20 swap for integra?
- jdm b16 VTEC Pressure switch, which one is ground and power. PLEASE HELP
- HASPORT ENGINE MOUNTS FOR EK9
- New Track Videos of The H22 4doh!!
- H22 in EG hatch, IACV pinout?
- Has anyone done a 5 lug conversion?
- PLEASE HELP- cant figure out the problem (O2 sensor wiring) (att anyone with a vx + swap)
- Is piston 1 on distributor side or timing belt side. Need Help
- jdm gsr swap: which cat? [SEARCHED]
- H22 in EG hatch, wont rev past about 2k RPM
- 00 LS into my EK...sensor probs
- California State Referee question OBD 0 to OBD 1
- B20B crx with turbo?
- B-series swap into 2000 EK
- B16A into 89 CRX Si .... mounts and axles question
- B-Series Transmissions
- Couple b20/vtec questions I need answered.
- Which Helms manual??
- b18c1 into 90 hatch axle question
- can deg . cams through timming of
- H22 in EG hatch, axle is binding!
- Needing help on b16a2 swap into 93 civic hb
- need help from wiring guru - k20a EK swap w/rsx cluster
- No Oil Pressure
- ?about ls vtec ecu
- b18b into 98 ex (swapping out tha D)
- what manifold is this?
- modified distributors???
- JDM B18C into 95 LS...HOW TO?
- wiring experts look inside please
- GSR radiator same as a Type R radiator?
- Damaged heater core outlet tube during swap.
- b18c into 92 civic cx
- I have a swap question
- anyone have a DC JDM header on an EG?
- H22 in EG, is second IACV wire ground or key power?
- LS/VTEC in 91 Si
- TrueRace K20 Header and stuff
- Suggestions for swap?
- B16 Help...
- help with stupid GSR IAB's, errrrrr
- have any of you ever gotten a motor that just sucked?
- Trouble hooking up knock sensor ans iab
- LS intake manifold
- H22 CX hatch almost on the road!
- h22 civic mounts
- installing golden eagle cam gears
- Need advice on trouble codes
- 98 gsr trans mount...
- Just a FYI
- A/C Bracket...
- Help !! Engineswap !!!
- b18c1 in EG, no CEL's but runs like ass
- Pondering Wiring GSR-> EK
- Are there any mounts for this swap???
- question on accord motors
- Wiring question
- Swaps / Prices please explain
- no vtec on b20 need help thanks.
- help on ls wiring in kansas
- h23 into a 87 crx engine mounts???
- Questions on swap B18C -> 93 EX
- What's the difference between a B20z and B20b
- Shipping a engine from AZ to NY cost?
- 99 usdm gsr swap in 2000cx hatch
- d16z6 swap into ed WONT START!!
- k20 swap price
- swapping a civic engine into a integra??
- Engineswap Civic 5d -98, Suggestion ??
- What timing belt to use?
- first b16 equipped car i USA?
- I got a tough one
- Funny Idle in LS Swap... Need help asap!
- HELP!!!!!CABLE TRANNY SWAP
- B18c IT-R Swap on 91 CRX si
- oil pan question
- Help fast!!! Need an H22 tranny ASAP!!!
- Speedometer problem Y2 -> S80
- Hotshot dyno graph???
- Which clutch, flywheel and headgasket for b20/vtec?
- JDM B1C into a 1995 Integra GSR
- how to read 0bd0-0bd1 engine codes
- did 0bd0-obd1 and car isn't running right please help
- Height adjuster
- how to read obd1 code in obd0 car
- what is the 92-95 single vtec firing order
- Fields vtec controller, need help tuning
- H22 Hotshot leak
- Another Swap!!
- LS/VTEC Oil Squirter Question
- 98 b18c1 into 97 dx..... help
- Tired of the msd switch how do i do it right????
- Legality of older BLOCKS?
- what headgasket for b20vtec?
- Engine shuts down... help
- P54 A/C BRACKET QUESTION...dont flame, allready searched...
- OBDI - OBDII conversion????
- A lil help with a b20 swap.
- anyone else interested in this ?
- b16a2 head/b18b block, LS/vtec Dyno #'s?
- GSR Axles vs Hasport EK K20A axles vs Hasport EG K20A axles
- motor swap in hatch, what's better?
- 95 LS into a 97 EK? Can it be done?
- b18c siezed, is head still good?
- Turbonetics T3/T4 turbo or b20 bottom end? please help!!
- JDM B18c in 93 EG
- Lookin for a write up on AC in a H22/Hatch(EG)! Tried a search!
- B16 Sir II engine v.s. B18 GSR need help
- 89 CRX ... will B16A motor foul bonnet?
- H23 JDM vtec 2.3l. info?????
- help on swap!!!!!
- jdm b16a SiR-II swap into 99 EK ... alternator wiring problem.....Any other info would be greatly ap
- HOW TO 95 H22a power steering in eg
- Which Throttle Cable?
- OEM fpr..... d series vs. b series
- Reverse switch? JDM GSR Tranny
- Bad Ass CRX
- is it possible to use eg h22 mounts on a ek h22?
- Do Honda CBR TPS sensors work on B series motors?
- CEL 9 cyp sensor??
- cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED
- rarity of obd2 b18c(gsr)
- b16a (sir1) swap question
- turbo ls auto
- B20 Block B18B head?
- B18c drop and auto to manuel conversion
- What harness can i use for a GSR shell?
- will a K series trani fit on a B series engine?
- 91 Si engine harness into 89 DX question
- CRX Swap...What to do?!
- Guess what I had plugged into the IAT Sensor
- 91 HB w/ Z6 swap and L3 - no check engine light?
- CRX with GSR Swap + Skunk 2 Intake Mani ( WHAT INTAKE? )
- B18B into EK swap problem
- wiring help please???
- 3 wire IACV on prelude to 2 wire IACV on civic harness???
- Camber Problems
- Will integra shift linkage fit a 93 hatch with a JDM sir motor in it??
- 2000 Civic DX Motor Swap Questions
- 97 d16y7 harness onto 01 b18c1
- What's this Wire
- obd0 to obd1 ?
- -->wiring skimatics for k20 into eg<--
- h22 sensor locations?
- Rebuilt B17a swap won't idle
- HELP WITH WIRING! please
- using DSM injectors
- B Series motor mount for Del sol?
- Is this where this hose goes?
- Where does this go?
- how can we/I trust them? Motor swaps...
- D16y7 into a 94 ex?
- vtec solenoid not getting power
- oik pressure really low?
- OBD 1 Harness -OBD 2 Ditributor Swap
- Can I swap my ob2 ecu to obd1 with harness...4 my h22 civic??
- Question for you B20 guys
- PR3 ecu: auto or manual? (obd0)
- Auto D Series to Auto LS VTEC
- OBD1 P72 pinout problems with 93 VX Hatchback
- Idle issue on B18c1 swap with Si(p2t) ecu...
- d series in a 3rd gen lude?
- Mini Me D16 ECU Question......
- Cool K24/K20 hybrid article
- difference? itr radiator and a ls/gsr integra radiator? help?
- Starting swap today
