View Full Version : Hybrid / Engine Swaps
- ysk1 questions
- b18c in 98 civic
- S80or Y21 tranny on B18c???
- Will a SOHC Turbo Manifold work if redrilled on DOHC???
- b16 in 98
- engine code 1 ? HELP PLEASE!!!!
- Can a CX ECU run an LS engine in my hatch??
- base line performance estimates on this setup:
- bogging b16
- adding b20/84mm option to the cr calculator??
- 96 civic wiring harness question on ls engine
- should I change the fuel pump????
- About to purchase an entire salvaged ITR. Need some good advice
- Difference between GSR and ITR cams?
- Hybrid folks in Central Florida
- "Leave the motorswaps to the Professionals"
- ATTN B18C5-EH2
- ITR engine swap question
- Interior Wiring need to be changed?
- b17a to b20 vtec turbo
- endyn slugs in b20
- help please
- s1/j1.......whats the difference between the 2?
- Where do I find JDM LSD parts?
- www.Jspecengines.8m.com WATCH OUT! if you buy a B16A2 they send u a B16A1!!
- help with swap
- Help with swap..........
- nos w/ stock exhaust....
- do i have to mod my exhaust what a ls/vtec swap?
- couple of swap questions
- what engine to buy??? Civic R, Integra R or H22a for 93 civic coupe ex
- problem wit my hybrid
- custom exhaust pipe on b18 swap.. help needed w/ o2 sensor
- what kinda times for a 92-95 CX hatch,,with a teg LS motor??basic bolt ons
- h22 in cl
- You Know Where to Find a D16A? D16A? See inside.
- LS/VTEC help
- H22a swaps help
- 95 ls in a 92 civic
- What kind of valve cover / oil pan gaskets for my B18 ?
- GSR Pistons, Rods and Crank fit on LS Block???
- How hard/easy is it to change an axle??
- code 9 onzc still
- B16 Civic and axles
- b18c obd-1 or obd-2
- JDM b16a2 vs USDM b18c
- ecu harnesses
- b18c5
- want really bad!!!!!!!!
- Engine swap info
- Hey! Just got my b18c1 from Evans Honda Specialist. Thumbs up so far.
- which motor mount inserts for a b18c1 ej1?
- Thunderhill 1/26/02?
- ITR cams in B16A2?
- Are these the right axles?
- PMS??
- Shifting hard
- 1st gen b16 water pump....
- is it possible to buy a b16a2 complete from the honda dealer?
- Anyone have pics of H22A swap in96+ civics
- Koni FULL Coil-Overs for EK Chassis Fit on an EG Chassis?
- little advice on type r head
- lsvtec over b18c1
- Where could i buy ECU plug pin. (Obd2)
- compression results...
- B20 VTEC NA - 14.1. Impressive or Not?
- Your hyrbid vs. VR6's???
- Help! 97 hatch with H22
- Where can I get a complete engine wiring harness?
- B20VTEC dyno results
- VSS sensor????
- Suspension mods for bone-stock 93 DX hatch
- My experiance with Different JDM motor companies
- R shifter in EF
- Hey guys. Would y'all be interested in a 2.5 inch mandrel bent exhaust specifically 4 hybrids
- b18c obd 1 into a nonobd teg
- ecu threw code 43
- crower cams for b20
- which mounts for ls/vtec?
- Can anyone answer this Question. H22a distributor question///Free MONEY///
- b18a swap links?
- B16A...turbo or not?
- ls/vtec or cr-vtec???? witch one for my sol???
- Some body help me
- Links to TRUE JDM parts
- i have aquestion about a LS motor in m y del sol
- Zdyne ECU & VAFC
- LSD install???
- LSD identification?
- need nsx motor and tranny!!!!!!!!!
- 6th gen swap, info on mounts?
- 3g gsr gauge cluster into 5g civic??
- Shop for Swap
- what i need for swap???
- I need some good (educated) suggestions on what next for my hybrid.
- engine and tranny weights
- please help!!!
- b18c2 specs
- Greddy exhaust
- How fast?
- B16A Tranny?
- B18b in 97 dx
- H22 into '93 or '94 Accord . . . which is better?
- JE pistons for B17 gsr need help????
- need info?
- Do jdm gsr's come with lsd?
- Wanted some H22 injectors
- i have a SOHC 95 del sol and i want to drop a jdm h22a in there but i have some questions???
- FT. Stewart,GA,Anyone?
- what route should I take ?
- LS/VTEC Ecu Q's??
- Nobody Can help me???
- ID'ing a 00 ITR head vs. a B16a head???
- I have code 74 flashing now now...errrr.....
- accord ex (f22?) to a EG6
- This CLOWN says that B-Series Motors are GARBAGE...Check This Out...
- can someone tell me what R cams are these???
- anyone selling a civic hatchback 92-95
- I need an LS motor
- semi building my B16A
- My dilema
- integra suspension and brakes on 94 hatch!?!?!?!
- which intake manifold
- Code 14....help a brotha out
- Turbo
- V-6 Hybrid CRX...
- JDM TypeS info needed.
- garret turbo stage T3/T4 kit on 93 integ gsr????
- JDM B16 1st G Header
- to alll hybrids out there
- VTEC problem, or so i think?
- Y21 tranny on a B18c1?
- DSM Injector/Honda Swap
- Help with codes ( and don't tell me to do a search, i need some answers) =)
- B18 block on B16 head?
- 1st gen B16a into a 92-95 hatchy????
- LS throttle body on a GSR head???
- Where to get a decent priced B16a2 swap package?
- ITR spoon pistons in a JDM b16A
- ZC timing help needed
- I have the tightest body style Honda, but the weakest motor, (1996 CIVIC HB CX) what can I do?
- type R swap questions for 93 del sol si
- b18c5 in '88 crx si: use j1 cable tranny or convert to hydro tranny (jdm itr)?
- omg i am going nuts...
- Online engine shopping...
- Is there an LSD available that'll fit a 1993 DX Hatch tranny?
- Not able to shift into gears...86 Civic w/B16 swap
- How much do you pay for your swap?
- What kind of bolt ons can i do with a eg gsr swap?
- swapping a b16
- Whats the average ET on a...
- how much would u pay?
- HAS ANYONE EVER RAN INTO THIS??
- need help on h22 into eg hatch
- cx to si swap problems????
- Removing Interior in Southern California: What's Illegal? What's Legal?
- specs for valve adjustments on B16A????
- swap help i got a 96 del sol i need some tech help on the best motor swap
- LS Swap in 96 civic ex is running but have a few small questions
- Just bought gsr from www.hondamotorsonline.com I def. reccomend them.
- Runing SOHC VTEC with PR3
- fuel filter for my hybrid
- b18b powered 5th gen hatch
- LS swap?
- Sohfast
- OT: WTB: D series Tranny (prefer EX)
- FS: injector resister box
- EG radiator in crx?
- damned infernal code 9!!!
- b18a1 vs b16a1
- b20vtec build
- B16A2 into a 91 Civic 4spd
- how long have u had ur hybrid?
- best swap?
- Whats up with this obd-1 and obd-2 stuff mang?
- obd-1 h22a into obd-2 accord using obd-1 jumper harness?
- I'm doin a swap and have some questions.
- Minor Ploblems after the swap.
- Gear ratios for Teg Ls, anybody know em...
- Jspecengine.8m.com SUCKS
- Differences between the auto & manual v-tec motors?
- Will a GSR crank work in an LS block?
- prelude swap in a eg
- 90 LS Trans: Will a GSR clutch work??
- EF fuel pump upgrade
- I think I got a setup I can live with now....
- b18c1 in a 97 civic coup
- Please read need some info on my JDM B16a1 i bought....
- B20B rod ratios
- MOTOR MOUNT QUESTION
- Infamous Jdm vs usdm questions
- Mount Kits for B series motor in 91 CRX
- ls/vtec wiring ?
- Automatic to 5spd?????
- is this a waste?
- need 4g help with the gsr
- EK bumper question
- Best place to find???
- distributor question
- Speedometer question
- hp #'s for b20b block with b16a2head
- GSR swaybar on EG hatch
- Quick question, what is the price of a b16a2 and install labor?
- What would be involved in this swap?
- B18B in a '00 Hatch, wiring question
- I will be doing a miniswap
- 97 GSR into a 00 civic Si
- Prelude JDM VTEC Auto Tranny into US Prelude Si Auto-question
- swap shops
- Swapping a H22a into a 95 Integra LS
- **WHICH CAMS BEST FOR B16??**
- Mini-Me questions
- LS motor swap
- LS swap into EG8
- CRX b18a swap
- LOTS of EG-Hybrid Pictures. MUST SEE!
- Pulling codes from H22A1 ECU
- does anyone know which aem cai for b18c eg with gsr and itr intake manifold?
- track and street results...?
- o2 sensor b16a
- LS/VTEC Guru's ????'s
- Finding a good built motor
- Opinions of RSR catback??
- d16 swap??
- 99 GSR SWAP - HELP!!!!
- B16A P30 ECU question
- vtec engagement?
- 90 crx 16 vales going in my 84 civic 1.5
- What needs to be done to get exhaust to work in EG with B18C??
- I finally made up my mind!
- Help w/ welded mounts in CRX
- eats mustang's shits corvette's
- 2002 motors swap
- Least noisy exhaust setup
- newest edition to the hybrid world...
- b16 exhaust manifold VS gsr manifold??
- EK Brake Conversion - HELP!
- tranny cases
- ex brake conversion for ef's
- Intake, header and exhaust for a hatch hybrid with usdm b18c
- Distrubutor for b16, can any others work.
- For all LSVTEC's??
- Cutting and welding Motor Mounts for B16A 1 - Opinions
- will DX headers fit on an Si engine?
- DRAG turbo kit times
- how much better is a GSR turbo over a LS-turbo
- dx to zc wiring.. help car wont start..
- OK...new to the whole "hybrid" thing...but i need some help...
- import builders' package 2 (ls/vtec) on G2 LS
