PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. ITR motor arrived today!!!!
  2. is a b16a swap worth it?
  3. hmotorsonline?
  4. coil pack question
  5. OBD conversion harness questions...
  6. Looking to buy/price OBD1 B16a ecu....
  7. P28 jumper....question
  8. bare minimum parts to run engine
  9. Idle too high! HELP!!
  10. JDM ITR in 00' LS...throwin codes 7 and 10!
  11. just got my b18c
  12. ??how many of you did your own swap??
  13. alternator help
  14. integra idles at 1500-2000 rpm!
  15. I need a good Machine shop in SO CAL
  16. how to wire a b16a1 into a 92 acura integra gs
  17. Engine code for 96 Teg LS?
  18. h22 swap ?'s
  19. h22 auto swap into ek civic auto.WHAT MOUNTS.
  20. vtec vs non vtec dizzy
  21. DC2-K20A2/A1 swap?
  22. CTR N1 pulley question.
  23. more power needed
  24. clutch problem, dont think my clutch is disengaging.
  25. Engine Question
  26. b20 max over bore
  27. AHH HELP NEED PART QUICKLY
  28. DOING A SWAP FOR A FRIEND??????
  29. Tranny Question, help me out please!
  30. 93 EG automatic, what tranny mount is used for DOHC swap?
  31. 95 civic with b16a2 swap throttle cable help? hose
  32. zc motor in 97' civic?
  33. Shift fork
  34. Automatic TRansmissions
  35. motor swap what parts needed
  36. H22 TPS
  37. Some pics of my H22....Just thought I would share
  38. Mount bolt question(HCP/EF18 mounts)...
  39. obd2 connector pin print out...
  40. CTR N1 Crank Pulley Belt!!
  41. What Cold Air Intake can I use????
  42. stock ls headgasket for ls/vtec?????
  43. wha kinda spark plugs should i use for b20 vetc compression 12.1
  44. Just when I was getting used to the hybrid...
  45. TYPE R swap/conversion questions
  46. An idea Will it work?????????
  47. please put all info about putting a b16a2 into a d16y8 99 honda civic ex
  48. Which is better, the F22B SOHC VTEC or the F22B DOHC
  49. CARB Certification questions???
  50. Major Problem: 91 Teg w/ 94 GSR motor turbo, no fuel/pump not turning on. Please help if possible.
  51. JDM R in my 00' LS...won't start!
  52. Junkyards near Northern VA area?
  53. pics of the finished h22 swap (56k beware)
  54. 00 itr crank pulley vs 99-00 si crank pulley (searched)
  55. Just blew motor, what to swap?
  56. H22 WITH P72 (GSR) ECU
  57. MSD?
  58. Just double checking on Axles for swap.... 95 del sol vtec axles...?
  59. Will a D series A/C mount work on a B series in a gsr???
  60. IAC valve-Which one for B16A2 with ITR intake manifold?
  61. D16Z6 help???
  62. OBD 0 distributor bearings
  63. b18c crank in a b16a
  64. Help a girl out!!!!
  65. OBD1 & O2 sensor
  66. Where is the best place to buy a B18C from?
  67. obd1 h22 in 96 accord help ?
  68. gsr compression
  69. b18a1
  70. BEST MOUNTS FOR H22 SWAP???
  71. Anyone who has done a B18 swap on a civic please look at this.
  72. engine swap help on 2001 civic
  73. place racing mounts
  74. 99 b18c1
  75. HMO.com = still best parts and service a even a year later
  76. B18C1
  77. bits and pices
  78. Newbi just crashed my Si - help me please
  79. jspecautosports.com
  80. Swaps for Auto 98 Ex
  81. swap shop in MD/DC/VA-h22 accord
  82. O.T./ Good site for VW
  83. P08 manual ECU CEL codes
  84. need help with exhaust piping on ek/gsr
  85. OBD2 to OBD1 Wiring question....Need some straight answers!
  86. -Please Help-distributor problems
  87. feilds sfc vtec help
  88. WHAT COOL OR COLD AIR INTAKE IN EG/H22?
  89. h22 ecu is this auto or manual?
  90. H22 IN EG EXHAUST ISSUES!!!
  91. auto block into manual CRX
  92. swap info/guideance for b18 ls swap into 93cx hb
  93. 95' b18c1 into 2000 civic?????
  94. b18b1 swap questions
  95. b16a questions
  96. LSD Tranny
  97. CRX motor swapping
  98. Anyone with B18C-R swaps in EK coupes?
  99. wtf? VAFC says throttle is always 100%
  100. h22 surging at low rpm?
  101. Will I have to adjust the TPS sensor after A6/Y8 buildup GUARANTEED?
  102. san diego shop for tranny swap?
  103. Real HCP Mounts H22/EH/DC
  104. b16a2 and ODB2b swap to '93 DX COUPE OBD1 HELP!!!! PLZ!
  105. ls auto or 5 speed engine?
  106. LS into LX
  107. motor mount question
  108. SWAP SHOPS IN NY AND SURROUNDING
  109. Intermediate shaft.....neep help asap/!!!!!!!!!!!!!
  110. 00 civic dx
  111. integra rack and pinion
  112. B series enine question.....help
  113. what clutch to use with a YS1?
  114. New Swap / What should be replaced?
  115. vacuum line routing on 00 b16a2 in 97cx
  116. how to read the ECU identifcation numbers on the side
  117. B16A distributor help! - B16A/EF swap
  118. Where to get a swap done in KY?
  119. Auto to 5 speed in a EG
  120. aem v2 worth the extra $80?
  121. OT, toyota pickup swap possibilities
  122. anybody got a pic of an-r header on h22?
  123. B16A1 swap into 90 integra throttle problems
  124. Is 1000 to much for an install?
  125. engine builders i need your help
  126. B16a1 into 98 integra ls
  127. B16B in a 98 4dr whats your opinion/installation cost/price/getting ride of old engine?
  128. Finding my Displacement after creating a hybrid?
  129. JRSC'ed B18C CRX questions...
  130. H22a into a 6th gen Accord
  131. How do you distinguis between an OBDI P75 ecu and OBDII p75 ecu?
  132. h22 scater sheld
  133. Winter wheels for the civic? GSR brakes- 14s or 15s
  134. What Exhaust are on your h22's eg
  135. Bought a GSR Motor swap for a guy...Stolen??? ...HELP...
  136. Which intermediate shaft?
  137. loss of horsepower b20vtec
  138. anybody have pic of ceramic coated an-r header?
  139. Zerolift Autolab & Osaka JDM Motors
  140. 99-00 Si throttle cable Part #?
  141. Group Buy on Greddy Timing Belts B16A and B18C!!!
  142. Need info on 00 ITR into 95 civic
  143. anyone who's swapped a Euro R h22, please help.
  144. 1994 h22 accord people HELP
  145. Accords arn't so slow no more.....
  146. Which two wires to switch if TPS is reading reverse?!?
  147. Power steering pump
  148. 99 jdm r in 98 ek???
  149. Best mods for GSR to run mid 14's
  150. LS 5th gear in GSR tranny
  151. 97' JDM ITR swap in my 00' LS?
  152. B tranny to H22...
  153. How to wire up Y8 IAC to EF (D16A6) EACV harness?
  154. JE pistons and eagle rods
  155. ECU Qustion??
  156. Richmond va motor swappers ?
  157. 5G or 6G Civic catalytic converter for my 89 Civic?
  158. help, still confused on swap question
  159. VTec Map for b18c1
  160. h22 civics, EK mostly, fuel filter line hitting tps
  161. Gauges to use with GSR swap
  162. Swapping out the long block....
  163. what is correct deck height
  164. jdm engine question
  165. what all do i need to put in a b16a into a 1990 honda crxhf
  166. After GSR Swap...Heater doesn't get hot??
  167. 90 INTEGRA PARTS
  168. b16 obd wiring question.
  169. 1st & 2nd gen b16
  170. Code 14
  171. This will confuse you all..
  172. how to reduce vibration in h22 EG?
  173. SHOULD A B18C1 COST ABOUT 4000 DOLLARS AFTER INSTALL?
  174. Jerky, stagnate acceleration...
  175. Best intake for a Euro R in a EG Hatch
  176. Dyno Results - Imagine Engineering Header!!!
  177. b20
  178. OBD 2 question.
  179. b18c5 scam or not?
  180. anybody that can help me or know of a good shop?
  181. 98 jdm itr into a 92 cx...?
  182. H23
  183. wiring a 95 GSR into a 95 si sol
  184. Swaps for 88-91 Ludes
  185. Ned Help 92-95 Civic Hybrid A/c Part Number needed.
  186. 93 Civic VX Swap??
  187. LS/VTEC oil lines
  188. Engine swaps for a 92 civic
  189. PLEASE HELP WITH B18C1 INSTALLATION INTO EG CIVIC....
  190. JDM D15B swap
  191. WTF is code 20 in PW0 b16 crx dual point to multi port conversion
  192. SR20DET in an EK?
  193. b18C clutch problems.
  194. backward F22- H23 swap... i have an F22 i need to put in my Prelude Si
  195. Hey idea for h22 shafts
  196. B16 Crank in the B20??
  197. b20vtec question with oil catch
  198. Cost to ship a B18B longblock?
  199. What motor to put in 90-93 LS?
  200. Break in period after engine swap?
  201. exhaust ? for 94 accord with a h22a
  202. GSR EG Civic: Wierd Code 22
  203. p28 5speed ecu for an h22 automatic
  204. need h22 help (wiring)
  205. How can you tell the difference between?
  206. clutch just sinks to the ground, B18B1 into EG
  207. distributor diagram needed...please help!
  208. D16Y8 into EG...some ?'s
  209. Finally! ITR motor on the way!!
  210. timing belt cover install?
  211. 1st gen B16a, will GSR tranny fit?
  212. h22 hotshot headers where to buy besides from dealer?
  213. rear disc swap, about the prop valve
  214. obd0 to obd1 conversion
  215. h22 EK swap HELP FINISH!! NY our surrounding areas.....
  216. gsr b18 into cx hatchback
  217. Wiring Dual Butterfly GSR Intake Manifold to an EK
  218. YS1 lsd swapped into Y1 tranny easily?
  219. obd1 ecu with b18c1 if dual stage im removed
  220. h22 port and polish worth it?
  221. B18C1 SWAP NEED HELP!
  222. H22 civic with s2000 rims?
  223. H22 Shifter Linkage? Avid Racing??
  224. dang...so what motor mounts and brackets do i need for a gsr swap into an ek?
  225. Crx motor mounts?
  226. Serious problem after swap, we're stumped, diagnostic PROS check here!!!
  227. Half/intermediate shaft and axle problem (search done, nothing found)
  228. Automatic b16a into ek swap, need a little help/advice...
  229. swap questions
  230. lsv/vtec in a 1st gen crx
  231. ZC DOHC valve stem seal question?
  232. b18a swap into ef sedan
  233. Might not be the best idea but its my cheapest & only option right now
  234. B20 block, B18 head???
  235. Who is runnin a D16A6 in an EG????????
  236. 5 months with swap , now wont start
  237. LS vtec head bolts torque specs one hole in the block might be stripped help
  238. B20 swap questions
  239. manifold sensors.
  240. Wiring vtec haveing problems!
  241. Did search can't find out what to do with these
  242. Civic H22 A/C??
  243. need some help and suggestions
  244. 2000 jdm itr swap into 95 ej. have wobbles
  245. need tips on swaping 98 jdm type R into 94 cx
  246. b20 block help
  247. HASPORT EG Power steering
  248. EG's in So Cali with B18C1?
  249. MPFI swap using stock dx ecu
  250. transmission swap
