PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 [166] 167 168 169 170 171 172 173 174
  1. ATTN: Hybrids--->lets' see them
  2. rough running b20?
  3. need help about a motor swap
  4. WTB clean 92-95 hb with gsr swap.
  5. 1/4 miles for a b16b eg?
  6. Help with VSS issue (relates to B16)... Please
  7. Do i need to change the axels on a 5th gen EG if i put a b18c1?
  8. Which lsd do I order?
  9. Will an AEM CAI fit in my 92 Dx with a JDM B18C GSR???
  10. Help gettin transaxle off of my engine!
  11. which ecu for 00 si
  12. eg cluster
  13. ? for those that have ITR rear LCAs on an EG
  14. What is the rear engine crossmember (subframe) ?
  15. H22 AXLES
  16. JDM P72 question
  17. Add power steering to a 5th gen civic hatchback cx or vx.92-94
  18. Doing Swap Tomorrow Please help with some ???'s
  19. Some updated pics of the hatch...
  20. people with B16A2 in your EG's, i got a question.
  21. Recommended ecu for CRVTEC build up?
  22. What tranny do I have?
  23. WHICH ECU ?????
  24. SOHC zc?
  25. PLease help me find an ek civic hatchback in FL
  26. Ditching 5G Lude for a 90-91 CRX or Civic Hatch...
  27. anyone have pics of 6th gen swap
  28. installing a ITR 22mm rear sway
  29. tranny for zc...
  30. ls/vtec cams?
  31. H22a in a 94 Accord????
  32. a few questions on 5-speed parts and if there is any substitute for these parts.
  33. Swapping a GSR engine into my 96 Civic DX
  34. Cost and application of EG engine mounts??
  35. Y1 LSD into a LS Trans?
  36. Hybrid Owners!!! What exhaust system did you get for your swap???
  37. LS VTEC ?
  38. EG engine swap questions
  39. just got back from smog...FAILED...change ECU???
  40. Suspension set-up suggestions..........
  41. question for all you LS/VTECer's
  42. For a 92 civic, I'm installing a obd1 jdm gsr, and I'm wondering, what is required for the wiring?
  43. Non-factory a/c block off plate.
  44. B18C5 is in... :)
  45. Engine IDENTIFICATION
  46. b18c1 in del sol VS. b16a in del sol with turbo? which will be better off?
  47. fuel pump for eg gsr swap
  48. b16b in a eg?
  49. Help Me build my first engine - b20z Vtec
  50. When buying ITR LCAs, Shocks, and Springs, how can you tell (externally) that they are ITR pieces an
  51. differences btwn obd0 and obd1 components.
  52. what can cause a car not to start???? help please????
  53. Jun III
  54. what do del sol's with jdm b18c sol's run with no other mods??????
  55. will a SC fit in my Hybrid GSR obd1 delsol???
  56. Hyrbid Accord needs your help??!?
  57. DOHC head on SOHC block...???
  58. zc questions, not performing as well
  59. Does anybody know the spring rate for the 2.25" drop springs made by SPRINT?
  60. whats the problem??
  61. B16A Distributor Differences
  62. h22 in 98 civic ex coupe
  63. axles
  64. How can a stock 1.5 run a 15.5?
  65. exhaust for swap
  66. I need help wiring a LS motor into a EK.....
  67. H22, what belt to use?
  68. B18C1 head on first gen B16A block.
  69. Swapping a gsr
  70. 1st Gen B16 in 91 CRX DX
  71. GSR vs H22 swap
  72. give up a b18c5 for a turbo b20 vtec
  73. Mini me head swap
  74. 2 engine swaps in one....or not
  75. h22a in a ek coupe???
  76. MAP Sensor Issues in LS swap.
  77. Problem swapping ITR master cylinder/booster with EG civic
  78. is LSD worth the extra $?
  79. CRVTEC Venting Q's
  80. What kinda brakes should I get
  81. B18C into crx
  82. 1/4 time?: b16a in crx and h22a in 90 accord
  83. Wiring problems in 90 DX ----> B16a1
  84. Good or Bad idea?
  85. Need Help Fast!!!!!!
  86. DC interior in EG
  87. Parts for a swap...
  88. wykideg6
  89. HELP with TPSensor
  90. does anyone in all of h-t have a h22 turbo in their eg???
  91. wtb: b series mount kit for ef
  92. Rear Drag Skinnys
  93. ecu needed!...zc motor
  94. need help with my b16sir2 swap into an 93eg
  95. what cams would you put in a b16a, street drivable, and mid range power is nice...
  96. vafc help
  97. vafc help "vtm" wire
  98. help
  99. please read...need help
  100. need 93-95 h22a injectors!
  101. Does anyone know how to retain the AC when doing a gsr swap into a 99+ civic, without the use of the
  102. 92 Civic HB Si ready to swap!
  103. Good sounding exhaust for a Hybrid....can you guys/gals recomend.
  104. H22 in Sol....
  105. H22 into 90 accord motor mount question
  106. CRX track car conversion questions
  107. Engine lift - where to borrow from?
  108. Need advice on brakes and suspension for 89 CRX going hybrid
  109. Engine conversion
  110. Civic with a GSR dash???
  111. Name that: Intake Manifold!
  112. d16z6, in 19 hatch, anyone got a way to make the Radiator fan working???
  113. d16z6 in 91 hatch, Error code #41??
  114. looking for LS tranny
  115. H22 or H23 swap
  116. CRX: HF vs SI?
  117. Need Help With Rear Tranny Mount Bolts For swap
  118. SHIFT LINKAGE
  119. b20 turbo crx!
  120. CRV MOROR OR H22
  121. clutch question
  122. B18c into a 97 civic???
  123. EGR system.....if the old engine has it does the new engine need to?
  124. NEED HELP! Buying Hybrid.......VTEC NOT Right???
  125. Spoon EG lower tie bar fit on a DA?
  126. H22 civics, please post your pics!!!!
  127. axles
  128. Hybrid info
  129. what guage wire to use?
  130. pictures or information on oil catch can setups?
  131. Help With CRVTEC Into 1987 CRX Si!?
  132. Help pick a color for my Hatch!!!!!
  133. Any 92-95 Civic Hatchback Hybrids for sale?
  134. REPUTABLE PERFORMANCE SHOPS IN SOCAL???
  135. Arizona residents! Urgent message - your car might be in jeopardy!
  136. How much for a 92 hatch w/ GSR ???
  137. ZC rev problems
  138. droppin a jdm R engine into my piece
  139. Teg LS motor in 96-00 Civic DX hatch?
  140. torque specs
  141. Auto to Manual Swap in CA
  142. Winter hybrid owners...ever get a bit *scared* to roll on the 13" steelies?
  143. 3000 to spend...need some advice from you hybrid crx's
  144. Please help a fellow hybrider
  145. EX head -> DX block - Specific questions!
  146. ecu code 23 problem!
  147. Finally got the motor out.......
  148. itr muffler on eg hb
  149. from 9.6:1 to 11:1; how much hp increase?
  150. ATT Katman or other jdm experts
  151. GSR into EF
  152. Anyone know of a good place for a motor swap in NorCal/BayArea?
  153. 2nd gen crx engine into 1st gen crx
  154. ::AXEL ? FOR CRX B16A SWAP::
  155. Calling all Techs: 95 Gsr into a 95 LS
  156. How can I tell if i really got a JDM engine or not
  157. b20 users! Where did you get it, how much where you happy!
  158. Need a code engine code reader for ODB1 Civic ?
  159. Where do I find Probe racing?
  160. how many 6th gen coupe hybrids? i need to ask a few questions
  161. Power Steering Pump/Hose Issues
  162. LS vtec Vs CRvtec
  163. B16a or B18B1 ?....
  164. setup opinions please
  165. sharing some swap photos...
  166. Hey guys come check this forum out.....
  167. Any good ZC website
  168. V-6 Civic
  169. White 5th gen HB with Type-R wheels/hubs in Seattle area?
  170. Which Exhaust System Should I Use?
  171. exhaust for b20 into EG
  172. calling all cali hybrids with bar stickers
  173. Sources for engines that need to be rebuilt.
  174. how muchpower with crvtec
  175. type r head on b18c block wiring questions
  176. Were can i find a b16a cheap?
  177. SI front brakes same as Integra?
  178. Throttle cable, and radiator hose questions.
  179. Howcome most of the hybrids civis with B18s I see have no AC installed?
  180. JDM ITR final drive in B18C1 tranny?
  181. h22 in eg???
  182. B16 into crx HF
  183. 92-95 sohc vtec into 93 Civic Dx Hatch
  184. Anyone running 68mm Holley Throttle body in their B18c1?
  185. someone please help..b20/vtec..any ideas???
  186. Wanted: GSR head
  187. What camber kit is best and why?
  188. B18C1 Help - Secondarys
  189. What's needed for Rear ITR LCA install into a '92 VX? and other ?
  190. Best shop in San Diego to get swap done
  191. Swaped 91 dx for a d16z6, WIREING TOTAL CONVERSION!!!! haaaaaaaaaaaa!!!
  192. please help..b20/vtec into a 95 teg
  193. b16a+b18c5
  194. b18c in 4g civic help please!!!!!!!!!!!!
  195. itr pistons in gsr
  196. JDM B16 map sensor, EVAP q's
  197. B16 swap in CRX (cat)
  198. H22's fit in gen 2 integras
  199. Accord Type R CAMS
  200. "Don't buy from JSPEC ENGINES"
  201. Swaping ITR into my 99 civic si, HELP PLEASE!
  202. fuel filter on hybrid...
  203. Sport Shift ECU in NON sport Shift Car!!!!
  204. To the person who wrote "Don't buy from JSPEC ENGINES"
  205. Hondata obd-1 conversion on a b18c5
  206. FS: B16a3 Short Block
  207. exhaust piping on a eg with a h22?
  208. car stuttering...sputtering...fuel prob?
  209. b18b crx.. stalls and dies...
  210. Accord SIR wagon
  211. So Cal smog hook up??
  212. cool hybrid...
  213. Jspec B16a Distrubitor Needed!
  214. REVENGE!!!!!!!!!
  215. wiring for a 91 ls motor in 89 civic si
  216. FS or Trade: 2000 IMPREZA for Civic HB hybrid
  217. For those who know how to post pics.......
  218. California Swap/Aftermarket Law Answers!!!
  219. head swap
  220. shaking h22civic..need help!!!
  221. which engine to go for off the straight line with a 98 civic ex coupe?......B18C1 or H22a
  222. Connecting Rods for LS/VTEC
  223. newbie needing solid advice...
  224. building hp and torgue
  225. ZC motor in a 89 CRX DX - anyone got info?
  226. 2G Teg Vaccum problem....
  227. D16 to B16, can I reuse anything?
  228. engine swap persuasion
  229. please bash/give me ideas for my b18c set up
  230. FOR SALE?????
  231. LS VTEC rods
  232. Look what I found when I got home today...
  233. What is the best engine that could be put in a del sol??
  234. Just wanted to say hi
  235. Any way to VTEC a F22???
  236. 93 Civic SI, 99 Civic B16 Swap?
  237. Honda Builder's Handbook
  238. VTEC WIRING
  239. Head GAsket for LS/VTEC
  240. check engine light after swap
  241. Swap Questions on B20/vtec...
  242. h22a swap into 92 prelude "s"
  243. 95-95 Integra non-vtec motor into 93 Civic Dx
  244. My VERY dirty hybrid...(notice anything different in these two pics from today?)
  245. 2 phase lsvtec
  246. crv crx
  247. CRX B16 Turbo or Supercharger?
  248. Need Help! Head swap options for D15
  249. how much in the quarter mile
  250. Valve to Piston clearance on LS/VTEC
