PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 [117] 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. few questions about 93 b18
  2. Vtec wiring diagram for OBII ECU
  3. which way does the rocker shaft suppose to go IN?
  4. 92 teg with 95 jdm b18c Can i pass the smog ref help?
  5. Questions about HAsport mounts
  6. obd1 sensor wiring
  7. alternator wiring......
  8. K20A2 in a EG?
  9. Cooling fan problemo
  10. cooling fan question
  11. ANOTHER B18C question!
  12. 1st gen integra...
  13. 95 ls swap into 94 civic cx?
  14. B16A1 into EG, ?? about the driver side mount...
  15. Is my engine fucked?
  16. Help me pick out some motor mounts...
  17. JDM B1C QTR MILE TIME?
  18. b20 in 96 hatch wireing questions
  19. 88 crx HF b17 install HELP!!! Wiring problems
  20. help. how to remove old intake gasket? thanks
  21. help me decide - chip my p28 or get the p72 for a b18c
  22. cable motor, hydro tranny
  23. Why isn't the B17A swap more popular?
  24. Pulling bseries tranny out of crx w/o pulling the motor?
  25. Motor swap into 96+ hatch...
  26. pvc valve for B20
  27. your opinion on jun cams....
  28. type-r pistons or forged
  29. Anyone still have their stock VX motor swaps lying around?
  30. Traction bars for H22 in Civic--WooHoo!!
  31. Wiring question: Vtec into a 91
  32. Final wiring question B18C5---->96 Ek.
  33. Help with pin on shift linkage
  34. Need some help guys tranny is being help only by one bolt on the tranny and mount. Need help on how
  35. Did Swap and minor problems
  36. NOOB question!
  37. cant find company that makes the EF GSR plug and play harness
  38. Place Racing mount review...
  39. H22 or B18 in civ96dx coupe?
  40. b16a help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  41. swapping obd1 into 98 hx civic, HELP
  42. more stupid wiring questions
  43. Checking my list twice guys, Help Plz.
  44. What parts do I need to do this swap?
  45. Engine Light Help
  46. more sensor fun... questions about JDM H22a OBD1 sensors...
  47. Itr pistons on ls rods
  48. bad trust bernings hard as hell to breck motor! apart! h23a1
  49. what wiring will go on a 1984 crx with a zc motor
  50. 92 Civic VX - sensor in back of block - oil pressure??
  51. knock sensor
  52. Honda Parts and LS/VTEC
  53. top speed of a 92-95 jdm h22a?
  54. H22 to Canada
  55. EK JDM AC Bracket & US Compressor Problem...not what you think please help
  56. B18C into European EF9. I have the block, and a few questions. (searched)
  57. H22 Running like ass when hot? Why?
  58. Ignition timing adjusting connector?
  59. I need a clutch alignment tool asap!!! In Dallas, TX
  60. h22a tune up w/o helms! need help!
  61. '00 Si wiring harness plug n' play w/ '00 B18C5???
  62. What are the recomended chips for an h22a eg with dc 4-2-1 headers?
  63. rebuilding before swap?
  64. Timing belt/Cam Gear Q...
  65. Why can't I keep my oil pan gasket from leaking?
  66. B16a2 in 93 Civic coupe.
  67. Parts question for JDM B16a1
  68. H22 Production Header
  69. wangs auto in pelham, NH ?? Anybody heard of this place?
  70. question? is a gsr flywheel the same as ls flywheel? weight wise?
  71. Radiator Swap-Help- 99 Si into a 92 VX
  72. does anyone know the tranny code for 96-00 civic ex?
  73. JDM p30 AT Question, help if you can
  74. does it matter what ecu i use??
  75. Will this catback fit?
  76. ** 98 JDM itr motor/ EG cx hatch, what ecu to use? help!**
  77. b16a funny business
  78. engine part not sure what it is help please????????????????????
  79. JDM header question for all you JDM freaks...
  80. Help Motor Is Bogging
  81. gonna buy an engine need some advice>>>>>
  82. egr removal?
  83. swap and pistons
  84. what ecu on gsr head b16 block?
  85. how long does crvtec last?
  86. how can check if a block is legit with the serial number ?
  87. Crvtec shopping list, please help, many questions
  88. jdm p73 spec??
  89. Valve cover cam gear cut outs
  90. best swap for a budget
  91. who know how to splice and extend wires??
  92. Tools to perform swap?
  93. Cable vs. Hydro tranny w/B20
  94. p30 ecu, its jdm right?
  95. HELP! with B20 swap into 91 CRX!
  96. 37820-p73-023 jdm or not??
  97. can you put vtec head on h23
  98. I need some help. Obd1 H22 into 96 accord lx.
  99. Project Civic EK - B18C1 Is In
  100. B series into 3g civic questions.
  101. B18c1 Civic help
  102. tool for flaring fuel line - what is it?
  103. Do secondary butterflies open when motor is reved in neutral?
  104. HMO. 00 jdm b18c spec-r
  105. part number for driver side mount b18c into ek hatch
  106. Help on GSR secondaries (b18c1 into 91 Civic Si)
  107. Swapping 95 Prelude H22A with 98 H22A
  108. gsr swap for 93 civic coupe dx, helP!?
  109. help needed on b16a swap to a 94 civic
  110. Please help me diagnose my bogging with my hybrid
  111. Help, Torn engine mounts, and replacement.
  112. All motor H22a Civic, What would you do to it with $1000?
  113. H22 Engine coolant Temperature (ECT) Questions/help
  114. where can i get a h22 usdm swap
  115. 91 B16a into 95 civic ex need help
  116. I really need help pricing this car.
  117. what headers,intake,cams are good for b18c civic hb?
  118. CV shafts on a H22a swap into a Civic HB
  119. B20 blocks
  120. besides using a diffrent VTEC OIL PSI SWITCH what can I ...
  121. TPS compatibility
  122. Yay my LSD on my Euro 4.785 ITR tranny is f00ked...drove it 3 times.
  123. Websites for places to buy low miled swaps?
  124. Wiring Questions
  125. ECU ???????
  126. Adding wires to a connector
  127. 3 more weeks
  128. selling my HASport H22 EG mount kit
  129. I'm gonna ask: What would it take to turbo my H22a EK?
  130. what is wrong with my clutch
  131. B18C/93 Hatch............Craving Fuel
  132. Where can I get this chip?
  133. B16a 1 into 95 civic ex need help
  134. obd-2 motor & civic harness
  135. Motor Mounts for B18C5 in 96 EK???
  136. FlashOptions.com cheap prices on everything JDM
  137. having probelms with 99 b16a2 intoa 92 integra , need help!!
  138. pr3 ecu, manual or automatic?
  139. does anyone know where to hook up a monstertach on a h22a j-spec more Q's read me
  140. LS motor, EG AC system, del sol bracket, which belt to use?????
  141. Will a 90-93 Accord motor fit in an 89 Accord LXi?
  142. Please help, nearly there
  143. TPS???
  144. anyone from the ny metro espically long island know any good swap shops?
  145. NSX engine swap...
  146. engine swap from 95 sohc to 03 sohc
  147. swap isn't running right gsr swap in cx
  148. Some Pictures.... Totem H22 mounts vs. HCP H22 mounts
  149. B16a1 ecu problem? Maybe?
  150. please help need diagram to wire knock sensor up on a sir2 swap
  151. OBDI engine in OBDII car. problems with passing emissions?
  152. What is needed for a h22 swap if I already have a ????
  153. B18C EG hatch w/Tein RAs & ITR spring rate?
  154. B7 head/block to Z6 Head - DISTRIBUTOR QUESTION
  155. B17 swap: Which car?
  156. New Car.... New Toy..... Advice??
  157. turbo h22...best setup?
  158. LS ecu on a ITR motor???
  159. H22 into EK Dist ?
  160. WTF is wrong with this h22 hybrid????
  161. Import Auto Salvage vs. Honda Motors Online...
  162. What hp do i expect from this
  163. swap problem
  164. B16A in 94 Civic EX HELP!!!!
  165. H22A: EGR on 90Accord , need help wiring thanks.
  166. little random question: what tires to get?
  167. B20 Head on B18B Block
  168. anyone wired vtec thru an rpm switch(msd)?-(SEARCHED)
  169. Small little quesiotn.
  170. H22A swap in a 6th gen Accord?
  171. ACT clutch question - remove small black tabs in Pressure plate??
  172. B17 throttle Body size??? need a quick answer
  173. blown vtec fuse, location?
  174. tpautomotive.com reputable??
  175. b18c1 civic hatch 1/4 times
  176. Questions on a b16a3 into a 1990 LS.
  177. 84mm bore on a b18c1
  178. gsr exhaust manifold ?
  179. where to get a b18a swap
  180. yo timing difference with f22a and h22a are they the same?
  181. Finished mY JDM itr swap
  182. obd1 b16a1???
  183. H22A for $2,000.00 - Good Deal? And Can I Do This Swpa Myself?
  184. b18b dropped in ek with times
  185. wireing an LS motor into my 91 dx
  186. Help CEL codes on OBD2 B18C1 in 00' hatch
  187. b18b in ek/what mounts are needed?
  188. What?
  189. question bout sir 2 change over in a 92 hatch si
  190. H22 problems
  191. can i re-wire an obd2 dizzy to run in an obd1 car??(searched_)
  192. I really should know this by now...
  193. For All You CR-vtec Fans Out There
  194. should i strait pipe my h22?
  195. ecu Q: 37820 P72 A02... OBDI or II?
  196. Finished the B18c1 swap, now the header has a gap.......
  197. HELP!!!!!!!
  198. ebay B17 crank, rods and pistons
  199. GSR Pistons in a B16 block?
  200. high flow cat
  201. how to convert obd-1 harness to obd-2 ??
  202. jdm h22a doesnt start....?
  203. A little B20 Info i need
  204. FINISHING wiring on Obd1 H22 into 96 EK
  205. Hybrid Body Molding
  206. Where to buy swap?
  207. mounts
  208. update on delsol swap.
  209. problem w/ GSR linkage in EG
  210. RHD wiring harness. Can it be used????
  211. Which swap?
  212. h.motorsonline problems about steve (Warning)
  213. '96 Civic DX engine swap
  214. ETown this weekend (TRI STATE)
  215. swap party Augusta ME
  216. 94 Accord LX F22b DOHC engine swap
  217. 92-93 (obd-1) LS wireing into a 91 dx hatch
  218. obd0 b16a into 94 integra what do I need?
  219. My cheap ITR motor!!!
  220. Quick question for Y'all
  221. swap confusion! obd2 obd0 problems
  222. can some one tell me what engine light code this is.....???
  223. ls/vtec stock numbers?
  224. erratic idle!!!-h23/eg
  225. Automatic Swap
  226. B18B into 97 Hx
  227. Hi guys i need your opinions and help!!
  228. i want to swap a zc dohc into a 83 rex how can i make the wiring if i go fuel injected
  229. JDM ITR motor is in......
  230. LS/VTEC swap question....
  231. axels for a b20 vtec
  232. Things I have found out about my h22/hybrid. Comments welcome!!!
  233. EK motor mounts with B18C5?
  234. b16 sir1 firing order
  235. pic of swap with turbo in a 91 civic
  236. Would buying a completed eg swap be cheaper than building your own?
  237. did anyone expect more out of the b18c1???
  238. auto-manual conversion, hardlines?
  239. dx-si swap
  240. Manual to Auto swap question...
  241. h22 civic swap
  242. help.... h23 goin in crx
  243. step by step instructions
  244. header compatibility ?
  245. Osaka motors or not?
  246. Pros and Cons of b18b swaps
  247. Wiring harness in a B18C EK hatch
  248. engine no worky!!!
  249. $1300 for full b18b swap with 3 month warranty sound ok?
  250. read urgent read urgent read urgent
