PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174
  1. 87' Legend- Swap in H22- Is it possible
  2. JRSC on dohc vtec hybrid
  3. VTEC solenoid gasket
  4. eg6 ls hybrid?
  5. legalities of swapping a JDM teg R engine..
  6. Will I need new shocks?
  7. Weight of LS engine compared to a B16a?
  8. b20/vtec ???
  9. need advice on EG swap
  10. MY JDM B18C GSR SWAP COMES THIS FRIDAY!!
  11. swapper arround atlanta
  12. thinking outside the box...
  13. ECU reprogramming
  14. troubleshooting
  15. i just sold my mustang to buy a crx, i wanna do a b 16 swap, what do u think
  16. Unmarked axles-how can i tell which are from Integras?
  17. Question about B16 swap?
  18. B16 head difference?
  19. Getting a B18B Friday..What all do I need for this swap?
  20. Hybrids At The Racetrack (MIR) Yesterday 11/11/01
  21. any one experienced with this swap?
  22. Thinking of getting another EG and putting a B20 in it, which tranny?
  23. HELP!! WHAT ENGINE SHOULD I GET??
  24. H22 Head w/H23 Bottom end? B18C5?
  25. Complete LS VTEC swap for sale!!!!
  26. socal get together this weekend
  27. Symptoms of a bad flywheel???
  28. Engines
  29. Civic Transplant
  30. boring out a b16a..need info..
  31. LS into a 96 Civic EX Help
  32. How much to cut linkage w/ HAsport kit?
  33. Real quick hybrid question
  34. Shiftlinkage for LS motor in Ek??
  35. Throttle body question
  36. Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG?
  37. MAP sensor vac lines ???
  38. b16 wont start.distributor problems...please help(long)
  39. My car won't start. I need help!!
  40. zex kit help
  41. Anyone have my ECU?
  42. what do you think this set up would run
  43. Best Places for Motor Swap in LA Area
  44. Anyone do a LS swap on an EK?
  45. New SMSP Header/Oil Pan Package
  46. swapping a gsr into a 98 hatch
  47. Need opinions on which block to use
  48. question for ls/vtec'ers from ls/vtec'er
  49. Get egale rods
  50. CR-vtec rod and piston questions?
  51. engine mounts for B18C1 into 96 civic
  52. rear engine/tranny bracket?
  53. SoCAL Hybrid Guys
  54. anyone have the book?
  55. H22a mounts
  56. zc Motor in '88 HF
  57. I F#*KING HATE THIEVES!!!
  58. 1994 Civic Hatchback w/GSR swap
  59. where can i get an ls/vtec??
  60. smog issues?!
  61. Engine Swap Costs?
  62. reliabilties of CRVTEC or other frankenstiened motors
  63. Cheap man's ITR?
  64. tubro in a B16A or B18C?
  65. B18C5 ET's
  66. B16 head on GSR block?????
  67. FS: HCP built Ls/vtec motor..$1000
  68. WHERE TO FIND DETAILED INSTRUCTIONS FOR SWAPPING A VTEC MOTOR?
  69. Parting out my b18c5 hybrid
  70. OBD1 motor into obd2 car???? please help
  71. B16 B Civic Type R?
  72. Estimate on what my car will run when its done????
  73. what engine is the best to put in a 96 civic ex on a 2500 price range? and how fast will it be?
  74. B18C5?
  75. Fitting ITR suspension to a EG Civic
  76. Which exhaust for B18c1 in EG???
  77. Is there a difference between between these two motor mounts?
  78. What's needed to make 92-95 Civic Shocks fit 89-91 Civic?
  79. Hybriding a 94-5 Accord..
  80. SOHC vtec motor in an EF
  81. JDM b16 replacement oil pump
  82. Need some technical Info for CTR 5-lug !!!
  83. What to do with 5 G's ???
  84. Which is better for my hybrid... Skunk2 intake manifold or ITR???
  85. Will 96-00 shocks and springs fit a 1992 hatchback dx?
  86. OBD 1 to OBD 2
  87. B20 head on B18C block?
  88. year of engine for swap?
  89. Nippon Motors
  90. VSS code, in b16 87 CRX Si
  91. Shit!!! B20 sucked up water!!!
  92. Hatch differences
  93. 88 civicSI -asph. oval track
  94. GSR or ITR in a EF (need some feedback on swaps)
  95. For those of you with B18C1 Hybrids, post your 1/4 mile time!
  96. 2.0 stroker kit for 1.8 ls
  97. Where should I buy my ls motor?
  98. More VTEC wiring issues
  99. ARP head studs for LS/VTEC...which ones?
  100. Recomendation and price
  101. Troubleshooting FYI
  102. Hybrid Exhaust
  103. engine
  104. WIRING??a A LS motor??
  105. CAMS CAMS CAMS
  106. Finally joined hybrid what next???
  107. selling my 94 b18 Civic $5500
  108. ? Code 8 on CHECK ENGINE LIGHT ? help
  109. H23A VTEC?
  110. Does HASport B series into 88-91 kit use a 90-93 Integra rear mount?
  111. EGR problem
  112. What do i need to have a low 14 sec daily driven jdm b16a crx ?
  113. what do i need to run low to mid 13 in h22 hatch
  114. Question about location of knocksensor(B16A2)
  115. B16 in 90-93 Teg
  116. civic type-R ET's
  117. Beginners Honda Civic Engine Swap FAQ
  118. FS: hcp built ls/vtec motor..$1000
  119. Help with GSR Sawp Throttle body with LS/ITR throttle cable??
  120. Auto 2 Manual conversion:need shoping list
  121. shift linkage ? b16 into 95 civic coupe
  122. Best mods to build an allmotor JDM B18C1 in a 92 hatchback...
  123. Hybrid Integra
  124. H22a into Teg questions
  125. who knows what
  126. 95 civic hybrid spring help
  127. money money money
  128. Engine Swap for 96 EX sedan
  129. Another B20 bites the dust...
  130. LS/CRVTEC 411!!!!!
  131. Frankenstein setup?
  132. swap done.. surging idle when cold start
  133. what ecu to use for LS/VTEC...asap
  134. Which radiator for my B18C1 HB hybrid????
  135. garage kwai?
  136. b16a2 swap into a 92-95 civic hatch, Need help!!
  137. 94' Accord + JDM H22A
  138. Shops IN SoCal?
  139. Rear brake lights stay on...keeps killing battery
  140. Any way to use the DX engine?
  141. Honda resourses: Plently of swap info
  142. How do you tell if your ECU is the correct one after an engine swap
  143. Acura CL lude swap.. any experience?
  144. zeX
  145. parts CD?
  146. Drove a 02 Sentra Se-R today
  147. Anybody running a built allmotor ls in an EG?
  148. Best ECU for 92 JDM B16A
  149. 97-up lude ecu?
  150. intakes?
  151. Will prelude springs fit on a civic?
  152. My JDM B16 powered hatchback...
  153. Air Condition in Hybrid. Please help!!
  154. JDM B20 question?
  155. California Bar on a Civic with a H22?
  156. Swap guide
  157. B16 build-up Options
  158. swap need help.. what is the 5 wire primary O2 sensor?
  159. B21A1 in an EG?...Newman?
  160. where can i get a full type r swap or longblock
  161. B20Z, all motor non-vtec.
  162. can't wait till my ctr cams get in!
  163. Wiring a 99-00 DX for VTEC and maybe EGR?
  164. Dc clutster in EG
  165. EG HyBRid question
  166. Pics of my B18C5-Powered Hybrid EG...What Do You Think?
  167. ::TUNING out a B16A with the V-AFC::
  168. Hybrid 93 Delsol w/ B18C1 swap for sale!
  169. LS vtec block concern
  170. JDM B18C1 swap ?'s
  171. CAI for a B18C1 hybrid hatchback
  172. Where to Find info on JDM B20?
  173. B18A swap in a 1990 Civic DX What am I getting myself into?
  174. Five stud?
  175. Sixth generation civics difference in swaps??
  176. Is the Fields Vtec controller worth it??
  177. Which header for my B18c1 powered hatchback???
  178. Where does the tach wire go????????????
  179. Check Engine Codes on a 96 Dx Harness....HELP!!!
  180. B16a/crx Axle problem..Help!
  181. FS: Ls/vtec long block
  182. Where to get LS motor online....
  183. OBD1 gsr into 91 CRX HF
  184. how the set timing on the LSvtec
  185. Quietest exhaust for B16 EG?
  186. put a B16 in or put a LS engine into crx???
  187. b18b in a civicEX
  188. vtec head
  189. cry for help....
  190. B20b-CRV.....
  191. NOS HELP!!??!!!
  192. Compression Test on motor out of the car??
  193. prelude engine in a 93 civic??
  194. 95 JDM b16 Vs. Gsr
  195. Dx Wiring Problem Help
  196. VTEC wiring problems on a non-vtec car...
  197. Short Shifter for my hybrid.
  198. Any shops around cincy that do motor swaps??
  199. crx b18b turbo?
  200. what cat back 4 a 6g b18c5 swap
  201. JDM B18C1's are more rare than blonde japanese chicks....
  202. ARGHH: Oxygen sensor woes
  203. what to buy with $300-400
  204. Quick question on crv swap
  205. How much boost..?
  206. Compression Ratio?
  207. another ls/vtec question
  208. need help on tranny ???
  209. Just Bought an EK Guys..got some ?'s
  210. Which Pin in the ECU Clips does the VTEC OIL PRESSURE sensor go
  211. ZC into '86 CRX
  212. H22 hanging lower than a B series?
  213. Need some Opinions..........
  214. VX rod and piston and deck height specs
  215. b16a2 vs b18c....$1000+ for GS-R worth it over the Si engine?
  216. FS: Complete ls/vtec swap plus extras...
  217. anyone here in CA with a BAR sticker?
  218. Stand Alone ECU's
  219. TODA Spec B or C?
  220. Hybrid Honda's from Thailand :)
  221. B18C5 trade for B20...
  222. GSR head vs B16A head....
  223. quick motor swap question...
  224. atomic performance- anyone buy a motor there?
  225. JUN 3 cams or type r cams on a B20 vtec?
  226. which ignition system?
  227. two codes left.... any help is appreciated
  228. anyone here actually put oil jets in a B18A/B?
  229. proof that im not a scammer
  230. Can an LS crank fit into a b16 block?
  231. JDM header comparison
  232. setting timing on LS/VTEC???
  233. B16 head on a gsr block??????
  234. could someone...
  235. cl swap
  236. ENGINE SWAP
  237. Need help wiring obd-2 b18c5 into obd-1 5th gen Civic
  238. B18C and B18C5 differences
  239. Bseries Tranny Swap
  240. I need a gague cluster for my 92 Hatchback Dx!! Whats the best?
  241. MORAL OF THE STORY....FOR ALL HYBRIDERS!!!!!*****
  242. H22 Vs Crvtec
  243. code 9 on my B18C....please help
  244. help w/ ls/vtec
  245. Does HASport B series into 88-91 kit have a rear mount?
  246. Who had the DC console in a CRX?
  247. How much would you pay for this car?
  248. 2000 Si gauge cluster in a 1992 DX hatchback?
  249. I need help swapping a JDM b18c1 into my 1992 civic hb DX!!
  250. Airbox for ls/vtec
