View Full Version : Hybrid / Engine Swaps
- jdm itr swap?
- b18 into 86 accord? (some info please)
- OBD b16 Swap Question
- ITR 5-lug suspension swap into EK/EJ Civic
- GSR swapped EG hatch. Exhaust contemplations.
- Reverse swap??
- problem with vtec not working
- tranny lsd question
- rear-disk conversion + camber
- how to ID tranny?
- how much did u guys pay to install your swap?
- installment qestions!
- Timing is advacing to far ahead plz help
- Auto ECU verses Manual
- GSR motor with LSD Turbo or Gsr head with ls/vtec turbo and with LSD
- Need Help Motor Swap.
- 2000ex d16y8 auto civic to b18c manual swap completed, pics inside. 56K friendly
- K20A2 1990 Prelude beginnings(pics)
- ls vtec vs gsr
- Anyone know where they have JDM GSR Longblocks in stock?
- d16z manual into a 99 ex cp AUTOMATIC (d16y8) **HELP HELP**
- PLEASE Help, I have searched. Classic 86 Accord Lxi swap info..(Lets get some info in here)
- are k series swap parts interchangeable between dc and ek's????
- to anybody that has dealt in several obd conversion harnesses..
- ecu for zc
- R not doing so hot...
- GSR ECU? Says ABJ... What is it realy?
- 93 Wiring harness Q's
- What would cause the ECU fuse to blow? H23 to H22 swap.
- DOHC zc swap in 91 Civic Si
- h22a5 into 99 accord
- Another Brake Swap Q HELP!!!!!!!!!
- How can I check a vin # to see if a motor is hot or not?
- Timing belt quesiton
- Can you shoehorn the Jenvey ITB's for K20 into EG ?
- b18c swap into 92 civic
- auto to manual how the hell are my brake and reverse light gonna work
- Jdm ITR question b4 swap
- OBD1 into OBD2 engine swap, need help !! PLEASE!!
- b16a2 manifold bolt up???.......Couldn't find info
- vafc problems???
- hydraulic or manual tensioner on h22a1???
- H22a/F22a1 Frankenstien
- auto too maunual probs
- Problem with tach
- OBD2b motor and ECU in a OBD0 car. Problem??
- Help ASAP!!!! Axle issue or something??
- Camp 1320 k20 swap axles tested :)
- Need help MY TRANNY swap !!? CLICK TO HELP ! EXPERTS ON TRANNY
- h22a5 with atts turbo into 99 accord
- engine runing out of time
- which ecu to use, ? searched
- AEM Hybrid Intake - probs w/ radiator hose clearance?
- ATTN: LS/VTEC OWNERS; which intake manifold
- H22A Civic Stock Radiator but Mugen Thermostat
- Headgasket question
- Very loud timing belt
- Anyone heard about or bought from JDMSOURCE? NEED Opinions ASAP
- h22 5th gen accord list....??
- Quick question.
- ls vtech
- I want a modded ECU, any suggestions?
- USDM B18B in 98 EK Hatch
- '99 GSR motor WITHOUT engine wire harness....searched
- 97 itr in 94 si obd1, use obd1 map sensor or obd2 map
- Valve adjustment? Compression?
- B20 Block with a B18 GSR head bored to a 2.2l
- A/C in a h22 EG
- help me pic out a vtec controller!!!
- Just Bought A JDM 94 B18C and had a few Q's
- I looked OBD1 dist Q's
- obd2 b16a2 into 95 civic Ex.
- Need Help on Finishing off Swap... B18B in Ek...
- PLEASE help me with my hatch....
- CR-V oil pump in B18C1
- Car started...now it won't...give me some ideas...
- OBD1 H22 into OBD2 Accord Wiring Help
- need some help! 99ex to d16z
- ls crank/rods into a b18c1 gsr block questions
- gsr crank in Ls block? + b20, b21(old prelude) for frankenstein
- 1994 D16z6 head on a 1995 Cx Bottom end???
- Tell me, am I jumping the gun? Pics of my engine.
- B16a in 1990 crx si will not start, using hasport subharnes
- Does any one know if the nsx caliper bracket fix the legend bracket?
- i want to know if thir is away to tell if ..................
- help ive searched
- B20/K20
- swap question
- H22a4 vac lines and dizzy
- obd-0 obd-1 swap????
- 0o Car SHUTS DOWN while driving???? o0
- 94 HATCH JDM ITR SWAP CYLINDERS #2 #3 NOT FIRING
- 90-93 DA rear disc brakes on EG ?
- ECU pinout locations
- Best way to modify a B18c1 instead of Turbo?
- Which header stud kit do I get?
- rear mount bracket h22??
- does a gsr tb fit b16/itr intake manifold?
- Thieves break into my car and it's totaled
- stroked b16
- what do i need to do to put a jdm b16 sirII short block in my 99 civic si?
- K20A turbo CRX
- h22 civic W/ZEX fuel pump Q's....
- B18a1 swap into 5th gen coupe
- Which Head Gaskette do I use?
- dizzy trouble
- Need Help with swap
- h22 ek fuel pump??.....190 or 255?
- non vtec ecu
- motor swap blues :(
- Got type s pistons in my h22a, should I get the head milled?
- Disabled egr, is there a way to get rid of the cel?
- dsm + evo = headache?
- JDM b16a plug and play for me?
- H22 in a 95 civic swap WHOLE CAR SHAKES NEED HELP!!!!
- anyone know what happens if a resistor wire disconnects on a fuel injector?
- how would i know if I had type s pistons for sure, whats written on the piston itself?
- LS rods with ITR pistons help
- What radiator for K series into EG
- BATFA?
- obd 1 or 2
- mix and match questions
- JDM ac compressor used on your hybrid?
- Can anyone tell me what harness this is??
- All of the sudden it sounds like im running on 3 cylinders?
- 94 b18c obd1 into a 98 civic ex obd2
- Noise on the driver side where the belts are
- B18c vs. B18c1
- vtec pressure switch Q"
- Another H22 civic axle problem. Please Help!!!
- Any other possibilities?
- 92-95, or 96-98 civic hatch? Which is a better option with H22 Swap?
- what gen b16 does the pr3 pistons come from?
- Methanol to help pass emissions
- obd2 b18b1 into obd1 93 civic
- gsr problems into a crx
- Drove h22 for first time. WEAK!!!!!
- b18a1 into 89 crx, axles?
- CEL CODE 20 PLEASE HELP!!!!!
- h series in sol. egr ground hookup
- LS VTEC high or low compression?
- Need feed back on wiring
- need help after swap!!
- vtec engaging when car is not moving??
- HELP!Bogging/hesitation
- Will 95 calipers fit on 90 teg brakes?
- Mini-me how to???
- What intake mani do i have??
- what intake tube i need to pass ca ref
- Motor Help
- ek motor mounts
- need feedback on ls vtec with gsr tranny
- ECU guru's, decipher this P72 please
- where on a b16z6 is the knock sensor located
- Strange error code....auto trans lockup
- EG w/ gsr Motor Mounts
- lsvtec problems
- d16z6 in crx distributor question
- Need a little help H22A Type-S into a 2000 Civic Si
- H22a Vtec Issues
- Just finished ITR/CIVC swap but NO Ignition power
- can i keep PS and/or AC in my k20 swapped 95 civic coupe
- 98 itr engine into a 97civic. electrical load question... did a search....
- track times h22a integra
- Is the ITR really worth the money?
- What would be the better option?
- Wiring Pr3/Pwo ecu into 91 teg
- Rekindled love for honda quality, now need some performance.(see inside)
- Need help! Car is ticking.
- B18C swap into 98 Civic Coupe
- h22/b16 hybrid distributors
- question about a b18c into my eg hatch
- whats left for my ls swap ?
- wiring a obd0 to obd1
- b18b swap into a hx
- civic cat smog with B18C
- HELP on LSD!!!
- LS/Vtec - gsr or jdm b16 head?
- engine swaps in nc????
- d16y8 to B16a conversion
- very sad day..no its not another stolen thread but might as well be
- B18C --> EG: Hasport mounts, now the hood won't shut
- tranny swap
- first swap is almost finished now i need your help
- zip tie your shift cables? (h22 trans)
- question on hybriding
- h22 3 wires iacv
- Code 5, Map Sensor, Running Rich. HELP!
- AEM Hybrid CAI need advice...
- F22b1 into 90-93 accord... anyone done this?
- vtec girdle on ls and b20 blocks
- hx to ex conversoin? d16y5 to d16y8?
- Cable to hydro
- jdm swap into OBD II car
- d16z6 into 89 crx si? What do i need?
- ?!?!?!?!B16 or Ls?!?!?!!?!?!?
- F22 bottom end with H22 head ??? is this possible
- d16z6 in crx will a obd0 b16 ecu+vafc work?
- can anybody help me
- how to wire IAB
- accord p/s pump fit on a h22??
- h22/civic: got shift linkage from Honda, did I get the right part?
- noise when I turn left...
- d16a6 in a 97 civic coupe
- Why doesn't my gauges work?
- Should i swap hx harness for 99-00 SI harness........b16 swap???
- ls/vtec idle issues
- b16a help
- EG B18C SWAP kNOCK SENSOR WIRING. HELP!!
- NeeDDD torque specs for b18a/b16a2 ASAP!!
- map sensor issues on b18c1 gsr in 91 crx hf!
- obd1 p75 ecu
- obd1 what injectors?
- Engine mounts for D16Z6 to JDM B16A2 swap
- can anyone help me ? 90 si dohc vtec 1.7
- EG K20
- I got b20..I rev...to like 2 or 3 rpm....then it sounds like air just release out of the intake!
- i was just want to know if the 87 intrgra rear disk conversion will work on an EF ?
- a/c
- What year was my ITR manufactured?
- h22 swap, shaking issues..........please help
- K series tranny on B series motor?
- b16a throwing code 9
- H22 VSS Power Steering Lines
- 91 si, b16a1 w/lsd speedo problems....please help
- Motor Question
- b18cr in 92 si, tach not working
- legend brake upgrade on 2000 civic ex
- JDM H22 bogging problem...any ideas or suggestions????
- can i use a 1994 obd1 gsr distributor on a 2000 type r b18c5
- Brakes question: DX --> EX
- Just got the B20 im my 99si. Questions
- B16 upgrades..
- H22 into a 1991 prelude how to rig it
- reputable shops in norcal to do my auto-manual swap?
- obd1 distributor is there a difference
- Wiring an H22a engine
- Mount question need to know quick
- So I finally popped in some ODB I injectors..
- harness problem
- Balancing shafts
- VIRGIN P72 W/H22
- h22 eg
- h22 transmission
- stuff
- b16 in ef sedan, wont start, no spark, ecu code 15
- B20 in a Lude
- H22?
- 1st Time Engine Swap: lots of questions
- Need some help from a tuner that can make me a .bin please
