View Full Version : Hybrid / Engine Swaps
- Del Sol Swap
- itr hybrid question
- ATTN H22a user's SMSP 4-1 header for sale next 2 days...
- B20 alternator belt...
- Q: About interchangability of Type R parts/accessories in a B17a GSr block !
- which head on a ls
- b20 in EG hatch help
- d-series tranny compatability
- Linkage ??
- obd 1 and 2
- CEL after I start the car =T
- best site for b16 swap!
- how much do polyurethane bushing installs cost at a shop?
- b16 in 92 vx teg axles and linkage?
- Endyn breather tank kit
- Which Radiator Fan/front strut brace for H22 EK swap?
- hybrid exhaust situation..
- Performance shop
- jdm itr in my 89 si hatch?
- OBD 1 LS ECU........
- obd1-obd2 tranny changes
- Auto to Manual Swap
- H22 EK intake?
- Final Details in GSR Swap
- straight B20B dyno!
- h22 in civic 4door 1/4 times??
- harness question?
- chip for p28
- OBD0 - OBDI Question
- DX to ZC wiring ecu problem?
- Proposed LSVTEC upgrades..... Suggest an Injector size?
- b16 wiring problem or ecu
- Need some help...the hybrid doesn't pull hard in the upper RPMs anymore.
- what plug???
- gsr tranny and block into coupe
- opinions wanted
- will a first gen b16 fit in a.....
- H22 into 5th gen civic questions
- b16a1 alternater belt?????
- what head gasket do i use???
- 1/4 mile times in a 99 EK HB with a GSR swap?
- Is an S80 tranny a Type R tranny? and are all LSD?
- JDM type R into my 89 si hatch
- Will the stock fuel lines from 87 CRX Si Allow enough fuel for CRVTEC (modded)?
- tranny
- Need a smog hookup in socal!!!!!
- ITR power steering complete system anyone?
- head swap b-18b1 block w/b16a head
- need fields vafc wiring directions please!!
- b16a2 in 92 vx questions
- B20 swap help
- Timing Advanced
- LHT Performance in FL
- What valve stem seals for a first gen b16??
- H22, JDM GSR, or Type R. wich one??
- GSR or H22a Accord (bang for the buck?)
- Whats the best overall swap? *bang for the buck* fast/reliable/easy... cuz i want a hybrid =)
- Exhaust Q?
- ATTN:Swap Guru's.......Fuel Line question
- Does anyone know a website that shows you how to do a LS-Vtec swap?
- please post your b20 b/z vtec/non-vtec dyno plots guys
- New-b with swap info needed
- Cel code 9 WTF??
- For the love of God where is the VTEC pressure switch on a JDM B18C?!
- be all end all to h22/civic wiring :)
- stage2 skunks, stage2 crowers, or ITR cams?
- b20vtec OR LSvtec...what has more potential for NA ?
- Head Work
- swap 97 ex motor into 89 crx
- Hasport Kit
- b20/vtec problems
- Which trannies can i use with this? need advice asap.
- B16a2/ 3rd gen GSR tranny in EJ (95coup) or EG chasis, anyone with this setup
- what cai intake for b16a into EF
- A few questions about a hybrid CRX!
- ? for people who done c5 head on c1 block
- do i need b16 axels for my cx
- mini me timing
- Engine swap for an Integra
- Question about clutch engagment
- obd2-obd1
- h22 going into a DC2...need HELP!
- Code 5, I'm going nuts!
- Is there a conversion harness from obd1 to obd2
- Help with brain fart... doing a swap tomorrow.
- H22 Drive shafts in EK
- H22 won't charge
- how to take off the TPS???
- MSD Blaster coil (when to get new one)
- Question........Help!
- taking out pins
- JDM B16A throttle cable for MY 90 CRX ..HELP !!!!
- ECU Connector Compatibility
- axels
- Need help finshing my h22 swap
- 92 Usdm B18a (ls) in 92 civic cx
- anybody sell a ready to go h22/civic harness?
- Best Fuel Pressure Regulator for the money?
- do you guys think this is good?
- best camshaft for a jdm b16a1??
- Motor VIN plate HELP!
- What Starter on a JDM B16?
- Which ECU 96 EX w/ b16a2 (searched)
- Wiring harness question & Ecu Ref.
- anyone running a CRVtec in their 92-95 hatch?
- Are all B series axles the same?
- Traction Problems
- Noobie Questions About h22 and LSD
- B20 for 2k
- H23/Vtec into a EG hatch
- d16y7 - b20b swap q's...
- Most informative sites on a proper b20vtec build ?
- JDM Engine Swaps (wiring)
- Are the ITR and GSR piston shape and volume the same?
- guage pod
- reguarding APEXI SUPER-afc? (fuel)
- h22 into my 93 hatch
- 95head on 90 - intake valve spring/stem #1 wont pop back up, crank stuck
- Hasport new products
- b20vtec builders in Mideast?
- ITR engine in my GSR? know any shops in so cal?
- help me pick my motor
- and swapers out there in prelude land please help!!!
- built gsr head, stock b20 block...safe to rev 9k+ ?
- b16 swap help
- d16z6 into 91 dx hatchback
- adding an oil cooler to B18A/B or B20B/Z blocks
- 1 gen b16, in a 00 SI?
- A/C Belt in 93 Civic w/LS Swap and Sol A/C Bracket
- Quesion: VSS on YS1? cap the P/S lines or not?
- GSR swap running rich
- knock sensor question
- anyone heard of amsoil?
- B20.....
- 5G civic hb LS/VTEC
- do you think I will have any sealing issues with 86mm...
- b18b complete swaps where to find any
- cometic head gaskets?
- Please HELP!! need engine soon in car!!
- Instaled AEM Fuel pressure regulator, have questions.
- GSR Swap problems....
- i'm officially CEL free!
- Best place to get engines...
- block no. is B20B1
- which intake manifold is the best
- h22 swap, upgrade fuel pump???
- reverse light not working after auto- manual swap
- WOOHOO!! no more CEL
- oil pan dented
- NA honda site???
- Intake Manifold b16a1?
- ecu or chip
- Found a 87 CRX si for 600.00 will a d16a6 fit in it? have one sitting around
- which version of OBD-II is a 2000 ls
- 99 eK SWAP problem with wireing harness,,, need help!
- help!! ls/vtec
- cat question guys
- 86mm block... do I bore out the chambers on the head?
- Shift linkage modification for '95 B18C into '91 CRX
- How do I get rid of the dip in Tq and HP @ around 4,750 when vtec kicks in.
- 92 CX hatch fuel system.. upgraded needed with B18C1?
- Meets
- What pistons and rods for ls/vtec?
- ys1 cable clutch help
- is there/has been any group buy's on HASport mounts??
- Time for a tune up on the hybrid...suggestions please
- immobilizer system on 97+ prelude ecu?
- difference in these bottom ends?
- help on a swap
- comptech Icebox/96+civic/GSR hybrid
- Question about what my car is doing?
- LS/Vtec Computer ?
- battery hook up
- Brand & Source for an INLINE fuel pump ???
- 1/4 mile time for a 98dx with a b16a. bone stock?
- Nitrous
- Tranny option Q?
- PROSPEED PERFORMANCE, anyone heard any good or bad news
- Knock sensor...96 B18C1 into 95 EX
- motor oil for frank?
- 88 civic hatch w/4 speed...help me decide
- is a gsr head better den b16 head on a stock b16a motor
- b18a into a 95 civic
- Double checking rear main seal for 91 b16..
- How much HP can u get out of a ZC running NA???
- OBDO throwing code 14?
- help! I need more speed!
- HCP h22 a/c mount bracket...what is it that i need to relocate? (i forget)
- gsr motor cost
- what clutch for jdm ys1?
- Anyone have experience with engines from Import Builders.com
- My current set: need some help on a few more things
- Recommendations for an inline fuel pump?
- black oil???
- Thinking of doing an lsvtec swap....what should i look out for?
- Emissions help.......
- Need wiring for 2000GSR
- please HELP!!!!!
- need hybrid guru to help with H22 problem
- 00 Si motor in a 97 CX....Problems
- please give me answers
- HCP or HAsport AC bracket on EF
- LS N/A questions for people who have it
- Getting ready to drop b16 in my rex. Need help
- Looking For Used and Unwanted D series blocks heads etc in SoCal area $$$$$
- 00 GSR motor in DX engine mount help
- H22A / Accord Not SHIFTING!!!!!!
- B series oil pans ?
- Strange Engine code
- popping sound???
- Motor question!
- ??? LS vs. CRV
- what do you think I should do? (options and dillemas)
- stupid question
- Intake Manifold Conversion
- 1s gen b16a in a eg
- H22 in a '97 integra????--Need HELP!!
- H22 in the Midwest?!?!?
- Do you need cubes if you have no weight???
- what swap is good for me???
- Question for anyone using Place Racing mounts
- Anyone use Technosquare ECU Tools?
- voltage too high
- Anyone ever use swapjdm.com?
- B18C in EK; ecu wiring pin help
- AEM intake to used in a 99 civic dx with a b16a engine
- h22a 88si crx help??
- IAB....?
- Which clucth to buy for cable tranny crx..
- Starting car...D16 ecu and B18C ecu.
- b16 swap almost done please help
- 88 hatch DX, swaps??
- I want to do LS/Vtec and dont know where to start
- H22/Civics come on in?!!?
- 95 Accord VTEC into an 88 Accord LX-i... possible?
- p72 for PWO or PR3 ecu,even trade?
- 87 integra engine into a 86 civic
- web cam's website?
- Wiring Info
- need advice on engine to get!!!
- B18 into civic hatch
- Some info on B16 heads for a CRVtec swap
- Broken motor mount bushing in 97 Civic EX hybrid R
- b20 swap in 94 civic.
- S2000 Start button
- je pistons for d16
- b18c1 bottem end build up
- CTR pistons?
- Crank opinions on LS/VTEC
