PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. B20vtec ARP rod bolt size/part number
  2. H23a Vtec Bluetop Wiring Help
  3. h22 swap wont start
  4. 00 civic h2b swap need help
  5. warm start issue
  6. Ls/Vtec Question
  7. choice of ECU for EK to B20 swap, emissions issues...
  8. civic wont crank
  9. B20b questions
  10. Running lean!
  11. ls vtec hesitate to rev
  12. Ls vtec chokes and lean when press gas
  13. Which engine with a CRV RD1 transmission???
  14. Gsr with H22a power steering pump?
  15. b20 0b2a sensors needed?
  16. J-series in a BB6 (prelude)
  17. axle play on drivers side b18c r
  18. Has anyone heard of King Engine Co.?
  19. Have a ctr motor should I go a different way ???
  20. swap help needed!!
  21. 79 Cvcc Powered by the B-SERIES
  22. where is a new h22 and transmission
  23. Obd1 gsr swap into 94 civic si
  24. h22a1 swapped civic help
  25. 97accord lx coupe swap
  26. 1997 honda accord lx coupe swap
  27. LS Vtec piston choice
  28. HX (Vtec-E) Into Civic LX
  29. H2B Swap Help
  30. o2 wire conversion question
  31. B18c jdm type r??
  32. BAR'D H22A 93 hatchback - Not started or registered since 2008
  33. F20B cable tranny help!!!!!
  34. H22A in a 2000 Honda civic
  35. my poor mans type r build advice/suggestions help lol
  36. 71 N600 w/ engine swap and RWD conversion
  37. 99 ek 4 door
  38. h2b intermediate shaft help, please
  39. Latvian Civic EG AWD Vtec
  40. B18a1 build
  41. b18a1 engine swap question
  42. 93 civic ecu/wire harness help GSR swap
  43. specific B20Z block gsr head
  44. Where can i find cheap h series motor swap mounts
  45. Best engine for my EK coupe?
  46. AWD Civic/CRV build w/ pics!
  47. ek coupe
  48. obd1 injector clips to obd2 injectors
  49. is LSD worth it?
  50. 2000 honda civic d16y8 swap to jdm b18c gsr problem
  51. 97 civic/h22a swap/chipped p75 ecu - in limp mode with no speedo
  52. better intake mani. to use
  53. F20B valves please help...
  54. G23: F23 Block H23 Head
  55. h22 vacuum/wiring harness problem. (yes, a big problem)
  56. num.1 cylinder not fireing
  57. 94 hatch/lsv - back fire
  58. which H series for my H2B swap.
  59. H22 swap done by previous owner. which engine mounts are that?
  60. LS into 93 EG Hatch?
  61. engine swap and car insurance
  62. B20 Throttle body size help
  63. b18b swap in a 2000 civic
  64. Ls/Vtec questions
  65. anyone bought from jdmstates.com in houston tx?
  66. jdm swaps in so fla ??
  67. New to Honda Engine Building... B18b1 Need advice
  68. k24/k20 all motor swap/build
  69. MINI ME SWAP; stock d15 to d15 block with y8 head
  70. PnP ewh
  71. b16b in to 94 del sol
  72. Putting F20B In Honda City Type Z
  73. Help identifying an engine swap
  74. Rich at idle, lean when on throttle??
  75. Gsr swap ecu help
  76. IAT TESTING
  77. F20B timing belt, water pump, and belt tensioner change
  78. del sol swapping in a b18b1...some questions
  79. What do I need for my new engine?
  80. Is this a real JDM ITR block ?
  81. 89 ef sedan 4wd b series turbo build
  82. Low compresion or high compresion on ek b20????????
  83. Lsvtec crx running issues
  84. K24/K20 Frankenstein
  85. engine swap prob
  86. h22 civic, which throttle cable
  87. B18B1 into 98 Ek hatch
  88. Ewh diagram?
  89. jdm b20 flywheel bolts?
  90. LS-V Turbo or LS-Turbo
  91. D16Y7 To D16Y8 Swap
  92. LS obd1 engine harness diagram help
  93. zc/z6 help
  94. b20b fuel systems
  95. engine bogs out at rappid acceleration
  96. 96 ls rpm fluctuation with steady throttle
  97. NEED HELP! car wont turn off after swap
  98. gsr swap into 00 dx hatch need input
  99. B17A1 to B18C5
  100. '97 HB H22a Swap - Do I have Accord or Prelude Intermediate Shaft?
  101. F20B 97" Civic Ex swap
  102. EG si GSR swap
  103. EM1 vs Integra Shift Linkage
  104. B20/VTEC vs GSR with LS Crank
  105. TPS issue?
  106. ref question?
  107. B18B1 swap questions.
  108. B18c4 in ej9 vtec spool solenoid
  109. Price range for a proper k swap?
  110. My traditional H22a civic swap!
  111. B18cR, CEL 8 & 14, Crazy idle, Severe bucking while at speed
  112. Help w/wiring in EG
  113. B18c1 99 civic SI
  114. Car has no spark?
  115. Wow crazy, newly installed engine has mounts break!
  116. H22 axle issue..
  117. Need Help b16a2 block with ctr pistons and gsr head
  118. F20B vs H22A
  119. Swapping Help
  120. EG b series post mount, same bolt spacing as EF D series post mount?
  121. Running rich 94 cx hatchback b18b1 please help!!!!!!
  122. crx b16 2nd o2 sensor wired to knock sensor?
  123. odb1 code test harness?
  124. f23 question into del sol.
  125. G23vtec Info
  126. F20B, ACL or Bisimoto Bearings
  127. F2B hood clearance in EF
  128. 91 civic hf obd0 to ob1 / h22 swap... wireing issue.
  129. H22a EJ6 CV Axle Boots... they're fucked
  130. EK3 Hatch B16A DOHC swap!!!
  131. j swap getting parts together
  132. 98 Integra DB LS OBD2a with 95 rebuilt stock gsr obd1 engine, ecu problem
  133. head gasket question
  134. B16 EG AC bracket issue
  135. y8/y7 mini me with stock p2p ecu
  136. B18b1 engine and LS tranny.
  137. H2B What slicks, what psi to run at track? HELP!!!
  138. h2b and hood clearance
  139. rear T bracket for H2B EG
  140. b series or d16y8/d15b head
  141. 97 civic lx all done but engine/paint building b18c1
  142. h22a swap into 95 accord misc. questions
  143. j32 vs k20!!!!
  144. trying to fit an EG drivers mount in my EF chassis
  145. B Series Ek Swap Help
  146. H22 Manual tranny to auto longblock question
  147. How to tell if dowel pins are golden eagle
  148. ef hatch LS-V/T build
  149. OBD1 LS INTO OBD2 INTEGRA
  150. Ring end gap for B20 VTEC - PHK Pistons
  151. 1993 civic dx d15b7 to b18c JDM GSR swap
  152. Help!! Obd1 to obd2 swap problems
  153. 99 accord, h22a4 swap, dreaded misfire... help?
  154. obd1 92 civic hatch obd2 b20b
  155. 95 civic ls swap CEL CODE 16 cylinder 4
  156. f22a6 crank in h22a1 block help help help
  157. Civic b16 Wiring in custom chassis
  158. "G23" Build Thread
  159. F22B1 block F22A head build and swap
  160. Swap into 95 EX HELP!!!!
  161. J series swap
  162. Questions for future H22/H23 EK swap
  163. 95 LX d15 auto to d15b auto Information needed...
  164. H23A Swapped 92 Civic wont start
  165. b20z2 block b16a2 head
  166. B18c1 crankshaft on b18 non vtec block?
  167. honda civic shell - what engine swap?
  168. 2000 Civic Ex B16A2 Swap
  169. Help going crazy cant find the problem!
  170. What kind of power should I be making?
  171. Doing a swap into my old Fiat, sell me on your preferred motor.
  172. H22 swap quetions plz help
  173. H22a1 in my hatch
  174. H22 Sputtering at 4.5k rpm
  175. Question for anyone with an H2B Crx
  176. LS Vtec or B20Vtec?
  177. 97 integra swap
  178. Piston-to-Valve clearance question for G23 build
  179. K Series to Tremec tranny bellhousing?
  180. F20B to EG Swap
  181. motor mounts
  182. 2012 Corvette with B18c swap.
  183. 01-05 Civic Non-Vtec to Vtec
  184. 08 civic 4dr Bswap?
  185. Mini Me Swap Question
  186. D15z1 into 95 civic coupe EX QUESTIONS
  187. k20 swap
  188. my H2B power output? and drivetrain loss on dyno?
  189. engine importers catalogue?
  190. Help!
  191. H22 swaped eg. Wont get spark need HELP!!!!!! PLEASE!!!
  192. Swap H2B!! HELP!!
  193. b18b1 swapped into 2000 ek civic - Ecu Problems
  194. H2B N0 Power barley runs.......
  195. What engine would you recommend for a EG?
  196. h22 swap
  197. Opinions on swap, k to ef
  198. H22A/ H2B Balance Shaft Removal
  199. B16A mild mods, worth swapping everything to b18a1?
  200. B16A mild mods, worth swapping everything to b18a1?
  201. OBD1 GSR manual into Automatic OBD2B LS wiring questions
  202. GSR Del Sol?
  203. Guys I need help badly..
  204. Del Sol Swap?
  205. BC cams or crower stage 2 cam h2b?
  206. 92 accord v6 swap?
  207. whats needed from parts car for vtec head swap to ls block
  208. h22a1 timing belt change write up
  209. Hmotorsonline.com??
  210. b18b swap 95 civic no fuel! help!
  211. wire tuck
  212. Jdm H23a with PDE Head
  213. what radiator and slim size fan....
  214. Turning my H2B into a daily driver.
  215. B20 Vtec
  216. b18b obd2a + 97 civic ex wiring or engine issue! Help please
  217. HELP!
  218. H22 swap in 96 ek issues!
  219. 1994 Civic with H22A2 swap problems, P28 ECU HELP !!!
  220. h22a1 civic start up problems please help!
  221. b16a2 oil pump work on b16b ctr
  222. no tach with b20 vtec swap...
  223. b18b map sensor question
  224. ls vtec head bolts
  225. 92 EG SI B series AWD conversion!! help plz!
  226. 96 civic ex h22 swap
  227. F20b with h22 head! Need help!!!
  228. civic h22 swap start up help!!
  229. B20b ecu Swap
  230. H2b dizzy help
  231. 84.5mm b20 vtec
  232. h22a1 civic start up problems please help!
  233. obd2b H2B swap in 99 civic ex
  234. ACL Bearing questions. LSV
  235. Help!!!! I need H2B, JDM Accord/Torneo in Russia
  236. Help! Need an H2B fork ASAP!!
  237. F22 into 1997 prelude SH
  238. Which Transmission
  239. 2000 civic sir b16a2 swap to b16b
  240. EM2 K20A2 Swap Cruise Control?
  241. New discoveries with my EK-22
  242. 97 civic H22 swap, what axles do I need?
  243. 96-00 civic b18b swapped. exhaust help.
  244. Looking to do civic H22 swap.. need info please!
  245. 99 civic hatch h22a swap limp mode help!!
  246. RX7 + F20C
  247. H2B Swap questions
  248. b20b/b16 head with ob1 b16 intake manifold
  249. Eg Owners!!!
  250. Removing AC from a 00 EM1
