PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. F.I.T.V ?????????
  2. Hybrid H22a motor? Pics inside
  3. LS Header fit B16A?? Need HELP quick
  4. How much would a swap cost?
  5. Will dropzone's kill me
  6. JDM d15b-d16z6 parts compatibility
  7. nOOb thanks...
  8. h22eg, how can i tighten my steering wheel?
  9. Gsr motor burned in fire
  10. LS engine overheated with swap
  11. JDM DC5-R brakes on DC2-R suspension
  12. Rear disc swap Q!
  13. asking for my boss: f22 vtech?
  14. Jdm gsr front clip
  15. I wanna learn about the k series
  16. B20 swap problem w/ fuel pressure
  17. Got a garbage B18B long block from Hmotorsonline... here is my story
  18. chipped p28 ?
  19. Can get my swap to start
  20. Heard of H22/EG springs????
  21. exhaust compatibility with swap
  22. anyone seen a rwd civic?
  23. Yet another idle qustion. Searched already and nothing
  24. I want to pass emissions
  25. annoying rattle coming from intake manifold
  26. how many bolts in OBD1 GSR alternator? (searched)
  27. problem with ZC to D16A9 swap
  28. HELP!! GSR/EG swap wiring problem
  29. P30 ECU... Looking for heater in O2 Sensor?
  30. Need Hlep Doing A Motor SWAp in VA Beach Area
  31. I have a problem when i am crusing.
  32. I have a problem with my cluster please help please.
  33. 2000 gsr motor in 92 civic si
  34. anyone done business with flashoptions.com?
  35. Wiring Problem! HELP!
  36. 92-95 mounts?
  37. Best Exhaust Diameter for Euro R Eg.
  38. Hasport header for EF with B swaps!
  39. A LITTLE OFF TOPIC
  40. Wanna see some K20 swaps?
  41. ARP headstuds: z6 block/y8 head Which studs?
  42. ZC/Si on an HF ? already searched.
  43. QUESTIONS FOR THE N/A ENGINE BUILDERS
  44. identify this vtec cam....
  45. question: B18c swap in an auto Civic hb
  46. Great h22 swap article.
  47. engine harness and hoses help...
  48. mounting non-atts tranny to atts block *searched*
  49. 97 B18B1 into 92CX
  50. need help from the N/A engine builders
  51. Clutch Question
  52. AWD... b20VTEC question...
  53. New buildup project (building it for my daughter) check it out
  54. Oil Line Kit
  55. K-series in EG Chassis - Keep this topic ALIVE!!!
  56. Ls-vtec HELP....
  57. z6 in ek ?'s help!!
  58. rev limiter on b20
  59. ecu question
  60. obd0 obd1 alternators
  61. JDM b16a2 into 00 civic hatch?
  62. mounts
  63. 94-00 GSR motor mounts and axles
  64. b16 swap question (trans)
  65. H22 EG--- what sway bar are you guys using
  66. best way to find TDC on a shortblock?
  67. swapping b16 shortblock for a b18 shortblock. easiest process?
  68. Idle problem... revisited
  69. need a engine?????????
  70. where can I find pr3 pistons?
  71. i need to find a shop in socal for changeover
  72. 23mm ITR Sway Bar On 90-93 Integra
  73. car craps out when it hits VTEC
  74. which throttle cable do i need for a gsr in a 88 crx dx??????
  75. ls/vtec
  76. 98 Prelude 5 lug onto a 98 Accord 4 lug?????? Possible!?
  77. are 2001 civic hx's capable of being swapped out with k-series?
  78. i wondering wath is your dyno result for stock civic h22
  79. d16y8 into an EK
  80. Password JDM engines
  81. JDM D15b in 88-91 CRX - Help
  82. F22/23 Swap
  83. Is there a difference on 5 lug conversion?
  84. HP gain after Rebuilding Motor
  85. 2000 Civic SI with b18b swap (ECU problems)
  86. In need of fuel pump suggestions.
  87. D series mount/bracket bolts compatible with B series mounts/brackets?
  88. which injectors on my integra(h22a swaped)
  89. ordering b20. half shaft the same?
  90. h22 civic exhaust
  91. anyone done a h22a into a 92 teg ,, i wanna know what problems
  92. JDM B18C Type R into 92 Cx - pro's correct me
  93. R&D ON MY PROJECT
  94. D to D series
  95. Need information with swap. PLEASE HELP
  96. timing belt help----
  97. Hybrid B18B with b16a internals
  98. 89 hatch with a b18c1 obd1
  99. B18C1 in CRX
  100. What are engine swap possibilitys for 3rd gen prelude?
  101. what injectors to use?
  102. calling crvtec owners
  103. idle air control problem?
  104. Back on the road, thanks! and need some help still...y8 swap
  105. Wiring harness for K20 swap
  106. transmission?
  107. need help in central jersey area
  108. accord -> prelude
  109. Should i do it?
  110. B18b swap into an automatic EK?
  111. Swap shops in Georgia or Louisianna. Need adivce.
  112. h22a in 98 EX, BUT Power Steering won't fit. WTF????
  113. What alternator?
  114. k20a swap into 03 ex
  115. p13 ecu SEARCHED!
  116. jdm k20a3 into a 03 civic lx ?
  117. got spark... got fuel.. no go hommie.
  118. Found a way to convert JDM VSS clusters to read in MPH..........FYI
  119. Has anyone mapped out the ECU and/or chips?
  120. 3, 6, 19 CEL, what are they? B series...
  121. Need a pic of an EG with no dash and no condenser
  122. Heater core hoses on B18c??
  123. Easy Engine Install Question
  124. Cable/Hydro tranny: Shift Linkage Differences?I've heard of a lot of people using GSR shift linkages
  125. Check this hybrid out lol
  126. civic swap H22A rear bracket
  127. 91 Integra motor,harness& ecu swap into 92 civic? I know it will fit but will it work??
  128. k24 swap into my 96 civ HB??
  129. Legality of swaping a B20Z into 98 civic hatch in canada
  130. Supercharged Integra Engine in 92-95 Civic Hatchback...
  131. ek swap...
  132. Anyone have these few problems with an h22 in an EX????
  133. swap legallity
  134. Help me decide?
  135. SOHC y8 and y7 questions
  136. Car will not start!! Info Inside Auto-Manual Troubles....
  137. best place to buy H22?
  138. need help with exhaust
  139. What else is needed?
  140. 04 Civic Sedan with factory installed K20 engine
  141. running rich/black smoke with b18c1 swap
  142. h23a in 4th gen accord
  143. B16a into my 00 civic hatch, How do I run my whole exhuast system?
  144. ecu question about del sol dohc vtec
  145. PICS OF MY HATCH SWAP
  146. would it fit?
  147. Oil squiters for ls/vtec????????
  148. B18C5 in EG Hatch
  149. where can i find 110 out of the pump in OC
  150. H22 into 95 civic hatch SI?
  151. B18 JDM GSR ENGINE INTO 91 CRX SI ADVISE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  152. SPARK SHOW!! swap help, LS into EG
  153. NEED HELP!!!!!!
  154. Throttle cable
  155. ITR to GSR swap question
  156. h22 Boost done right..
  157. ecu help
  158. tried to pull codes today....
  159. ecu?
  160. b16a2 into 95 dx EJ coupe how to keep a/c
  161. WIll a d16y7 distributor work on a d16y8 head?
  162. will 1990 Integra engine fit in a 1993 civic?
  163. Need some advice
  164. ITR(96) engine in EG, which harness?
  165. 15 or 16 for h22 eg
  166. Which springs for H22a Civic?
  167. need help on ls swap into a 93 eg
  168. progress suspension...anyone have it?
  169. where do i get header wrap?
  170. test
  171. Question about o2 sensors
  172. obdII p13 ecu
  173. Spark Plugs for B20 Vtec
  174. LS turbo swap
  175. Testpipe and 02 Sensor
  176. 92 eg si and jdm b18c-r
  177. Does anyone know a good cheap place to get Swaps?
  178. B series injectors in a H22A??
  179. h22a idle problem
  180. H22A4 94 Del Sol Running but...
  181. For all those with JDM H22's
  182. b20/b16 hybrid
  183. Which axles for a 93 hatch w/ 1st gen b16 swap? Searched, conflicting answers.
  184. Pulley's really worth it?
  185. B18C1 in EG Coupe/hatch...need advice
  186. b20z vtec questions
  187. Trying to find... OBD2A to OBD1 Jumper Harness
  188. some info
  189. ZC headbolts in an ls
  190. OBD-1 alternator plug ?
  191. H22A Swap into '91 Intergra LS PLEASE HELP...
  192. :two thumbs: for Raxles.com
  193. need help!! car won't start on b16a
  194. 4x114 ITR Brake replacement parts??
  195. GSR/DX- CEL #1, normal performance, gas mileage
  196. O2 sensor HELP
  197. Need help on 92 hatch swap sohc vtec..
  198. steering problem
  199. Very Weird Swap, Need Help
  200. Can someone link me?
  201. benfits of an overbored throttle body?
  202. engine wiring help
  203. which clutch cable in b16 rex swap?
  204. h22a swap into 93 accrod
  205. Extra plug on swap? LS -> VTEC
  206. Poor man's R Compression Q
  207. Anyone have wiring diagrams for 89 DX hatch (engine harness)
  208. Just got the new engine in
  209. Calling all Crvtec owners
  210. Piston question.
  211. D16y8 or D16z6 worth putting in a 1990 honda crx hf??????????
  212. H22 into a CRV... been done ?
  213. WIRINGG GURUS HELP! SiR Harness into DX questions
  214. What Kind Of HP Gains & 1/4 Times
  215. ls throttle body on d16y8?
  216. GSR in hatch.....ecu fuse keeps blowing
  217. b18b header in hatch
  218. 1st Gen JDM B16A into EG hatch
  219. shock absorbers i need to find some shock absorbers for my prelude 88 anyone
  220. ls head with b16 springs and retainers
  221. new built motor wont turn over..!!
  222. D15b2?'s
  223. LS into EK....upper motor mount question, need advise quickly....tonight!!
  224. Distributor Fitment Question for B18C
  225. help!!!!!!!!!!!! h23 swap... not starting =(
  226. B16B Water Pump Question
  227. K-series into 5th Gen civics
  228. HCP website?
  229. EG hatches with GSR swaps...
  230. EJ suspension Question
  231. rpm jumping between 1500 to 2000 rpm
  232. need help with jdm b18c in cx
  233. B16A 92-95 (SiR-II) into a 2000 Civic Si
  234. eg h22 suspention setup
  235. how much is my ride worth ?
  236. imagine engineering in an h22 eg pics
  237. need help with vtec wiring on b16a
  238. d15b??
  239. place race mounts
  240. B20 Head ITR Intake Manifold?
  241. oil in spark plug cylinders...
  242. hmm..18 or 20?
  243. Where Besides JDMHONDAPARTS To Get JDM Exhaust Flange?
  244. D16z6 into a 95 4dr LX
  245. gsr swap ?
  246. ECM is it bad?
  247. Heater stays on when car is turned off. Can anyone help me?
  248. how do i run my msd rpm activated switch
  249. idling super low...
  250. Exactly what engines will bolt right into
