View Full Version : Hybrid / Engine Swaps
- buying a used swap - opinions? (sorry i know these are annoying ?s)
- need moderators help!!!!!!!!!!!!!!
- usdm gsr vs. jdm gsr?? pros and cons.
- Anyone running with heater not connected? any problems?
- stuff for sale
- how could I...
- engine codes
- b20vtec timing mark problem & CAI question
- JDM B20B Rev Limit
- Your Definition of Wiring Harness
- crank pully
- does any one know a company that makes a header with 2 o2 bungs?
- Need help quick!
- Correct way to time a honda motor...in Order!!??
- throttle bracket for skunk2 int. man.
- need help!! cant get swap running
- Car died (Oil flooded spark plugs)
- sleeved H22 w/type S pistons
- Constant Flashing code 8
- b18c5 into a 95 civic CX
- Auto to manual conversion parts list, please?
- h23 hatch
- brake problem please help!!!!!!
- crower rods
- About MY Victor X Mani
- What should I put in a 89 dx?
- ZC into 90 CRX Si......easy as dropping a D16a6?
- 1st 60 miles with b16. (some issues) kind of long
- do i really need all this stuff...
- b20/Vtec b16 head, Will 94-95 Del So b16 distributor work?
- proper tach and speed reading for my H22 swap
- classifieds
- b16a swap disaster story....(long)
- Ecu's
- Integra G2 (B18A) OBD-I fuel injectors ---work in---> Integra G3 (B18B) OBD-I ?
- redline on B20?
- 96 cx distrib in my B20Z?
- Help weird noise from b16
- 96 rear disc conversion - which prop valve?
- need help '92 cx + '00 B16A2(with the '00 Si ECU)
- newbie w/b16b question
- Y8 Mini-me completed! / why does my idle rev?
- How do I wire a cx engine harness for vtec?
- Price of ITR swap.
- ya or na on AC/PS bracket on a B20b into a EK
- swapping a GSR manual into a 00 civic DX automatic??
- OT: Big for sale list
- serious project
- Oil sending unit thread size.
- oil line kit..
- Accord crank in H22A block
- new swap jumps at idle
- hyrbid classifieds
- B18C knocking!!!???
- H22a or H22a "Type-S"???
- Swaping in TN?
- the first B20VTEC Prelude in the world...
- JDM ECU, has speed limits?
- 92-93 LS longblock to 92 dx
- how to check engine codes
- Wiring my B-series EK-need some help
- 2nd Gen B16A, 92 GSR finally on the dyno with A/F curves
- Question about building a block.
- quick b16 intake manifold question
- gsr crank in ls block??
- b18c5 head on b18c1 block
- Confused about motor mounts. Please Help
- any ls/vtec tuning tips
- Strret/Race Tires
- what intake should i "really" be using on my b16 hb?
- reverse grinds. please help
- LS crank and CTR pistons in a GSR block
- No Vtec getting code 17. Need Advice??
- B18C bottom end with B16 head...
- prelude sh swap in a accord
- what is the right header for the b16-or does it really matter??
- b18c
- ekh22 mount question?
- EK H22A swap <---what axles???
- jdmhondaparts does SUCK
- Need help with O2 sensor for B18C1 in EG
- jdmhondaparts SUCKS
- ZC flat accel between 3500 and 6000
- MSD RPM Activator
- Who's rods are the best for the money?
- Place Racing Mounts
- Type R Throttle Body
- Did you replace your oil pump prior to install?
- GreAT LaKeS DRAGaWaY IMoOrt DRaG waRs oct. 20th
- b18A into 98(ek) civic???
- Opinions on HCP's new EF-18+ mounts and linkage?
- Anyone ever hybrized one of these?
- price quoting on first gen LSD tranny
- Attn: CX hatches w/ LS swaps, whats ur typical MPT??
- del sol ac bracket
- '00 gsr swap into 97 cx hatch..help, some bugs i cant work out
- ECU-immobilizer question
- About My B16a1
- b16a1 swap questions
- what about it?
- Which Wiring harness? ZC sohc in '89
- no power to fuel pump/starter...need some help
- couldnt find in search, b18a in crx
- h22 in a 94 integra
- Calling all +++JDM swap++++ gurus!!
- are new sleeves needed for n/a crvtec making ~215whp?
- LS/VTEC upper PS bracket?
- will obd2 engine harness work on obd1 engine?
- need help, dam frustrating
- WTB: B Series cable tranny with LSD
- Brown Valve Cover ZC motor question
- Timing adv on ZC (how much is safe)
- 0pinion on swapping internal
- Why not HMO??? What gives fellas?
- Tranny swapping question
- Slimy Sticky Plug on F22A
- B16 Tranny
- Testing the Waters: Red GSR Converted into a B20Vtec ITR!!!!!!!!!!
- Mysterious "check engine" light, code 3.
- Wiring conversion from 96 dx to 97 ex or i need a 96-00 ex wiring harness
- Is 253hp/264ftlbs in a hatch worth trying?
- SOHC vtec into 87 possible??
- have 2k to spend on mods
- prelude 4 wheel disc's on civic EK (cheapman's big brake upgrade)
- Anyone here bought a engine or block for importbuilders.com?
- b20/vtec into 90-93 integra ls, good idea?
- B18a in 88 DX questions
- Does anyone make wiring harnesses on here?
- Half shaft???
- Swapping problem, techincal question
- JDM B18C questions
- Mother of all Honda swaps ...
- I need a 92-95 ex/si wiring harness
- What could I do with an 88 integra?
- Does anyone know, or know someone who has....................
- Exedy or ACT?
- knock scencor
- wiring truble
- GSR brakes on an EK
- H22 swap guys...got a clutch alignment tool I could borrow!?
- Still using the '93 CX fuel pump for my H22A, need some fuel pump options.
- ac problems gsr swap civic pump
- obd-2 LS swappers
- ITR rear sway bar on an EK hatch
- 96 CX with JDM B16A.... Need Some Help
- 93 civic cx swap?
- gotta question........
- B16 surges when cold
- Best choice for a headgasket?
- how do the h22a handle in a 99 civic ex?
- Car wont start!!! Please take time to see if you can help.
- Going all motor, need advice on crvtec
- H22 arrived. Should there be a transmission bracket on it?
- test piping
- EK engine in an EG shell - does it work?
- Just got my h22 from HMO...
- 2kSi engine harness into a 97 hb dx body. Question about diatribe with Katman...
- Mini me swap: will these ARP head studs work?
- h23vtec/turbo or b20vtec/turbo
- Question on exhaust fitment
- MAP Question for B16a
- does anyone have a crvtec setup with stock bottom-end...?
- d15 turbo...wanna chage my head
- b20 swap finished
- So what am I gonna do do get a tach? b20z dizzy question
- Speedo going crazy, sometimes working-sometimes not
- ls swap questions..
- 92 Honda civic Vtec swap!!! loaded leather seats etc etc CHEAP!!!
- b17 speed sensor problem and ecu question
- gsr head on a b16 bottom end???
- New problems/discoveries in Mini-Me swap (Y8), please help
- So my JDM ITR came in today. Acouple quesitons.
- S1 tranny...
- Accord motors? Eg Hatch
- Code 19, b16 in crx
- how to get a 99 civic coupe ex hybrid into the 13's??
- 94 b16a3 in a 98 hatch dx????
- NEED: Help swapping 92 SOHC VTEC motor into 92 CX..NJ/NY area!
- 94+ Integra radiator fit in 92 Integra or are they sized different ?
- ecu pinouts for h22 crx
- ECU pinouts for a 97 GS-R or Type-R
- h22 swap questions
- For a friend, ef zc swap- throttle cable. Is stock SI wrong?
- h22a4 swap into a 92-95 hatch
- will a b16a1 tranny ecu and head mate to b18..?
- crv ecu???
- Toronto members lets try this again.....
- Civic battery is a goner. What to replace with for h22?
- h22a ecu
- H22A1 ctus at 6500 rpms, no codes, VTEC works
- ThrottlePossitionSensor DPFI to MPFI SWAP...?
- Attention Toronto, On, Canada Members * October 17th Meet "ROLL CALL"!!!!
- Advanced h22/civic question??!?
- FPR question
- can someone give me a complete parts list for doing a ls or b20/vtec in a crx..?
- Do JDM engines/ecu's/whatever have governors???
- o2 sensors.....
- B16a Intake manifold...
- pix of my swap ,what do you think ??
- uh oh?!?!?!
- taking motor out need help
- ultimate hybrid
- "papers" for swap?
- ecu question
- Engine mounts
- sh block questions
- SlvrEj6Dx i got some questions ????
- Engine mounts?!?!
- Starter/ Tranny question
- -> Need to know's when purchasing a used engine ....
- nj tuning?
- ALLMOTOR hybrid build question / comparison? need opinions
- ZC bogging @ 3100 rpm
- need your advice???
- engine wiring harness question
- quick LS/VTEC question
- What is the easiest Hybrid engine for a 90 CRX Si?
- p73 or p72 ?
- -DONT want to hear NEGative BS about this. H22 swap for CRX Si, what is needed?
- Same year engine?!?!?!?!
- B20B or B20Z with a VTEC Head
- h22a-civic
- type-r cams in b16....
- b20b non-vtec ???
- 6th gen DX harness, good for D16Y8?
- Swap: the weirdest thing...
- h22 place racing mount broke in my civic first day at the track!!
- ITR oil and water pump on B16a
- B20B + GSR Tranny
- H22 Civics, what clutch master cylinder did you use?? civic or prelude?
- vibration and humm from back of car
- B18C1 in 88-91???
- h22 swap in a 2001 accord
- New sig for Vtecpimp, how do you guys like it....
- MMMmmmmm.... JDM VTEC.... It's finally in and running!
- is it possable to use only one o2 scencer instead of 2 and how
- Shielded wire for O2 sensor?
- Is the O2 sensor on 95 GSR the same as a '00 Civic SI?
- throttle sticking shut!
- b16a emissions
- Is this even possible??
- Any difference between 4 wire O2 sensors from DX engine -> b16a2
- What to do? With what to swap?
- how much would you pay, seriously
- here's a link of some pics of h22a swap
- D16z6 is here - now onto the ECU...
- who sells d series engines.
- where can i buy redline fully synthetic lsd manual tranny oil
- Little more help with my swap please.
- b20 eg hatch motor stutters at 4.5 and up
