View Full Version : Hybrid / Engine Swaps
- H22 in 3rd gen Prelude
- How hard is it to take off the head while the motor is in the car?
- which ecu code list should I go by?
- What b16 to use to stay emissions legal?
- Subject: Oil leak; Reason for post: Need help!
- help with drop?
- B16A tb & D16A1 tb...... what are their size in .....mm
- PR3 vs. PW0 (stats)
- Tranny Mount
- Confused, Need help on which a/c bracket to use!!?
- cool swap pics
- best cable tranny set up you could choose
- FS B16a with CTR pistons inside.
- All Motor Works in Fresno, CA? Any experiences with them?
- New vids of my car
- Quick ?: Which catalytic converter to use for B18C1 on EH?
- nos
- B16A1 replacement parts....
- taking powersteering OUT!
- help on swaping a b20 (non-vtec) in a 95 integra ls
- question about TPS
- differences in hydro and cable halfshafts???????
- LS parts list
- Just swapped in 2nd generation B16A ... compression test is low on all cylinders
- plan: d16y7 to d16y8 mini-me swap
- tranny
- Is removing a layer out of the headgasket reliable?
- Engine Install Help?
- ATTN: All hybriders using OBDI P72 and have a Skunk2 IM on their B18C1
- NEED HELP!!!
- B series engine swap in a 99 Civic HB
- high RPM, low speed b16 tranny
- WHich one should i get 1st gen b16a with cable or 2nd gen with hydro?
- Better crvtec Setup
- Hybrid Suspension
- Converting HX or VX harness to use 4wire o2?
- 98 civic hatch- b18c1 swap...
- Which helms should I buy?
- banjo connection?
- Taking off Tranny on a GSR motor
- Swapping a LS into a EG hb i have the motor, tranny and ECU what else do i need
- b20b vtec dyno plot. help please!
- what to do with old motor?
- spoon/itr cam setup?
- is the ITR tranny that much better???
- 16a w/ITR CAMS
- Any Hood clearance issues for CRVTEC into 87 CRX with HASport Mounts?
- p75???
- CAI for CRVTEC in 1987 CRX?
- help with a/c compressor install..
- H22a shift linkage
- PROS NEEDED!!!! striped block thead
- Which bore should I go with for my b20?
- transmisson question
- 4th gen dx to b16a dist. ???
- p28 mugen chipped...
- ECU help
- about to do a motor swap...
- difference in intermediate shafts ??
- hp differance b18b jdm b20b
- jdm b20b swap in 95 ls
- B16B internals in a B16A block.....results?
- what can i do to make my car run right?
- B16A into a 96-00 hatch
- how to tell if gsr transmission has LSD?
- freind needs help please
- B16 into CRX... Having clutch adjustment problems.....
- Code 91
- H22 in 5gen hatch Input on suspention. PLZ help!
- is it worth it?
- b16a1 O2 sensor options
- 92 Integ ECU in 91 CRX SI
- Ok... might possibly be getting a H22 Monday theres only one problem...
- 92-95 Civic with B series Icebox question???
- daily driven Hybrid?
- ls/vtec lazy
- obd2 to obd1... please help!!!!
- Motor Swap Help/Advise ?????????????
- Engine Swap
- All Motor Swap Here
- gutting the EG (need some help)
- Cel codes?
- oil in intake manifold.,.,, HELP
- b16a3 or b18c1
- I need an engine. USDM spec please.
- In need of a JDM H22A by next week.
- gsr intake cam
- Got money burning a hole in my pocket, what to get?
- HELP: Just put in new motor and....
- shift linkage ??
- P30 running a GSR motor......better results??
- HELP, JDM Gurus
- does a 4g63 "bolt in" to a 90-95 talon...
- 2g B16a into cx HB
- JDM cluster in EG dash??
- Engine stand owners...
- can everyone w/LSvtec list there set up and there over all experiences ?
- B18B has a sensor that the B20B doesn't have!! Do I need it?
- b16 in 92 si need guidance.
- LS/VTEC??
- B-Series Tranny Guide - STOP the Confusion! Help Hybriders Out!
- Need assistance with vacuum hose routing (PICTURE DIAGRAM INSIDE)
- ?'s bout nsx calipers.
- JDM motor reconition
- What to buy (Accord or Civic)?
- hard time starting
- JSpec B16A 2nd gen. question!!!
- Can anyone get these parts for a good price?
- Is anyone running a B20 with a B17 crank?
- CRV/VTEC.....B17 crank or B20 crank???
- trans compatiibility question
- OMG Boobies
- CRVTEC with CTR head and tranny?
- EGR VALVE???
- what is the difference between a gsr head and b16 head?
- What's needed to do this EG front end conversion ?
- got my POS dynoed today
- quick question on hybird ??
- ECU Pins
- obdI vs. obdII
- failing VA emissions inspection..
- 4th generation H22?
- B20 vtec???
- Help, EG H22A Install
- Need pics of a D16A1
- b16a in 00 ek
- MMMM this would make a tasty hybrid!!
- CTR gear ratio?
- swappin a B16A1 into a 5G D16Z6 ( EX/SI ) what is needed
- which AEM intake will fit?
- Switching from ls motor to vtec does anyone know what i have how to do the wiring?
- Skunk Stage2 Cams...very nice
- HT members in the oregon or WA state area need your help!
- How much did you pay for your swap?
- Thermal R&D universal muffler???
- Adding slave cylinder?
- auto to manuel conversion
- B20VTEC CRANK GIRDLE QUESTION??
- How much to Hybrid???
- with the data systems VTEC controller can i get rid of speed limter ??
- 1987 twin carb prelude engine swap into 87 crx? what will i need? will it work?
- B20 LS.. Is it worth it?
- ls head swap for a b20 head????
- What to do w/ 94 Civic DX automatic.
- b16a3 and ls trans compatibility
- HELP? 97 LS MOTOR INTO A 93 DX HB..
- Help me do a search, Im an FI guy and need yr help
- Swap into a 90 Si Hatch in the BX.
- will ground control coilovers work for me??
- any guides to do a mini-me swap?
- help, boring ???'s
- b18c1 block w/ a b16a head
- Comptech header and ls/vtec
- 91 EF...b18c5 swap/Y1 LSD....what kinda times should i expect?
- sir 1 B16a into third gen CRX
- 96 Civic EX Coupe
- need help with pistons
- LS to GSR...
- Are Hybrid Engines (CRVtec) Legal in CA???
- Tranny's - which is which?
- 89 dx with ls won't start and there is no fire..
- Think 12:1 is to high for ls/vtec...
- which one should i get for my 92 dx eg?
- how much is a b16 block worth?
- Need help with A couple of questions
- Mini-Me (D16A6/Z6) swap into 1st gen CRX
- Tranny ID
- Making your own OBDII to OBDI harness??
- Swap for 87 Si
- Y1/J1/S1 gears in YS1 tranny?
- anyone have a b series valve cover laying around??
- Just got my Comptech Header today. :)
- wHICH B16 head is better on a b18c block?
- 1st gen B16a into 92 CX
- B16 Auto into g2 teg???
- What's the going price rate for these parts?
- JDM b16a v. USDM del sol DOHC vtec v. USDM '99+ SI b16...
- hy·brid hatchback (pics)
- Here's one of the type of car i've go to contend with .....
- D16A1 info?? (into '88 Civic HB 4spd)
- help on JDM tranny Identification.
- what spring rates for hybrid? racers help!?
- exhaust question
- Formidable Engine Dealers
- Motor mount question? plz help
- having trouble locating parts for ls/vtec...
- master cyclinder question
- What displacement would i have if...
- h22
- any peeps in the va/dc/md area? Trying to start a club for EK hybrids...
- Swap and power steering?????
- Questions on Going Turbo in 2001 Prelude Sh
- tail lights
- master!!!
- b16 engine?
- b16 or ?????
- port and polish?
- 01 motor into 94 teg
- sleeving a b16a2
- Jdm B18c and ecu?
- need help B16
- B16a oil pan on GSR block?
- My brother's GS-R got stolen...
- local shop found b16,w/R cams,and GSR tranny better then GSR swap?
- Which internals to go with ?
- Rare ECU Help!!!
- B20B hybrid problem..
- How many of your cars started out as a bare shell?
- WhO dose your motor swap?
- New NOS system?
- Radiator fan not coming on....help w/ diagnostics
- Weird, code 22 and 23, but vtec still activates.
- hybrid catalytic converter
- rad problems for b16 swap in 91 crx si diff dia hose, help!!!!
- b16a in a 91 crx si
- GSR WIRING DIAGRAM FOR OBDII?
- AEM CAI question for q EG hybrid??
- help somebody help me
- Lower ball joint???
- Help with 1st Gen b16 in 94 LS DC2
- Ok now im confused?!?!
- WHAT HEAD IS BETTER FOR LS/VTEC
- H22 swap in EG, speedometer problem
- B16B
- starting a new swap, need advices!!
- What basics to ensure good running
- over bore b16a vs b18c
- making teg dash fit in civic?
- why is b18c1 redlining at 6500k w/ gsr ecu??
- A.market mounts, inserts, which ones do I need? which company?
- ls/vtec vs. b18c1 who would win...
- '80 EW1 to '84 EW1
- Check my math/logic, please.
- Anyone here done a JDM b18c into an EK coupe?
- Help with putting b16a2 into 92 civic
- having a small problem with my clutch cable.
- Wheel Size question Help !!!!!
- B20/vtec Q's
- Thieves should get Ebola and DIE!
- Clutch Master/Slave Cylinder Compatibility Question
- B20 VTEC...let's discuss this
- GSR BRAKE CONVERSION
- 96 hatch Y7 to Y8 head...do i need the ECU to work proper?
- B18C5 in a 92 SI
- Considering a D16A1 instead of JDM B16A for an 87 CRX Si..comments?
- i'm planning on installing a JDM b18c(5) ITR engine into my 96 ek coupe.. anyone know what i'll nee
- what do you guys think about GSR block and b16a head?
- Doing a swap and ran into some trouble, need help!!! B16A into 94 civic DX
- exedy flywheel install HELP!
