View Full Version : Hybrid / Engine Swaps
- Another 5 lug ? , Need Hep fast.
- B18B to EK swap ?'s and Parts List
- mismatched axels in gsr swap...
- In need of h22 vss....where can i get it?
- Whats the best-bang-for-buck short-ram intake for a h22 in a 96 coupe?
- What shift linkage do i have?
- h22 or b18c5
- Fuel Pump ? How to physically tell the difference?
- motor mounts b16 in 94hb???
- 2000 b16 changeover
- Help Swap ?
- poor mans type r, LS stroker. questions
- pr3 ecu...code 41... how to fix?
- woHOOO FAN WORKS
- how long did it take for your new motor to start up?(need help too!)
- 94 civic with drum brakes... want to do rear disk conversion, what do i need?
- RPM bounces back at 7,000... but i have a GSR swap???
- Did search!! 94 civ coupe H22 quest
- D16Y8 into 91 Civic DX HB
- life span and horror stories of lsvtec
- Will the LS starter work with the b20b?
- Hasport or Enjo?
- Boosted H22 Hatch Dyno Video
- H22 turbo in crx.... is this possible?
- GSR vs SI tranny
- swap question
- bi#%h pin
- Pickin up my h23 ? where to start with wiring!!
- H22***black w/yellow***H22
- H22 Cooling Lines
- B18C turbo conversion on an EG/Gen 2 CRX - help/advice needed
- TYPE R MOTOR IN A 91 HF CRX
- New motor trouble
- anyone with this combo GSR head b16 block
- JDM 92-93 DA tranny
- B16/B18 Vtec, Auto Tranny????
- what's the difference between us p30 and jdm p30?
- 93 civic swap
- WTB : 88-89 Integra ECU
- h22 in accord exhaust/powersteering/any one having problems with your swap???
- the h22A
- LS turbo or H22a?
- Where and how to look for a lower miles engine?
- Costs for an engine install?
- Does anyone know a good place to buy a tranny for a b18b long block?
- blown ECU... will GSR ecu work for H22?
- b20 questions/please help
- Radiator/cooling problems - B18C1 in 94 hatch
- H22 EG swap - which koni yellows? - civic or integra - does it matter?
- h22 vtec point
- eg5 h22 swap
- JDM B20B Swap help!
- ?s for b16 from 00si into 96 hatch
- couple of H22 EF q's
- Swap Done, No Tach though?
- Which fuel injectors to use in b20b?
- motor question
- will i still need to with my lsvtec??
- Another b16 head/gsr block topic
- Help Needed ASAP
- Any skilled motor builders around Raleigh NC? Help mount b16a head/block and set the timing?
- B20z in Miami
- Quick!, b20vtec (91 b16a head) headbolt specs?
- h22 civic dist
- b18c tranny prolem
- where to buy an INTERMEDIATE SHAFT
- grrrrrrrr vtec pressure sel...
- greetings! i got my EK! yay!
- O2 sensor... NEED HELP!!! katman?
- H22 in EG6 Question
- What axles do i use for zc swap going into eg?
- B18C1 in 94 Si hatch, fuel pump?
- 97 h22 distributor w/external coil, into 96 wiring harness with obd1 engine???
- B20Z Bogging and CEL Problems
- Best chip for B18B 90-91 PR4 4th Gen Civic
- SI-R(y1) Starter
- how much could you get me b20vtec for an EG for?
- B20B running lean?
- any one know if accord powersteering hose fits prelude pump?
- ITR Valvesprings Same as B16s??
- What makes the b16 so popular compared to b18b, b18c, h22, etc.?
- to all my b16a2 eg's
- h22 guys? newman?
- so the car just decided not to turn on, not even a click
- Cam choice.....
- 89 integra LS swap into 88 HF CRX nessecities??
- bogging at full throttle
- LS motor in 96 Accord
- 92-93 Shift Linkage on a 94+ B-Series Tranny?
- HELP!! Got a B16A2 block & tranny... What else do I need?
- 95 Prelude Distributor ??
- motor in now some problems......
- B18c swap hesitation
- just bought a b20 motor
- Popular Names for Resleeving
- anyone ever heard of a b18c3?
- need help asap
- Some LS/Vtec swap questions?
- vtec seal!?
- 4-SALE : 1998 HONDA CIVIC
- HELP!! intermediate seal parts number????
- newbie question
- B20 head on a B18B?
- Spoon? That is the question!
- broken rear mount..ARGGGGHHH
- H22 Swap
- All B-series Valvetrain the same?
- anyone have a used 88-91 Si tranny?
- differences between obd1 and obd2????
- modifying a d16 harness for gsr swap...
- "gsr" rear mount bolts don't line up
- RC injectors
- Engine swaps
- b16b
- auto tranny problem. no 1st gear!!
- b18 A (automatic)+ 2000 dx = ?
- Hood on my crx won't close with a b18
- Putting b16 in 88 hatch. I need dx to b16 wiring. Hasport is 250, anywhere cheaper?
- for flatbrokehatch and 99ekhatch
- b16a1 into ek question
- HCP billet H22-EG driver side motor mount
- B16A1 or a D16ZC....
- How much for H22 Swap????
- My Rover Coupe from the UK, B16 powered
- wiring question?
- CTR/ITR/EK LCAs...
- Red A/C Wire?
- How much oil in ZC?
- Power Steering in a B18C swap into 98 DX??
- is japan domestic motors any good?
- wiring jdm harness
- Tranny help!!!!!
- jdm b18c into eg
- 94 EX power steering pump with 2k b18c1
- Swap Problem...Won't Start
- Clutch pedal sensor. 93 civic
- Vtec Solenoid....B-series Same as D-Series?
- Swap assistance please....
- b16a swap in to a EF civic si wiring?
- 89 Hatch with 97 gsr.. wiring help needed
- code 20? need some HELP!
- Has anyone else had any problems with there DSS axles?
- Is japan domestic motor any good?
- Automatic H22A same as 5speed H22A ??
- B16 VS. B18 intermediate...SAME?????
- upper rad hose.
- what are some cams,valves and parts for a B20 head??????
- super bad vibrations on h22a....
- Which power steering hose? # is p2t 040058u Check pic
- 92-95 Civic, Del Sol: Possible cure for idling issue.
- Triming transmision mount???
- What Fuel Rail is best for H22a Swap in EG
- Exhaust pipes on Hybrid EK
- why does my car cutoff at 6500rpm when it used to be 7500?
- Struts
- Teaser pics of project skyline-240 (56k warning)
- Need Help!!! b18b going into 99' Civic Hatch
- a "hybrid" tranny??
- b20z CELs and car WONT start....HELP!
- What CEL's did you have, and how did you fix it?
- H22A into 93 Accord EX-R...truth about mounts...
- Mugen Twin Loop ??
- help i have a surge
- FUEL INJECTORS H22 + B18C
- LS 4-2-1 DC header on GSR?
- pin out for vtec pressure switch on obd2a harness.
- Buying USDM vtec pressure switch but which part?
- putting a motor in from the bottom
- Q's about LS/Vtec build up *already searched*
- where to get P28 chipped to P08 specs?
- WTB b16a1 stock downpipe
- Getting ready to order a OBD1 JDM B18C from HMO
- Code 41! Ho2s 95 B18c1 in 92 VX
- 92 DX engine into a 91 CRX DX
- Problem installing obd2a motor into obd2b ek9.
- SIR II B16 into Gen 2 GSR wiring
- 12sec h22eg/how hard?
- radiator problems....
- more problems..... (code 3) on h22a hybrid.
- B16a swap issues
- b20z
- swap info needed.......
- Need help: cel 23
- acura 2.2/2.3 cl swap???
- An rsx turbo engine in a ek civic can it be done
- Total Cost for H22a?
- 92 VX to JDM d15b O2 sensor question
- spark plug gap for a 93 jdm h22a?
- h22a usdm auto tcu same as jdm tcu?
- Upgrade Radiator in B20b del Sol?
- ? for b20 owners, concerning MPG
- B16 into a EF clutch cable HELP ASAP
- b20vtec and ls/vtec drilling oil line?
- please... really need help...
- LS/VTEC Head Gasket
- How do I know if its a H22A?
- Specific Eagle rods for ls/vtec
- short ram or cold air for h22ek?
- help...need help...Limp mode...no code
- help: forced induction
- Son's 92 Integra with auto and I4 1.8 liter. What's the best upgrade?
- MY H22a Died after i just got it born!!! OBD2 chassis, obd1 motor h22a EK.
- itr swap
- 93 Civic VX to JDM B16A 02 sensor Question...
- help guys obd2 mini me problems
- What mounts do I need to put 96 LS motor in 96 Civic EX?
- Running in limp mode, 2500 rev-limit.
- cel 36 h22a
- H22 del Sol suspension setups
- Another h22 in the ek question
- are all D16 series cranks the same?
- anybody in the NOVA area willing to help
- H22 Engine Bays
- Any good reference material?
- Buying a Head...What to Look for...
- Misplaced ect sensor wire the cause of my CEL?
- Need Help: LS dist. = GSR dist.
- Hasport wiring plug and play???
- stock gsr manifold wiring in b18c1 CRX?
- Pass emissions JDM B18C-R???
- Some B16 Swap Questions. Please Help!
- 02 sensor high voltage?
- ls or b16
- wiring help h22 94 LS integra
- i have power steering on my h22 ek
- injector inq!? any yous guys usin 240's on h22s!?
- JRSC'd B18B timeslips
- what parts are needed for swap???
- b16a SIR II
- HOW?????
- Integra brake fitment question
- 96-98 EX wire harness, what are these dead plugs behind IM?
- Where to get a ITR motor?
- got scammed 4 $2,354
- pro street import!
- OBD2 to OBD1 question
- IACV Wires
- starter question?
- Difference between D16 and ZC?
- H22 Low Oil Pressure?
- 3 sensor on the black a 90 LS block
- B20 PCV
- K20 into 1985 Civic
- radiator fan switch
- ITR MC AND BOOSTER , what lines need to ...
- Intermediate Shaft questions
- Simple swap question...
- another dumb question....
- FI E/M Fuse Blows.....
- will D17A2 fit a Civic CX?
