B17 oil pump question
Old Feb 15, 2011 | 06:18 PM
EGSleeper06's Avatar
Default B17 oil pump question
I have a B17 that I am in the process of building. I want to be as thorough on the rebuild as possible. I'm having a little bit of trouble locating an oil pump from anywhere but the dealer, and they want $180. I can, however, find a B16 one for fairly cheap. My question is since the B17 is basically the same exact thing as a B16 just stroked, can I use a B16 oil pump?
I have searched and found a little bit of info on the subject, but I want to be sure. What I find so far is that the B16 pump has the crank sensor in it, and the B17 crank sensor is in the distributor. Also I have found that my lower timing cover won't work either.
Any help would be greatly appreciated.
Old Feb 15, 2011 | 09:09 PM
thumper64's Avatar
Default Re: B17 oil pump question
The B17 uses a 1.6 liter (b16) block. Just get one for a B16. And I know on the B18Cs, it's cheaper getting a OBD2 oil pump, the only difference is a threaded hole and a stud on the outside. Everything fits fine.
Old Feb 19, 2011 | 05:23 AM
91tegraRS's Avatar
use an obd2 oil pump and lower timing cover thats what i have on my b17
Old Feb 20, 2011 | 11:06 AM
Cool. Thanks for the help.
efking1985
Jul 15, 2008 12:34 PM
germanegturbo
12
Jun 1, 2007 10:28 AM
sepulchral
Jun 8, 2006 12:01 AM
b16vtecsol
Nov 18, 2003 12:45 AM
