View Full Version : Hybrid / Engine Swaps
- P28 on B18c1??
- Will ITR Rear Seats Fit in a 99 Civic EX Coupe?????
- SWAP help
- b18c5 question
- b18c1 vs b20vtec
- b-series head on D16z6
- drum to disk brake conversion please help
- What do you guys think about the Cusco 5.00 FD
- Pictures of GRENADED B17A windage tray, block and rod
- 98 EX engine into 92 CX hatch...install Q's!
- Valve clearances on OBDI JDM B16A SiR? Same as B17A and/or USDM OBDI B16A?
- stripped oil drain plug problem, help please!
- Where to find probe products?
- Everything i need to drop a B18c5 into a 99 CX HB?
- 6th gen swap help needed.....
- FOR SALE: 89 CRX Si, flawless
- Jdm engine harness
- Is the b16 rod / stroke ratio that important to have????
- Fuel Pressure Regulator....
- Vtec update =)
- Which mounts for B20 in a 96 DX
- prelude swap need some answers!!!!!
- MY ENGINE LIGHT
- need a ecu
- 91 teg seats into 89 civic? how to?
- need help regarding ECU
- MPGFI
- b16a starter!
- Will a milled Type R head fit a B20 Block?
- parts and prices for b20 vtec setup
- b16a intake manifold on b18c1 block?
- CRX swap kits...axle placement?
- Best ecu for skunk2 manifold???
- I e-mailed Skunk2 about what spring rates they suggested...
- My winter project... Take a look!!!
- Vehicle Speed Sensor...I need help guys
- b18c1 block with b16a head.....??
- FYI - Some used stuff for sale
- FAQ: Detailed B Series Swap into 5th Gen Civic How-To - Check it Out and Help Everyone Else Too!
- OBDII to OBDI wiring??
- Question for KAMiN
- Whats needed for b16 in 90-93 teg
- d16a6 cam in a a 99' Civic EX?
- Hood clearance problem: B18C1 to EG
- Reserve Tank
- ok,,getting closer to a swap
- Oil check light but full on oil ?!?
- Toda B's??? Turbo Compatible???
- Curious about other people's engine lifting points on B series VTEC for pulling out motor.
- how hard is it to get a b16 in a 96 hatch to hit 13???
- Insurance - do you tell them about your motor?
- canadian hybrids...parts search
- Starting problems!!
- Knock sensor relocation
- Motor help
- Opinions h22 swap.
- wondering a ? about swap.................
- b16a with ctr cams
- 84 swap to a 90 h22
- CODE 6? need help!
- clutch question ?
- b20/vtec basic steup?
- What clutch with 92 JDM YS1 cable tranny?
- anyone who has a 92-96 jdm or usdm h22a tranny please read
- anyone have pics of hcp or place mounts ???
- b16 header
- Tricks on getting DrivePLate/Flywheel bolts off HELP HLP!!
- swap gauges after motor swap??
- Where did you buy your swap?
- B16a sir feels the same under 5000 rpm???
- F/S B-Series Tranny
- hybrid badge! very nice!
- B16a Si motor 160hp complete swap under 30,000 miles cheap!!!!
- B16A1 vs B16A2 Knock-sensor....
- iight fellow techs... need your help w/ swap FAST!! thanks
- b18c's In 98 CIVIC hatch's????
- Which clutch to use with a CRV 2.0 block?
- hell no
- ohhme, i want your tranny
- AEM CAI.... Will the GSR CAI fit a B16a in an integra? 1996 Body
- Launching the hybrid (tips)
- B16a2 Sol
- GSR fuel pressure..
- guesstimate this!
- diagnostic code?
- Need help with my LS swap
- F#@K!!! I busted the head off my rear LCA bolt...
- pulling out the motor........
- need help on h22 tranny
- ITR tranny without LSD $1400
- Swapping tomorrow!! Please Help me know ALL of what i need to do
- ATTN: Fellow east coast hybriders!!!
- GSR HEAD ON LS????
- b18C5... is it obd1 or obd2?
- b16 hydro to cable tranny??
- cocoa beach/ melbourne area read this!
- type r swap into a crx... change to obd1 or no?
- Somthin wrong.. cant rev past 3500
- The Sound of CAMS question
- ATTN: collinblewhisbottomend! .... first, we're going to have fun with you.......
- Question about LSD?
- HELP Have some question on a 94 civic hatch swaping heads
- Just installed progress coilovers
- can u hear vtec on toda b's???
- light flywheel on b16a....
- True meany if SIR?¿?
- CTR B16B Hybrid Pics
- black girdle....gsr vs z10
- 1st Generation B16 in 92 honda civic Si Hatch???
- SiR 1..into a 5th gen civic
- i need to go faster in hybrid
- Few questions about my B16a1 swap into EF (Pretty technical)
- is this a good time? please look.
- Where is the thermo switch on first gen B16a???
- If you have a D series engine read this!
- Crvtec Oil pump differences???
- Lightest H/B body?
- Choices -- read and decide
- Quick wiring ?
- For the hybrids gurus: Vtec killer cams.
- lightened flywheel for b18c ?
- way OT: but....
- 99 si's mounts???
- How to do ls/vtec with 1st gen b16 head
- what to make it fit.....JDM ITR header into a b16a 91 Civic
- d16z6 into EG but! its a del sol motor
- What Else would i need
- EX motor in a DX crx
- teg dash into civic.... whats all needed from teg.??
- Place Racing Poly Mounts in EK... Necessary???
- obd2 TB on b20 CRX
- good place to order engines???
- So....you wanna be a member of Hybridforum.net...
- o2 sensor question
- JDM B20B = 9.8:1 Compression?
- Whats the compression ratio of B20B / LS Head
- B20 VTEC, will the valves clear?
- OBD1 B18B into a 1997 ?
- Can anyone figure this out?
- looking for b18(94-up) non-VTEC
- ITR muffler on 95 hatchback?
- ? about what makes different honda motors different.
- Woopee, MY ZC LIVES.
- For those of you from Hybridforums.net....
- anybody know ways to make JDM smog legal
- stuttering problem after ECU replacement
- Need a Part... Civic Type R catback exhaust..
- map sensor code 5, but still running fine.
- which axles/int shaft for CRX w/b20+ys1
- Auto to Manual Tranny Swap. What should I get?
- Here is the nfo for swapping Integra Cluster into EG civic that I just finished.
- scammed again guys fck balls!!!!!
- Hybrid Gurus: Will an LS head fit PERFECTLY on the CRV block?
- zc motor wont start up
- which ecu will i need and will it fit in my wiring harness?
- new hasport billet mounts.
- ls frankenstein v.s. built b18c1
- poorman itr
- JDM or USDM B18C1?
- Hi Res pictures of ongoing progress with B16A swap
- nessesary OBDII -> OBDI
- ZC motor into 90 SI. Wiring harness / hose adaptation ?s
- What intake for a GSR head w/Skunk2 Intake man. in 97 hatch?
- which OEM airbox is best flowing for 1st gen b16a in a EG hatch?
- Please post pix of your ITR tranny. Need to know what it looks like.
- b16 1st gen head
- What ECU program to get???
- 91 CRX DX to B18B swap list, questions
- B16a2 won't start :(
- code
- Anyone in TX have an 92-93 LS Distributor???
- 97 LS in 96 EX IAC or FIT valve question PLEASE HELP!!!!
- Question. WHat gasket fits between Upper and lower manifold halves on ZC.
- B16A2 Knock-sensor
- B18C1...tranny decisions...
- swap out the hubs for a 93 CX with a b16a?
- dist question
- LSD tranny for NON-VTEC b18
- what year integra LS engine needed to swap into 89 crx si,,
- d15 16 valve in an hf?
- help with dash
- **SHOULD I GO LS TURBO OR LS/VTEC TURBO??**
- o2 sensor wireing in eg...
- Hybrid Insurance Problems
- OBD0 91 Teg Distributor on OBD1 95 B18C1 in 91 Civic Si running a chipped P28: Yay or nay?
- p13 ecu questions please help
- anyone seen or done a ls swap in a eg?
- 6th gen Hybrid check...
- adding power steering...tech info.
- No Secondaries
- no vtec still.
- Engine Weight B16a B18a b18b b18c1 b18c5 h22 other
- who has a fast all-motor LS engine?
- 2.2 VTEC in 6G Civic with NOS
- IACV differences between 4G & 5th gen?
- b18a/b in a 4th gen
- B16A in EF
- EG B18C1 hybrids with the Spoon Tri-Y header...clearance issues
- thinking about a b18b
- Vacuum lines on crx w/ B16 swap?
- Idle Problem... Please Help Me!!!
- H22 into a 3g Integra/vs Turbo LS
- which aem cai for eg w/ls?
- putting in B18C5 in 99si what to do about getting around the imobilezer
- Hybrid Websites
- hondata ?
- GSR vs CR-Vtec
- Weight of: b16a1 vs B18C
- Web site for Helms?
- What should I replace on a 96 B18c swap before I put it in.
- So. Cali. 2-10-2002 Meet: Fudruckers in Pasadena @ 12:00PM, Dromo 1 afterwards, Details Inside...
- need help with b20 into 89 civic si
- Its alive....ALIVE!! We're gonna have a lot of fun now.
- jdm motors
- Is this good for mid 13's?
- !!!!!!!!!ZC TRANNY OIL SEALS INFO !!!!!!!!!!
- Radar Detectors / Scanners
- Minime
- Possible scammer:TURBODC2
- B20 vtec n/a or B20 vtec SC'd
- Doing H22/Civic swap. Will i need a fuel pump?
- b16a1, b16a2, b16a3 head...... differences....?
- Wooohoooo! I am now hybrid!!
- k20 motor
- exhaust -b1c1 hybrid-
- obd0 to obd1
- ?::Replacing Gen 1 B16A Distributor Cap & Rotor Button::?
- weird - engine cuts out at 5300rpm?!?!
- JDM type r manifold
- b20b with turbo. How good are you guys??
- some pictures...CRX.
- Will 94-up stock gsr intake fit civic with swap gsr motor??
- I'm getting a Spoon header soon...should I put it in the ITR or the hybrid?
- b16a in a civic 91 si...has anyone used the HCP front mount
- Wanting to do a swap...what do you guys recommend?
- my ls/vtec high or low compression?
- WTB a car for 3-4k
- NC Hybrid meet?
- stupid question
- OBD 2 to OBD1, yeah covered a 1000 times I know, did a search
- What happens when dealer says they will do a swap.
- h22 in 96-00 civic question
- ls vtec knock sensor
- H23 in a civic...
- once the swap is done how fast will i be
- 99-00 5 lug Hatch people - got sway question(s)
- Integra LS = Limited Slip ???
- SPOON Ventuli Plate
- help me
- 91 ls tranny question??
