PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Best place to buy F20B, H23A or H22 Type S Long block?
  2. swap done, no CELS but runs sluggish??
  3. Check out my Koyo
  4. conver a 92-95 headlight to 96-00
  5. Japanese Street Racing Video for the masses!!!
  6. d16 in a mazda hatch 323???
  7. OBD2 to OBD1 conversion harness...
  8. LS obd1 into 96+ civic
  9. Rear Disc Brake swap?????
  10. 1992 LX with 1.6L???
  11. PVC PIPING...hmm
  12. B18a1 to VTEC?????????
  13. full race traction bars 98-02 accords
  14. Place Racing Solid Mounts, Axles, Shift Linkage, Wire Harness for EF???
  15. h23 vtec
  16. CF hood for H22 CRX?
  17. A couple of questions on a JDM B18C-R motor swap...
  18. b16a wiring in a 77 austin mini
  19. guye i am really confuse i need some help....
  20. what timing belt do i use for lsvtec, block will have gsr oil and water pump???
  21. H22 vs B18
  22. H22 civic hatch shifter problems...
  23. JDM B16A2 IN 1.6EL QUESTION
  24. h22 intake?
  25. which vtec solenoid do i buy
  26. JDM B16 into 99EX coupe Quick Question.
  27. question about a b20b on 96 ek
  28. DC Knuckles on DA?
  29. 97 CTR motor obd2a or obd2b?
  30. EK Hatch Vibration after 2nd->3rd hard shift...
  31. Did b18c header will clear B20 block? Fit under the b20 oil pan?
  32. LS Block Help
  33. axle problem
  34. which a/c belt to use....
  35. b18b head on b16 block (puts flame suit on)
  36. 93 Civic CX w/h22 swap wiring with AEM EMS
  37. Has anybody ever heard of Redline Performance in Bronx,NY?
  38. Car pegs off at 2500rpm! HELP!
  39. Swap shops in Nevada
  40. 92 si into 92 cx wiring harness diagram and ecu info
  41. wiring k20 in a 92 cx hatch
  42. $2,000 to spend on motor swap, PLEASE HELP !!!
  43. JDM B16 (hmotorsonline92-95) with 99 si ECU and Wiring harness HELP IMMEDIATELY
  44. B18a swap into LX...searched and still have mounting problems
  45. OBDII to OBDI??
  46. need help wiring
  47. speed sensor swap Q (ls swap in eg)
  48. HELP Shiftlinkage/shift fork is messed up!
  49. Throttle body question?
  50. port polish Q
  51. Axle Application guide
  52. turbo h22 thats in a DC2 chassis?
  53. Funky idle/slight idle problem. .MOV file w/ sound. Anyone know what it is???
  54. lsvtec wont start HELP!
  55. ls/vtec oil pressure question
  56. URGENT: Help Ls/v-tec swap
  57. Can anyone help me figure out this axles/lsd/tranny combo??
  58. b18a1 swap in a eg hatch
  59. b16a2 header will reach?
  60. b18c1 head on b16a2 block?
  61. Oohhhhhhh...makes me feel bad for the car!!! LMAO...idiot!!!
  62. All I have to say is DAMN!!! DAMN, DAMN, DAMN!!! C for Ur Self...
  63. LS/Vtec ecu Questions need help asap
  64. Prelude brakes and axle W b-series
  65. OBD0 to OBD1: Car won't start
  66. Help thermo switch odb0 to odb1
  67. phantom grip question ......
  68. B16a2 (obd2b) into 92 si hatch (obd1)
  69. EZ question: Will a B17A Oil Pan fit B18A?
  70. obd2 b16a2 wiring in a 92 cx hatch
  71. timing belt tensioner
  72. K20a2 Race Exhausts - Do I use an O2 sensor?
  73. GSR oil pump problem
  74. lsvtec ? please help ASAP
  75. Help with codes please!!
  76. Need help, need pictures of Hasport mounts
  77. Stalling @ 3000rpms!!!!
  78. Jun chip was installed at shop without my consent...now car feels slugish!?
  79. OBD1 '95 B18b motor into a '97 DX (OBD2), havin wiring problems ecu+harness etc
  80. passing C.A ref with OBD2 engine in OBD1 car
  81. dowel pin ? on lsvtec need help FAST!
  82. LS/Vtec Cooling issue...
  83. Adding a little performance to a 93 GS, lsvtec/b20vtec or something else?
  84. need suggestions for wiring on jspec h22a in eg hatch!!?!?!??!?
  85. JDM or USDM?
  86. Axle question
  87. Alternator has blown 2 coils........what could be the problem???
  88. type r transmission internals with lsd into b16a tranny casing?
  89. Ls/Vtec...... is this neccesary???
  90. Best Online Store for a Swap?
  91. HMO b18c: oil in cylinders bad?
  92. Sorry for a repost....B16A Axle problem
  93. ls vtec question
  94. Air/Fuel gauge rewiring for b18c swap in a EK????
  95. need help with dzzy
  96. Complete D15B7 - 1.5L SOHC...is it worth more than 200 dollars?
  97. how to legalize swap?
  98. USDM vs JDM Crank Key
  99. 99-00 si engine in a 97 dx coupe
  100. ls vtec head bolts question
  101. **o2 SENSOR IN 92 CIVIC VX W/ SiR2 B16**
  102. which cams to run?
  103. will this clutch work with a cable tranny?
  104. H23A Block with an H22A Head
  105. correct axle for 88-91 hatch swap.
  106. torque loss w/ CRVtec?
  107. can't clear cel codes
  108. Chassis tuning, weight of particular motors?
  109. what should i look for when buying a longblock????????????
  110. problem getting in2 3rd gear
  111. B18B1 Swap question
  112. looking for vacuum diagram for an H22
  113. crx swap help
  114. I NEED A DYNO TUNER IN THE SOUTH!!!
  115. hybrid gurus...
  116. fuel pump not coming on
  117. 88 crx to 90-93 integra disc brake conversion need help.
  118. help! need to find odb0 female plug
  119. LS into 93 civic 4 door
  120. jdm b18c type r swap
  121. Which belt can i use?
  122. LS/Vtec....GSR or ITR rods
  123. what do i need for this swap
  124. d16y8 into 88 hf crx?
  125. jdm d15b swap is it recomended to change axles?
  126. JRSC'ed h22 into a DC2 chassis?
  127. speed sensor on b16A
  128. More Info about the LS VTEC
  129. How to tell if you have a Blown Headgasket or cracked Cylinder head?
  130. putting a obd1 motor into a obd2 car with no cel
  131. Need info on 94 integra ls motor swap into my 93 delsol
  132. How much more weight with a B16 swap?
  133. IAB question
  134. OBD1 B16A 92-95 (SiR-II) Vacuum Diagram
  135. H22 Shifter Option: Needing Consumer Feedback/Opinions
  136. swapping motors into a honda insight?
  137. B20 Vtec help
  138. LS/VTEC Opportunity!
  139. LS vtec trouble!!!!
  140. B20 and the B16 Head aka CRVTEC
  141. New Setup: All Motor - 97 Civic - G23 VTEC
  142. adopter plates
  143. OBD1 B18A from 1992 Integra into a EG hatch. Can i use DA mounts and axles??
  144. Battery Terminal Wire in JDM B18C
  145. I really need wiring help, I'm in a pickle. JDM B16, 93 Civic CX, 94 ex harness
  146. bay area jdm engine dealers. Experience Overall.Let us know the ones from the bay?
  147. h22 in 95 integra?
  148. Dizzy Question!!!!!!!!!!!!!!!!!!!!!
  149. b16a2 motor mount question
  150. B16a2 into crx
  151. b16 swap on ek dx???
  152. 6500rpm cut off in a 92' civic with a 95' h22a
  153. starter problems
  154. ANOTHER Overheating prob.....very weird....but please read! STUMPED!!!
  155. High idle while rolling out of gear...
  156. Automatic B18C swap into EG NEED HELP
  157. Any Toronto ppl in here??
  158. gsr with an automatic tranny???
  159. Putting a 95 ls into a 95 civic ex motor mount question.
  160. Locating tuner shops that do engine swaps.
  161. B20Z VTEC. Need to know about valve reliefs: Necessary or Not?
  162. JDM GSR into 92 Civic CX
  163. H22 Will Not Start...Please Help
  164. Speedwerks Customs . . . . Any 1 Heard of Them?
  165. shifter linkage for b series in Eg??...
  166. which head for a b20
  167. radiator help
  168. d15z1 into CRX/89 sedan
  169. d16y8 with d16y6 block?
  170. hydro vs. cable
  171. B16A2 swap into 98 Civic
  172. 98 gsr in 98 dx
  173. Gas mileage?
  174. jdm gsr swap into 00 civic ex ???'s
  175. f20b swap
  176. Need some help.
  177. ek exhaust
  178. what water temp does your h22 idle at
  179. which loom and ecu for h22?
  180. Need to get my jdm h22a eg cali bar'd
  181. b18a into 93 ex and no spark
  182. PLEASE HELP , B16 block with GSR head timing off
  183. B16 head on GSR block?
  184. help car just cranks and wont start
  185. Attention all the Harness and pinout experts!!!!!!
  186. Wiring Air/Fuel Ratio gauge B18C
  187. civic ef w/hydro tranny
  188. harness ?
  189. LS/VTEC head on a B16?
  190. EF ZC auto swap question
  191. prelude crank in b18a question?
  192. vtec solinoid
  193. Throwing a Code 21 in 95' H22A in a 92' Civic
  194. Breaking in a used engine...?
  195. Accord euro type r h22
  196. Ls/vtec rebuild.....Questions about pistons
  197. Obd2 gsr into OBD1 B16
  198. H22a1 swap in 3rd gen Integra
  199. NEED HELP, CAN YOU GUYS HELP ME OUT? HAVE A FEW Q'S
  200. jdm b16 into a 96 civic
  201. 2000 CRV Radiator fit on 94+ integra?
  202. custom all wheel drive
  203. H22 Distributor
  204. OBD-1 ls motor into my OBD-2 car (researched)
  205. H22 mani fitted with a f22 TB
  206. All new problem with an all new video
  207. d15b7 exhast and b18c swap
  208. is my fuel my going bad
  209. AC Bracket for 92-95 b16a2 that will work with D series compressor
  210. LS PR4 ECU Hybrid for H22
  211. b-series throttle body on h22 will it work ?????????????????
  212. 89 si hatch with b18c1 ... no fuel or injectors...
  213. b16 not running up to par
  214. h22 swap 96 accord lx highflow cat?
  215. type r or K20 in 95 hatch
  216. B18C OBD1 engine harness
  217. any k series da integras?????
  218. Power/weght ratio and speed, which is more efficient?
  219. Crank sensor
  220. dpfi intake mani on vtec head?????????
  221. how do i convert my 94 ls obd-1 to obd-2
  222. need some info plzzz
  223. Identify these mounts!
  224. compresion ?
  225. Reputable shops in PA?
  226. distinguishing between heads
  227. Hydro-lock new engine help
  228. H22 with B-series tranny???
  229. h22a help
  230. civic swap map/idle probs still
  231. Help with code 4
  232. K20A Type R into 99-00 SI?
  233. Place Racing EG/H22 Mount Kit, Axles, Harness, etc
  234. b16 engine auto body
  235. h22 conversion kit for b18 trans
  236. H22A EG cali smog
  237. Mugen Header with AC?
  238. Need help: which p/s pump for a 97 civic w/ 99 gsr
  239. need help with ecu!!!!
  240. help with cel--b18c1 in eg
  241. axle problems
  242. runs fine but kills when i turn on my brights?
  243. JDM/USDM header outlet diameter difference?
  244. engine swap help!!
  245. k20a in an EK
  246. motor swap
  247. header/cat problem
  248. Need Help Diagnosing Bogging/lack of power B18
  249. D16 A/C on B18B???/
  250. h22 hotshot header leak
