View Full Version : Hybrid / Engine Swaps
- H23 VTEC Integra, IM question
- F20B FAQ
- please help me choose one?????
- avid stage 1 axles h22 swap?
- h22 in 97 dx hatch, innovative mounts, touching shock tower. Solutions?
- putting d16a jdm obd1 in cxg 97 hb
- obd1 b16 into an ek
- injector clip confusion....
- wiring help for code 22
- need help...
- JDM OBD1 B18C in 90 DA9
- how to tell the difference
- H22 EG Ride height???
- B18C1 into EG throttle cable help
- idle problem GRRRRRRR
- what clutch and axles? ( h2b )
- mini me swap has detonation
- 90 Crx b16a2(Usdm) P30(Obd1) should i get a pr3
- will a OBD2 JDM VTEC solenoid work on a USDM OBD2 Motor & ECU?
- Fixing distributor plug on 99 EX harness for 96 ITR swap
- b-series swap in a 95 cx hatch
- vtec selonoid??
- quik question about crvtec
- F20B owners, does your engine have a steel or aluminum oil pan?
- Clutch line question
- engine bucks at 3500 in 5th
- Any body like AVID motors mounts?
- Automatic B Series EK (not 56k friendly)
- td-41u in jdm b16 obd1
- b18c1 idle problem in 97 ek
- H22A Rear Bracket Question
- B16 Distiributor
- JDM b16a engine from an 89 civic sir, overheating problem, what thermostat do I need?
- DC/EG/EK h22 swap, how to get A/C to work???
- So I'm getting an EG with a B20B4 swap... What's next?
- EK with h22. Horror stories of torn chassis mounts?
- quick jumper ?
- GSR BLOCK LS CRANK N RODS 84MM PISTONS
- check engine question obd2 to obd1 converted
- 92 Honda Accord H22A4 swap missing misfire at idle
- Type R head and B18b block
- which axles?
- Where can I buy a JDM H22 transmission??????
- need help with smog in norcal?anyone?anyone?
- Anyone running traction bars with their H2B?
- Problem with gaskets for my f20b
- Tranny question ???
- Can I use my B16 oil pump for the LS vtec?
- What is the weak link in the LS vtec???
- What shift box is this? Just purchased an h22 swap
- Euro R Cams for H22?
- JHP jumper harness quality
- EF D15B cutout problem
- 89 civic hatch with JDM B16A engine and tranny, is a conversion from cable to hydraulic clutch pedal
- H22A axles: Whic intermediate shaft do I have? (Pics included)
- d series ac compressor with b seires motor?
- 1996 Civic H/B LS1 swap....complete corvette drivetrain (just incase u havent seen it in the other r
- b18b1 with no black box?? wth??
- B series tranny
- h22 swap gone bad
- B16A1 & B16A2 Block questions
- h22 swap in the uk
- Extra coolant hookup on mini-me.
- why am i throwing a code 12? Yes, I've searched and have a p30 basemap.
- Are intakes a problem on K swaps?
- Drain plug relocation nut (oil pan h2b h2d f2d f2b) M14-1.5
- Quick tranny/clutch question
- H22 eg track times? HP numbers?
- help on my h22 eg: start up problem
- h22 swaps in america
- Rod lenght ? for 100mm and 102mm h22
- ANOTHER FRIGGIN H22 QUESTION
- header for ef with b16
- H22 SWAP NEED HELP ASAP....
- H22 SWAP ..real quick..
- H22 vtec wont work help!!!
- vibration when accelerating-92 hatch/w jdm b16a
- H2B electronics and induction q's
- K24 bottem end with k20a2/1 head????
- anybody heard anything about the avid racing k-series mounts
- IACV question. 3wire to 2wire conversion. I not converting to a vtec head So what are my options?
- HELP!!!!!!!!! Injectors wont work...need advice
- coolant fan?
- New motor !!!
- 6th gen accord with jdm h22a-s
- B18c into 92 Civic Hatch DX q's
- Won't start?
- Code #23 and #9
- quick axle question
- honda to acura prt number reference?
- 99 Ex with 99 Si swap.
- car WILL start with usdm ecu but WONT start with usdm ecu -b18c in civic-
- Low idle at running temp. only
- k series problem in a ek
- help on my h22 in civic ex...revving up to 2grand and back down to 1 grand
- h22a header
- H2b in a eg
- CA Emissions for GSR swap in an EG...
- GSR TB ON B16 INTAKE MANI...
- h22a ek no spark
- K20A2 in an EG: wheels/tires
- obd1 and obd2 dizzy
- Power steering with the h swap?
- CAMP1320 EXCLUSIVE H2B Innovative Alternator Relocator bracket!
- Ls V-TEC vavle clearance question
- shift linkage
- B18c1 into 93 VX hunchback
- b18c into a obd1 da teg...couple ?'s
- Please Help Code 16
- 00 civic H22 swap issues
- First K20(RSX) EG swap
- obd2 with only 1 02 sensor?
- D16Z6-
- need help with b-series build!
- Need some help with my timing and fuel pressure on my h22a
- 98 ex head on 91 si block ???????
- Eliminating CKF Sensor. Has anyone done this?
- h2b ???????
- B18C5 into an EK - few quick questions
- b20 vtec
- Quick? wich tranny bracket for EF b-series hydro tranny
- cel code
- Adding a knock sensor to Y7 harness where does the ground go?
- Unknown hoses.
- obd0 and obd1 dizzy
- 06 si engine how swappable?
- Swap is done, now about that hole under the shifter...
- VAFC II questions?? it only flashes red and green
- Need help!!!!!! which throttle cable to use H22 swap integra
- Would a ls tranny fit a b16a motor? Is it efficient? Good or bad combination? (I tried to do reserch
- passing washginton state emissions with ls/vtec
- H2B WHICH TRANNY IS BEST?
- a CIVIC (96-00) with 1.8 liter engine
- a/c bracket part#
- B18c5 swap
- EG Chassis. Question involved rear motor mount.
- gsr oil pickup
- still failing BAR with JDM GSR Swap
- RPM for setting ignition timing on H22A ?
- what shift linkage?
- h22 teg wont start after ecu harness was redone cel 20 wtf?
- gsr alternator
- K2B
- yaaaaay new CAI
- H2B / F2B FAQ
- SiR II B16 into 97 Civic EX.
- Need help with G22 Vtec swap? (oil)
- HeikDiesel's F2B Swap
- GSR swap Ek, what upper radiator hose?
- Obd2b motor in Obd2a car...
- D16Y8 with OBD1 wiring. and distributor
- going h2b and can't get my alex. braket to fit
- Mini Me
- F20B Oil Pump
- Obd2B to Obd2A conversion?
- filter to rail fuel line (making new one)?
- Idles 1000-3000 rpm. Cold Or Hot.
- WHICH H2B KIT IS BETTER
- Anyone in the ORLANDO area good with wiring the engine harness?
- D16 Block B16 head?
- b18 swap and wont start up, has no electrical inside. can anybody help me
- Best OEM intake/head combo for TQ?
- What headers fit my swap? Yes i searched only to find wrong info
- B16a swap into EF3 ex ZC pow3r
- problem with b18b into eg swap
- Failed emissions twice, even with a new cat?
- Brake swaps among different chassis?
- New Engine....waiting for star up
- whats the difference vs ekk1/2 mounts
- Bought some ones problems B16 96 Civic EX
- Euro B18C6 wiring pin out problems...
- Converting OBDII to OBDI conversion harness, problem
- Which spindles/knuckles are best: 90-93 Integra or 88-91 Civic Si??
- What parts etc. do i need
- B18C5 conversion harness
- 95 EX w/B16 A/C question
- What msd cap and coil for 91 OBD0 B16
- F20B VS H22A
- Another Which motor for me EK thread
- pictures of the h2b
- h22 external coil help!!!!!
- b18a swap
- need an answer
- Ecu problem help !!!
- B20 Vtec HELP
- b18c1/94 del sol problems
- Anyone bought a motor from Ebay?
- ek won,t run
- H22a in a 97 ek
- weird combination...need help.
- h22 distributor external coil ????
- B18C1 is this a good deal?
- anyone got a H2B EK?
- 92-95 w/ k20a2 swap - What full size aluminum radiator?
- B16A2 or A1 head on D16A9 block - possible?
- OBD1 H22 DISTRIBUTOR WIRING
- Anyone ever heard of Crescent Tuning swap mounts?
- Full QSD H2B Ek write-up (56k No way in hell, over 65 pics.) Enjoy.
- confusion about mounts? (b series into ek)
- Tranny mount question (b18c1 into ek) PLEASE HELP!
- s2000 head on f22b1/2 block?
- VTEC PRESSURE SWITCH
- K24a1/K20a2 head oil orifice blocking question?
- What engine harness for my B20 (NON VTEC)
- Can i use 96 civic supension?
- h22 in EK Swap - full throttle&ECU issues
- 97 gsr obd2 ecu harness to obd1 ecu harness
- LS swap vs. b20 swap which would you want in your ek?
- CTR PULLEY WITH BALANCED ROTATION ASSEMBLY
- Help, converting back to OBD2
- Setting timing on H22A with Advance Timing Light
- B18C JDM gsr into a 96 civic dx post swap issues please help!!!
- CRX W/GSR swap: won't fire right
- Interchangeable downpipes?
- EGR Block Off Plate Question (Gasket?)
- Honda D15 Powered 1990 Toyota Tercel Help !
- need some help please!!!
- obd0 to obd1 conversion problems
- driver side underhood harness
- wiring nightmare!!! omg someone help 91 crx with the b18c1 (1995)
- Help me please
- b20a4 swap ?
- F22 head swap?? Quick question!
- b17a, what head should i use??
- H22 EGR to 1994 Civic DX ej1 wiring confusion / question
- d16y8 intake manifold on a d16y7
- h2b guys. help
- a few questions on b18c block on b16a head
- H22A into 91 accord trans mount difference?
- Just Failed BAR ....
- h22 ej1 sensor and wiring question
- What final drive on your H2B ??
- Bad night, now forced to put an Ls in my Gs-R!
- are b16 and ls main bolts the same/compatable?
- Are all d series shortblocks the same?
- b20b clutch
- mounts for ls in ek
- ITR gauge cluster swap into civic 96 coupe (d16y8 engine) ??
- H2B, Ups/Downs?! / Which Tranny Is Best?!
- new to ht, What is the diff between obd0, obd1,obd2
- VTEC controller question involving d16z6 in a crx
- 1500 rpm surge i need help any ideas or fix
- what mount is this?
- h22 into eg coupe axles?
- f22 aftermarket pistons
- recalibrate TPS??????anyone?
